  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 466.6k Views 30 Watching
  • F Fabien
    This tutorial is up to date for 2.0 release ?
    AnticimexA
    AnticimexA
    Anticimex
    @Fabien Yes, top post is now updated for 2.0.0. Documentation is in doxygen.
    • F
      F
      Fabien
      Thank you @Anticimex I will update my network soon and had RFM69 Encryption too.
      • NiklasON
        NiklasON
        NiklasO
        wrote on last edited by NiklasO
        #277
        Trying this:
        https://www.mysensors.org/build/raspberry
        How do I enable signing and give the gateway the serial, hmac and aes-key when running on Linux? (rPi).
        Edit: Pin 7 as random number generator maybe need some change?
        AnticimexA 1 Reply Last reply
        • NiklasON NiklasO
          Trying this:
          AnticimexA
          AnticimexA
          Anticimex
          @NiklasO @marceloaqno is working on this.
          • E
            E
            executivul
            I have about 100 ATSHA204 I2C variant to be used in a MySensors project.
            Do you think that by modifying the personalizer sketch to disable the I2C bit in the configuration (0x03 word address) the chips can be set to be used as single-wire, or are they hardcoded to use only one protocol, but then why having the config bit?
            • E executivul
              AnticimexA
              AnticimexA
              Anticimex
              #280
              @executivul The bit is readonly. You cannot change it. It is used to determine the variant of chip, not to select mode of operation.
              From the documentation:
              0_1478094689558_upload-93242040-4814-4ad6-8951-4ad4d1e99a23
              But you are welcome to submit a pull request for adding support for I2C variants of ATSHA204a. I have none myself so I have not bothered looking into that and currently I am out of time to spend on it I am afraid.
              E 1 Reply Last reply
              • AnticimexA Anticimex
                E
                E
                executivul
                Please excuse my noobish ignorance: How and where do I submit one?
                • E executivul
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @executivul By forking the MySensors core repository and create a local git branch, do your code, push it back to your fork on GitHub and then create a pull request from that. There are good guides on GitHub for how do do it.
                    meddie
                    ok, thank you, but do you know why the sketch didnt generate the keys, and instead of random i get only keys ffffffffffff ?
                    thank you
                    • M meddie
                      thank you
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @meddie Without actually seeing your sketch it is pretty hard for me to help with anything ;)
                      My guess is, you did not enable the proper defines to instruct it to generate and store any keys.
                        meddie
                        @Anticimex
                        Hi i have posted my sketch few posts ago, but no problem here is it:
                        #include "sha204_library.h"
                        #define MY_CORE_ONLY
                        #if DOXYGEN
                        #define LOCK_CONFIGURATION
                        #define LOCK_DATA
                        #define SKIP_KEY_STORAGE
                        #define USER_KEY
                        #define SKIP_UART_CONFIRMATION
                        #define USE_SOFT_SIGNING
                        #define STORE_SOFT_KEY
                        #define USER_SOFT_KEY
                        #define STORE_SOFT_SERIAL
                        #define USER_SOFT_SERIAL
                        #define STORE_AES_KEY
                        #define USER_AES_KEY
                        //#define LOCK_CONFIGURATION
                        //#define LOCK_DATA
                        //#define USER_KEY
                        //#define USE_SOFT_SIGNING
                        //#define STORE_SOFT_KEY
                        //#define USER_SOFT_KEY
                        //#define STORE_SOFT_SERIAL
                        //#define USER_SOFT_SERIAL
                        //#define STORE_AES_KEY
                        //#define USER_AES_KEY
                        #ifdef USER_KEY
                        #ifdef USER_SOFT_KEY
                        #ifdef USER_SOFT_SERIAL
                        #ifdef USER_AES_KEY
                        #ifndef USE_SOFT_SIGNING
                        void halt()
                        	while(1);
                        	uint16_t crc = 0;
                        	uint8_t config_word[4];
                        	uint8_t ret_code;
                        	bool do_write;
                        		do_write = true;
                        		if (i == 20) {
                        			config_word[0] = 0x8F;
                        			config_word[1] = 0x80;
                        			config_word[2] = 0x80;
                        			config_word[3] = 0xA1;
                        		} else if (i == 24) {
                        			config_word[0] = 0x82;
                        			config_word[1] = 0xE0;
                        			config_word[2] = 0xA3;
                        			config_word[3] = 0x60;
                        		} else if (i == 28) {
                        			config_word[0] = 0x94;
                        			config_word[1] = 0x40;
                        			config_word[2] = 0xA0;
                        			config_word[3] = 0x85;
                        		} else if (i == 32) {
                        			config_word[0] = 0x86;
                        			config_word[2] = 0x87;
                        			config_word[3] = 0x07;
                        		} else if (i == 36) {
                        			config_word[0] = 0x0F;
                        			config_word[1] = 0x00;
                        			config_word[2] = 0x89;
                        			config_word[3] = 0xF2;
                        		} else if (i == 40) {
                        			config_word[0] = 0x8A;
                        			config_word[1] = 0x7A;
                        			config_word[2] = 0x0B;
