  2. Announcements
  3. ๐Ÿ’ฌ Relay
๐Ÿ’ฌ Relay
139 Posts 47 Posters 82.5k Views 45 Watching
  • EfflonE Efflon
    I'm trying to wrap my head around the button example and don't understand what the loop() really does. To me it only alters the "state" but how does it affect the relay?
    Is the button physically connected to the relay or should the controller send the new state back and let the receive() function handle the actual relay switching?
    Also, after presentation, shouldn't there be a send() to the controller?
    korttomaK
    korttomaK
    korttoma
    @Efflon you are right about the loop() function it seems like the part where it should change the relay state is missing. Did you try to use this example code?
    The button should be wired between PIN 3 and GND so that when you push the button PIN 3 is Grounded.
    PIN 3 is connected to a "Debouncer" in the "setup()" ( so that when you push the button the code detects only one push and not several ).
    loop() monitors the debouncer and when it detects that you have pushed the button it will send the new state to the controller. I think it should also change the state so if it does not do that you could add the following line
    digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF); //write new state to relay output
    Before this line in the loop() function:
    send(msg.set(state?false:true), true); // Send new state and request ack back
    You could also add the line:
    saveState(CHILD_ID, state); // Store state in eeprom
    To the same part of the code so that the state change is written to eeprom so that the previous state can be returned after a power failure.
    • Tomas
    EfflonE 1 Reply Last reply
    • korttomaK korttoma
      EfflonE
      EfflonE
      Efflon
      @korttoma
      Thanks for the explanation! Just as I suspected with missing relay code.
      • EfflonE Efflon
        Boots33B
        Boots33B
        Boots33
        The loop in the relay with button actuator sketch does three main things
        checks for a new button push
        changes the current state
        Sends the new state to the controller
        If you look at the message code you can see it also asks for an ACK back from the controller. That is the true at the end of the line.
        It is this returned ACK that is used to switch the relay to the new state in the void receive function
        The one drawback in this code if it is used for say a light switch is that if this node looses contact with the controller then the relay cannot be changed by pressing the button.
        • Boots33B Boots33
          EfflonE
          EfflonE
          Efflon
          @Boots33 Ok, you explanation is what was my only explanation to the "missing" code. When experimenting with this using the mqtt gateway sketch and home-assistant as controller, the ACK is just an ACK and not a "real" message with payload thus just toggling the state bool and getting things out of sync..
          • WoekaW
            WoekaW
            Woeka
            wrote on last edited by Woeka
            #35
            I did not get the example working properly with my 8 channel SSR. So here is my updated version of the example.
            I have changed the way the pins are assigned by using a array. The current example tries to connect relays 7 and 8 to pins 9 and 10 when you select an 8 channel relays. This won't work because those pins are used by the radio module.
            I think you can connect a relays to any pin which is not used. If so this will make it possible to connect up to 14 relays to the mini pro when also the pins A5-A7 are available.
            #define MY_REPEATER_FEATURE
            const int PINS[] = {3, 4, 5, 6, 7, 8, 14, 15}; // I/O pins 3, 4, 5, 6, 7, 8, A0, A1 for the relays
            #define NUMBER_OF_RELAYS 8 // Total number of attached relays
            void before()
                for (int sensor=1; sensor<=NUMBER_OF_RELAYS; sensor++) {
                    pinMode(PINS[sensor-1], OUTPUT);
                    digitalWrite(PINS[sensor-1], loadState(sensor)?RELAY_ON:RELAY_OFF);
                sendSketchInfo("Relay", "1.0");
                    present(sensor, S_BINARY);
                if (message.type==V_STATUS) {
                    // Change relay state
                    digitalWrite(PINS[message.sensor-1], message.getBool()?RELAY_ON:RELAY_OFF);
            I 1 Reply Last reply
              Samuel235
              I'm attempting to get my double relay board containing two switch inputs. I see that the two sketches suggested on the relay page are there but one seems to be updated to the new version which allows you to use multiple relays on the board but the other isn't, as far as i can see. How do I go about making the sketch with buttons accept more relays?
              MySensors 2.1.1
              Boots33B 1 Reply Last reply
              • WoekaW Woeka
                void before()
                I
                I
                ijobain
                wrote on last edited by ijobain
                #37
                Hi @Woeka
                I've been testing your code, but works inverse mode
                if switch in domoticz is on the relay is off and vice versa
                RaspberryPi - Domoticz - last stable | MySensors Gateway USB - 2.1.1 | RFLink Gateway USB - 45.9
                • I ijobain
                  Hi @Woeka
                  Boots33B
                  Boots33B
                  Boots33
                  @ijobain Try changing
                  To
                  and see if that works as you expected
                  • S Samuel235
                    Boots33B
                    Boots33B
                    Boots33
                    @Samuel235 Have a look at this thread for some ideas.
                    S 1 Reply Last reply
                    • Boots33B Boots33
                      To
                      I
                      I
                      ijobain
                      @Boots33
                      Thank you so much
                      I am newbie
                      • Boots33B Boots33
                        Samuel235
                        @Boots33 - Thanks dude, I have had a quick skim read just but will bookmark it when i get my gateway working. These issues right now are driving me insane, and spending the day to try and find the problem. Thank you for linking me to that post!
                        MySensors 2.1.1
                        • R
                          R
                          Rene046
                          I just tried this sketch, works on latest version, but i cant seen any relais in Domoticz, only see the node relais, did i miss something
                          HenryWhiteH 1 Reply Last reply
                          • R Rene046
                            HenryWhiteH
                            HenryWhiteH
                            HenryWhite
                            @Rene046 you could try my sketch: https://forum.mysensors.org/topic/6638/multiple-relays-motion-sketch-fully-customizable-optional-timer-manual-override
                            R 1 Reply Last reply
                            • HenryWhiteH HenryWhite
                              R
                              R
                              Rene046
                              @HenryWhite
                              thx
                                sineverba
                                wrote on last edited by sineverba
                                #45
                                Hi to all!
                                I would edit the secure relay sketch so in loop the node sends to the gateway, let's say every hours, his state (on or off).
                                1. I avoid delay otherwise Arduino cannot receive the comands from gateway, so I will use the millis sketch, modified from the official Arduino website.
                                My doubt is... How can I get the current state of the relay?
                                Relevant part of sketch is in loop and before setup()
                                /* TIME variables */
                                unsigned long previousMillis = 0;        // will store last time state is sent
                                // constants won't change:
                                const long interval = 10000;           // interval at which to send state (milliseconds === seconds x 1000). For test we try every 10 seconds
                                And the main loop
                                  // check to see if it's time to send state; that is, if the difference
                                  // between the current time and last time you sent state is bigger than
                                  // the interval at which you want to send the state.
                                  if (currentMillis - previousMillis >= interval) {
                                    // save the last time you blinked the LED
                                    // send the state here!
                                    // test
                                    Serial.println("This is the moment where I need to send state");
                                    //send(?????????); // Send current state. Probabily will update also the log?
                                The base sketch is >>> https://github.com/mysensors/MySensors/blob/master/examples/SecureActuator/SecureActuator.ino
                                And the millis example is >>> https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
                                Thank you to all!
                                • S sineverba
                                  Hi to all!
                                  And the main loop
                                      // test
                                  Thank you to all!
                                  sineverba
                                  #46
                                  @sineverba
                                  Edit:
                                  I did edit the pre-setup configuration
                                  int val = 0;  // the value of digital pin
                                  And I did edit the loop:
                                      // test
                                      val = digitalRead(LOCK_1);
                                      Serial.print("Il valore del relay รจ ");
                                      Serial.println(val);
                                      send(msg.set(val),true); // Send new state and request ack back.
                                  I got the update in Domoticz in Hardware > Configuration > Children of nodes
                                  And I did test also every 3 seconds, all ok.
                                  But I don't have the refresh in "main page":
                                  I did test removing current to Arduino when Relay was ON. With Arduino off, I did change the state in domoticz to OFF.
                                  Because Arduino save previous state in EEPROM, after full start the relay did go ON, in Domoticz got "1" in children (all right, because digitalRead was 1) but main panel shows OFF.
                                  I did expect a graphical change...
                                  Thank you (and hope that all is clear) :)
                                    sineverba
                                    Hi to all!
                                    To achieve my goal (node that sends relay state after power failure to sync with domoticz), I'm editing the button script.
                                    I have added this line
                                    state = digitalRead(RELAY_PIN);
                                    in setup, so I thought it send only one time at startup the current state after power failure.
                                    But..... the relay shutdown/shuton (or viceversa) twice, in fast sequence....
                                    Thank you very much!
                                    S Boots33B 2 Replies Last reply
                                    • S sineverba
                                      Hi to all!
                                      sineverba
                                      @sineverba
                                      Bingo!
                                      If I did understand well, the actuator sketch DOESN'T directly acts the relay, but sends to the gateway and expect from the gw itself the "new state" (in effect, you short GND & PIN 4, arduino sends new state to the gateway and gateway resend the new state).
                                      So, 'cause I would to update the state on controller, I did this simple edit on setup:
                                       state = loadState(CHILD_ID);
                                       Serial.print("Lo stato ultimo era ");
                                       Serial.println(state);
                                       if ( state == 1) {
                                         state = 0;
                                         state = 1;
                                      Basically, If relay was OFF on a power failure, and someone on Domoticz try to start the relay, the state in Domoticz will be "on".
                                      When power returns, the arduino read the state (in my example OFF == 0), convert in 1 and send to the gateway the 1. The gateway // Domoticz will be answer with 0.
                                      So, relay doesn't nothing and Domoticz state is update.
                                      But.... why I need to invert the logic? :D
                                      • S sineverba
                                        Hi to all!
                                        Boots33B
                                        Boots33B
                                        Boots33
                                        @sineverba said in ๐Ÿ’ฌ Relay:
                                        Have a look at the sketch I used for my Synchronising Light switch you may be able to use some of that code perhaps.
                                        • Boots33B Boots33
                                          sineverba
                                          @Boots33
                                          Never seen the request function.
                                          You are hero-member for a reason...
                                          Thank you very much! :) :)
                                          With your input, this post could be even better ๐Ÿ’—
