  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 466.6k Views 30 Watching
  • AnticimexA Anticimex
    @meddie you could consider using a conversion board (@tbowmo has published one at openhardware.io) and use rfm69 radios which do AES encryption in hw. It should put less strain on memory resources.
    alexsh1A
    alexsh1A
    alexsh1
    @Anticimex I am using a default SensebenderGatewaySerial sketch and get the following error when compiling:
    In file included from C:\Users\Alex\Documents\Arduino\SensebenderGatewaySerial-2.1.1\SensebenderGatewaySerial-2.1.1.ino:98:0:
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: redefinition of 'uint8_t device_pin'
     static uint8_t device_pin;
    In file included from C:\Users\Alex\Documents\Arduino\libraries\MySensors/MySensors.h:131:0,
                     from C:\Users\Alex\Documents\Arduino\SensebenderGatewaySerial-2.1.1\SensebenderGatewaySerial-2.1.1.ino:96:
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: 'uint8_t device_pin' previously declared here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void swi_set_signal_pin(uint8_t)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: redefinition of 'void swi_set_signal_pin(uint8_t)'
     static void swi_set_signal_pin(uint8_t is_high)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: 'void swi_set_signal_pin(uint8_t)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t swi_send_bytes(uint8_t, uint8_t*)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:35:16: error: redefinition of 'uint8_t swi_send_bytes(uint8_t, uint8_t*)'
     static uint8_t swi_send_bytes(uint8_t count, uint8_t *buffer)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:35:16: error: 'uint8_t swi_send_bytes(uint8_t, uint8_t*)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t swi_send_byte(uint8_t)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:74:16: error: redefinition of 'uint8_t swi_send_byte(uint8_t)'
     static uint8_t swi_send_byte(uint8_t value)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:74:16: error: 'uint8_t swi_send_byte(uint8_t)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t swi_receive_bytes(uint8_t, uint8_t*)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:79:16: error: redefinition of 'uint8_t swi_receive_bytes(uint8_t, uint8_t*)'
     static uint8_t swi_receive_bytes(uint8_t count, uint8_t *buffer)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:79:16: error: 'uint8_t swi_receive_bytes(uint8_t, uint8_t*)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t sha204p_receive_response(uint8_t, uint8_t*)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:178:16: error: redefinition of 'uint8_t sha204p_receive_response(uint8_t, uint8_t*)'
     static uint8_t sha204p_receive_response(uint8_t size, uint8_t *response)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:178:16: error: 'uint8_t sha204p_receive_response(uint8_t, uint8_t*)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t sha204c_resync(uint8_t, uint8_t*)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:212:16: error: redefinition of 'uint8_t sha204c_resync(uint8_t, uint8_t*)'
     static uint8_t sha204c_resync(uint8_t size, uint8_t *response)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:212:16: error: 'uint8_t sha204c_resync(uint8_t, uint8_t*)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t sha204c_send_and_receive(uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:234:16: error: redefinition of 'uint8_t sha204c_send_and_receive(uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t)'
     static uint8_t sha204c_send_and_receive(uint8_t *tx_buffer, uint8_t rx_size, uint8_t *rx_buffer,
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:234:16: error: 'uint8_t sha204c_send_and_receive(uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t sha204m_read(uint8_t*, uint8_t*, uint8_t, uint16_t)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:379:16: error: redefinition of 'uint8_t sha204m_read(uint8_t*, uint8_t*, uint8_t, uint16_t)'
     static uint8_t sha204m_read(uint8_t *tx_buffer, uint8_t *rx_buffer, uint8_t zone, uint16_t address)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:379:16: error: 'uint8_t sha204m_read(uint8_t*, uint8_t*, uint8_t, uint16_t)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void sha204c_calculate_crc(uint8_t, uint8_t*, uint8_t*)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:399:13: error: redefinition of 'void sha204c_calculate_crc(uint8_t, uint8_t*, uint8_t*)'
     static void sha204c_calculate_crc(uint8_t length, uint8_t *data, uint8_t *crc)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:399:13: error: 'void sha204c_calculate_crc(uint8_t, uint8_t*, uint8_t*)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t sha204c_check_crc(uint8_t*)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:424:16: error: redefinition of 'uint8_t sha204c_check_crc(uint8_t*)'
