  3. node disconnects - workaround?
6 Posts 2 Posters 1.9k Views 2 Watching
  • parachutesjP
    parachutesjP
    parachutesj
    I have one node (controlls a roller shutter) which keeps disconnecting or is unavailable.
    As controller I use openHAB - but don't think that this is important.
    My node with two relays should have enough power, changed the power supply and radio connection should also be ok. I even switched the arduino which did not solve it.
    Issue:
    OpenHAB controls it, up in the morning, down in the evening. Works most of the time. Sometimes after one day, somtimes after a week I can see in the log that the message failed.
    When I press the physical up or down buttons on the node to control the rollershutter, it "reconnects" to the gateway and can be controlled as before until it fails again.
    When I power cycle the node, it is also back to live. When I initiate a connection via physical buttons, it is always working and gets the connection - so I think the uplink direction is fine and radio communication in general should be ok.
    However on the downlink side it fails from time to time and does not get back to live - only after a uplink was initialized.
    Do we have a solution here? Can I test a connection several times a day e.g?
    A workaround could be attaching a temp sensor and just transmitt every 10-20 mins and I guess it should be fine but not really the solution to the RC.
    I am on 2.0x with my nodes and GW.
    Cheers,
    SJ
    • parachutesjP parachutesj
      Issue:
      Cheers,
      SJ
      FotoFieberF
      FotoFieberF
      FotoFieber
      @parachutesj
      Could you please post your sketch?
      A wiring diagram or a picture of the node could be helpful too.
      parachutesjP 1 Reply Last reply
      • FotoFieberF FotoFieber
        @parachutesj
        parachutesjP
        parachutesjP
        parachutesj
        @FotoFieber
        see my sketch below.
        Don't have a wiring diagram. However it is simply a relay module connected to the digital pins and some physical switches with each a resistor on +5V
           REVISION HISTORY
           Version 1.0 - Henrik Ekblad
           DESCRIPTION
           Example sketch showing how to control physical relays.
           This example will remember relay state after power failure.
           http://www.mysensors.org/build/relay
        #define MY_REPEATER_FEATURE
        #define NUMBER_OF_RELAYS 2 // Total number of attached relays
        MyMessage sensorMsg0(0, V_DIMMER);
        MyMessage sensorMsg1(1, V_DIMMER);
        static int currentLevel0 = 0;  // Current dim level...
        static int currentLevel1 = 0;  // Current dim level...
        int upPin0 = 14;   // choose the input pin (for a up)
        int downPin0 = 15;   // choose the input pin (for a down)
        int motorUp0 = 0;     // variable for reading the pin status
        int motorDown0 = 0;     // variable for reading the pin status
        int upPin1 = 15;   // choose the input pin (for a up)
        int downPin1 = 16;   // choose the input pin (for a down)
        int motorUp1 = 0;     // variable for reading the pin status
        int motorDown1 = 0;     // variable for reading the pin status
        int switchState0 = 0; //0=off, 1=up, 2=down
        int tempSwitchState0 = 0; //0=off, 1=up, 2=down
        int rUnitPos0 = 0;
        int switchState1 = 0; //0=off, 1=up, 2=down
        int tempSwitchState1 = 0; //0=off, 1=up, 2=down
        int rUnitPos1 = 0;
        void shuttersUp(int shutter)
          if (shutter == 0) {
            Serial.println("A Shutter 0 going up.");
            digitalWrite (RELAY_1 + 1, LOW);
            delay(100);
            digitalWrite (RELAY_1, HIGH);
            send( sensorMsg0.set(0) );
          else {
            Serial.println("A Shutter 1 going up.");
            digitalWrite (RELAY_1 + 3, LOW);
            delay(100);
            digitalWrite (RELAY_1 + 2, HIGH);
            send( sensorMsg1.set(0) );
        void shuttersDown(int shutter)
          if (shutter == 0) {
            Serial.println("A Shutter 0 going down.");
            digitalWrite (RELAY_1, LOW);
            delay(100);
            digitalWrite (RELAY_1 + 1, HIGH);
            send( sensorMsg0.set(100) );
          else {
            Serial.println("A Shutter 1 going down.");
            digitalWrite (RELAY_1 + 2, LOW);
            delay(100);
            digitalWrite (RELAY_1 + 3, HIGH);
            send( sensorMsg1.set(100) );
        void shuttersStop(int shutter)
          if (shutter == 0) {
            Serial.println("A Shutter 0 halted.");
          else {
            Serial.println("A Shutter 1 halted.");
          sendSketchInfo("RollerShutter AZ", "2.1");
          pinMode(upPin0, INPUT);    // declare pushbutton as input
          pinMode(downPin0, INPUT);    // declare pushbutton as input
