  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.3k Views 30 Watching
  • M meddie
    @Anticimex
    Hi i have posted my sketch few posts ago, but no problem here is it:
    #include "sha204_library.h"
    #define MY_CORE_ONLY
    #if DOXYGEN
    #define LOCK_CONFIGURATION
    #define LOCK_DATA
    #define SKIP_KEY_STORAGE
    #define USER_KEY
    #define SKIP_UART_CONFIRMATION
    #define USE_SOFT_SIGNING
    #define STORE_SOFT_KEY
    #define USER_SOFT_KEY
    #define STORE_SOFT_SERIAL
    #define USER_SOFT_SERIAL
    #define STORE_AES_KEY
    #define USER_AES_KEY
    //#define LOCK_CONFIGURATION
    //#define LOCK_DATA
    //#define USER_KEY
    //#define USE_SOFT_SIGNING
    //#define STORE_SOFT_KEY
    //#define USER_SOFT_KEY
    //#define STORE_SOFT_SERIAL
    //#define USER_SOFT_SERIAL
    //#define STORE_AES_KEY
    //#define USER_AES_KEY
    #ifdef USER_KEY
    #ifdef USER_SOFT_KEY
    #ifdef USER_SOFT_SERIAL
    #ifdef USER_AES_KEY
    #ifndef USE_SOFT_SIGNING
    void halt()
    	while(1);
    	uint16_t crc = 0;
    	uint8_t config_word[4];
    	uint8_t ret_code;
    	bool do_write;
    		do_write = true;
    		if (i == 20) {
    			config_word[0] = 0x8F;
    			config_word[1] = 0x80;
    			config_word[2] = 0x80;
    			config_word[3] = 0xA1;
    		} else if (i == 24) {
    			config_word[0] = 0x82;
    			config_word[1] = 0xE0;
    			config_word[2] = 0xA3;
    			config_word[3] = 0x60;
    		} else if (i == 28) {
    			config_word[0] = 0x94;
    			config_word[1] = 0x40;
    			config_word[2] = 0xA0;
    			config_word[3] = 0x85;
    		} else if (i == 32) {
    			config_word[0] = 0x86;
    			config_word[2] = 0x87;
    			config_word[3] = 0x07;
    		} else if (i == 36) {
    			config_word[0] = 0x0F;
    			config_word[1] = 0x00;
    			config_word[2] = 0x89;
    			config_word[3] = 0xF2;
    		} else if (i == 40) {
    			config_word[0] = 0x8A;
    			config_word[1] = 0x7A;
    			config_word[2] = 0x0B;
    			config_word[3] = 0x8B;
    		} else if (i == 44) {
    			config_word[0] = 0x0C;
    			config_word[1] = 0x4C;
    			config_word[2] = 0xDD;
    			config_word[3] = 0x4D;
    		} else if (i == 48) {
    			config_word[0] = 0xC2;
    			config_word[1] = 0x42;
    			config_word[2] = 0xAF;
    			config_word[3] = 0x8F;
    			config_word[0] = 0xFF;
    			config_word[2] = 0xFF;
    			config_word[3] = 0x00;
    			config_word[1] = 0xFF;
    			config_word[3] = 0xFF;
    				halt();
    			do_write = false;
    		// Write config word
    		if (do_write) {
    				Serial.print(i);
    				halt();
    	return crc;
    void write_key(uint8_t* key)
    	uint8_t ret_code;
    	// Write key to slot 0
    		halt();
    void dump_configuration()
    	uint8_t buffer[32];
    	for (int j=0; j<32; j++) {
    		if (buffer[j] < 0x10) {
    		Serial.print(buffer[j], HEX);
    	Serial.println();
    	for (int j=0; j<9; j++) {
    	Serial.println();
    	for (int j=0; j<16; j++) {
    	Serial.println();
    	uint8_t ret_code;
    			halt();
    		if (i == 0x00) {
    			for (int j=0; j<4; j++) {
    				if (j == 1) {
    					Serial.print(F(" | "));
    					Serial.print(F("   "));
    			Serial.println();
    		} else if (i == 0x04) {
    			Serial.println();
