  3. Encryption, Signing and OTA is there any how-to?
42 Posts 6 Posters 13.1k Views 10 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    I hope to be able to file a pull request with updates to the personalizer this or next week. @LastSamurai @MLs @meddie i would really appreciate if you tested and reviewed the change so that you (and others) no longer are deterred from using signing due to its complexity. I will update the pull request until you feel confident in the procedure. I will post a link here when I have something to show for.
    • AnticimexA Anticimex
      @LastSamurai I see. Well, I intentionally left the personalizer to be highly customizable since users have varying requirements, but I can add flags to it which preconfigure some typical usecases if that would help?
      L
      L
      LastSamurai
      @Anticimex said in Encryption, Signing and OTA is there any how-to?:
      That would actually be great! Some flags that automatically set up for:
      • create everything at the gw and save it
      • node: takes the provided HMAC (and aes) and saves it, generates new node id
      and perhaps some others would really help me (and others I hope). I gladly test your new changes, just keep me updated!
      PS We could also add a section to your text describing that you need well working radios (+ caps) because of the longer message sizes. Signing doesn't work for all nodes for me due to that and when I started working with it I thought this to be a problem with signing.
      AnticimexA 1 Reply Last reply
      • L LastSamurai
        AnticimexA
        AnticimexA
        Anticimex
        @LastSamurai node IDs is not a signing thing so the personalizer will not touch that.
        And regarding working radios, the "real" documentation feature a troubleshooting section where that topic is covered. Doxygen that is. Link is available through the readme on the library on github. I will see if I can incorporate that somehow on the main site. Unfortunately there is no automatic link between the generate docs which are the most recent, and the article on the main site.
        • L
          L
          LastSamurai
          I meant the serial number (forgot that name and it is like a node id, right?). The one thats needed for e.g. whitelisting.
          The documentation mentions somewhere that signing might cause errors if the radios aren't working at a 100%? Haven't seen that but that might be important to avoid people being "afraid" of using signing.
          • L LastSamurai
            AnticimexA
            AnticimexA
            Anticimex
            Both serial and node id is used for whitelisting.
            However, only serial is generated by the personalizer (and only for software signing, atsha204a has a fixed serial).
            This is the full documentation with troubleshooting section: https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MySigninggrp.html
              MLs
              @Anticimex
              Ofcourse
              //Mattias
              • AnticimexA
                AnticimexA
                Anticimex
                While I am working on the personalizer simplifications, perhaps you could have a look at https://www.mysensors.org/about/signing#how-to-use-this where there are (and have been all along) an explicit list of flags to enable/disable for "master" and "slave" devices. I believe this is what you were looking for @LastSamurai ?
                L 1 Reply Last reply
                  L
                  L
                  LastSamurai
                  @Anticimex Oh, right that looks very helpful! Some shortcuts for these would be great anyways :)
                  • L LastSamurai
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @LastSamurai I agree, and I will rename a a few concepts as well.
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      #22
                      I am inclined to stick to the concept as documented instead of having "node" and "gateway" concepts as we discussed. I will still simplify the procedure.
                      The reason for this is that I believe it is simpler to have this procedure:
                      • Configure personalizer to generate keys
                      • Reconfigure personalizer to retain and store generated keys
                      as opposed to
                      • Configure personalizer for "gateway" (to generate and store keys)
                      • Configure personalizer for "node" (to store retained keys)
                      The reason I think the first and original design is simpler is because it allows you to execute the personalizer once with one setting to obtain keys, then reconfigure the personalizer once and execute the same personalizer on ALL devices. That minimizes the risk of having misalignment in the personalized security data between the nodes. What I will do is to provide two "top-level" definitions which takes care of every setting except the setting of the retained autogenerated keys and the use of ATSHA204A or software signing. The personalizer does output the auto generated keys in a very copy+paste friendly manner so it is not difficult to set these.
                      The only thing which need to be different between nodes/gateways is the serial (if soft signing is used) so that will always be randomly generated (unless one specifically reconfigure the personalizer to use a specific serial).
                      Thoughts on this? I am still open for input as it is you that are the users :)
                      EDIT: I will have four "top-level" flags, so you select ATSHA or soft variant at the top level.
                        as opposed to
                        L
                        L
                        LastSamurai
                        @Anticimex That sounds really nice to me. I would also (if thats possible without breaking something in the code) move these new flags and the settings for the HMAC (and everything else that needs to be inserted) to the top of the sketch, so that if you stay with the "default" settings you don't need to scroll down. Just for easy of use and for beginners.
