  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 466.6k Views 30 Watching
  • alexsh1A alexsh1
    @Anticimex I think a noob's section would be good. Having said that, the point is that signing is not something beginners should touch. What do you think?
    How about a section on the web-site? Somewhere here - https://www.mysensors.org/build/
    AnticimexA
    AnticimexA
    Anticimex
    @alexsh1 hm, yeah, perhaps something for @hek to consider. At least a link to the signing section of the doxygen docs could be placed there. I have tried to make the documentation as step-by-step friendly as I can. That said, as I also did the actual implementation, I may well be blind for certain aspects I take for granted that a "novice" does not.
      The next release of the main site will be much more flexible and integrated with openhardware-added projects. The idea is to allow community members to maintain their projects and/or "articles" themselves. The how-to for signing is a good example of an article.
      • F
        F
        Fabien
        This tutorial is up to date for 2.0 release ?
        AnticimexA 1 Reply Last reply
        • F Fabien
          AnticimexA
          AnticimexA
          Anticimex
          @Fabien Yes, top post is now updated for 2.0.0. Documentation is in doxygen.
          • F
            F
            Fabien
            Thank you @Anticimex I will update my network soon and had RFM69 Encryption too.
            • NiklasON
              NiklasON
              NiklasO
              wrote on last edited by NiklasO
              #277
              Trying this:
              https://www.mysensors.org/build/raspberry
              How do I enable signing and give the gateway the serial, hmac and aes-key when running on Linux? (rPi).
              Edit: Pin 7 as random number generator maybe need some change?
              • NiklasON NiklasO
                Trying this:
                AnticimexA
                AnticimexA
                Anticimex
                @NiklasO @marceloaqno is working on this.
                • E
                  E
                  executivul
                  I have about 100 ATSHA204 I2C variant to be used in a MySensors project.
                  Do you think that by modifying the personalizer sketch to disable the I2C bit in the configuration (0x03 word address) the chips can be set to be used as single-wire, or are they hardcoded to use only one protocol, but then why having the config bit?
                  • E executivul
                    AnticimexA
                    AnticimexA
                    Anticimex
                    #280
                    @executivul The bit is readonly. You cannot change it. It is used to determine the variant of chip, not to select mode of operation.
                    From the documentation:
                    0_1478094689558_upload-93242040-4814-4ad6-8951-4ad4d1e99a23
                    But you are welcome to submit a pull request for adding support for I2C variants of ATSHA204a. I have none myself so I have not bothered looking into that and currently I am out of time to spend on it I am afraid.
                    E 1 Reply Last reply
                    • AnticimexA Anticimex
                      E
                      E
                      executivul
                      Please excuse my noobish ignorance: How and where do I submit one?
                      • E executivul
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @executivul By forking the MySensors core repository and create a local git branch, do your code, push it back to your fork on GitHub and then create a pull request from that. There are good guides on GitHub for how do do it.
                          meddie
                          ok, thank you, but do you know why the sketch didnt generate the keys, and instead of random i get only keys ffffffffffff ?
                          thank you
                          • M meddie
                            thank you
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @meddie Without actually seeing your sketch it is pretty hard for me to help with anything ;)
                            My guess is, you did not enable the proper defines to instruct it to generate and store any keys.