    		} else if (i == 0x08) {
    			Serial.println();
    		} else if (i == 0x0C) {
    				if (j < 3) {
    			Serial.println();
    		} else if (i == 0x10) {
    				if (j < 3) {
    			Serial.println();
    		} else if (i == 0x14) {
    				if (j == 1) {
    			Serial.println();
    		} else if (i == 0x18) {
    				if (j == 1) {
    			Serial.println();
    		} else if (i == 0x1C) {
    				if (j == 1) {
    			Serial.println();
    		} else if (i == 0x20) {
    				if (j == 1) {
    			Serial.println();
    		} else if (i == 0x24) {
    				if (j == 1) {
    			Serial.println();
    		} else if (i == 0x28) {
    				if (j == 1) {
    			Serial.println();
    		} else if (i == 0x2C) {
    				if (j == 1) {
    			Serial.println();
    		} else if (i == 0x30) {
    				if (j == 1) {
    			Serial.println();
    		} else if (i == 0x34) {
    				if (j < 3) {
    			Serial.println();
    		} else if (i == 0x38) {
    				if (j < 3) {
    			Serial.println();
    		} else if (i == 0x3C) {
    				if (j < 3) {
    			Serial.println();
    		} else if (i == 0x40) {
    				if (j < 3) {
    			Serial.println();
    		} else if (i == 0x44) {
    			Serial.println();
    		} else if (i == 0x48) {
    			Serial.println();
    		} else if (i == 0x4C) {
    			Serial.println();
    		} else if (i == 0x50) {
    			Serial.println();
    		} else if (i == 0x54) {
    				if (j < 3) {
    			Serial.println();
    	uint8_t ret_code;
    	uint8_t lockConfig = 0;
    	uint8_t lockValue = 0;
    	uint16_t crc;
    	(void)crc;
    	// initialize pseudo-RNG
    	uint8_t key[32];
    	(void)key;
    	hwInit();
    		halt();
    		halt();
    #ifdef STORE_SOFT_KEY
    #ifdef USE_SOFT_SIGNING
    		halt();
    	if (lockConfig == 0x00) {
    #endif // not USER_SOFT_KEY
    	for (int i=0; i<32; i++) {
    		Serial.print("0x");
    		if (key[i] < 0x10) {
    		Serial.print(key[i], HEX);
    		if (i < 31) {
    			Serial.print(',');
    	Serial.println();
    #endif // STORE_SOFT_KEY
    #ifdef STORE_SOFT_SERIAL
    	for (int i = 0; i < 9; i++) {
    		halt();
    	for (int i=0; i<9; i++) {
    		Serial.print("0x");
    		if (i < 8) {
    			Serial.print(',');
    	Serial.println();
    #endif // STORE_SOFT_SERIAL
    #ifdef STORE_AES_KEY
    #ifdef USER_AES_KEY
    		halt();
    #endif // not USER_AES_KEY
    	Serial.print("#define MY_AES_KEY ");
    	for (int i=0; i<16; i++) {
    		Serial.print("0x");
    		if (i < 15) {
    			Serial.print(',');
    	Serial.println();
    #endif // STORE_AES_KEY
    	Serial.println(F("EEPROM configuration:"));
    	dump_configuration();
    	// Output device revision on console
    	ret_code = sha204.sha204m_dev_rev(tx_buffer, rx_buffer);
    		Serial.print(F("Failed to determine device revision. Response: "));
    		halt();
    		Serial.print(F("Device revision: "));
    		for (int i=0; i<4; i++) {
    			if (rx_buffer[SHA204_BUFFER_POS_DATA+i] < 0x10) {
    			Serial.print(rx_buffer[SHA204_BUFFER_POS_DATA+i], HEX);
    		Serial.println();
    	// Output serial number on console
    	ret_code = sha204.getSerialNumber(rx_buffer);
    		Serial.print(F("Failed to obtain device serial number. Response: "));
    		halt();
    		Serial.print(F("Device serial:   "));
    		Serial.print('{');
