  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.3k Views 30 Watching
  • M meddie
    @Anticimex said in 💬 Sensebender Gateway:
    @meddie Sorry, missed that post.
    You have SKIP_KEY_STORAGE defined so no keys will be stored. This is the default and intentional, to avoid people just executing the sketch and accidentally overwrite existing keys.
    Furthermore, you have selected to personalize a ATSHA device, and have it generate the keys. That means that you have to define LOCK_CONFIGURATION or the ATSHA random number generator will not work.
    @Anticimex
    sorry i have one more question, because i didnt fully understand this. In the gettings started how to you wrote:
    Pick a “master” device with serial debug port.
    Set the following sketch configuration of the personalizer:
    Enable SKIP_KEY_STORAGE
    Execute the sketch on the “master” device to obtain a randomized key. Save this key to a secure location and keep it confidential so that you can retrieve it if you need to personalize more devices later on.
    Now reconfigure the sketch with these settings:
    Disable SKIP_KEY_STORAGE
    Put the saved key in the user_key_data variable.
    Now execute the sketch on all devices you want to personalize with this secret key.
    on the first run i have to enable SKIP_KEY_STORAGE so i removed the comments.
    But here in forum you write i have to disable this. After i has disabled it wroked fine for me.
    But now i have to run the sketch on my node, and i think i have to disable the SKIP function too, because i need that the keys will be stored in the node.
    So if i am right, the on both runs the SKIP function has to be commented out? Or i am wrong?
    Thank you.
    AnticimexA
    AnticimexA
    Anticimex
    #293
    @meddie If your read the text carefully it says:
    So in other words; you first use the settings described in the first setting, execute that once. Follow the instructions carefully. Write down the key you got. Then you reconfigure the sketch and execute it on all devices you want to personalize. That is, you execute it twice on the first device.
    I wrote that you need to undefine SKIP_KEY_STORAGE if you want to store a key. But the first set of instructions in the documentation is not saying that you are supposed to store a key. It says "Execute the sketch on the “master” device to obtain a randomized key."
    So the documentation is correct, and describe a flow where you personalize nodes and gateways with the minimum amount of changes needed. First you generate a key, and this step can actually be skipped altogether if you just make your own random key or password to use for HMAC/AES.
    Then you reconfigure the personalizer to use your generated (or selected) key and write it to all your devices.
      meddie
      @Anticimex
      but as i runned the sketch with SKIP_KEY_STORAGE defined, so no keys were generated.
      i did not like to say that the documentation is incorrect, i like your documentation and your work very well! i just didnt understand it!
      Thank you very much!
      Greets Eddie
      AnticimexA 1 Reply Last reply
      • M meddie
        @Anticimex
        Greets Eddie
        AnticimexA
        AnticimexA
        Anticimex
        @meddie are you sure you ran with the exact settings described for generating the keys? The SKIP_KEY_STORAGE flag does not prevent the keys from being generated. They are still printed in the serial log. It prevents the keys from being stored to the atsha204a device.
          meddie
          i fear to write again, but my fail story goes on :-(
          i have uploaded on the gateway this sketch:
          * Version 1.0 - Henrik EKblad
          * This GW code is designed for Sensebender GateWay / (Arduino Zero variant)
          * - Inclusion button should be connected to SW2
          * LEDs on board (default assignments):
          * - Orange: USB RX/TX - Blink when receiving / transmitting on USB CDC device
          * - Yellow: RX  - Blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
          * - Green : TX  - Blink fast on radio message transmitted. In inclusion mode will blink slowly
          * - Red   : ERR - Fast blink on error during transmission error or recieve crc error
          * - Blue  : free - (use with LED_BLUE macro)
          #include <stdint.h>
          #include <pins_arduino.h>
          #define SKETCH_VERSION "0.2"
          #define MY_SIGNING_ATSHA204
          #define MY_GATEWAY_W5100
          //#define MY_W5100_SPI_EN 4
          // radio on the same spi bus.