          // Fetch relay status
          for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
            present(sensor, S_COVER);
            pinMode(pin, OUTPUT);
            digitalWrite(pin, LOW);
          motorUp0   = digitalRead(upPin0);  // read input value
          motorDown0 = digitalRead(downPin0);  // read input value
          if (motorUp0 == LOW && motorDown0 == HIGH) {
            switchState0 = 1;
            //Serial.println("SWITCH: " + String(switchState0)); //Schalterposition
          else if (motorDown0 == LOW && motorUp0 == HIGH) {
            switchState0 = 2;
          else if (motorDown0 == HIGH && motorUp0 == HIGH)
            switchState0 = 0;
          if (tempSwitchState0 != switchState0) //man only needed in case of changed switch state
            if (motorUp0 == LOW && rUnitPos0 != 1) //manuell hoch
              switchState0 = 1;
              tempSwitchState0 = 1;
              delay(200);
              shuttersUp(0);
              rUnitPos0 = 1;
              Serial.println("//////////////man 0 hoch");
            if (motorDown0 == LOW && rUnitPos0 != 2) // manuell runter
              switchState0 = 2;
              tempSwitchState0 = 2;
              delay(200);
              shuttersDown(0);
              rUnitPos0 = 2;
              Serial.println("//////////////man 0 down");
            if (motorUp0 == HIGH && motorDown0 == HIGH && rUnitPos0 != 0) //manuell stopp
              switchState0 = 0;
              delay(200);
              shuttersStop(0);
              rUnitPos0 = 0;
              Serial.println("//////////////man 0 stopp");
          // Let's check for the message type.
          if (message.type == V_DIMMER) {
            Serial.print( "Changing level to " );
            Serial.print( ", from " );
            Serial.println("NodeID:" + String(message.sensor) + " " + currentLevel0 );
            if (requestedLevel == 0) {
              // move up
              shuttersUp(message.sensor);
            else if (requestedLevel == 100) {
              // move down
              shuttersDown(message.sensor);
            else {
              // move percentage
              // Serial.println("currentLevel" + String(shutters.currentLevel()));
              Serial.println("move to desired postion");
              //shutters.requestLevel(80);
            currentLevel0 = requestedLevel;
          else if (message.type == V_UP) {
            Serial.println("going up:" + String(message.type));
          else if (message.type == V_DOWN) {
            Serial.println("going down:" + String(message.type));
          else if (message.type == V_STOP) {
            shuttersStop(message.sensor);
            Serial.println("stopping:" + String(message.type));
          else {
            Serial.println("wrong data received:" + String(message.type));
        • FotoFieberF
          FotoFieberF
          FotoFieber
          Try to replace all "delay" with "wait", as the node is not responsible, when you are in a delay.
          Try to add a watchdog:
          • add a a wdt_enable(WDTO_8S) in setup
          • add a wdt_reset() at the start of the loop
          I had several problems with relays and power spikes when they are switched. I changed them all to SSRs and the problems are gone.
          Good luck
          Markus
            Good luck
            Markus
            parachutesjP
            parachutesjP
            parachutesj
            @FotoFieber
            Thank you for your reply. I know delay is not optimal but there is not so much interaction that this would or should cause the node to hang. And if it hangs, also an additional comand later on sent via webinterface etc. fails. So if it would send a failing comand while it is busy with the delay I would understand but it will not come back to live at all.
            The reason is avoiding power on both motor directions (up & down) for the same time as relays are slow.
            However I will try a "wait" instead.
            Watchdog: I thought about that before but as mentioned when I press the manual up/down button it comes back to live. If the sketch would be blocked and resolved by a watchdog, I would expect different behaviour.
            The power consumption related to classical relays might be influencing something - that is a chance. I have a bunch of SSRs laying around but was too lazy to build up something yet. Too many other unfinished projects in the pipeline...
            But back to my original thought: is there a function which would test a connection to the gateway which could be triggered manually?
            Thank you again
            SJ
            • FotoFieberF
              FotoFieberF
              FotoFieber
              You can send heartbeats:
              https://forum.mysensors.org/topic/2267/ping-function/3