    			Serial.print(F("0x"));
    			if (rx_buffer[i] < 0x10) {
    			Serial.print(rx_buffer[i], HEX);
    			if (i < 8) {
    				Serial.print(',');
    		Serial.print('}');
    		Serial.println();
    		Serial.println();
    	if (lockConfig != 0x00) {
    		// Write config and get CRC for the updated config
    		crc = write_config_and_get_crc();
    		// List current configuration before attempting to lock
    		Serial.println(F("Chip configuration:"));
    #ifdef LOCK_CONFIGURATION
    		// Purge serial input buffer
    #ifndef SKIP_UART_CONFIRMATION
    		while (Serial.available()) {
    			Serial.read();
    		Serial.println(F("Send SPACE character now to lock the configuration..."));
    		while (Serial.available() == 0);
    		if (Serial.read() == ' ')
    #endif //not SKIP_UART_CONFIRMATION
    			Serial.println(F("Locking configuration..."));
    			// Correct sequence, resync chip
    			ret_code = sha204.sha204c_resync(SHA204_RSP_SIZE_MAX, rx_buffer);
    			if (ret_code != SHA204_SUCCESS && ret_code != SHA204_RESYNC_WITH_WAKEUP) {
    				Serial.print(F("Resync failed. Response: "));
    				halt();
    			// Lock configuration zone
    			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_CONFIG,
    			                                  crc, 0, NULL, 0, NULL, 0, NULL,
    			                                  LOCK_COUNT, tx_buffer, LOCK_RSP_SIZE, rx_buffer);
    				Serial.print(F("Configuration lock failed. Response: "));
    				halt();
    				Serial.println(F("Configuration locked."));
    				// Update lock flags after locking
    					halt();
    		else {
    			Serial.println(F("Unexpected answer. Skipping lock."));
    #else //LOCK_CONFIGURATION
    		Serial.println(F("Configuration not locked. Define LOCK_CONFIGURATION to lock for real."));
    		Serial.println(F("Skipping configuration write and lock (configuration already locked)."));
    #ifdef SKIP_KEY_STORAGE
    	Serial.println(F("Disable SKIP_KEY_STORAGE to store key."));
    #ifdef USER_KEY
    	memcpy(key, user_key_data, 32);
    	Serial.println(F("Using this user supplied HMAC key:"));
    		halt();
    		Serial.println(F("Take note of this key, it will never be the shown again:"));
    	Serial.print("#define MY_HMAC_KEY ");
    		Serial.print("0x");
    		if (i < 31) {
    			Serial.print(',');
    		if (i+1 == 16) {
    			Serial.print("\\\n                    ");
    	Serial.println();
    	// It will not be possible to write the key if the configuration zone is unlocked
    		// Write the key to the appropriate slot in the data zone
    		Serial.println(F("Writing key to slot 0..."));
    		write_key(key);
    		Serial.println(F("Skipping key storage (configuration not locked)."));
    		Serial.println(F("The configuration must be locked to be able to write a key."));
    	if (lockValue != 0x00) {
    #ifdef LOCK_DATA
    			Serial.read();
    		Serial.println(F("Send SPACE character to lock data..."));
    				halt();
    			// If configuration is unlocked, key is not updated. Locking data in this case will cause
    			// slot 0 to contain an unknown (or factory default) key, and this is in practically any
    			// usecase not the desired behaviour, so ask for additional confirmation in this case.