          #define MY_SOFTSPI
          #ifndef MY_RF24_CE_PIN
          #define MY_RF24_CE_PIN 5
          #ifndef MY_RF24_CS_PIN
          #define MY_RF24_CS_PIN 6
          // Enable to UDP
          //#define MY_USE_UDP
          #define MY_IP_ADDRESS 10,0,0,253   // If this is disabled, DHCP is used to retrieve address
          #define MY_PORT 5003
          // Enable inclusion mode
          // Set blinking period
          // Flash leds on rx/tx/err
          #if defined(MY_USE_UDP)
          #include <EthernetUdp.h>
          #include <Ethernet.h>
          #include <SD.h>
          //#include <drivers/ATSHA204/ATSHA204.cpp>
          Sd2Card card;
          #define EEPROM_VERIFICATION_ADDRESS 0x01
          static uint8_t num_of_leds = 5;
          static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
          void preHwInit()
            pinMode(MY_SWC1, INPUT_PULLUP);
            pinMode(MY_SWC2, INPUT_PULLUP);
            if (digitalRead(MY_SWC1) && digitalRead(MY_SWC2)) {
              return;
            uint8_t tests = 0;
            for (int i=0; i< num_of_leds; i++) {
              pinMode(leds[i], OUTPUT);
            uint8_t led_state = 0;
            if (digitalRead(MY_SWC1)) {
              while (!Serial) {
                digitalWrite(LED_BLUE, led_state);
                led_state ^= 0x01;
                delay(500);
              } // Wait for USB to be connected, before spewing out data.
            digitalWrite(LED_BLUE, LOW);
            if (Serial) {
              Serial.println("Sensebender GateWay test routine");
              Serial.print("Mysensors core version : ");
              Serial.println(MYSENSORS_LIBRARY_VERSION);
              Serial.print("GateWay sketch version : ");
              Serial.println("----------------------------------");
              Serial.println();
            if (testSha204()) {
              digitalWrite(LED_GREEN, HIGH);
              tests++;
            if (testSDCard()) {
              digitalWrite(LED_YELLOW, HIGH);
              tests++;
            if (testEEProm()) {
              digitalWrite(LED_ORANGE, HIGH);
              tests++;
            if (testAnalog()) {
              digitalWrite(LED_BLUE, HIGH);
              tests++;
            if (tests == 4) {
              while(1) {
                for (int i=0; i<num_of_leds; i++) {
                  digitalWrite(leds[i], HIGH);
                  delay(200);
                  digitalWrite(leds[i], LOW);
              while (1) {
                digitalWrite(LED_RED, HIGH);
                delay(200);
                digitalWrite(LED_RED, LOW);
                delay(200);
          bool testSha204()
            uint8_t ret_code;
            if (Serial) {
              Serial.print("- > SHA204 ");
            atsha204_init(MY_SIGNING_ATSHA204_PIN);
            ret_code = atsha204_wakeup(rx_buffer);
            if (ret_code == SHA204_SUCCESS) {
              ret_code = atsha204_getSerialNumber(rx_buffer);
                if (Serial) {
                  Serial.println(F("Failed to obtain device serial number. Response: "));
                if (Serial) {
                  Serial.print(F("Ok (serial : "));
                  for (int i=0; i<9; i++) {
                    if (rx_buffer[i] < 0x10) {
                    Serial.print(rx_buffer[i], HEX);
                  Serial.println(")");
                return true;
              if (Serial) {
                Serial.println(F("Failed to wakeup SHA204"));
            return false;
          bool testSDCard()
            if (Serial) {
              Serial.print("- > SD CARD ");
            if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
              if (Serial) {
                Serial.println("SD CARD did not initialize!");
              if (Serial) {
                Serial.print("SD Card initialized correct! - ");
                Serial.print("type detected : ");
                switch(card.type()) {
                case SD_CARD_TYPE_SD1:
                  Serial.println("SD1");
                case SD_CARD_TYPE_SD2:
                  Serial.println("SD2");
                case SD_CARD_TYPE_SDHC:
                  Serial.println("SDHC");
                default:
                  Serial.println("Unknown");
              return true;
            return false;
          bool testEEProm()
            uint8_t eeprom_d1, eeprom_d2;
            SerialUSB.print(" -> EEPROM ");
            Wire.begin();
            eeprom_d1 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
            delay(500);
            eeprom_d1 = ~eeprom_d1; // invert the bits
            i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
            delay(500);
            eeprom_d2 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
            if (eeprom_d1 == eeprom_d2) {
              SerialUSB.println("PASSED");
              i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, ~eeprom_d1);
              return true;
            SerialUSB.println("FAILED!");
            return false;
          bool testAnalog()
            int bat_detect = analogRead(MY_BAT_DETECT);
            Serial.print("-> analog : ");
            Serial.print(bat_detect);
            if (bat_detect < 400 || bat_detect > 650) {
              Serial.println(" Failed");
              return false;
            Serial.println(" Passed");
            return true;
            meddie