     static uint8_t sha204c_check_crc(uint8_t *response)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:424:16: error: 'uint8_t sha204c_check_crc(uint8_t*)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void atsha204_init(uint8_t)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:438:6: error: redefinition of 'void atsha204_init(uint8_t)'
     void atsha204_init(uint8_t pin)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:438:6: error: 'void atsha204_init(uint8_t)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void atsha204_idle()':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:455:6: error: redefinition of 'void atsha204_idle()'
     void atsha204_idle(void)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:455:6: error: 'void atsha204_idle()' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void atsha204_sleep()':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:460:6: error: redefinition of 'void atsha204_sleep()'
     void atsha204_sleep(void)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:460:6: error: 'void atsha204_sleep()' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t atsha204_wakeup(uint8_t*)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:465:9: error: redefinition of 'uint8_t atsha204_wakeup(uint8_t*)'
     uint8_t atsha204_wakeup(uint8_t *response)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:465:9: error: 'uint8_t atsha204_wakeup(uint8_t*)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t atsha204_execute(uint8_t, uint8_t, uint16_t, uint8_t, uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t*)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:495:9: error: redefinition of 'uint8_t atsha204_execute(uint8_t, uint8_t, uint16_t, uint8_t, uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t*)'
     uint8_t atsha204_execute(uint8_t op_code, uint8_t param1, uint16_t param2,
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:495:9: error: 'uint8_t atsha204_execute(uint8_t, uint8_t, uint16_t, uint8_t, uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t*)' previously defined here
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t atsha204_getSerialNumber(uint8_t*)':
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:571:9: error: redefinition of 'uint8_t atsha204_getSerialNumber(uint8_t*)'
     uint8_t atsha204_getSerialNumber(uint8_t * response)
    C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:571:9: error: 'uint8_t atsha204_getSerialNumber(uint8_t*)' previously defined here
    Multiple libraries were found for "SD.h"
     Used: C:\Users\Alex\Documents\Arduino\libraries\SD
     Not used: C:\Program Files (x86)\Arduino\libraries\SD
    Using library MySensors at version 2.1.1 in folder: C:\Users\Alex\Documents\Arduino\libraries\MySensors
    Using library Wire at version 1.0 in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\Wire
    Using library SPI at version 1.0 in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\SPI
    Using library SD at version 1.1.1 in folder: C:\Users\Alex\Documents\Arduino\libraries\SD
    exit status 1
    Error compiling for board Sensebender Gateway.
    If I delete "#include <drivers/ATSHA204/ATSHA204.cpp>", it compiles just fine.
    Any ideas please?
    I am using Mysensors 2.1.1, Arduino IDE 1.8.1 and latest SAMD board def.
    AnticimexA 1 Reply Last reply
    • alexsh1A alexsh1
      exit status 1
      Any ideas please?
      AnticimexA
      AnticimexA
      Anticimex
      @alexsh1 That is because the sketch has this line
      @tbowmo Is it intentional to include the cpp and not the header in the sketch?
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        @Anticimex Thanks! I can confirm it compiles fine with the header included rather than the cpp. I suppose it was not an intention
        • tbowmoT
          tbowmoT
          tbowmo
          @alexsh1
          What environment are you building in? platform.io ? Or?
          I know it's awkward to include the cpp file, but it must have been done intentional at some point in time, and arduino way of doing things are very weird at times..
          Btw it does compile fine for me (even with the .cpp as include)
          • tbowmoT tbowmo
            @alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            @tbowmo No, I am just using Arduino IDE in Windows 10
            • AnticimexA
              AnticimexA
              Anticimex
              I tried building the sketch in Arduino 1.8.1 on Windows 10. Worked fine here. In your log, the sketch name looks changed. It does not end with -2.1.1 here.
              Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\P\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\P\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Cloud\Google Drive\gits\libraries -fqbn=MySensors:samd:mysensors_gw_native -ide-version=10801 -build-path
              "C:\Users\P\AppData\Local\Temp\arduino_build_482491/SensebenderGatewaySerial.ino.elf" "C:\Users\P\AppData\Local\Temp\arduino_build_482491\sketch\SensebenderGatewaySerial.ino.cpp.o" "C:\Users\P\AppData\Local\Temp\arduino_build_482491\libraries\Wire\Wire.cpp.o" "C:\Users\P\AppData\Local\Temp\arduino_build_482491\libraries\SPI\SPI.cpp.o" "C:\Users\P\AppData\Local\Temp\arduino_build_482491\libraries\SD\File.cpp.o" "C:\Users\P\AppData\Local\Temp\arduino_build_482491\libraries\SD\SD.cpp.o" "C:\Users\P\AppData\Local\Temp\arduino_build_482491\libraries\SD\utility\Sd2Card.cpp.o" "C:\Users\P\AppData\Local\Temp\arduino_build_482491\libraries\SD\utility\SdFile.cpp.o" "C:\Users\P\AppData\Local\Temp\arduino_build_482491\libraries\SD\utility\SdVolume.cpp.o" "C:\Users\P\AppData\Local\Temp\arduino_build_482491\core\variant.cpp.o" -Wl,--start-group "-LC:\Users\P\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\Users\P\AppData\Local\Temp\arduino_build_482491/core\core.a" -Wl,--end-group
              "C:\Users\P\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary  "C:\Users\P\AppData\Local\Temp\arduino_build_482491/SensebenderGatewaySerial.ino.elf" "C:\Users\P\AppData\Local\Temp\arduino_build_482491/SensebenderGatewaySerial.ino.bin"
              "C:\Users\P\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom  "C:\Users\P\AppData\Local\Temp\arduino_build_482491/SensebenderGatewaySerial.ino.elf" "C:\Users\P\AppData\Local\Temp\arduino_build_482491/SensebenderGatewaySerial.ino.hex"
               Used: C:\Cloud\Google Drive\gits\libraries\SD
              Using library MySensors at version 2.1.1 in folder: C:\Cloud\Google Drive\gits\libraries\MySensors
              Using library Wire at version 1.0 in folder: C:\Users\P\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\Wire
              Using library SPI at version 1.0 in folder: C:\Users\P\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\SPI
              Using library SD at version 1.1.1 in folder: C:\Cloud\Google Drive\gits\libraries\SD
              Sketch uses 42984 bytes (16%) of program storage space. Maximum is 262144 bytes.
                alexsh1A
                alexsh1A
                alexsh1
                @Anticimex Sorry, my bad I forgot to mention that the sketch compiles OK as is.
                Only when I add signing:
                //#define MY_SIGNING
                #define MY_SIGNING_ATSHA204
                It fails to compile:
                Arduino: 1.8.1 (Windows 10), Board: "Sensebender Gateway"
                C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Alex\AppData\Local\Arduino15\packages -hardware C:\Users\Alex\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Alex\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Alex\Documents\Arduino\libraries -fqbn=MySensors:samd:mysensors_gw_native -ide-version=10801 -build-path C:\Users\Alex\AppData\Local\Temp\arduino_build_806240 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino5-static -prefs=runtime.tools.bossac.path=C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0 -prefs=runtime.tools.CMSIS.path=C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0 -verbose C:\Users\Alex\AppData\Local\Temp\arduino_modified_sketch_295317\SensebenderGatewaySerial.ino
                C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Alex\AppData\Local\Arduino15\packages -hardware C:\Users\Alex\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Alex\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Alex\Documents\Arduino\libraries -fqbn=MySensors:samd:mysensors_gw_native -ide-version=10801 -build-path C:\Users\Alex\AppData\Local\Temp\arduino_build_806240 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino5-static -prefs=runtime.tools.bossac.path=C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0 -prefs=runtime.tools.CMSIS.path=C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0 -verbose C:\Users\Alex\AppData\Local\Temp\arduino_modified_sketch_295317\SensebenderGatewaySerial.ino
                Using board 'mysensors_gw_native' from platform in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5
                Using core 'arduino' from platform in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12
                Detecting libraries used...