    					Serial.read();
    				Serial.println(F("*** ATTENTION ***"));
    				Serial.println(F("Configuration is not locked. Are you ABSULOUTELY SURE you want to lock data?"));
    				Serial.println(F("Locking data at this stage will cause slot 0 to contain a factory default key"));
    				Serial.println(
    				    F("which cannot be change after locking is done. This is in practically any usecase"));
    				Serial.println(F("NOT the desired behavour. Send SPACE character now to lock data anyway..."));
    				if (Serial.read() != ' ') {
    					halt();
    			// Lock data zone
    			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_DATA | LOCK_ZONE_NO_CRC,
    			                                  0x0000, 0, NULL, 0, NULL, 0, NULL,
    				Serial.print(F("Data lock failed. Response: "));
    				halt();
    				Serial.println(F("Data locked."));
    					halt();
    		else {
    #else //LOCK_DATA
    		Serial.println(F("Data not locked. Define LOCK_DATA to lock for real."));
    		Serial.println(F("Skipping OTP/data zone lock (zone already locked)."));
    	Serial.println(F("--------------------------------"));
    	Serial.println(F("Personalization is now complete."));
    	Serial.print(F("Configuration is "));
    		Serial.println("LOCKED");
    		Serial.println("UNLOCKED");
    	Serial.print(F("Data is "));
    	if (lockValue == 0x00) {
    /** @brief Sketch execution code */
    AnticimexA
    AnticimexA
    Anticimex
    @meddie Sorry, missed that post.
    You have SKIP_KEY_STORAGE defined so no keys will be stored. This is the default and intentional, to avoid people just executing the sketch and accidentally overwrite existing keys.
    Furthermore, you have selected to personalize a ATSHA device, and have it generate the keys. That means that you have to define LOCK_CONFIGURATION or the ATSHA random number generator will not work.
    • AnticimexA
      AnticimexA
      Anticimex
      You can read about personalization here.
        meddie
        Ah, thank you very much, yes now i get generated a key. But one more question the AES key will not be generated? I got only the HMAC Key, do i have to put the AES Key at myself?
        Thank you very much!
        AnticimexA 1 Reply Last reply
        • M meddie
          AnticimexA
          AnticimexA
          Anticimex
          @meddie Please read the documentation and the sketch carefully. It quite clearly states in both documentation and code that you need to define STORE_AES_KEY to generate and store an AES key.
            meddie
            @Anticimex
            sorry sorry for so many questions, i have read the how to use already some times, but maybe its my bad english or the fear to do something wrong or to destroy the chip. I get a little bit unsure.
            Now i get both keys. If i understood correctly, the keys are now stored, i have now to put the shown keys to the sketch as HMAC and AES Key, and run this sketch on the sensor nodes.
            On the gateway on which i generated the keys i dont need to do anything more as to upload the gateway sketch ?
            Thank you very much for your support!
            • M meddie
              @Anticimex
              AnticimexA
              AnticimexA
              Anticimex
              @meddie assuming you locked the configuration of the atsha, no you should not need to do more.
              • AnticimexA Anticimex
                meddie
                @Anticimex said in 💬 Sensebender Gateway:
                @Anticimex
                sorry i have one more question, because i didnt fully understand this. In the gettings started how to you wrote:
                Pick a “master” device with serial debug port.
                Set the following sketch configuration of the personalizer:
                Enable SKIP_KEY_STORAGE
                Execute the sketch on the “master” device to obtain a randomized key. Save this key to a secure location and keep it confidential so that you can retrieve it if you need to personalize more devices later on.
                Now reconfigure the sketch with these settings:
                Put the saved key in the user_key_data variable.
                Now execute the sketch on all devices you want to personalize with this secret key.
                on the first run i have to enable SKIP_KEY_STORAGE so i removed the comments.
                But here in forum you write i have to disable this. After i has disabled it wroked fine for me.
                But now i have to run the sketch on my node, and i think i have to disable the SKIP function too, because i need that the keys will be stored in the node.
                So if i am right, the on both runs the SKIP function has to be commented out? Or i am wrong?
                Thank you.
                • M meddie
                  @Anticimex
                  Thank you.
                  AnticimexA
                  AnticimexA
                  Anticimex
                  #293
                  @meddie If your read the text carefully it says:
                  So in other words; you first use the settings described in the first setting, execute that once. Follow the instructions carefully. Write down the key you got. Then you reconfigure the sketch and execute it on all devices you want to personalize. That is, you execute it twice on the first device.
