  3. Receiving but !TSM:UPL:FAIL and no communication? 2.1.1 issue?
17 Posts 4 Posters 4.4k Views 5 Watching
  • C Offline
    C Offline
    chbla
    Hi there,
    I want to get started with mysensors but it doesn't want to work. GW is a Nodemcu with MQTT, Client is a Pro Mini clone. Radio is Adafruit 433Mhz breakout board.
    Gateway log:
    1384, room 16
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGE--,VER=2.1.1
    0;255;3;0;9;TSF:LRT:OK
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    scandone
    f 0, .0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSF:MSG:PINGED,ID=1,HP=1
    0;255;3;0;9;!TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    ...scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 3
    cnt
    connected with wlanbt, channel 1
    dhcp client start...
    ....ip:192.168.1.57,mask:255.255.255.0,gw:192.168.1.1
    .IP: 192.168.1.57
    0;255;3;0;9;MCO:BGN:STP
    IP: 192.168.1.57
    0;255;3;0;9;MQTT connected
    pm open,type:2 0
    Client log:
    MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1
    10 TSM:INIT
    12 TSF:WUR:MS=0
    16 TSM:INIT:TSP OK
    18 TSM:INIT:STATID=1
    20 TSF:SID:OK,ID=1
    22 TSM:FPAR
    22 TSM:FPAR:STATP=0
    26 TSM:ID
    26 TSM:ID:OK
    28 TSM:UPL
    161 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    2168 TSM:UPL
    2299 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    4308 TSM:UPL
    4440 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    6447 TSM:UPL
    6578 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    8585 !TSM:UPL:FAIL
    8587 TSM:FPAR
    8587 TSM:FPAR:STATP=0
    8589 TSM:ID
    8591 TSM:ID:OK
    8593 TSM:UPL
    8726 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    10733 TSM:UPL
    10864 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    12871 TSM:UPL
    13004 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    15011 TSM:UPL
    15142 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    17152 !TSM:UPL:FAIL
    17154 TSM:FPAR
    17154 TSM:FPAR:STATP=0
    17158 TSM:ID
    17158 TSM:ID:OK
    17160 TSM:UPL
    17295 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    19302 TSM:UPL
    19435 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    21442 TSM:UPL
    21573 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    23580 TSM:UPL
    23711 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    25718 !TSM:UPL:FAIL
    25720 TSM:FPAR
    25720 TSM:FPAR:STATP=0
    25724 TSM:ID
    25724 TSM:ID:OK
    25726 TSM:UPL
    It seems the GW receives data, but something fails. Can anyone tell me what causes this?
    Maybe a 2.1.1 issue?
    GW and Client code is here: https://gist.github.com/solars/8644c5e310c63cecf93d86dc76955d68
    • F Offline
      F Offline
      Fabien
      You issue is on GW. Node ping GW, GW recieve ping but pong response is never recieve by node.
      NodeMCU and especially Chinese clone doesn't have a good 3.3V regulator. Try to power your radio module with external 3.3V (but connect GND together).
      I highly recommand you to use another device like Wemos for GW
      • C Offline
        C Offline
        chbla
        Thanks for the reply @Fabien
        I'm using this breakout board: https://www.adafruit.com/product/3071 - as far as I understood it has a regulator, is this not sufficient?
          In case of communication problems with wireless modules, adding a cap on vcc it is always a good thing to try
          • F Offline
            F Offline
            Fabien
            Forget the cap with RFM69 modules. Did you put a one wire antenna (164.7 mm) ?
            Regulator on breakout board is ok. And what about your VIN power ? Is it sufficient ?
            Can you post photo of your GW ?
            C 1 Reply Last reply
            • F Fabien
              C Offline
              C Offline
              chbla
              @Fabien, thanks for your help!
              The antenna is 164.7mm yes.
              Regarding VIN - what's ideal to use here? I'm not sure how much power it needs, I've got a bunch of USB power supplies
              that I tried.
              Pictures of the GW and RFM69 Module:
              https://www.dropbox.com/sh/txuqvkk1di9awj9/AABpvof5jKt2nq5Vd2rvFrn4a?dl=0
              I would really appreciate if anyone could help me get this to run :/
              • F Offline
                F Offline
                Fabien
                Actually you are powering your RFM69 with your 3V from your NodeMCU. It cannot work because you have a 3.3V regulator on the RFM69 board AND 3.3V on NodeMCU is not very good.
                First you can try to move your red wire from 3V to VIN on the NodeMCU side. It can works f you use a good USB power supply (1A min).
                Just another tip : check in your gateway sketch you have #define MY_IS_RFM69HW
                • F Fabien
                  C Offline
                  C Offline
                  chbla
                  VIN on the Nodemcu produces WDT resets, not sure why.
                  I've now connected the RFM69 to the 5V output of a Wemos D1 Mini, and the board via USB.
                  I'm still getting the same results: https://gist.github.com/solars/7ed4541372f37166910ca4d1842d8c32
                  Trying to use a regulator I have for the breadboard if I find a suitable power supply.