                "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\cores\arduino" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\variants\mysensors_gw" "C:\Users\Alex\AppData\Local\Temp\arduino_build_806240\sketch\SensebenderGatewaySerial.ino.cpp" -o "nul"
                "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\cores\arduino" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\variants\mysensors_gw" "-IC:\Users\Alex\Documents\Arduino\libraries\MySensors" "C:\Users\Alex\AppData\Local\Temp\arduino_build_806240\sketch\SensebenderGatewaySerial.ino.cpp" -o "nul"
                "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\cores\arduino" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\variants\mysensors_gw" "-IC:\Users\Alex\Documents\Arduino\libraries\MySensors" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\Wire" "C:\Users\Alex\AppData\Local\Temp\arduino_build_806240\sketch\SensebenderGatewaySerial.ino.cpp" -o "nul"
                "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\cores\arduino" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\variants\mysensors_gw" "-IC:\Users\Alex\Documents\Arduino\libraries\MySensors" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\Wire" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\SPI" "C:\Users\Alex\AppData\Local\Temp\arduino_build_806240\sketch\SensebenderGatewaySerial.ino.cpp" -o "nul"
                "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\cores\arduino" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\variants\mysensors_gw" "-IC:\Users\Alex\Documents\Arduino\libraries\MySensors" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\Wire" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\SPI" "-IC:\Users\Alex\Documents\Arduino\libraries\SD\src" "C:\Users\Alex\AppData\Local\Temp\arduino_build_806240\sketch\SensebenderGatewaySerial.ino.cpp" -o "nul"
                Using cached library dependencies for file: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\Wire\Wire.cpp
                Using cached library dependencies for file: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\SPI\SPI.cpp
                Using cached library dependencies for file: C:\Users\Alex\Documents\Arduino\libraries\SD\src\File.cpp
                Using cached library dependencies for file: C:\Users\Alex\Documents\Arduino\libraries\SD\src\SD.cpp
                Using cached library dependencies for file: C:\Users\Alex\Documents\Arduino\libraries\SD\src\utility\Sd2Card.cpp
                Using cached library dependencies for file: C:\Users\Alex\Documents\Arduino\libraries\SD\src\utility\SdFile.cpp
                Using cached library dependencies for file: C:\Users\Alex\Documents\Arduino\libraries\SD\src\utility\SdVolume.cpp
                Generating function prototypes...
                "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\cores\arduino" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\variants\mysensors_gw" "-IC:\Users\Alex\Documents\Arduino\libraries\MySensors" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\Wire" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\SPI" "-IC:\Users\Alex\Documents\Arduino\libraries\SD\src" "C:\Users\Alex\AppData\Local\Temp\arduino_build_806240\sketch\SensebenderGatewaySerial.ino.cpp" -o "C:\Users\Alex\AppData\Local\Temp\arduino_build_806240\preproc\ctags_target_for_gcc_minus_e.cpp"
                "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Alex\AppData\Local\Temp\arduino_build_806240\preproc\ctags_target_for_gcc_minus_e.cpp"
                Compiling sketch...
                "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\cores\arduino" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\variants\mysensors_gw" "-IC:\Users\Alex\Documents\Arduino\libraries\MySensors" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\Wire" "-IC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\SPI" "-IC:\Users\Alex\Documents\Arduino\libraries\SD\src" "C:\Users\Alex\AppData\Local\Temp\arduino_build_806240\sketch\SensebenderGatewaySerial.ino.cpp" -o "C:\Users\Alex\AppData\Local\Temp\arduino_build_806240\sketch\SensebenderGatewaySerial.ino.cpp.o"
                In file included from C:\Users\Alex\AppData\Local\Temp\arduino_modified_sketch_295317\SensebenderGatewaySerial.ino:91:0:
                                 from C:\Users\Alex\AppData\Local\Temp\arduino_modified_sketch_295317\SensebenderGatewaySerial.ino:89:
                exit status 1
                Error compiling for board Sensebender Gateway.```
                • tbowmoT
                  tbowmoT
                  tbowmo
                  Have you tried to comment the #include out?