                  I wrote that you need to undefine SKIP_KEY_STORAGE if you want to store a key. But the first set of instructions in the documentation is not saying that you are supposed to store a key. It says "Execute the sketch on the “master” device to obtain a randomized key."
                  So the documentation is correct, and describe a flow where you personalize nodes and gateways with the minimum amount of changes needed. First you generate a key, and this step can actually be skipped altogether if you just make your own random key or password to use for HMAC/AES.
                  Then you reconfigure the personalizer to use your generated (or selected) key and write it to all your devices.
                    meddie
                    @Anticimex
                    but as i runned the sketch with SKIP_KEY_STORAGE defined, so no keys were generated.
                    i did not like to say that the documentation is incorrect, i like your documentation and your work very well! i just didnt understand it!
                    Greets Eddie
                    • M meddie
                      @Anticimex
                      Greets Eddie
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @meddie are you sure you ran with the exact settings described for generating the keys? The SKIP_KEY_STORAGE flag does not prevent the keys from being generated. They are still printed in the serial log. It prevents the keys from being stored to the atsha204a device.
                        meddie
                        i fear to write again, but my fail story goes on :-(
                        i have uploaded on the gateway this sketch:
                        * Version 1.0 - Henrik EKblad
                        * This GW code is designed for Sensebender GateWay / (Arduino Zero variant)
                        * - Inclusion button should be connected to SW2
                        * LEDs on board (default assignments):
                        * - Orange: USB RX/TX - Blink when receiving / transmitting on USB CDC device
                        * - Yellow: RX  - Blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
                        * - Green : TX  - Blink fast on radio message transmitted. In inclusion mode will blink slowly
                        * - Red   : ERR - Fast blink on error during transmission error or recieve crc error
                        * - Blue  : free - (use with LED_BLUE macro)
                        #include <stdint.h>
                        #include <pins_arduino.h>
                        #define SKETCH_VERSION "0.2"
                        #define MY_SIGNING_ATSHA204
                        #define MY_GATEWAY_W5100
                        //#define MY_W5100_SPI_EN 4
                        // radio on the same spi bus.
                        #define MY_SOFTSPI
                        #ifndef MY_RF24_CE_PIN
                        #define MY_RF24_CE_PIN 5
                        #ifndef MY_RF24_CS_PIN
                        #define MY_RF24_CS_PIN 6
                        // Enable to UDP
                        //#define MY_USE_UDP
                        #define MY_IP_ADDRESS 10,0,0,253   // If this is disabled, DHCP is used to retrieve address
                        #define MY_PORT 5003
                        // Enable inclusion mode
                        // Set blinking period
                        // Flash leds on rx/tx/err
                        #if defined(MY_USE_UDP)
                        #include <EthernetUdp.h>
                        #include <Ethernet.h>
                        #include <SD.h>
                        //#include <drivers/ATSHA204/ATSHA204.cpp>
                        Sd2Card card;
                        #define EEPROM_VERIFICATION_ADDRESS 0x01
                        static uint8_t num_of_leds = 5;
                        static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
                        void preHwInit()
                          pinMode(MY_SWC1, INPUT_PULLUP);
                          pinMode(MY_SWC2, INPUT_PULLUP);
                          if (digitalRead(MY_SWC1) && digitalRead(MY_SWC2)) {
                            return;
                          uint8_t tests = 0;
                          for (int i=0; i< num_of_leds; i++) {
                            pinMode(leds[i], OUTPUT);
                          uint8_t led_state = 0;
                          if (digitalRead(MY_SWC1)) {
                            while (!Serial) {
                              digitalWrite(LED_BLUE, led_state);
                              led_state ^= 0x01;
                              delay(500);
                            } // Wait for USB to be connected, before spewing out data.