            and on the node this sketch:
            #include <stdint.h>
            //#define MY_SIGNING_SOFT
            But the node does not connect and i get this on the serial monitor:
            0 MCO:BGN:INIT NODE,CP=RNNNAA-,VER=2.1.1
            4 TSM:INIT
            4 TSF:WUR:MS=0
            12 TSM:INIT:TSP OK
            14 TSF:SID:OK,ID=100
            16 TSM:FPAR
            18 Will not sign message for destination 255 as it does not require it
            67 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2076 !TSM:FPAR:NO REPLY
            2078 TSM:FPAR
            2080 Will not sign message for destination 255 as it does not require it
            2127 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            4139 !TSM:FPAR:NO REPLY
            4141 TSM:FPAR
            4143 Will not sign message for destination 255 as it does not require it
            4190 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            6199 !TSM:FPAR:NO REPLY
            6201 TSM:FPAR
            6203 Will not sign message for destination 255 as it does not require it
            6250 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            8259 !TSM:FPAR:FAIL
            8261 TSM:FAIL:CNT=1
            8263 TSM:FAIL:PDT
            18266 TSM:FAIL:RE-INIT
            18268 TSM:INIT
            18276 TSM:INIT:TSP OK
            18278 TSF:SID:OK,ID=100
            18280 TSM:FPAR
            18282 Will not sign message for destination 255 as it does not require it
            18331 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            20340 !TSM:FPAR:NO REPLY
            20342 TSM:FPAR
            20344 Will not sign message for destination 255 as it does not require it
            20393 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            22403 !TSM:FPAR:NO REPLY
            22405 TSM:FPAR
            22407 Will not sign message for destination 255 as it does not require it
            22456 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            24465 !TSM:FPAR:NO REPLY
            24467 TSM:FPAR
            24469 Will not sign message for destination 255 as it does not require it
            24518 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            26527 !TSM:FPAR:FAIL
            26529 TSM:FAIL:CNT=2
            26531 TSM:FAIL:PDT
            36534 TSM:FAIL:RE-INIT
            36536 TSM:INIT
            36544 TSM:INIT:TSP OK
            36546 TSF:SID:OK,ID=100
            36548 TSM:FPAR
            36550 Will not sign message for destination 255 as it does not require it
            36599 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            38610 !TSM:FPAR:NO REPLY
            38612 TSM:FPAR
            38615 Will not sign message for destination 255 as it does not require it
            38664 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            40673 !TSM:FPAR:NO REPLY
            40675 TSM:FPAR
            40677 Will not sign message for destination 255 as it does not require it
            40726 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            42735 !TSM:FPAR:NO REPLY
            42737 TSM:FPAR
            42739 Will not sign message for destination 255 as it does not require it
            42788 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            44800 !TSM:FPAR:FAIL
            44802 TSM:FAIL:CNT=3
            44804 TSM:FAIL:PDT
            54808 TSM:FAIL:RE-INIT
            54810 TSM:INIT
            54818 TSM:INIT:TSP OK
            54820 TSF:SID:OK,ID=100
            54822 TSM:FPAR
            54824 Will not sign message for destination 255 as it does not require it
            54874 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            56883 !TSM:FPAR:NO REPLY
            56885 TSM:FPAR
            56887 Will not sign message for destination 255 as it does not require it
            56936 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            please help me once again
            Thank you
            AnticimexA 3 Replies Last reply
            • M meddie
              #include <stdint.h>
              4 TSM:INIT
              4 TSF:WUR:MS=0
              12 TSM:INIT:TSP OK
              16 TSM:FPAR
              2078 TSM:FPAR
              4141 TSM:FPAR
              6201 TSM:FPAR
              8259 !TSM:FPAR:FAIL
              8261 TSM:FAIL:CNT=1
              8263 TSM:FAIL:PDT
              18268 TSM:INIT
              18280 TSM:FPAR
              20342 TSM:FPAR
              22405 TSM:FPAR
              24467 TSM:FPAR
              26531 TSM:FAIL:PDT
              36536 TSM:INIT
              36548 TSM:FPAR
              38612 TSM:FPAR
              40675 TSM:FPAR
              42737 TSM:FPAR
              44804 TSM:FAIL:PDT
              54810 TSM:INIT
              54822 TSM:FPAR
              56885 TSM:FPAR
              Thank you
              AnticimexA
              AnticimexA
              Anticimex
              #298
              @meddie if you want your node to sign messages to the gateway you have to tell the gateway to require it. The log says that it does not require it and it is clear from your gateway sketch that you have disabled the requirement.
              Is that your problem?
              EDIT: I see that the messages are broadcasts, those will never be signed. So the "will not sign messages" are perfectly normal no matter how you configure your gateway in this case.