                              meddie
                              @Anticimex
                              Hi i have posted my sketch few posts ago, but no problem here is it:
                              #include "sha204_library.h"
                              #define MY_CORE_ONLY
                              #if DOXYGEN
                              #define LOCK_CONFIGURATION
                              #define LOCK_DATA
                              #define SKIP_KEY_STORAGE
                              #define USER_KEY
                              #define SKIP_UART_CONFIRMATION
                              #define USE_SOFT_SIGNING
                              #define STORE_SOFT_KEY
                              #define USER_SOFT_KEY
                              #define STORE_SOFT_SERIAL
                              #define USER_SOFT_SERIAL
                              #define STORE_AES_KEY
                              #define USER_AES_KEY
                              //#define LOCK_CONFIGURATION
                              //#define LOCK_DATA
                              //#define USER_KEY
                              //#define USE_SOFT_SIGNING
                              //#define STORE_SOFT_KEY
                              //#define USER_SOFT_KEY
                              //#define STORE_SOFT_SERIAL
                              //#define USER_SOFT_SERIAL
                              //#define STORE_AES_KEY
                              //#define USER_AES_KEY
                              #ifdef USER_KEY
                              #ifdef USER_SOFT_KEY
                              #ifdef USER_SOFT_SERIAL
                              #ifdef USER_AES_KEY
                              #ifndef USE_SOFT_SIGNING
                              void halt()
                              	while(1);
                              	uint16_t crc = 0;
                              	uint8_t config_word[4];
                              	uint8_t ret_code;
                              	bool do_write;
                              		do_write = true;
                              		if (i == 20) {
                              			config_word[0] = 0x8F;
                              			config_word[1] = 0x80;
                              			config_word[2] = 0x80;
                              			config_word[3] = 0xA1;
                              		} else if (i == 24) {
                              			config_word[0] = 0x82;
                              			config_word[1] = 0xE0;
                              			config_word[2] = 0xA3;
                              			config_word[3] = 0x60;
                              		} else if (i == 28) {
                              			config_word[0] = 0x94;
                              			config_word[1] = 0x40;
                              			config_word[2] = 0xA0;
                              			config_word[3] = 0x85;
                              		} else if (i == 32) {
                              			config_word[0] = 0x86;
                              			config_word[2] = 0x87;
                              			config_word[3] = 0x07;
                              		} else if (i == 36) {
                              			config_word[0] = 0x0F;
                              			config_word[1] = 0x00;
                              			config_word[2] = 0x89;
                              			config_word[3] = 0xF2;
                              		} else if (i == 40) {
                              			config_word[0] = 0x8A;
                              			config_word[1] = 0x7A;
                              			config_word[2] = 0x0B;
                              			config_word[3] = 0x8B;
                              		} else if (i == 44) {
                              			config_word[0] = 0x0C;
                              			config_word[1] = 0x4C;
                              			config_word[2] = 0xDD;
                              			config_word[3] = 0x4D;
                              		} else if (i == 48) {
                              			config_word[0] = 0xC2;
                              			config_word[1] = 0x42;
                              			config_word[2] = 0xAF;
                              			config_word[3] = 0x8F;
                              			config_word[0] = 0xFF;
                              			config_word[2] = 0xFF;
                              			config_word[3] = 0x00;
                              			config_word[1] = 0xFF;
                              			config_word[3] = 0xFF;
                              				halt();
                              			do_write = false;
                              		// Write config word
                              		if (do_write) {
                              				Serial.print(i);
                              				halt();
                              	return crc;
                              void write_key(uint8_t* key)
                              	uint8_t ret_code;
                              	// Write key to slot 0
                              		halt();
                              void dump_configuration()
                              	uint8_t buffer[32];
                              	for (int j=0; j<32; j++) {
                              		if (buffer[j] < 0x10) {
                              		Serial.print(buffer[j], HEX);
                              	Serial.println();
                              	for (int j=0; j<9; j++) {
                              	Serial.println();
                              	for (int j=0; j<16; j++) {
                              	Serial.println();
                              	uint8_t ret_code;
                              			halt();
                              		if (i == 0x00) {
                              			for (int j=0; j<4; j++) {
                              				if (j == 1) {
                              					Serial.print(F(" | "));
                              					Serial.print(F("   "));
                              			Serial.println();
                              		} else if (i == 0x04) {
                              			Serial.println();
                              		} else if (i == 0x08) {
                              			Serial.println();