                          digitalWrite(LED_BLUE, LOW);
                          if (Serial) {
                            Serial.println("Sensebender GateWay test routine");
                            Serial.print("Mysensors core version : ");
                            Serial.println(MYSENSORS_LIBRARY_VERSION);
                            Serial.print("GateWay sketch version : ");
                            Serial.println("----------------------------------");
                            Serial.println();
                          if (testSha204()) {
                            digitalWrite(LED_GREEN, HIGH);
                            tests++;
                          if (testSDCard()) {
                            digitalWrite(LED_YELLOW, HIGH);
                            tests++;
                          if (testEEProm()) {
                            digitalWrite(LED_ORANGE, HIGH);
                            tests++;
                          if (testAnalog()) {
                            digitalWrite(LED_BLUE, HIGH);
                            tests++;
                          if (tests == 4) {
                            while(1) {
                              for (int i=0; i<num_of_leds; i++) {
                                digitalWrite(leds[i], HIGH);
                                delay(200);
                                digitalWrite(leds[i], LOW);
                            while (1) {
                              digitalWrite(LED_RED, HIGH);
                              delay(200);
                              digitalWrite(LED_RED, LOW);
                              delay(200);
                        bool testSha204()
                          uint8_t ret_code;
                          if (Serial) {
                            Serial.print("- > SHA204 ");
                          atsha204_init(MY_SIGNING_ATSHA204_PIN);
                          ret_code = atsha204_wakeup(rx_buffer);
                          if (ret_code == SHA204_SUCCESS) {
                            ret_code = atsha204_getSerialNumber(rx_buffer);
                              if (Serial) {
                                Serial.println(F("Failed to obtain device serial number. Response: "));
                              if (Serial) {
                                Serial.print(F("Ok (serial : "));
                                Serial.println(")");
                              return true;
                            if (Serial) {
                              Serial.println(F("Failed to wakeup SHA204"));
                          return false;
                        bool testSDCard()
                          if (Serial) {
                            Serial.print("- > SD CARD ");
                          if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
                            if (Serial) {
                              Serial.println("SD CARD did not initialize!");
                            if (Serial) {
                              Serial.print("SD Card initialized correct! - ");
                              Serial.print("type detected : ");
                              switch(card.type()) {
                              case SD_CARD_TYPE_SD1:
                                Serial.println("SD1");
                              case SD_CARD_TYPE_SD2:
                                Serial.println("SD2");
                              case SD_CARD_TYPE_SDHC:
                                Serial.println("SDHC");
                              default:
                                Serial.println("Unknown");
                            return true;
                          return false;
                        bool testEEProm()
                          uint8_t eeprom_d1, eeprom_d2;
                          SerialUSB.print(" -> EEPROM ");
                          Wire.begin();
                          eeprom_d1 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
                          delay(500);
                          eeprom_d1 = ~eeprom_d1; // invert the bits
                          i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
                          delay(500);
                          eeprom_d2 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
                          if (eeprom_d1 == eeprom_d2) {
                            SerialUSB.println("PASSED");
                            i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, ~eeprom_d1);
                            return true;
                          SerialUSB.println("FAILED!");
                          return false;
                        bool testAnalog()
                          int bat_detect = analogRead(MY_BAT_DETECT);
                          Serial.print("-> analog : ");
                          Serial.print(bat_detect);
                          if (bat_detect < 400 || bat_detect > 650) {
                            Serial.println(" Failed");
                            return false;
                          Serial.println(" Passed");
                          return true;
                          meddie
                          and on the node this sketch:
                          #include <stdint.h>
                          //#define MY_SIGNING_SOFT
                          But the node does not connect and i get this on the serial monitor:
                          0 MCO:BGN:INIT NODE,CP=RNNNAA-,VER=2.1.1
                          4 TSM:INIT
                          4 TSF:WUR:MS=0
                          12 TSM:INIT:TSP OK
                          14 TSF:SID:OK,ID=100
                          16 TSM:FPAR
                          18 Will not sign message for destination 255 as it does not require it
                          67 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          2076 !TSM:FPAR:NO REPLY