                        			config_word[3] = 0x8B;
                        		} else if (i == 44) {
                        			config_word[0] = 0x0C;
                        			config_word[1] = 0x4C;
                        			config_word[2] = 0xDD;
                        			config_word[3] = 0x4D;
                        		} else if (i == 48) {
                        			config_word[0] = 0xC2;
                        			config_word[1] = 0x42;
                        			config_word[2] = 0xAF;
                        			config_word[3] = 0x8F;
                        			config_word[0] = 0xFF;
                        			config_word[2] = 0xFF;
                        			config_word[3] = 0x00;
                        			config_word[1] = 0xFF;
                        			config_word[3] = 0xFF;
                        				halt();
                        			do_write = false;
                        		// Write config word
                        		if (do_write) {
                        				Serial.print(i);
                        				halt();
                        	return crc;
                        void write_key(uint8_t* key)
                        	uint8_t ret_code;
                        	// Write key to slot 0
                        		halt();
                        void dump_configuration()
                        	uint8_t buffer[32];
                        	for (int j=0; j<32; j++) {
                        		if (buffer[j] < 0x10) {
                        		Serial.print(buffer[j], HEX);
                        	Serial.println();
                        	for (int j=0; j<9; j++) {
                        	Serial.println();
                        	for (int j=0; j<16; j++) {
                        	Serial.println();
                        	uint8_t ret_code;
                        			halt();
                        		if (i == 0x00) {
                        			for (int j=0; j<4; j++) {
                        				if (j == 1) {
                        					Serial.print(F(" | "));
                        					Serial.print(F("   "));
                        			Serial.println();
                        		} else if (i == 0x04) {
                        			Serial.println();
                        		} else if (i == 0x08) {
                        			Serial.println();
                        		} else if (i == 0x0C) {
                        				if (j < 3) {
                        			Serial.println();
                        		} else if (i == 0x10) {
                        				if (j < 3) {
                        			Serial.println();
                        		} else if (i == 0x14) {
                        				if (j == 1) {
                        			Serial.println();
                        		} else if (i == 0x18) {
                        				if (j == 1) {
                        			Serial.println();
                        		} else if (i == 0x1C) {
                        				if (j == 1) {
                        			Serial.println();
                        		} else if (i == 0x20) {
                        				if (j == 1) {
                        			Serial.println();
                        		} else if (i == 0x24) {
                        				if (j == 1) {
                        			Serial.println();
                        		} else if (i == 0x28) {
                        				if (j == 1) {
                        			Serial.println();
                        		} else if (i == 0x2C) {
                        				if (j == 1) {
                        			Serial.println();
                        		} else if (i == 0x30) {
                        				if (j == 1) {
                        			Serial.println();
                        		} else if (i == 0x34) {
                        				if (j < 3) {
                        			Serial.println();
                        		} else if (i == 0x38) {
                        				if (j < 3) {
                        			Serial.println();
                        		} else if (i == 0x3C) {
                        				if (j < 3) {
                        			Serial.println();
                        		} else if (i == 0x40) {
                        				if (j < 3) {
                        			Serial.println();
                        		} else if (i == 0x44) {
                        			Serial.println();
                        		} else if (i == 0x48) {
                        			Serial.println();
                        		} else if (i == 0x4C) {
                        			Serial.println();
                        		} else if (i == 0x50) {
                        			Serial.println();
                        		} else if (i == 0x54) {
                        				if (j < 3) {
                        			Serial.println();
                        	uint8_t ret_code;
                        	uint8_t lockConfig = 0;
                        	uint8_t lockValue = 0;
                        	uint16_t crc;
                        	(void)crc;
                        	// initialize pseudo-RNG
                        	uint8_t key[32];
                        	(void)key;
                        	hwInit();
                        		halt();
                        		halt();
                        #ifdef STORE_SOFT_KEY
                        #ifdef USE_SOFT_SIGNING
                        		halt();
                        	if (lockConfig == 0x00) {
                        #endif // not USER_SOFT_KEY
                        	for (int i=0; i<32; i++) {
                        		Serial.print("0x");
                        		if (key[i] < 0x10) {
                        		Serial.print(key[i], HEX);
                        		if (i < 31) {
                        			Serial.print(',');
                        	Serial.println();
                        #endif // STORE_SOFT_KEY
                        #ifdef STORE_SOFT_SERIAL
                        	for (int i = 0; i < 9; i++) {
                        		halt();
                        	for (int i=0; i<9; i++) {
                        		Serial.print("0x");
                        		if (i < 8) {
                        			Serial.print(',');
                        	Serial.println();
                        #endif // STORE_SOFT_SERIAL
