  3. Multi mysensor sketch help
9 Posts 3 Posters 3.2k Views 4 Watching
  • R
    R
    rob
    Hello i have a question and need some help since im new to arduino . ive tried to build my first multi sensor sketch and it works only i need to add one more (smoke sensor) and i need someone to look at it and tell me how to clean it up better. im a quick learner and need some pointers.
    The sketch is working i get all the readings in my openhab2 server running on a pi the ethernet gateway is runnning on the mysensors binding. we are rebuilding our entire home and making it a selfsuccient smart home. were 1 year into the build and getting there
    here is the sketch for my wifes greenhous i got a dht sensor (had troubles with the 2320sensors) a soil sensor with a 2 relay module and a door/window button. they talk over a nrf network wich runs ok allready got a bunch of sensor nodes up and running.
    im trying to use the millis count to keep it al working the help i need is cleaning the sketch up. can someone please give me pointers on what i can do to clean it up or where i may have made misstakes.
    Regards and sorry for the bad english
    Robert
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    //#define MY_RS485
    #include <math.h>       // Conversion equation from resistance to % tbv soil
    #define MY_NODE_ID 5
    // Setting up
    #define NUM_READS 10    // Number of sensor reads for filtering
    #define CHILD_ID_SOIL 7
    #define CHILD_ID_HUM 8
    #define CHILD_ID_TEMP 9
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    #define CHILD_ID_BUTTON 6
    #define BUTTON_PIN  5  // Arduino Digital I/O pin for button/reed switch
    // unsigned long   var1_usl;     //uptime in ms
    Bounce debouncer = Bounce();
    int oldValue=-1;
    MyMessage msgBut(CHILD_ID_BUTTON, V_TRIPPED);
    MyMessage msgSoil(CHILD_ID_SOIL, V_LEVEL);
    long buffer[NUM_READS];
    int index;
    /// @brief Structure to be used in percentage and resistance values matrix to be filtered (have to be in pairs)
    typedef struct {
        int moisture; //!< Moisture
        long resistance; //!< Resistance
    } values;
    const long knownResistor = 4700;  // Constant value of known resistor in Ohms
    int supplyVoltage;                // Measured supply voltage
    int sensorVoltage;                // Measured sensor voltage
    values valueOf[NUM_READS];        // Calculated moisture percentages and resistances to be sorted and filtered
    int i;                            // Simple index variable
    #define DHT_DATA_PIN 8
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 20000;
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    // Timings
    unsigned long temperature_time;
    unsigned long soil_time;
      sendSketchInfo("Greenhouse", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_SOIL, S_MOISTURE);
      present(CHILD_ID_BUTTON, S_DOOR);
            present(sensor, S_BINARY);
    // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
    //relay ohohwerkieofni
            pinMode(pin, OUTPUT);
      //soil
      // initialize the digital pins as an output
        // Pin 6,7 is for sensor 1
        // initialize the digital pin as an output.