              The problem, at least based on the node log is that your node cannot find a parent to communicate with for some reason.
              • M meddie
                #include <stdint.h>
                4 TSM:INIT
                4 TSF:WUR:MS=0
                12 TSM:INIT:TSP OK
                16 TSM:FPAR
                2078 TSM:FPAR
                4141 TSM:FPAR
                6201 TSM:FPAR
                8259 !TSM:FPAR:FAIL
                8261 TSM:FAIL:CNT=1
                8263 TSM:FAIL:PDT
                18268 TSM:INIT
                18280 TSM:FPAR
                20342 TSM:FPAR
                22405 TSM:FPAR
                24467 TSM:FPAR
                26531 TSM:FAIL:PDT
                36536 TSM:INIT
                36548 TSM:FPAR
                38612 TSM:FPAR
                40675 TSM:FPAR
                42737 TSM:FPAR
                44804 TSM:FAIL:PDT
                54810 TSM:INIT
                54822 TSM:FPAR
                56885 TSM:FPAR
                Thank you
                AnticimexA
                AnticimexA
                Anticimex
                @meddie for parsing the log file you can use this tool
                • M meddie
                  #include <stdint.h>
                  4 TSM:INIT
                  4 TSF:WUR:MS=0
                  12 TSM:INIT:TSP OK
                  16 TSM:FPAR
                  2078 TSM:FPAR
                  4141 TSM:FPAR
                  6201 TSM:FPAR
                  8259 !TSM:FPAR:FAIL
                  8261 TSM:FAIL:CNT=1
                  8263 TSM:FAIL:PDT
                  18268 TSM:INIT
                  18280 TSM:FPAR
                  20342 TSM:FPAR
                  22405 TSM:FPAR
                  24467 TSM:FPAR
                  26531 TSM:FAIL:PDT
                  36536 TSM:INIT
                  36548 TSM:FPAR
                  38612 TSM:FPAR
                  40675 TSM:FPAR
                  42737 TSM:FPAR
                  44804 TSM:FAIL:PDT
                  54810 TSM:INIT
                  54822 TSM:FPAR
                  56885 TSM:FPAR
                  Thank you
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @meddie I also see that you fail to find parent. Have you verified that you had working node-gateway communication before you enabled signing?
                    meddie
                    @Anticimex
                    Hi, i have just uploaded the GatewayW5100 Sketch to the Gateway and the HumidtyTemp Sketch to the Node and it works fine, but without signing and encryption.
                    • M meddie
                      @Anticimex
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @meddie You had encryption enabled when it failed? That could explain the failure of the broadcast if you did not have a matching setting between the nodes/gateway.
                      • AnticimexA Anticimex
                        meddie
                        @Anticimex
                        yes the encryption was enabled. Should i upload the personalized sketch again with my keys?
                        • M meddie
                          @Anticimex
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @meddie You can just run an unmodified personalizer to have it read the EEPROM contents. That way you can verify that all devices share the exact same AES key. Assuming a mismatch in the AES key was the reason for the problem.
                          But I strongly encourage you to just enable one security feature at a time if you are not sure what you are doing or it will be hard to debug what is going wrong.
                            meddie
                            @Anticimex
                            yes, i try to activate one feature and when it works the next. So i decided to activate the encryption and then when it works then i try to activate the signing. But first i would to check the keys like you said and when i now upload the securitypersonalization sketch unmodified i dont get any output on the serial monitor.
                            :disappointed:
                            • M meddie
                              @Anticimex
                              :disappointed:
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @meddie Well, you have to make the patch to the baud rate and the changes we discussed earlier. I presume you did something necessary since you got output previously.
                                meddie
                                @Anticimex
                                when i run the personalizer sketch i see in all keys FFFFFF....... What does it mean that no keys are stored?
                                • M meddie
                                  @Anticimex
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @meddie yes, that mean eeprom is in default state. The node has not been properly personalized.
                                    meddie
                                    @Anticimex
                                    ok, i think i know what went wrong! But i dont know how to fix it. On the first run when i tried came the prompt to sens space to lock configuration i did it.
                                    Now when i upload the modified personalization sketch with my keys i get this output on serial monitor:
                                    of course i removed my keys with xx!
                                    Device serial:   {0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX}
                                    xxxxxxxxxxxxxxxxxxxxx
                                    Skipping configuration write and lock (configuration already locked).
