  3. Different values in GW and other recieve node with node-to-node communication
6 Posts 3 Posters 1.6k Views 4 Watching
  • S Offline
    SweSthlmIoMT
    I am trying to use the EnergyMeter sketch to send the watt value both to my GW (to my Vera Edge) and to another node sensor (Energy Display).
    I have used the EnergyMeter sketch for a year before now only receiving the data in Vera and it has been working fine.
    When I now try to add code to make it send the data also to my new Energy Display node some strange things happens.
    The data still is correct in my Vera but I get false values to my Energy Display node. I am using the same parameter and the EnergyMeter node seems to send the correct data to both the GW and the Energy Display node. But still I receive different values in the GW and the other node.
    Here is how the output looks in the Energy Display node:
    send: 15-15-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
    send: 15-15-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-15 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    sensor started, id=15, parent=0, distance=1
    send: 15-15-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,st=ok:Watt Display
    send: 15-15-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
    send: 15-15-0-0 s=1,c=0,t=25,pt=0,l=0,sg=0,st=ok:
    send: 15-15-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,st=ok:
    Clear Screen
    read: 0-0-15 s=255,c=3,t=1,pt=0,l=10,sg=0:1487507660
    read: 7-0-15 s=1,c=1,t=17,pt=5,l=4,sg=0:233 (163 in Vera)
    Received last watt value from node 7:233
    Update Watt-value
    35
    read: 7-0-15 s=1,c=1,t=17,pt=5,l=4,sg=0:361 (164 in Vera)
    Received last watt value from node 7:361
    Update Watt-value
    36
    read: 7-0-15 s=1,c=1,t=17,pt=5,l=4,sg=0:816 (165 in Vera)
    Received last watt value from node 7:816
    Update Watt-value
    37
    read: 7-0-15 s=1,c=1,t=17,pt=5,l=4,sg=0:172 (165 in Vera)
    Received last watt value from node 7:172
    I have added the correct values that is presented thru my GW (in Vera).
    Here is the code in the EntergyMeter (sending) node:
    #include <MyTransportNRF24.h>
    #include <MyHwATMega328.h>
    #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
    #define MAX_WATT 15000          // Max watt value to report. This filetrs outliers.
    #define RF24_PA_LEVEL_GW RF24_PA_MAX
    unsigned long SEND_FREQUENCY = 30000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
    // NRFRF24L01 radio driver (set to max transmit power)
    MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
    MyHwATMega328 hw; // Select AtMega328 hardware profile
    MySensor gw(radio, hw);
    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
    boolean pcReceived = false;
    unsigned long oldPulseCount = 0;
    unsigned long oldWatt = 0;
    double oldKwh;
    unsigned long lastSend;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage kwhMsg(CHILD_ID,V_KWH);
    MyMessage pcMsg(CHILD_ID,V_VAR1);
    MyMessage wattMsgLCD(CHILD_ID,V_WATT); // Message to Entergy Display sensor
      gw.begin(incomingMessage, 7, false);
      gw.sendSketchInfo("Energy Meter", "1.7");
      gw.present(CHILD_ID, S_POWER);
      gw.request(CHILD_ID, V_VAR1);
      attachInterrupt(INTERRUPT, onPulse, RISING);
      lastSend=millis();
      wattMsgLCD.setDestination(15); // Set sensor ID 15 for Energy Display sensor
      unsigned long now = millis();
      if (pcReceived && (SLEEP_MODE || sendTime)) {
        if (!SLEEP_MODE && watt != oldWatt) {
          if (watt<((unsigned long)MAX_WATT)) {
            gw.send(wattMsg.set(watt));  // Send watt value to gw
            gw.send(wattMsgLCD.set(watt));  // Send watt value to energy display
          Serial.print("Watt:");
          Serial.println(watt);
          oldWatt = watt;
        // Pulse count has changed
        if (pulseCount != oldPulseCount) {
          gw.send(pcMsg.set(pulseCount));  // Send pulse count value to gw
          double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
          oldPulseCount = pulseCount;
          if (kwh != oldKwh) {
            gw.send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
            oldKwh = kwh;
        lastSend = now;
      } else if (sendTime && !pcReceived) {
        // No count received. Try requesting it again
        lastSend=now;
      if (SLEEP_MODE) {
        gw.sleep(SEND_FREQUENCY);
      if (message.type==V_VAR1) {
        pulseCount = oldPulseCount = message.getLong();
        Serial.print("Received last pulse count from gw:");
        Serial.println(pulseCount);
        pcReceived = true;
    void onPulse()
      if (!SLEEP_MODE) {
        unsigned long interval = newBlink-lastBlink;
        if (interval<10000L) { // Sometimes we get interrupt on FALLING
          return;
        watt = (3600000000.0 /interval) / (ppwh * 2);
        lastBlink = newBlink;
      pulseCount++;
    Here is the code from the Energy Display (receiving) node:
    #include <U8glib.h>
    #include <Time.h>
    #define CHILD_ID 1
    U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);
    MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);  // NRFRF24L01 radio driver
    boolean timeReceived = false;
    unsigned long lastTimeUpdate=0, lastRequest=0;
    int min_value[60] = {0};
      gw.begin(incomingMessage, 15, false, 0);
      Wire.begin();  // init I2C
      gw.sendSketchInfo("Watt Display", "1.1");
      gw.present(CHILD_ID, S_SCENE_CONTROLLER);
      // Request time from controller.