        // Pin 6 is sense resistor voltage supply 1
        pinMode(6, OUTPUT);
        // Pin 7 is sense resistor voltage supply 2
        pinMode(7, OUTPUT);
      //dht
      if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod())
      //initialize times
      temperature_time = millis();
      soil_time = millis();
        unsigned long time_passed = 0;
     //BUTTON
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msgBut.set(value==HIGH ? 1 : 0));
         oldValue = value;
    // Temp/Hum sensor
      // dht.readSensor(true);
    time_passed = millis() - temperature_time;
    if (time_passed < 0)
    if (time_passed > 6000)
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
    // sleep(UPDATE_INTERVAL);
    //soil
    time_passed = millis() - soil_time;
     measure(6,7,1);
        Serial.print ("\t");
        Serial.println (average());
        long read1 = average();
        measure(7,6,0);
        long read2= average();
        long sensor1 = (read1 + read2)/2;
        Serial.print ("resistance bias =" );
        Serial.println (read1-read2);
        Serial.print ("sensor bias compensated value = ");
        Serial.println (sensor1);
        Serial.println ();
        //send back the values
        send(msgSoil.set((long int)ceil(sensor1)));
        // delay until next measurement (msec)
    //    sleep(SLEEP_TIME);
    void measure (int phase_b, int phase_a, int analog_input)
        // read sensor, filter, and calculate resistance value
        // Noise filter: median filter
        for (i=0; i<NUM_READS; i++) {
            // Read 1 pair of voltage values
            digitalWrite(phase_a, HIGH);                 // set the voltage supply on
            delayMicroseconds(25);
            supplyVoltage = analogRead(analog_input);   // read the supply voltage
            digitalWrite(phase_a, LOW);                  // set the voltage supply off
            delay(1);
            digitalWrite(phase_b, HIGH);                 // set the voltage supply on
            sensorVoltage = analogRead(analog_input);   // read the sensor voltage
            digitalWrite(phase_b, LOW);                  // set the voltage supply off
            // Calculate resistance
            // the 0.5 add-term is used to round to the nearest integer
            // Tip: no need to transform 0-1023 voltage value to 0-5 range, due to following fraction
            long resistance = (knownResistor * (supplyVoltage - sensorVoltage ) / sensorVoltage) ;
            delay(1);
            addReading(resistance);
            Serial.print (resistance);
    // Averaging algorithm
    void addReading(long resistance)
        buffer[index] = resistance;
        index++;
        if (index >= NUM_READS) {
            index = 0;
    long average()
        long sum = 0;
        for (int i = 0; i < NUM_READS; i++) {
            sum += buffer[i];
        return (long)(sum / NUM_READS);
        if (message.type==V_STATUS) {
            // Change relay state
            // Store state in eeprom
    • rejoe2R
      rejoe2R
      rejoe2
      I'm not en expert, but the sketch looks quite ok.
      One thing seems to be faulty: the reassignment of the temperature_time is within the #ifdef ... section. If you comment out MY_DEBUG, this will not be executed.
      Options for enhancements:
      • as time_passed is unsigned long, it could not get lower than 0, so asking for this is not necessary (some explanation: time_passed will be a very huge figure in case millis() is lower than temperature time). Same for soil_time.
      • as you use the same timings, distinguishing between both is not necessary
      • 6 seconds as a intervall for this kind of measurement seems pretty short imo
      • with only one button you could also use an interrupt and make the node sleep() or wait() in between (needs a change in HW also, PIN2 or 3 for swith; see the BinarySwitchSleep-example for details or the PulseWaterMeter for using a seperate routine. In later case you have to include the send() instruction within the interrupt routine).
      • R
        R
        rob
        Thank you for your quick response !
        Ill have a go changing all you said, the 6 seconds interval was for testing purposes so i didnt have to wait for the output.
        Ill have a looksee at the examples you mentioned.
        my next step is to hook up the 1000 meters of cat6e cable i put everywhere, to hook up all the door/window buttons and sensors/arduinos and making rules to get them all to work with all the philips hue lights and whatnot.
        this was my first multi sketch with a lot of copy paste and trial and error :D
        gohanG 1 Reply Last reply
        • rejoe2R
          rejoe2R
          rejoe2
          You are welcome!
          If you are interested in some examples of combined sensors: Most of my stuff is located at github: https://github.com/rejoe2
          You may be especially interested in the code here: https://github.com/rejoe2/MySensors_Small/tree/master/MyS103, but be warned: there seems to be some problem with this node, but imo this is related to either RF or the BMP180 part of it.
          • R rob
            @rob
            Is your node battery powered? If not, sleep isn't that mandatory and if node is sleeping you can't send commands to activate relays, just saying in case you missed it.
            • R
              R
              rob
              Yeah thats on my todo list to , the weather station :D i got al the sensors now to hook them up and write the sketches then agian i got a verryyyyy long todo list
              rejoe2R 1 Reply Last reply
                You are not alone between those with long to do lists 😁
                • R
                  R
                  rob
                  no this node is not batterpowerd, hence the millis etc for the wait period still need to clean up the sketch and still remove some of the stuff left behind from al that copy and pasting :D
                  • R rob
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @rob The weather station is not tested at all, just a collection of ideas and a lot of parts laying around for a long time already :disappointed:
                    @gohan Thx for clarification wrt. to !sleep()!