                                    Chip configuration:
                                    EEPROM DATA:
                                    AES_KEY       | XXFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                    ATSHA204A DATA:
                                               SN[0:1]           |         SN[2:3]           | XX   XX | XX   XX
                                                              Revnum                         | 00   09   04   00
                                                              SN[4:7]                        | XX   XX   XX   XX
                                        SN[8]    |  Reserved13   | I2CEnable | Reserved15    | EE | 10 | 00 | 00
                                      I2CAddress |  TempOffset   |  OTPmode  | SelectorMode  | C8 | 00 | 55 | 00
                                             SlotConfig00        |       SlotConfig01        | 8F   80 | 80   A1
                                             SlotConfig02        |       SlotConfig03        | 82   E0 | A3   60
                                             SlotConfig04        |       SlotConfig05        | 94   40 | A0   85
                                             SlotConfig06        |       SlotConfig07        | 86   40 | 87   07
                                             SlotConfig08        |       SlotConfig09        | 0F   00 | 89   F2
                                             SlotConfig0A        |       SlotConfig0B        | 8A   7A | 0B   8B
                                             SlotConfig0C        |       SlotConfig0D        | 0C   4C | DD   4D
                                             SlotConfig0E        |       SlotConfig0F        | C2   42 | AF   8F
                                      UseFlag00  | UpdateCount00 | UseFlag01 | UpdateCount01 | FF | 00 | FF | 00
                                      UseFlag02  | UpdateCount02 | UseFlag03 | UpdateCount03 | FF | 00 | FF | 00
                                      UseFlag04  | UpdateCount04 | UseFlag05 | UpdateCount05 | FF | 00 | FF | 00
                                      UseFlag06  | UpdateCount06 | UseFlag07 | UpdateCount07 | FF | 00 | FF | 00
                                                          LastKeyUse[0:3]                    | FF   FF   FF   FF
                                                          LastKeyUse[4:7]                    | FF   FF   FF   FF
                                                          LastKeyUse[8:B]                    | FF   FF   FF   FF
                                                          LastKeyUse[C:F]                    | FF   FF   FF   FF
                                      UserExtra  |    Selector   | LockValue |  LockConfig   | 00 | 00 | 55 | 00
                                    Using this user supplied HMAC key:
                                    #define MY_HMAC_KEY 0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,\
                                    Writing key to slot 0...
                                    Data not locked. Define LOCK_DATA to lock for real.
                                    Configuration is LOCKED
                                    Data is UNLOCKED
                                    i thin this is the reason:
                                    and what i find very interestin that the first two signs of AES Key are correct the rest of them are FFFFF
                                    is it possible to unlock the configuration or did i kill the chip?
                                    Thank you
                                    Greets Eddie
                                    • M meddie
                                      @Anticimex
                                      Chip configuration:
                                      EEPROM DATA:
                                      ATSHA204A DATA:
                                      Data is UNLOCKED
                                      Thank you
                                      Greets Eddie
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @meddie you cannot undo a lock, and you have to lock the chip in order to use it. And it is not an error that it reports chip is already locked since you have locked it already.
                                      Furthermore, AES key and eeprom has nothing to do with the atsha204a chip so the lock state of the chip is irrelevant.
                                      Now, why your AES key is only partially stored, I am not sure. But my bet would be that you have an error in the line where you define it in the sketch. A space or something like that.
                                      Finally, as long as you don't lock the data zone, and you don't tamper with the configuration bits for the atsha204a device, you cannot destroy the chip. You can always replace the hmac key, which is the only thing you program to the atsha using the personalizer. Except for the chip configuration bits, and those the sketch handles for you and once config is locked they are fixed in place.
                                      M 2 Replies Last reply
                                        meddie
                                        @Anticimex
                                        i checked the sketch already few times but i dont see an error.