                          2078 TSM:FPAR
                          2080 Will not sign message for destination 255 as it does not require it
                          2127 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          4139 !TSM:FPAR:NO REPLY
                          4141 TSM:FPAR
                          4143 Will not sign message for destination 255 as it does not require it
                          4190 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          6199 !TSM:FPAR:NO REPLY
                          6201 TSM:FPAR
                          6203 Will not sign message for destination 255 as it does not require it
                          6250 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          8259 !TSM:FPAR:FAIL
                          8261 TSM:FAIL:CNT=1
                          8263 TSM:FAIL:PDT
                          18266 TSM:FAIL:RE-INIT
                          18268 TSM:INIT
                          18276 TSM:INIT:TSP OK
                          18278 TSF:SID:OK,ID=100
                          18280 TSM:FPAR
                          18282 Will not sign message for destination 255 as it does not require it
                          18331 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          20340 !TSM:FPAR:NO REPLY
                          20342 TSM:FPAR
                          20344 Will not sign message for destination 255 as it does not require it
                          20393 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          22403 !TSM:FPAR:NO REPLY
                          22405 TSM:FPAR
                          22407 Will not sign message for destination 255 as it does not require it
                          22456 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          24465 !TSM:FPAR:NO REPLY
                          24467 TSM:FPAR
                          24469 Will not sign message for destination 255 as it does not require it
                          24518 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          26527 !TSM:FPAR:FAIL
                          26529 TSM:FAIL:CNT=2
                          26531 TSM:FAIL:PDT
                          36534 TSM:FAIL:RE-INIT
                          36536 TSM:INIT
                          36544 TSM:INIT:TSP OK
                          36546 TSF:SID:OK,ID=100
                          36548 TSM:FPAR
                          36550 Will not sign message for destination 255 as it does not require it
                          36599 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          38610 !TSM:FPAR:NO REPLY
                          38612 TSM:FPAR
                          38615 Will not sign message for destination 255 as it does not require it
                          38664 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          40673 !TSM:FPAR:NO REPLY
                          40675 TSM:FPAR
                          40677 Will not sign message for destination 255 as it does not require it
                          40726 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          42735 !TSM:FPAR:NO REPLY
                          42737 TSM:FPAR
                          42739 Will not sign message for destination 255 as it does not require it
                          42788 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          44800 !TSM:FPAR:FAIL
                          44802 TSM:FAIL:CNT=3
                          44804 TSM:FAIL:PDT
                          54808 TSM:FAIL:RE-INIT
                          54810 TSM:INIT
                          54818 TSM:INIT:TSP OK
                          54820 TSF:SID:OK,ID=100
                          54822 TSM:FPAR
                          54824 Will not sign message for destination 255 as it does not require it
                          54874 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          56883 !TSM:FPAR:NO REPLY
                          56885 TSM:FPAR
                          56887 Will not sign message for destination 255 as it does not require it
                          56936 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          please help me once again
                          Thank you
                          AnticimexA 3 Replies Last reply
                          • M meddie
                            #include <stdint.h>
                            4 TSM:INIT
                            4 TSF:WUR:MS=0
                            12 TSM:INIT:TSP OK
                            16 TSM:FPAR
                            2078 TSM:FPAR
                            4141 TSM:FPAR
                            6201 TSM:FPAR
                            8259 !TSM:FPAR:FAIL
                            8261 TSM:FAIL:CNT=1
                            8263 TSM:FAIL:PDT
                            18268 TSM:INIT
                            18280 TSM:FPAR
                            20342 TSM:FPAR
                            22405 TSM:FPAR
                            24467 TSM:FPAR
                            26531 TSM:FAIL:PDT
                            36536 TSM:INIT
                            36548 TSM:FPAR
                            38612 TSM:FPAR
                            40675 TSM:FPAR
                            42737 TSM:FPAR
                            44804 TSM:FAIL:PDT
                            54810 TSM:INIT
                            54822 TSM:FPAR
                            56885 TSM:FPAR
                            Thank you
                            AnticimexA
                            AnticimexA
                            Anticimex
                            #298
                            @meddie if you want your node to sign messages to the gateway you have to tell the gateway to require it. The log says that it does not require it and it is clear from your gateway sketch that you have disabled the requirement.