                  This is really frustrating.
                  I tried with a Wemos D1 Mini earlier - only produces WDT resets.
                  Then tried with Arduino Uno + W5100 Ethernet shield, only to find out it's quite complicated
                  to get this to run with an RFM69 due to soft spi.
                  All I want is get this communication to work..
                  • F Offline
                    F Offline
                    Fabien
                    Very strange, I have a wemos mini gateway working fine (With nodeMCU i have a lot of commmunication probelms because of regulator). Do you have other radios for testing ? With your wemos+nodemcu did you connect GND together ?
                    Wdt resets probably occurs because your usb power supply isn't sufficent.
                    • F Fabien
                      C Offline
                      C Offline
                      chbla
                      wrote on last edited by chbla
                      @Fabien I have now used a second power supply for the RFM69 (5V), USB for the Nodemcu, connected grounds together. But it's still the same..
                      I also tried a different radio.
                      Do you maybe have a picture how you connected the Wemos D1 Mini and sketch used? I guess I just had a wiring problem with the wemos.
                      I would like to try again.
                      • F Offline
                        F Offline
                        Fabien
                        I just build a new one because I bought a sensebender Gateway !
                        So my new setup :
                        RFM69 -> Wemos Mini D1
                        SS -> GPIO16 (D0)
                        SCK -> GPIO14 (D5)
                        MISO -> GPIO12 (D6)
                        MOSI -> GPIO13 (D7)
                        IRQ -> GPIO15 (D8)
                        Connect GND and 5V power (in my case I Don't use breakout board but direct connection to RFM69
                        Sketch :
                        #define MY_BAUD_RATE 9600
                        #define MY_RADIO_RFM69
                        #define MY_RF69_IRQ_PIN 15
                        #define MY_RF69_SPI_CS 16
                        #define MY_RF69_IRQ_NUM 15
                        #define MY_GATEWAY_ESP8266
                        #define MY_ESP8266_SSID "Fab-WLAN"
                        #define MY_ESP8266_PASSWORD "password"
                        #define MY_PORT 5003
                        #include <ESP8266WiFi.h>
                        With your Breakout board you must add : #define MY_IS_RFM69HW
                        And now the log with some testing sensors :
                        0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGE--,VER=2.1.0-beta
                        scandone
                        state: 0 -> 2 (b0)
                        state: 2 -> 3 (0)
                        state: 3 -> 5 (10)
                        add 0
                        aid 5
                        cnt
                        f r0,
                        connected with Fab-WLAN, channel 1
                        scandone
                        ..ip:192.168.1.55,mask:255.255.255.0,gw:192.168.1.1
                        .IP: 192.168.1.55
                        pm open,type:2 0
                        0;255;3;0;9;TSF:MSG:READ,15-15-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                        • F Fabien
                          So my new setup :
                          SS -> GPIO16 (D0)
                          SCK -> GPIO14 (D5)
                          MISO -> GPIO12 (D6)
                          MOSI -> GPIO13 (D7)
                          IRQ -> GPIO15 (D8)
                          Sketch :
                          scandone
                          state: 0 -> 2 (b0)
                          state: 2 -> 3 (0)
                          state: 3 -> 5 (10)
                          add 0
                          aid 5
                          cnt
                          f r0,
                          scandone
                          .IP: 192.168.1.55
                          pm open,type:2 0
                          C Offline
                          C Offline
                          chbla
                          @Fabien thanks a lot!
                          I've set it up like you now, but now the GW doesn't seem to read any messages... damn
                          https://gist.github.com/solars/823bc62306909efd3fbb1a66b5211b31
                          Any idea what's wrong again now?
                          Johannes HodneJ 1 Reply Last reply
                          • C chbla
                            Johannes HodneJ Offline
                            Johannes Hodne
                            @chbla I gave up on the 2.1.1 library, and tried with 2.0.0. Then everything start working :-D
                            • F Offline
                              F Offline
                              Fabien
                              In your gateway your don't #define MY_RFM69_FREQUENCY RF69_433MHZ . By default it sets to RF69_868MHZ
                              • F Fabien
                                C Offline
                                C Offline
                                chbla
                                @Fabien said in Receiving but !TSM:UPL:FAIL and no communication? 2.1.1 issue?:
                                Oh my god! What an incredible stupid mistake!
                                I wasted all this time trying to get the NodeMCU to work only because I forgot that setting in my initial Wemos Sketch...
                                It's finally working now.. haha. Let me know when you're in Austria @Fabien you deserve a beer :)
                                @Johannes-Hodne thanks for the suggestion but it's finally working now :)
                                F 1 Reply Last reply
                                • Johannes HodneJ Offline
                                  Johannes Hodne
                                  Great! I might have to give the 2.1.1 library another try.
                                  • C chbla
                                    F Offline
                                    F Offline
                                    Fabien
                                    @chbla Good news ! Now you can play with sensors !
                                    12.2k