                                        here is the code i have only change my key with XX
                                        #include "sha204_library.h"
                                        #define MY_CORE_ONLY
                                        #if DOXYGEN
                                        #define LOCK_CONFIGURATION
                                        #define LOCK_DATA
                                        #define SKIP_KEY_STORAGE
                                        #define USER_KEY
                                        #define SKIP_UART_CONFIRMATION
                                        #define USE_SOFT_SIGNING
                                        #define STORE_SOFT_KEY
                                        #define USER_SOFT_KEY
                                        #define STORE_SOFT_SERIAL
                                        #define USER_SOFT_SERIAL
                                        #define STORE_AES_KEY
                                        #define USER_AES_KEY
                                        //#define LOCK_DATA
                                        //#define SKIP_KEY_STORAGE
                                        #define USER_KEY
                                        //#define USE_SOFT_SIGNING
                                        //#define STORE_SOFT_KEY
                                        //#define USER_SOFT_KEY
                                        //#define STORE_SOFT_SERIAL
                                        //#define USER_SOFT_SERIAL
                                        #ifdef USER_KEY
                                        #define MY_HMAC_KEY 0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX
                                        #ifdef USER_SOFT_KEY
                                        #ifdef USER_SOFT_SERIAL
                                        #ifdef USER_AES_KEY
                                        #define MY_AES_KEY 0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX
                                        #ifndef USE_SOFT_SIGNING
                                        void halt()
                                        	while(1);
                                        	uint16_t crc = 0;
                                        	uint8_t config_word[4];
                                        	uint8_t ret_code;
                                        	bool do_write;
                                        		do_write = true;
                                        		if (i == 20) {
                                        			config_word[0] = 0x8F;
                                        			config_word[1] = 0x80;
                                        			config_word[2] = 0x80;
                                        			config_word[3] = 0xA1;
                                        		} else if (i == 24) {
                                        			config_word[0] = 0x82;
                                        			config_word[1] = 0xE0;
                                        			config_word[2] = 0xA3;
                                        			config_word[3] = 0x60;
                                        		} else if (i == 28) {
                                        			config_word[0] = 0x94;
                                        			config_word[1] = 0x40;
                                        			config_word[2] = 0xA0;
                                        			config_word[3] = 0x85;
                                        		} else if (i == 32) {
                                        			config_word[0] = 0x86;
                                        			config_word[2] = 0x87;
                                        			config_word[3] = 0x07;
                                        		} else if (i == 36) {
                                        			config_word[0] = 0x0F;
                                        			config_word[1] = 0x00;
                                        			config_word[2] = 0x89;
                                        			config_word[3] = 0xF2;
                                        		} else if (i == 40) {
                                        			config_word[0] = 0x8A;
                                        			config_word[1] = 0x7A;
                                        			config_word[2] = 0x0B;
                                        			config_word[3] = 0x8B;
                                        		} else if (i == 44) {
                                        			config_word[0] = 0x0C;
                                        			config_word[1] = 0x4C;
                                        			config_word[2] = 0xDD;
                                        			config_word[3] = 0x4D;
                                        		} else if (i == 48) {
                                        			config_word[0] = 0xC2;
                                        			config_word[1] = 0x42;
                                        			config_word[2] = 0xAF;
                                        			config_word[3] = 0x8F;
                                        			config_word[0] = 0xFF;
                                        			config_word[2] = 0xFF;
                                        			config_word[3] = 0x00;
                                        			config_word[1] = 0xFF;
                                        			config_word[3] = 0xFF;
                                        				halt();
                                        			do_write = false;
                                        		// Write config word
                                        		if (do_write) {
                                        				Serial.print(i);
                                        				halt();
                                        	return crc;
                                        void write_key(uint8_t* key)
                                        	uint8_t ret_code;
                                        	// Write key to slot 0
                                        		halt();
                                        void dump_configuration()
                                        	uint8_t buffer[32];
                                        	for (int j=0; j<32; j++) {
                                        		if (buffer[j] < 0x10) {
                                        		Serial.print(buffer[j], HEX);
                                        	Serial.println();
                                        	for (int j=0; j<9; j++) {
                                        	Serial.println();
                                        	for (int j=0; j<16; j++) {
                                        	Serial.println();
                                        	uint8_t ret_code;
                                        			halt();
                                        		if (i == 0x00) {
                                        			for (int j=0; j<4; j++) {
                                        				if (j == 1) {
                                        					Serial.print(F(" | "));
                                        					Serial.print(F("   "));
                                        			Serial.println();
                                        		} else if (i == 0x04) {
                                        			Serial.println();
                                        		} else if (i == 0x08) {
                                        			Serial.println();
                                        		} else if (i == 0x0C) {
                                        				if (j < 3) {
                                        			Serial.println();
                                        		} else if (i == 0x10) {