                  alexsh1A 2 Replies Last reply
                  • tbowmoT tbowmo
                    alexsh1A
                    alexsh1A
                    alexsh1
                    This is the sketch:
                    * This GW code is designed for Sensebender GateWay / (Arduino Zero variant)
                    * - Inclusion button should be connected to SW2
                    * LEDs on board (default assignments):
                    * - Orange: USB RX/TX - Blink when receiving / transmitting on USB CDC device
                    * - Yellow: RX  - Blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
                    * - Green : TX  - Blink fast on radio message transmitted. In inclusion mode will blink slowly
                    * - Red   : ERR - Fast blink on error during transmission error or recieve crc error
                    * - Blue  : free - (use with LED_BLUE macro)
                    #define SKETCH_VERSION "0.2"
                    // Enable serial gateway
                    #define MY_GATEWAY_SERIAL
                    #if F_CPU == 8000000L
                    #define MY_BAUD_RATE 38400
                    // Enable inclusion mode
                    // Set blinking period
                    // Flash leds on rx/tx/err
                    #include <SD.h>
                    Sd2Card card;
                    #define EEPROM_VERIFICATION_ADDRESS 0x01
                    static uint8_t num_of_leds = 5;
                    static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
                    void preHwInit()
                    	pinMode(MY_SWC1, INPUT_PULLUP);
                    	pinMode(MY_SWC2, INPUT_PULLUP);
                    	if (digitalRead(MY_SWC1) && digitalRead(MY_SWC2)) {
                    		return;
                    	uint8_t tests = 0;
                    	for (int i=0; i< num_of_leds; i++) {
                    		pinMode(leds[i], OUTPUT);
                    	uint8_t led_state = 0;
                    	if (digitalRead(MY_SWC1)) {
                    		while (!Serial) {
                    			digitalWrite(LED_BLUE, led_state);
                    			led_state ^= 0x01;
                    			delay(500);
                    		} // Wait for USB to be connected, before spewing out data.
                    	digitalWrite(LED_BLUE, LOW);
                    	if (Serial) {
                    		Serial.println("Sensebender GateWay test routine");
                    		Serial.print("Mysensors core version : ");
                    		Serial.println(MYSENSORS_LIBRARY_VERSION);
                    		Serial.print("GateWay sketch version : ");
                    		Serial.println("----------------------------------");
                    		Serial.println();
                    	if (testSha204()) {
                    		digitalWrite(LED_GREEN, HIGH);
                    		tests++;
                    	if (testSDCard()) {
                    		digitalWrite(LED_YELLOW, HIGH);
                    		tests++;
                    	if (testEEProm()) {
                    		digitalWrite(LED_ORANGE, HIGH);
                    		tests++;
                    	if (testAnalog()) {
                    		digitalWrite(LED_BLUE, HIGH);
                    		tests++;
                    	if (tests == 4) {
                    		while(1) {
                    			for (int i=0; i<num_of_leds; i++) {
                    				digitalWrite(leds[i], HIGH);
                    				delay(200);
                    				digitalWrite(leds[i], LOW);
                    		while (1) {
                    			digitalWrite(LED_RED, HIGH);
                    			delay(200);
                    			digitalWrite(LED_RED, LOW);
                    			delay(200);
                    bool testSha204()
                    	uint8_t ret_code;
                    	if (Serial) {
                    		Serial.print("- > SHA204 ");
                    	atsha204_init(MY_SIGNING_ATSHA204_PIN);
                    	ret_code = atsha204_wakeup(rx_buffer);
                    	if (ret_code == SHA204_SUCCESS) {
                    		ret_code = atsha204_getSerialNumber(rx_buffer);
                    			if (Serial) {
                    				Serial.println(F("Failed to obtain device serial number. Response: "));
                    			if (Serial) {
                    				Serial.print(F("Ok (serial : "));
                    				for (int i=0; i<9; i++) {
                    					if (rx_buffer[i] < 0x10) {
                    					Serial.print(rx_buffer[i], HEX);
                    				Serial.println(")");
                    			return true;
                    		if (Serial) {
                    			Serial.println(F("Failed to wakeup SHA204"));
                    	return false;
                    bool testSDCard()
                    	if (Serial) {
                    		Serial.print("- > SD CARD ");
                    	if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
                    		if (Serial) {
                    			Serial.println("SD CARD did not initialize!");
                    		if (Serial) {
                    			Serial.print("SD Card initialized correct! - ");
                    			Serial.print("type detected : ");
                    			switch(card.type()) {
                    			case SD_CARD_TYPE_SD1:
                    				Serial.println("SD1");
                    			case SD_CARD_TYPE_SD2:
                    				Serial.println("SD2");
                    			case SD_CARD_TYPE_SDHC:
                    				Serial.println("SDHC");
                    			default:
                    				Serial.println("Unknown");
                    		return true;
                    	return false;
                    bool testEEProm()
                    	uint8_t eeprom_d1, eeprom_d2;
                    	SerialUSB.print(" -> EEPROM ");
                    	Wire.begin();
                    	eeprom_d1 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
                    	delay(500);
                    	eeprom_d1 = ~eeprom_d1; // invert the bits
                    	i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
                    	delay(500);
                    	eeprom_d2 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
                    	if (eeprom_d1 == eeprom_d2) {
                    		SerialUSB.println("PASSED");
                    		i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, ~eeprom_d1);
                    		return true;
                    	SerialUSB.println("FAILED!");
                    	return false;
                    bool testAnalog()
                    	int bat_detect = analogRead(MY_BAT_DETECT);
                    	Serial.print("-> analog : ");
                    	Serial.print(bat_detect);
                    	if (bat_detect < 400 || bat_detect > 650) {
                    		Serial.println(" Failed");
                    		return false;
                    	Serial.println(" Passed");
                    	return true;
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      The gateway sketch include a test of the atsha which I don't think belong there. You can probably remove the include and the test function.
