  3. Real Time Clock with Display Example
displayrtc
12 Posts 7 Posters 7.4k Views 2 Watching
  • korttomaK
    korttomaK
    korttoma
    I was thinking the same thing as @GREGL
    I'm using the following to initialize my LCD:
    LiquidCrystal_I2C lcd(0x27,20,4);
    lcd.init();
    Don't think I'm using the same Lib either.
    • Tomas
    • greglG
      greglG
      gregl
      wrote on last edited by gregl
      I was just poking around on codebender and found the lib..but none of the examples use all these params.
      IIRC ,I use a different lib...as my i2c lcd controllers are pretty old..byvac from memory.
        Found the new liquidcrystal library while searching my display Funduino/1602.
        The parameters are:
        addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
        https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
        Example:
        http://jaredstemen.blogspot.se/2014/01/getting-funduino-1602-lcd-to-print.html
        • korttomaK
          korttomaK
          korttoma
          Tried the lib out in my setup and it seems to be working just fine so I think I will use that one to so that I can be on the same page as @hek
          • Tomas
          hekH 1 Reply Last reply
          • korttomaK korttoma
            @korttoma
            I has been checked in to master.
            https://github.com/mysensors/Arduino/tree/master/libraries/LiquidCrystal
            • bjornhallbergB
              bjornhallbergB
              bjornhallberg
              wrote on last edited by bjornhallberg
              These OLED displays seem pretty cool also if the quality is ok and the library doesn't eat up too much space:
              https://www.youtube.com/watch?v=mMiMNTv25Bw
              A lot more information being displayed in a much smaller package. Price is similar to the 16x2 LCD and they run on 3.3-5V apparently. Available as I2C also.
              • greglG
                greglG
                gregl
                Hey maybe i can use this with the microview http://forum.mysensors.org/topic/48/idea-s-microview/
                  marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  I have a couple of these (I2C) and they are great.
                  I have tried to use them together with a temp sensor but I failed doing so.
                  I was able to compile and upload the sketch but due to a lack of patience I did not investigate why it failed.
                  My gut feeling is that the problem was the use of too many string values...
                  Fulltime Servoy Developer
                  • R
                    R
                    Rek
                    I have a couple of these OLED displays on order, will see if I can get them working with the sensors.
                      Put together a new example inspired by @gregl for the RTC module.
                      Also added a display to show date, time and temperature.
                      http://www.mysensors.org/build/display
                      https://codebender.cc/sketch:48371
                      cadetC
                      cadetC
                      cadet
                      wrote on last edited by cadet
                      @hek said in Real Time Clock with Display Example:
                      Hi
                      Can you modify code for adding temp sensor to GW.
                      And may be display day of week.
                      Thank you.