                                        				if (j < 3) {
                                        			Serial.println();
                                        		} else if (i == 0x14) {
                                        				if (j == 1) {
                                        			Serial.println();
                                        		} else if (i == 0x18) {
                                        				if (j == 1) {
                                        			Serial.println();
                                        		} else if (i == 0x1C) {
                                        				if (j == 1) {
                                        			Serial.println();
                                        		} else if (i == 0x20) {
                                        				if (j == 1) {
                                        			Serial.println();
                                        		} else if (i == 0x24) {
                                        				if (j == 1) {
                                        			Serial.println();
                                        		} else if (i == 0x28) {
                                        				if (j == 1) {
                                        			Serial.println();
                                        		} else if (i == 0x2C) {
                                        				if (j == 1) {
                                        			Serial.println();
                                        		} else if (i == 0x30) {
                                        				if (j == 1) {
                                        			Serial.println();
                                        		} else if (i == 0x34) {
                                        				if (j < 3) {
                                        			Serial.println();
                                        		} else if (i == 0x38) {
                                        				if (j < 3) {
                                        			Serial.println();
                                        		} else if (i == 0x3C) {
                                        				if (j < 3) {
                                        			Serial.println();
                                        		} else if (i == 0x40) {
                                        				if (j < 3) {
                                        			Serial.println();
                                        		} else if (i == 0x44) {
                                        			Serial.println();
                                        		} else if (i == 0x48) {
                                        			Serial.println();
                                        		} else if (i == 0x4C) {
                                        			Serial.println();
                                        		} else if (i == 0x50) {
                                        			Serial.println();
                                        		} else if (i == 0x54) {
                                        				if (j < 3) {
                                        			Serial.println();
                                        	uint8_t ret_code;
                                        	uint8_t lockConfig = 0;
                                        	uint8_t lockValue = 0;
                                        	uint16_t crc;
                                        	(void)crc;
                                        	// initialize pseudo-RNG
                                        	uint8_t key[32];
                                        	(void)key;
                                          Serial.begin(9600);
                                        	hwInit();
                                        		halt();
                                        		halt();
                                        #ifdef STORE_SOFT_KEY
                                        #ifdef USE_SOFT_SIGNING
                                        		halt();
                                        	if (lockConfig == 0x00) {
                                        #endif // not USER_SOFT_KEY
                                        	for (int i=0; i<32; i++) {
                                        		Serial.print("0x");
                                        		if (key[i] < 0x10) {
                                        		Serial.print(key[i], HEX);
                                        		if (i < 31) {
                                        			Serial.print(',');
                                        	Serial.println();
                                        #endif // STORE_SOFT_KEY
                                        #ifdef STORE_SOFT_SERIAL
                                        	for (int i = 0; i < 9; i++) {
                                        		halt();
                                        		Serial.print("0x");
                                        		if (i < 8) {
                                        			Serial.print(',');
                                        	Serial.println();
                                        #endif // STORE_SOFT_SERIAL
                                        #ifdef STORE_AES_KEY
                                        #ifdef USER_AES_KEY
                                        		halt();
                                        #endif // not USER_AES_KEY
                                        	Serial.print("#define MY_AES_KEY ");
                                        	for (int i=0; i<16; i++) {
                                        		Serial.print("0x");
                                        		if (i < 15) {
                                        			Serial.print(',');
                                        	Serial.println();
                                        #endif // STORE_AES_KEY
                                        	Serial.println(F("EEPROM configuration:"));
                                        	dump_configuration();
                                        	// Output device revision on console
                                        	ret_code = sha204.sha204m_dev_rev(tx_buffer, rx_buffer);
                                        		Serial.print(F("Failed to determine device revision. Response: "));
                                        		halt();
                                        		Serial.print(F("Device revision: "));
                                        		for (int i=0; i<4; i++) {
                                        			if (rx_buffer[SHA204_BUFFER_POS_DATA+i] < 0x10) {
                                        			Serial.print(rx_buffer[SHA204_BUFFER_POS_DATA+i], HEX);
                                        		Serial.println();
                                        	// Output serial number on console
                                        	ret_code = sha204.getSerialNumber(rx_buffer);
                                        		Serial.print(F("Failed to obtain device serial number. Response: "));
                                        		halt();
                                        		Serial.print(F("Device serial:   "));
                                        		Serial.print('{');
                                        			Serial.print(F("0x"));
                                        			if (i < 8) {
                                        				Serial.print(',');
                                        		Serial.print('}');
                                        		Serial.println();
                                        		Serial.println();
                                        	if (lockConfig != 0x00) {
                                        		// Write config and get CRC for the updated config
                                        		crc = write_config_and_get_crc();