                        #ifdef STORE_AES_KEY
                        #ifdef USER_AES_KEY
                        		halt();
                        #endif // not USER_AES_KEY
                        	Serial.print("#define MY_AES_KEY ");
                        	for (int i=0; i<16; i++) {
                        		Serial.print("0x");
                        		if (i < 15) {
                        			Serial.print(',');
                        	Serial.println();
                        #endif // STORE_AES_KEY
                        	Serial.println(F("EEPROM configuration:"));
                        	dump_configuration();
                        	// Output device revision on console
                        	ret_code = sha204.sha204m_dev_rev(tx_buffer, rx_buffer);
                        		Serial.print(F("Failed to determine device revision. Response: "));
                        		halt();
                        		Serial.print(F("Device revision: "));
                        		for (int i=0; i<4; i++) {
                        			if (rx_buffer[SHA204_BUFFER_POS_DATA+i] < 0x10) {
                        			Serial.print(rx_buffer[SHA204_BUFFER_POS_DATA+i], HEX);
                        		Serial.println();
                        	// Output serial number on console
                        	ret_code = sha204.getSerialNumber(rx_buffer);
                        		Serial.print(F("Failed to obtain device serial number. Response: "));
                        		halt();
                        		Serial.print(F("Device serial:   "));
                        		Serial.print('{');
                        			Serial.print(F("0x"));
                        			if (rx_buffer[i] < 0x10) {
                        			Serial.print(rx_buffer[i], HEX);
                        			if (i < 8) {
                        				Serial.print(',');
                        		Serial.print('}');
                        		Serial.println();
                        		Serial.println();
                        	if (lockConfig != 0x00) {
                        		// Write config and get CRC for the updated config
                        		crc = write_config_and_get_crc();
                        		// List current configuration before attempting to lock
                        		Serial.println(F("Chip configuration:"));
                        #ifdef LOCK_CONFIGURATION
                        		// Purge serial input buffer
                        #ifndef SKIP_UART_CONFIRMATION
                        		while (Serial.available()) {
                        			Serial.read();
                        		Serial.println(F("Send SPACE character now to lock the configuration..."));
                        		while (Serial.available() == 0);
                        		if (Serial.read() == ' ')
                        #endif //not SKIP_UART_CONFIRMATION
                        			Serial.println(F("Locking configuration..."));
                        			// Correct sequence, resync chip
                        			ret_code = sha204.sha204c_resync(SHA204_RSP_SIZE_MAX, rx_buffer);
                        			if (ret_code != SHA204_SUCCESS && ret_code != SHA204_RESYNC_WITH_WAKEUP) {
                        				Serial.print(F("Resync failed. Response: "));
                        				halt();
                        			// Lock configuration zone
                        			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_CONFIG,
                        			                                  crc, 0, NULL, 0, NULL, 0, NULL,
                        			                                  LOCK_COUNT, tx_buffer, LOCK_RSP_SIZE, rx_buffer);
                        				Serial.print(F("Configuration lock failed. Response: "));
                        				halt();
                        				Serial.println(F("Configuration locked."));
                        				// Update lock flags after locking
                        					halt();
                        		else {
                        			Serial.println(F("Unexpected answer. Skipping lock."));
                        #else //LOCK_CONFIGURATION
                        		Serial.println(F("Configuration not locked. Define LOCK_CONFIGURATION to lock for real."));
                        		Serial.println(F("Skipping configuration write and lock (configuration already locked)."));
                        #ifdef SKIP_KEY_STORAGE
                        	Serial.println(F("Disable SKIP_KEY_STORAGE to store key."));
                        #ifdef USER_KEY
                        	memcpy(key, user_key_data, 32);
                        	Serial.println(F("Using this user supplied HMAC key:"));
                        		halt();
                        		Serial.println(F("Take note of this key, it will never be the shown again:"));
                        	Serial.print("#define MY_HMAC_KEY ");
                        		Serial.print("0x");
                        		if (i < 31) {
                        			Serial.print(',');
                        		if (i+1 == 16) {
                        			Serial.print("\\\n                    ");
                        	Serial.println();
                        	// It will not be possible to write the key if the configuration zone is unlocked
                        		// Write the key to the appropriate slot in the data zone
                        		Serial.println(F("Writing key to slot 0..."));
                        		write_key(key);
                        		Serial.println(F("Skipping key storage (configuration not locked)."));
                        		Serial.println(F("The configuration must be locked to be able to write a key."));
                        	if (lockValue != 0x00) {
                        #ifdef LOCK_DATA
                        			Serial.read();
                        		Serial.println(F("Send SPACE character to lock data..."));
                        				halt();
                        			// If configuration is unlocked, key is not updated. Locking data in this case will cause
                        			// slot 0 to contain an unknown (or factory default) key, and this is in practically any
                        			// usecase not the desired behaviour, so ask for additional confirmation in this case.