      gw.requestTime(receiveTime);
     // Flip screen
      u8g.setRot180();
      Serial.println("Clear Screen");
      clearScreen();
      gw.wait(2000);
    //  Serial.println("Loop");
      u8g.firstPage();
      do {
    //    Serial.println("Display Watt");
        displayWatt();
    //    Serial.println("Display kWh");
        displaykWh();
      } while( u8g.nextPage() );
      // rebuild the picture after some delay
      gw.wait(4000);
    //  Serial.println("Clear Screen");
      clearScreen();
      gw.wait(1000);
      // If no time has been received yet, request it every 10 second from controller
      // When time has been received, request update every hour
      if ((!timeReceived && now-lastRequest > (unsigned long)10*1000)
        || (timeReceived && now-lastRequest > (unsigned long)60*1000*60)) {
        Serial.println("requesting time");
        lastRequest = now;
      // Update watt-value every minute
      if (timeReceived && now-lastTimeUpdate > (unsigned long)1000*60) {
        //Update minute-watt-value.
        Serial.println("Update Watt-value");
        int var_minute = minute();
        Serial.println(var_minute);
        min_value[var_minute] = watt;
        lastTimeUpdate = now;
    // This is called when a new watt value is received
      if (message.type==V_WATT) {
      Serial.print("Received last watt value from node 7:");
      Serial.println(message.getULong());
        if (message.getULong()<((unsigned long)15000)) {
          watt = message.getULong();
    // This is called when a new time value is received
    void receiveTime(unsigned long time) {
      // Ok, set incoming time
      setTime(time);
      timeReceived = true;
    void clearScreen() {
      u8g.firstPage();
      do {
    void displayWatt() {
      char buf[15];
      dtostrf(watt, 5, 0, buf);
    //   u8g.setFont(u8g_font_freedoomr25n);
       u8g.setFont(u8g_font_unifont);
    //   Serial.println("Draw string Watt");
       u8g.drawStr( 0, 10, buf);
       u8g.drawStr( 50, 10, "Watt");
    void displaykWh() {
      float kWh_value = 0;
      for (int i = 0; i < 60; i++) {
        kWh_value = kWh_value + min_value[i];
    //    Serial.print("kWh_value: ");
    //    Serial.println(kWh_value);
    //    Serial.print("min_value[i]: ");
    //    Serial.println(min_value[i]);
      float kWh_hour = (kWh_value / (float)60000.0);
    //  Serial.print("kWh_hour: ");
    //  Serial.println(kWh_hour);
      char buf2[15];
      dtostrf(kWh_hour, 6, 3, buf2);
    //  Serial.println("Draw string kWh");
      u8g.drawStr( 0, 30, buf2);
      u8g.drawStr( 50, 30, "kWh/h");
    Can anyone tell me what is wrong here? :)
    Br
    Henrik
    • K Offline
      K Offline
      kimot
      I do not check all your code, but you have got some weird things there.
      For example in function displayWatt() "watt" is unsigned long and you use dtostrf(watt, 5, 0, buf);
      double to string, not ulong to string ?!?
      • S Offline
        SweSthlmIoMT
        Thanks kimot!
        I will change that. :)
        But perhaps that isn't the root cause to the problem. The display always shows the same value as in the console, that the sensor is receiving, so the conversion seems to work even that it is double to string.
        • S Offline
          SweSthlmIoMT
          Hi again!
          I have now had more time to test and it showed that there wasn't anything wrong with the code.
          I put a longer cable (5 meters) on the light (IR) sensor so that I could place the arduino with antenna further away from the electricity meter, and then everything started working as it should.
          Perhaps the problem was electrical interference/magnetic fields or something like that.
          So now I have a display in the house that shows how much electricity that is consumed in real time (updates every 30 sec).
          Here is now also one more example of code for node-to-node communication. It took me some time to find how to do that so hopefully this can help someone else. ; )
            Did you use the IR receiver on a red LED and it works?
            S 1 Reply Last reply
              SweSthlmIoMT
              @gohan
              No my electricity meter has a IR led.
              But during my tests I actually used a regular red led and that worked too with the Light/IR receiver I use. : )
              https://www.aliexpress.com/item/5-pcs-LM393-Light-Sensor-Photosensitive-Sensitivity-light-Sensor-Module-For-Arduino-Smart-Car/1729424221.html
              12.1k