                              		} else if (i == 0x0C) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x10) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x14) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x18) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x1C) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x20) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x24) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x28) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x2C) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x30) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x34) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x38) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x3C) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x40) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x44) {
                              			Serial.println();
                              		} else if (i == 0x48) {
                              			Serial.println();
                              		} else if (i == 0x4C) {
                              			Serial.println();
                              		} else if (i == 0x50) {
                              			Serial.println();
                              		} else if (i == 0x54) {
                              				if (j < 3) {
                              			Serial.println();
                              	uint8_t ret_code;
                              	uint8_t lockConfig = 0;
                              	uint8_t lockValue = 0;
                              	uint16_t crc;
                              	(void)crc;
                              	// initialize pseudo-RNG
                              	uint8_t key[32];
                              	(void)key;
                              	hwInit();
                              		halt();
                              		halt();
                              #ifdef STORE_SOFT_KEY
                              #ifdef USE_SOFT_SIGNING
                              		halt();
                              	if (lockConfig == 0x00) {
                              #endif // not USER_SOFT_KEY
                              	for (int i=0; i<32; i++) {
                              		Serial.print("0x");
                              		if (key[i] < 0x10) {
                              		Serial.print(key[i], HEX);
                              		if (i < 31) {
                              			Serial.print(',');
                              	Serial.println();
                              #endif // STORE_SOFT_KEY
                              #ifdef STORE_SOFT_SERIAL
                              	for (int i = 0; i < 9; i++) {
                              		halt();
                              	for (int i=0; i<9; i++) {
                              		Serial.print("0x");
                              		if (i < 8) {
                              			Serial.print(',');
                              	Serial.println();
                              #endif // STORE_SOFT_SERIAL
                              #ifdef STORE_AES_KEY
                              #ifdef USER_AES_KEY
                              		halt();
                              #endif // not USER_AES_KEY
                              	Serial.print("#define MY_AES_KEY ");
                              	for (int i=0; i<16; i++) {
                              		Serial.print("0x");
                              		if (i < 15) {
                              			Serial.print(',');
                              	Serial.println();
                              #endif // STORE_AES_KEY
                              	Serial.println(F("EEPROM configuration:"));
                              	dump_configuration();
                              	// Output device revision on console
                              	ret_code = sha204.sha204m_dev_rev(tx_buffer, rx_buffer);
                              		Serial.print(F("Failed to determine device revision. Response: "));
                              		halt();
                              		Serial.print(F("Device revision: "));
                              		for (int i=0; i<4; i++) {
                              			if (rx_buffer[SHA204_BUFFER_POS_DATA+i] < 0x10) {
                              			Serial.print(rx_buffer[SHA204_BUFFER_POS_DATA+i], HEX);
                              		Serial.println();
                              	// Output serial number on console
                              	ret_code = sha204.getSerialNumber(rx_buffer);
                              		Serial.print(F("Failed to obtain device serial number. Response: "));
                              		halt();
                              		Serial.print(F("Device serial:   "));
                              		Serial.print('{');
                              			Serial.print(F("0x"));
                              			if (rx_buffer[i] < 0x10) {
                              			Serial.print(rx_buffer[i], HEX);
                              			if (i < 8) {
                              				Serial.print(',');
                              		Serial.print('}');
                              		Serial.println();
                              		Serial.println();
                              	if (lockConfig != 0x00) {
                              		// Write config and get CRC for the updated config
                              		crc = write_config_and_get_crc();
                              		// List current configuration before attempting to lock
                              		Serial.println(F("Chip configuration:"));
                              #ifdef LOCK_CONFIGURATION
                              		// Purge serial input buffer
                              #ifndef SKIP_UART_CONFIRMATION
                              		while (Serial.available()) {
                              			Serial.read();
                              		Serial.println(F("Send SPACE character now to lock the configuration..."));
                              		while (Serial.available() == 0);
                              		if (Serial.read() == ' ')
                              #endif //not SKIP_UART_CONFIRMATION
                              			Serial.println(F("Locking configuration..."));
                              			// Correct sequence, resync chip
                              			ret_code = sha204.sha204c_resync(SHA204_RSP_SIZE_MAX, rx_buffer);
                              			if (ret_code != SHA204_SUCCESS && ret_code != SHA204_RESYNC_WITH_WAKEUP) {
                              				Serial.print(F("Resync failed. Response: "));
                              				halt();
                              			// Lock configuration zone
                              			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_CONFIG,
        crc, 0, NULL, 0, NULL, 0, NULL,
        LOCK_COUNT, tx_buffer, LOCK_RSP_SIZE, rx_buffer);
                              				Serial.print(F("Configuration lock failed. Response: "));
                              				halt();