                        					Serial.read();
                        				Serial.println(F("*** ATTENTION ***"));
                        				Serial.println(F("Configuration is not locked. Are you ABSULOUTELY SURE you want to lock data?"));
                        				Serial.println(F("Locking data at this stage will cause slot 0 to contain a factory default key"));
                        				Serial.println(
                        				    F("which cannot be change after locking is done. This is in practically any usecase"));
                        				Serial.println(F("NOT the desired behavour. Send SPACE character now to lock data anyway..."));
                        				if (Serial.read() != ' ') {
                        					halt();
                        			// Lock data zone
                        			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_DATA | LOCK_ZONE_NO_CRC,
                        			                                  0x0000, 0, NULL, 0, NULL, 0, NULL,
                        				Serial.print(F("Data lock failed. Response: "));
                        				halt();
                        				Serial.println(F("Data locked."));
                        					halt();
                        		else {
                        #else //LOCK_DATA
                        		Serial.println(F("Data not locked. Define LOCK_DATA to lock for real."));
                        		Serial.println(F("Skipping OTP/data zone lock (zone already locked)."));
                        	Serial.println(F("--------------------------------"));
                        	Serial.println(F("Personalization is now complete."));
                        	Serial.print(F("Configuration is "));
                        		Serial.println("LOCKED");
                        		Serial.println("UNLOCKED");
                        	Serial.print(F("Data is "));
                        	if (lockValue == 0x00) {
                        /** @brief Sketch execution code */
                        • M meddie
                          @Anticimex
                          #if DOXYGEN
                          #define LOCK_DATA
                          #define USER_KEY
                          //#define LOCK_DATA
                          //#define USER_KEY
                          #ifdef USER_KEY
                          #ifdef USER_AES_KEY
                          void halt()
                          	while(1);
                          	uint16_t crc = 0;
                          	uint8_t ret_code;
                          	bool do_write;
                          		do_write = true;
                          		if (i == 20) {
                          				halt();
                          			do_write = false;
                          		if (do_write) {
                          				Serial.print(i);
                          				halt();
                          	return crc;
                          	uint8_t ret_code;
                          		halt();
                          	uint8_t buffer[32];
                          	Serial.println();
                          	Serial.println();
                          	Serial.println();
                          	uint8_t ret_code;
                          			halt();
                          		if (i == 0x00) {
                          				if (j == 1) {
                          			Serial.println();
                          			Serial.println();
                          			Serial.println();
                          				if (j < 3) {
                          			Serial.println();
                          				if (j < 3) {
                          			Serial.println();
                          				if (j == 1) {
                          			Serial.println();
                          				if (j == 1) {
                          			Serial.println();
                          				if (j == 1) {
                          			Serial.println();
                          				if (j == 1) {
                          			Serial.println();
                          				if (j == 1) {
                          			Serial.println();
                          				if (j == 1) {
                          			Serial.println();
                          				if (j == 1) {
                          			Serial.println();
                          				if (j == 1) {
                          			Serial.println();
                          				if (j < 3) {
                          			Serial.println();
                          				if (j < 3) {
                          			Serial.println();
                          				if (j < 3) {
                          			Serial.println();
                          				if (j < 3) {
                          			Serial.println();
                          			Serial.println();
                          			Serial.println();
                          			Serial.println();
                          			Serial.println();
                          				if (j < 3) {
                          			Serial.println();
                          	uint8_t ret_code;
                          	uint16_t crc;
                          	(void)crc;
                          	uint8_t key[32];
                          	(void)key;
                          	hwInit();
                          		halt();
                          		halt();
                          		halt();
                          		Serial.print("0x");
                          		if (i < 31) {
                          			Serial.print(',');
                          	Serial.println();
                          		halt();
                          		Serial.print("0x");
                          		if (i < 8) {
                          			Serial.print(',');
                          	Serial.println();
                          #ifdef USER_AES_KEY
                          		halt();
                          		Serial.print("0x");
                          		if (i < 15) {
                          			Serial.print(',');
                          	Serial.println();
                          		halt();
                          		Serial.println();
                          		halt();
                          		Serial.print('{');
                          			if (i < 8) {
                          				Serial.print(',');
                          		Serial.print('}');
                          		Serial.println();
                          		Serial.println();
                          			Serial.read();
                          				halt();
                          				halt();
                          					halt();
                          		else {
                          #ifdef USER_KEY
                          		halt();
                          		Serial.print("0x");
                          		if (i < 31) {
                          			Serial.print(',');
                          		if (i+1 == 16) {
                          	Serial.println();
                          		write_key(key);
                          #ifdef LOCK_DATA
                          			Serial.read();
                          				halt();
                          					Serial.read();
                          				Serial.println(
                          					halt();
                          			// Lock data zone
                          				halt();
                          					halt();
                          		else {
                          #else //LOCK_DATA
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @meddie Sorry, missed that post.