                        Great timing from you btw: I am in the process of switching the controller anyways and will redo some of my nodes too. Now I can incorporate signing (and perhaps encryption) too.
                        • L LastSamurai
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @LastSamurai I am pretty much rewriting the entire personalizer. So I am glad to have a motivated test team at hand ;)
                          Ease of use is prio1 with flexibility coming in second.
                            Agreed, if you can make the configuration easy of the most common commands, it would be great for beginners. ;)
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              There is a pull request now for a new personalizer. Please try it. It might still be a few issues, but I need more test coverage.
                              https://github.com/mysensors/MySensors/pull/794
                                L
                                L
                                LastSamurai
                                @Anticimex I already download the pr... the new sketch looks very nice! I'll try it out tomorrow.
                                • L
                                  L
                                  LastSamurai
                                  Seems to work just fine. The output is way cleaner and the options are easy to use imo (tried the PERSONALIZE_SOFT_RANDOM_SERIAL). One questions though:
                                  The output gives me EEPROM and Key Storage. With different values for the Serial number. What's the difference here?
                                  • L LastSamurai
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @LastSamurai Can you please provide the output?
                                    The sketch will output EEPROM value first, and (in the case of PERSONALIZE_SOFT_RANDOM_SERIAL) generate a new serial which will replace the value in EEPROM. If you run the sketch without any flags set, it will just show the currently stored states.
                                    • L
                                      L
                                      LastSamurai
                                      Haven't saved it. Will rerun it later ;) There were just different categories and one was EEPROM another was Key Storage. Inbetween was the gererated key (which was the same as in the key storage). So I guess it read the values, wrote the new ones and displayed the new ones. Might be a little confusing though. I'll try to post it later
                                      Everything seems to be working now though with the signing enabled.
                                      • L LastSamurai
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @LastSamurai EEPROM is exactly what it says; the data in EEPROM.
                                        Key storage is the keys being stored "somewhere", it could be EEPROM (if you use soft signing) or ATSHA204A if you use that. If you execute the key generation stage, you will see "Key generation" instead of "Key storage".
                                        The special case is the PERSONALIZE_SOFT_RANDOM_SERIAL in which you will do both key generation and key storage (but only generation for the serial).
                                        • L
                                          L
                                          LastSamurai
                                          This is what I get:
                                          |                           MySensors security personalizer                          |
                                          |                               Configuration settings                               |
                                          | * Guided personalization/storage of keys in EEPROM                                 |
                                          | * Guided storage and generation of random serial in EEPROM                         |
                                          | * Software based personalization (no ATSHA204A usage whatsoever)                   |
                                          | * Will not require UART confirmation before locking ATSHA204A configuration        |
                                          | * Will store HMAC key to EEPROM                                                    |
                                          | * Will store AES key to EEPROM                                                     |
                                          | * Will generate soft serial using software                                         |
                                          | * Will store soft serial to EEPROM                                                 |
                                          |                           Hardware security peripherals                            |
                                          | Device       | Status       | Revision     | Serial number                | Locked |
                                          | AVR          | DETECTED     | N/A          | N/A (generation required)    | N/A    |
                                          |                                       EEPROM                                       |
                                          | Key ID | Status | Key                                                              |
                                          | HMAC   | OK     | ... |
                                          | AES    | OK     | 00000000000000000000000000000000                                 |
                                          | SERIAL | OK     | 0E0103FA44D749F163                                               |
                                          |                                   Key generation                                   |
                                          | SERIAL | OK     | 0F5B932A87D43AD318                                               |
                                          |                                    Key storage                                     |
                                          | HMAC   | OK     | ... |
                                          |                                  WHAT TO DO NEXT?                                  |
                                          | This device has now been personalized. Run this sketch with its current settings   |
                                          | on all the devices in your network that have security enabled.                     |
                                          |                                  Execution result                                  |
                                          | SUCCESS        |
                                          Ah ok. Still a little confusing in my opinion. Why show the key storage at all with Soft_serial? In this case the key always gets saved in the eeprom (right?). Just the "key generation" and one eeprom afterwards or one before and one after (with different names) would be clearer imo.
                                          Just some (hopefully constructive) critisism. I still like it way more than the old system!