                      • tbowmoT tbowmo
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @tbowmo it compiles with this:
                        #include <drivers/ATSHA204/ATSHA204.h>
                        However, I cannot confirm that the singing is working - I need more time to set-up a node to test it.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Anticimex
                          It's the default sketch, that itead is putting in the gateway, including a simple hardware self-test routine.
                          I would like to keep it there, in case people run into troubles.. Then they can go back to factory stock firmware...
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @Anticimex You suggest to remote it? It compiles fine if I remove it. I will set-up a node tomorrow to test signing with #include <drivers/ATSHA204/ATSHA204.cpp> removed.
                            • tbowmoT tbowmo
                              @Anticimex
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @tbowmo may I suggest an update which would switch out the include of the cpp file and the test if atsha based signing is enabled? Or is it too late to ship firmware updates to iTead?
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @Anticimex
                                Such a change won't affect the firmware that is put into the sensebender GW per se, as we don't use signing in the default sketch. I was about to suggest the same :)
                                AnticimexA M 2 Replies Last reply
                                • tbowmoT tbowmo
                                  @Anticimex
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @tbowmo then we have a way forward :)
                                  • tbowmoT tbowmo
                                    @Anticimex
                                    meddie
                                    @Anticimex
                                    sorry i didnt let hear anything from me for the last few days.
                                    i had the same problems with compiling the sketch. It depends on the signing. When you remove the #define MY_SIGNING_ATSHA204 the you can compile but when the singning is defined you get an error until you remove this line:
                                    i have removed the line and defined the signing and for me works the singing and encryption.
                                    but i have an another problem, i dont know if i am right here or i better have to post in the sensebender micro forum, i posted that i had some troubles with the space on the sb micro, i have removed the #define my_debug that solved my space problem, but now i have observed that the node is starting and sends few times the temp and humidity but after the few times nothing happens anymore.
                                      meddie
                                      i observed, when i hold the sensor in the fingers so that it will be worm, and start the node then it sends all minute the temp, but when the temp goes donw to the room temperature the the node sends only when the humidity or temp changes over the threshhold, but in the room i dont have much changes and i think that when the node does not send about longer time, that the the problem comes up.
                                      I tested it in some different distances, on another floor but in very short distance too. I dont think that is a radio problem.
                                      What do you think about?
                                      The Problem is, that i cant debug the node because i disabled it because of space problems.
                                      Thank you
                                      • AnticimexA
                                        AnticimexA
                                        Anticimex
                                        Please post these kind of things in the sensebender thread, they are not signing related.
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Anticimex I have a quick question. I have the following in the node log:
                                          2076 Will not sign message for destination 255 as it does not require it
                                          2117 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          2779 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          2785 Skipping security for command 3 type 8
                                          2789 TSF:MSG:FPAR OK,ID=0,D=1
                                          4126 TSM:FPAR:OK
                                          4126 TSM:ID
                                          4128 TSM:ID:OK
                                          4130 TSM:UPL
                                          4132 Will not sign message for destination 0 as it does not require it
                                          4143 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          4161 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          4165 Skipping security for command 3 type 25
                                          both the GW and the node have #define MY_SIGNING_REQUEST_SIGNATURES
                                          Am I missing anything? Why signing is skipped?