                          You have SKIP_KEY_STORAGE defined so no keys will be stored. This is the default and intentional, to avoid people just executing the sketch and accidentally overwrite existing keys.
                          Furthermore, you have selected to personalize a ATSHA device, and have it generate the keys. That means that you have to define LOCK_CONFIGURATION or the ATSHA random number generator will not work.
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            You can read about personalization here.
                              meddie
                              Ah, thank you very much, yes now i get generated a key. But one more question the AES key will not be generated? I got only the HMAC Key, do i have to put the AES Key at myself?
                              Thank you very much!
                              • M meddie
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @meddie Please read the documentation and the sketch carefully. It quite clearly states in both documentation and code that you need to define STORE_AES_KEY to generate and store an AES key.
                                  meddie
                                  @Anticimex
                                  sorry sorry for so many questions, i have read the how to use already some times, but maybe its my bad english or the fear to do something wrong or to destroy the chip. I get a little bit unsure.
                                  Now i get both keys. If i understood correctly, the keys are now stored, i have now to put the shown keys to the sketch as HMAC and AES Key, and run this sketch on the sensor nodes.
                                  On the gateway on which i generated the keys i dont need to do anything more as to upload the gateway sketch ?
                                  Thank you very much for your support!
                                  • M meddie
                                    @Anticimex
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @meddie assuming you locked the configuration of the atsha, no you should not need to do more.
                                      meddie
                                      @Anticimex said in 💬 Sensebender Gateway:
                                      @Anticimex
                                      sorry i have one more question, because i didnt fully understand this. In the gettings started how to you wrote:
                                      Pick a “master” device with serial debug port.
                                      Set the following sketch configuration of the personalizer:
                                      Enable SKIP_KEY_STORAGE
                                      Execute the sketch on the “master” device to obtain a randomized key. Save this key to a secure location and keep it confidential so that you can retrieve it if you need to personalize more devices later on.
                                      Now reconfigure the sketch with these settings:
                                      Put the saved key in the user_key_data variable.
                                      Now execute the sketch on all devices you want to personalize with this secret key.
                                      on the first run i have to enable SKIP_KEY_STORAGE so i removed the comments.
                                      But here in forum you write i have to disable this. After i has disabled it wroked fine for me.
                                      But now i have to run the sketch on my node, and i think i have to disable the SKIP function too, because i need that the keys will be stored in the node.
                                      So if i am right, the on both runs the SKIP function has to be commented out? Or i am wrong?
                                      Thank you.
                                      • M meddie
                                        @Anticimex
                                        Thank you.
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        #293
                                        @meddie If your read the text carefully it says:
                                        So in other words; you first use the settings described in the first setting, execute that once. Follow the instructions carefully. Write down the key you got. Then you reconfigure the sketch and execute it on all devices you want to personalize. That is, you execute it twice on the first device.
                                        I wrote that you need to undefine SKIP_KEY_STORAGE if you want to store a key. But the first set of instructions in the documentation is not saying that you are supposed to store a key. It says "Execute the sketch on the “master” device to obtain a randomized key."
                                        So the documentation is correct, and describe a flow where you personalize nodes and gateways with the minimum amount of changes needed. First you generate a key, and this step can actually be skipped altogether if you just make your own random key or password to use for HMAC/AES.
                                        Then you reconfigure the personalizer to use your generated (or selected) key and write it to all your devices.
                                          meddie
                                          @Anticimex
                                          but as i runned the sketch with SKIP_KEY_STORAGE defined, so no keys were generated.
                                          i did not like to say that the documentation is incorrect, i like your documentation and your work very well! i just didnt understand it!
                                          Greets Eddie