                                        		// List current configuration before attempting to lock
                                        		Serial.println(F("Chip configuration:"));
                                        #ifdef LOCK_CONFIGURATION
                                        		// Purge serial input buffer
                                        #ifndef SKIP_UART_CONFIRMATION
                                        		while (Serial.available()) {
                                        			Serial.read();
                                        		Serial.println(F("Send SPACE character now to lock the configuration..."));
                                        		while (Serial.available() == 0);
                                        		if (Serial.read() == ' ')
                                        #endif //not SKIP_UART_CONFIRMATION
                                        			Serial.println(F("Locking configuration..."));
                                        			// Correct sequence, resync chip
                                        			ret_code = sha204.sha204c_resync(SHA204_RSP_SIZE_MAX, rx_buffer);
                                        			if (ret_code != SHA204_SUCCESS && ret_code != SHA204_RESYNC_WITH_WAKEUP) {
                                        				Serial.print(F("Resync failed. Response: "));
                                        				halt();
                                        			// Lock configuration zone
                                        			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_CONFIG,
        crc, 0, NULL, 0, NULL, 0, NULL,
        LOCK_COUNT, tx_buffer, LOCK_RSP_SIZE, rx_buffer);
                                        				Serial.print(F("Configuration lock failed. Response: "));
                                        				halt();
                                        				Serial.println(F("Configuration locked."));
                                        				// Update lock flags after locking
                                        					halt();
                                        		else {
                                        			Serial.println(F("Unexpected answer. Skipping lock."));
                                        #else //LOCK_CONFIGURATION
                                        		Serial.println(F("Configuration not locked. Define LOCK_CONFIGURATION to lock for real."));
                                        		Serial.println(F("Skipping configuration write and lock (configuration already locked)."));
                                        #ifdef SKIP_KEY_STORAGE
                                        	Serial.println(F("Disable SKIP_KEY_STORAGE to store key."));
                                        #ifdef USER_KEY
                                        	memcpy(key, user_key_data, 32);
                                        	Serial.println(F("Using this user supplied HMAC key:"));
                                        		halt();
                                        		Serial.println(F("Take note of this key, it will never be the shown again:"));
                                        	Serial.print("#define MY_HMAC_KEY ");
                                        		Serial.print("0x");
                                        		if (i < 31) {
                                        			Serial.print(',');
                                        		if (i+1 == 16) {
                                        			Serial.print("\\\n                    ");
                                        	Serial.println();
                                        	// It will not be possible to write the key if the configuration zone is unlocked
                                        		// Write the key to the appropriate slot in the data zone
                                        		Serial.println(F("Writing key to slot 0..."));
                                        		write_key(key);
                                        		Serial.println(F("Skipping key storage (configuration not locked)."));
                                        		Serial.println(F("The configuration must be locked to be able to write a key."));
                                        	if (lockValue != 0x00) {
                                        #ifdef LOCK_DATA
                                        			Serial.read();
                                        		Serial.println(F("Send SPACE character to lock data..."));
                                        				halt();
                                        			// If configuration is unlocked, key is not updated. Locking data in this case will cause
                                        			// slot 0 to contain an unknown (or factory default) key, and this is in practically any
                                        			// usecase not the desired behaviour, so ask for additional confirmation in this case.
                                        					Serial.read();
                                        				Serial.println(F("*** ATTENTION ***"));
                                        				Serial.println(F("Configuration is not locked. Are you ABSULOUTELY SURE you want to lock data?"));
                                        				Serial.println(F("Locking data at this stage will cause slot 0 to contain a factory default key"));
                                        				Serial.println(
                                        				    F("which cannot be change after locking is done. This is in practically any usecase"));
                                        				Serial.println(F("NOT the desired behavour. Send SPACE character now to lock data anyway..."));
                                        				if (Serial.read() != ' ') {
                                        					halt();
                                        			// Lock data zone
                                        			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_DATA | LOCK_ZONE_NO_CRC,
        0x0000, 0, NULL, 0, NULL, 0, NULL,
                                        				Serial.print(F("Data lock failed. Response: "));
                                        				halt();
                                        				Serial.println(F("Data locked."));
                                        					halt();
                                        		else {
                                        #else //LOCK_DATA
                                        		Serial.println(F("Data not locked. Define LOCK_DATA to lock for real."));
                                        		Serial.println(F("Skipping OTP/data zone lock (zone already locked)."));
                                        	Serial.println(F("--------------------------------"));
                                        	Serial.println(F("Personalization is now complete."));
                                        	Serial.print(F("Configuration is "));
                                        		Serial.println("LOCKED");
                                        		Serial.println("UNLOCKED");
                                        	Serial.print(F("Data is "));
                                        	if (lockValue == 0x00) {
                                        /** @brief Sketch execution code */
                                          meddie
                                          @Anticimex
                                          the interesting thing is when i upload the same sketch to the sensebender micro it works the AES Key will be stored correctly.
                                          But on the Sensebender Gateway only the first two digits