                              				Serial.println(F("Configuration locked."));
                              				// Update lock flags after locking
                              					halt();
                              		else {
                              			Serial.println(F("Unexpected answer. Skipping lock."));
                              #else //LOCK_CONFIGURATION
                              		Serial.println(F("Configuration not locked. Define LOCK_CONFIGURATION to lock for real."));
                              		Serial.println(F("Skipping configuration write and lock (configuration already locked)."));
                              #ifdef SKIP_KEY_STORAGE
                              	Serial.println(F("Disable SKIP_KEY_STORAGE to store key."));
                              #ifdef USER_KEY
                              	memcpy(key, user_key_data, 32);
                              	Serial.println(F("Using this user supplied HMAC key:"));
                              		halt();
                              		Serial.println(F("Take note of this key, it will never be the shown again:"));
                              	Serial.print("#define MY_HMAC_KEY ");
                              		Serial.print("0x");
                              		if (i < 31) {
                              			Serial.print(',');
                              		if (i+1 == 16) {
                              			Serial.print("\\\n                    ");
                              	Serial.println();
                              	// It will not be possible to write the key if the configuration zone is unlocked
                              		// Write the key to the appropriate slot in the data zone
                              		Serial.println(F("Writing key to slot 0..."));
                              		write_key(key);
                              		Serial.println(F("Skipping key storage (configuration not locked)."));
                              		Serial.println(F("The configuration must be locked to be able to write a key."));
                              	if (lockValue != 0x00) {
                              #ifdef LOCK_DATA
                              			Serial.read();
                              		Serial.println(F("Send SPACE character to lock data..."));
                              				halt();
                              			// If configuration is unlocked, key is not updated. Locking data in this case will cause
                              			// slot 0 to contain an unknown (or factory default) key, and this is in practically any
                              			// usecase not the desired behaviour, so ask for additional confirmation in this case.
                              					Serial.read();
                              				Serial.println(F("*** ATTENTION ***"));
                              				Serial.println(F("Configuration is not locked. Are you ABSULOUTELY SURE you want to lock data?"));
                              				Serial.println(F("Locking data at this stage will cause slot 0 to contain a factory default key"));
                              				Serial.println(
                              				    F("which cannot be change after locking is done. This is in practically any usecase"));
                              				Serial.println(F("NOT the desired behavour. Send SPACE character now to lock data anyway..."));
                              				if (Serial.read() != ' ') {
                              					halt();
                              			// Lock data zone
                              			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_DATA | LOCK_ZONE_NO_CRC,
        0x0000, 0, NULL, 0, NULL, 0, NULL,
                              				Serial.print(F("Data lock failed. Response: "));
                              				halt();
                              				Serial.println(F("Data locked."));
                              					halt();
                              		else {
                              #else //LOCK_DATA
                              		Serial.println(F("Data not locked. Define LOCK_DATA to lock for real."));
                              		Serial.println(F("Skipping OTP/data zone lock (zone already locked)."));
                              	Serial.println(F("--------------------------------"));
                              	Serial.println(F("Personalization is now complete."));
                              	Serial.print(F("Configuration is "));
                              		Serial.println("LOCKED");
                              		Serial.println("UNLOCKED");
                              	Serial.print(F("Data is "));
                              	if (lockValue == 0x00) {
                              /** @brief Sketch execution code */
                              • M meddie
                                @Anticimex
                                #if DOXYGEN
                                #define LOCK_DATA
                                #define USER_KEY
                                //#define LOCK_DATA
                                //#define USER_KEY
                                #ifdef USER_KEY
                                #ifdef USER_AES_KEY
                                void halt()
                                	while(1);
                                	uint16_t crc = 0;
                                	uint8_t ret_code;
                                	bool do_write;
                                		do_write = true;
                                		if (i == 20) {
                                				halt();
                                			do_write = false;
                                		if (do_write) {
                                				Serial.print(i);
                                				halt();
                                	return crc;
                                	uint8_t ret_code;
                                		halt();
                                	uint8_t buffer[32];
                                	Serial.println();
                                	Serial.println();
                                	Serial.println();
                                	uint8_t ret_code;
                                			halt();
                                		if (i == 0x00) {
                                				if (j == 1) {
                                			Serial.println();
                                			Serial.println();
                                			Serial.println();
                                				if (j < 3) {
                                			Serial.println();
                                				if (j < 3) {