                            Is that your problem?
                            EDIT: I see that the messages are broadcasts, those will never be signed. So the "will not sign messages" are perfectly normal no matter how you configure your gateway in this case.
                            The problem, at least based on the node log is that your node cannot find a parent to communicate with for some reason.
                            • M meddie
                              #include <stdint.h>
                              4 TSM:INIT
                              4 TSF:WUR:MS=0
                              12 TSM:INIT:TSP OK
                              16 TSM:FPAR
                              2078 TSM:FPAR
                              4141 TSM:FPAR
                              6201 TSM:FPAR
                              8259 !TSM:FPAR:FAIL
                              8261 TSM:FAIL:CNT=1
                              8263 TSM:FAIL:PDT
                              18268 TSM:INIT
                              18280 TSM:FPAR
                              20342 TSM:FPAR
                              22405 TSM:FPAR
                              24467 TSM:FPAR
                              26531 TSM:FAIL:PDT
                              36536 TSM:INIT
                              36548 TSM:FPAR
                              38612 TSM:FPAR
                              40675 TSM:FPAR
                              42737 TSM:FPAR
                              44804 TSM:FAIL:PDT
                              54810 TSM:INIT
                              54822 TSM:FPAR
                              56885 TSM:FPAR
                              Thank you
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @meddie for parsing the log file you can use this tool
                              • M meddie
                                #include <stdint.h>
                                4 TSM:INIT
                                4 TSF:WUR:MS=0
                                12 TSM:INIT:TSP OK
                                16 TSM:FPAR
                                2078 TSM:FPAR
                                4141 TSM:FPAR
                                6201 TSM:FPAR
                                8259 !TSM:FPAR:FAIL
                                8261 TSM:FAIL:CNT=1
                                8263 TSM:FAIL:PDT
                                18268 TSM:INIT
                                18280 TSM:FPAR
                                20342 TSM:FPAR
                                22405 TSM:FPAR
                                24467 TSM:FPAR
                                26531 TSM:FAIL:PDT
                                36536 TSM:INIT
                                36548 TSM:FPAR
                                38612 TSM:FPAR
                                40675 TSM:FPAR
                                42737 TSM:FPAR
                                44804 TSM:FAIL:PDT
                                54810 TSM:INIT
                                54822 TSM:FPAR
                                56885 TSM:FPAR
                                Thank you
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @meddie I also see that you fail to find parent. Have you verified that you had working node-gateway communication before you enabled signing?
                                  meddie
                                  @Anticimex
                                  Hi, i have just uploaded the GatewayW5100 Sketch to the Gateway and the HumidtyTemp Sketch to the Node and it works fine, but without signing and encryption.
                                  • M meddie
                                    @Anticimex
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @meddie You had encryption enabled when it failed? That could explain the failure of the broadcast if you did not have a matching setting between the nodes/gateway.
                                      meddie
                                      @Anticimex
                                      yes the encryption was enabled. Should i upload the personalized sketch again with my keys?
                                      • M meddie
                                        @Anticimex
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @meddie You can just run an unmodified personalizer to have it read the EEPROM contents. That way you can verify that all devices share the exact same AES key. Assuming a mismatch in the AES key was the reason for the problem.
                                        But I strongly encourage you to just enable one security feature at a time if you are not sure what you are doing or it will be hard to debug what is going wrong.
                                          meddie
                                          @Anticimex
                                          yes, i try to activate one feature and when it works the next. So i decided to activate the encryption and then when it works then i try to activate the signing. But first i would to check the keys like you said and when i now upload the securitypersonalization sketch unmodified i dont get any output on the serial monitor.
                                          :disappointed:
