  2. Announcements
  3. ๐Ÿ’ฌ Relay
๐Ÿ’ฌ Relay
139 Posts 47 Posters 82.5k Views 45 Watching
  • WoekaW
    WoekaW
    Woeka
    wrote on last edited by Woeka
    #35
    I did not get the example working properly with my 8 channel SSR. So here is my updated version of the example.
    I have changed the way the pins are assigned by using a array. The current example tries to connect relays 7 and 8 to pins 9 and 10 when you select an 8 channel relays. This won't work because those pins are used by the radio module.
    I think you can connect a relays to any pin which is not used. If so this will make it possible to connect up to 14 relays to the mini pro when also the pins A5-A7 are available.
    #define MY_REPEATER_FEATURE
    const int PINS[] = {3, 4, 5, 6, 7, 8, 14, 15}; // I/O pins 3, 4, 5, 6, 7, 8, A0, A1 for the relays
    #define NUMBER_OF_RELAYS 8 // Total number of attached relays
    void before()
        for (int sensor=1; sensor<=NUMBER_OF_RELAYS; sensor++) {
            pinMode(PINS[sensor-1], OUTPUT);
            digitalWrite(PINS[sensor-1], loadState(sensor)?RELAY_ON:RELAY_OFF);
        sendSketchInfo("Relay", "1.0");
            present(sensor, S_BINARY);
        if (message.type==V_STATUS) {
            // Change relay state
            digitalWrite(PINS[message.sensor-1], message.getBool()?RELAY_ON:RELAY_OFF);
            // Store state in eeprom
    I 1 Reply Last reply
      Samuel235
      I'm attempting to get my double relay board containing two switch inputs. I see that the two sketches suggested on the relay page are there but one seems to be updated to the new version which allows you to use multiple relays on the board but the other isn't, as far as i can see. How do I go about making the sketch with buttons accept more relays?
      MySensors 2.1.1
      Boots33B 1 Reply Last reply
      • WoekaW Woeka
        void before()
        I
        I
        ijobain
        wrote on last edited by ijobain
        #37
        Hi @Woeka
        I've been testing your code, but works inverse mode
        if switch in domoticz is on the relay is off and vice versa
        RaspberryPi - Domoticz - last stable | MySensors Gateway USB - 2.1.1 | RFLink Gateway USB - 45.9
        • I ijobain
          Hi @Woeka
          Boots33B
          Boots33B
          Boots33
          @ijobain Try changing
          To
          and see if that works as you expected
          • S Samuel235
            Boots33B
            Boots33B
            Boots33
            @Samuel235 Have a look at this thread for some ideas.
            S 1 Reply Last reply
            • Boots33B Boots33
              To
              I
              I
              ijobain
              @Boots33
              Thank you so much
              I am newbie
              • Boots33B Boots33
                Samuel235
                @Boots33 - Thanks dude, I have had a quick skim read just but will bookmark it when i get my gateway working. These issues right now are driving me insane, and spending the day to try and find the problem. Thank you for linking me to that post!
                MySensors 2.1.1
                • R
                  R
                  Rene046
                  I just tried this sketch, works on latest version, but i cant seen any relais in Domoticz, only see the node relais, did i miss something
                  HenryWhiteH 1 Reply Last reply
                  • R Rene046
                    HenryWhiteH
                    HenryWhiteH
                    HenryWhite
                    @Rene046 you could try my sketch: https://forum.mysensors.org/topic/6638/multiple-relays-motion-sketch-fully-customizable-optional-timer-manual-override
                    R 1 Reply Last reply
                    • HenryWhiteH HenryWhite
                      R
                      R
                      Rene046
                      @HenryWhite
                      thx
                        sineverba
                        wrote on last edited by sineverba
                        #45
                        Hi to all!
                        I would edit the secure relay sketch so in loop the node sends to the gateway, let's say every hours, his state (on or off).
                        1. I avoid delay otherwise Arduino cannot receive the comands from gateway, so I will use the millis sketch, modified from the official Arduino website.
                        My doubt is... How can I get the current state of the relay?
                        Relevant part of sketch is in loop and before setup()
                        /* TIME variables */
                        unsigned long previousMillis = 0;        // will store last time state is sent
                        // constants won't change:
                        const long interval = 10000;           // interval at which to send state (milliseconds === seconds x 1000). For test we try every 10 seconds
                        And the main loop
                          // check to see if it's time to send state; that is, if the difference
                          // between the current time and last time you sent state is bigger than
                          // the interval at which you want to send the state.
                          if (currentMillis - previousMillis >= interval) {
                            // save the last time you blinked the LED
                            // send the state here!
                            // test
                            Serial.println("This is the moment where I need to send state");
                            //send(?????????); // Send current state. Probabily will update also the log?
                        The base sketch is >>> https://github.com/mysensors/MySensors/blob/master/examples/SecureActuator/SecureActuator.ino
                        And the millis example is >>> https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
                        Thank you to all!
                        • S sineverba
                          Hi to all!
                          And the main loop
                              // test
                          Thank you to all!
                          sineverba
                          #46
                          @sineverba
                          Edit:
                          I did edit the pre-setup configuration
                          int val = 0;  // the value of digital pin
                          And I did edit the loop:
                              // test
                              val = digitalRead(LOCK_1);
                              Serial.print("Il valore del relay รจ ");
                              Serial.println(val);
                              send(msg.set(val),true); // Send new state and request ack back.
                          I got the update in Domoticz in Hardware > Configuration > Children of nodes
                          And I did test also every 3 seconds, all ok.
                          But I don't have the refresh in "main page":
                          I did test removing current to Arduino when Relay was ON. With Arduino off, I did change the state in domoticz to OFF.
                          Because Arduino save previous state in EEPROM, after full start the relay did go ON, in Domoticz got "1" in children (all right, because digitalRead was 1) but main panel shows OFF.
                          I did expect a graphical change...
                          Thank you (and hope that all is clear) :)
                            sineverba
                            Hi to all!
                            To achieve my goal (node that sends relay state after power failure to sync with domoticz), I'm editing the button script.
                            I have added this line
                            state = digitalRead(RELAY_PIN);
                            send(msg.set(state?false:true), true); // Send new state and request ack back
                            in setup, so I thought it send only one time at startup the current state after power failure.
                            But..... the relay shutdown/shuton (or viceversa) twice, in fast sequence....
                            Thank you very much!
                            S Boots33B 2 Replies Last reply
                            • S sineverba
                              Hi to all!
                              sineverba
                              @sineverba
                              Bingo!
                              If I did understand well, the actuator sketch DOESN'T directly acts the relay, but sends to the gateway and expect from the gw itself the "new state" (in effect, you short GND & PIN 4, arduino sends new state to the gateway and gateway resend the new state).
                              So, 'cause I would to update the state on controller, I did this simple edit on setup:
                               state = loadState(CHILD_ID);
                               Serial.print("Lo stato ultimo era ");
                               Serial.println(state);
                               if ( state == 1) {
                                 state = 0;
                                 state = 1;
                              Basically, If relay was OFF on a power failure, and someone on Domoticz try to start the relay, the state in Domoticz will be "on".
                              When power returns, the arduino read the state (in my example OFF == 0), convert in 1 and send to the gateway the 1. The gateway // Domoticz will be answer with 0.
                              So, relay doesn't nothing and Domoticz state is update.
                              But.... why I need to invert the logic? :D
                              • S sineverba
                                Hi to all!
                                Boots33B
                                Boots33B
                                Boots33
                                @sineverba said in ๐Ÿ’ฌ Relay:
                                Have a look at the sketch I used for my Synchronising Light switch you may be able to use some of that code perhaps.
                                • Boots33B Boots33
                                  sineverba
                                  @Boots33
                                  Never seen the request function.
                                  You are hero-member for a reason...
                                  Thank you very much! :) :)
                                  • S sineverba
                                    @Boots33
                                    Boots33B
                                    Boots33B
                                    Boots33
                                    You can find request and other useful info on the API page.
                                    Hope you are enjoying your MySensors journey :)
                                    • fhenrycoF
                                      fhenrycoF
                                      fhenryco
                                      since the relay has leds and is therefore power consuming, i was wondering if someone has written a sketch for a low power usage of the relay (as for the sensors) allowing the arduino (and the relay) to sleep all the time and wake up every 5 minutes for instance just to check if the controller has changed the desired state of the switch.
                                      Of course then the relay could be as late as 5minute, but this is not an issue for my application ...
                                      thanks for any suggestion
                                      • fhenrycoF fhenryco
                                        @fhenryco can't the relay node use power from whatever it is controlling?
                                        For sleeping nodes, the smartsleep feature can be useful. Search for that keyword in the forum and look at https://www.mysensors.org/download/sensor_api_20#sleeping
                                        fhenrycoF 1 Reply Last reply
                                        • fhenrycoF
                                          fhenrycoF
                                          fhenryco
                                          thanks , indeed it's because the relay is controlling a 12V battery power to solenoid valve , that low power consumption is needed. BTW the 12V is obtained from a 4S lipo (16.5V max voltage) and a 12 regulator and i dont know if its better to feed the arduino from a 5V regulator fed by the same Lipo , or use an additional set of AA batteries ... i remember that it's better to have an as low as possible drop in voltage to save power...
                                          With your input, this post could be even better ๐Ÿ’—