                                			Serial.println();
                                				if (j == 1) {
                                			Serial.println();
                                				if (j == 1) {
                                			Serial.println();
                                				if (j == 1) {
                                			Serial.println();
                                				if (j == 1) {
                                			Serial.println();
                                				if (j == 1) {
                                			Serial.println();
                                				if (j == 1) {
                                			Serial.println();
                                				if (j == 1) {
                                			Serial.println();
                                				if (j == 1) {
                                			Serial.println();
                                				if (j < 3) {
                                			Serial.println();
                                				if (j < 3) {
                                			Serial.println();
                                				if (j < 3) {
                                			Serial.println();
                                				if (j < 3) {
                                			Serial.println();
                                			Serial.println();
                                			Serial.println();
                                			Serial.println();
                                			Serial.println();
                                				if (j < 3) {
                                			Serial.println();
                                	uint8_t ret_code;
                                	uint16_t crc;
                                	(void)crc;
                                	uint8_t key[32];
                                	(void)key;
                                	hwInit();
                                		halt();
                                		halt();
                                		halt();
                                		Serial.print("0x");
                                		if (i < 31) {
                                			Serial.print(',');
                                	Serial.println();
                                		halt();
                                		Serial.print("0x");
                                		if (i < 8) {
                                			Serial.print(',');
                                	Serial.println();
                                #ifdef USER_AES_KEY
                                		halt();
                                		Serial.print("0x");
                                		if (i < 15) {
                                			Serial.print(',');
                                	Serial.println();
                                		halt();
                                		Serial.println();
                                		halt();
                                		Serial.print('{');
                                			if (i < 8) {
                                				Serial.print(',');
                                		Serial.print('}');
                                		Serial.println();
                                		Serial.println();
                                			Serial.read();
                                				halt();
                                				halt();
                                					halt();
                                		else {
                                #ifdef USER_KEY
                                		halt();
                                		Serial.print("0x");
                                		if (i < 31) {
                                			Serial.print(',');
                                		if (i+1 == 16) {
                                	Serial.println();
                                		write_key(key);
                                #ifdef LOCK_DATA
                                			Serial.read();
                                				halt();
                                					Serial.read();
                                				Serial.println(
                                					halt();
                                			// Lock data zone
                                				halt();
                                					halt();
                                		else {
                                #else //LOCK_DATA
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @meddie Sorry, missed that post.
                                You have SKIP_KEY_STORAGE defined so no keys will be stored. This is the default and intentional, to avoid people just executing the sketch and accidentally overwrite existing keys.
                                Furthermore, you have selected to personalize a ATSHA device, and have it generate the keys. That means that you have to define LOCK_CONFIGURATION or the ATSHA random number generator will not work.
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  You can read about personalization here.
                                    meddie
                                    Ah, thank you very much, yes now i get generated a key. But one more question the AES key will not be generated? I got only the HMAC Key, do i have to put the AES Key at myself?
                                    Thank you very much!
                                    • M meddie
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @meddie Please read the documentation and the sketch carefully. It quite clearly states in both documentation and code that you need to define STORE_AES_KEY to generate and store an AES key.
                                        meddie
                                        @Anticimex
                                        sorry sorry for so many questions, i have read the how to use already some times, but maybe its my bad english or the fear to do something wrong or to destroy the chip. I get a little bit unsure.
                                        Now i get both keys. If i understood correctly, the keys are now stored, i have now to put the shown keys to the sketch as HMAC and AES Key, and run this sketch on the sensor nodes.
                                        On the gateway on which i generated the keys i dont need to do anything more as to upload the gateway sketch ?
                                        Thank you very much for your support!
                                        • M meddie
                                          @Anticimex
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @meddie assuming you locked the configuration of the atsha, no you should not need to do more.
