  2. Announcements
  • M marceloaqno
    @hawk_2050 same for you guys who helped, thank you for all the feedback.
    @jerseyguy1996 I don't see anything wrong with your config.Try to add a small delay() after the first send() and before the sendBattery().
    @annegerben This looks like a wire problem. I updated the guide, check the wire section again.
    marlin
    @marceloaqno I am trying to get a Pi 3 working with MySensors 2.1.1 and nrf24l01 and using your updated wire guide, but all I get as output is the following:
    mysgw: Starting gateway...
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:PDT
    [The output repeats itself, increasing the CNT every time, while at the same time one of the cores on the Pi 3 is running at full CPU utilization.]
    By reading earlier comments I assume this is a wiring problem. One possible cause is inconsistency between
    0_1488723559852_upload-e3165792-1f42-4663-8e68-efd96bd275f8
    and
    0_1488723638471_upload-d7048ef8-8a33-4214-9935-0356cf9291c2
    where the first picture indicates that pin 24 and pin 26 should be used, while the second indicates pins 22 and 24 should be used. However, I have tried both options but I still get the same output (I used different nrf24's for the different setups, in case the nrf24 got burned from the first setup).
    I have VCC from nrf24 connected to pin 17 on the Pi 3 and GND connect to pin 25.
    Any suggestions on what to try next?
    [The Pi 3 is running Raspbian with Pixel. For information, I already have a running Arduino with MySensors MQTT GW and a simple node with MySensors and DHT22. From this I know that by nrf24 chips works when being fed with 3.3V.]
    G keldandorinK 2 Replies Last reply
      I have connected my nrf24 like the secon table you posted and it is working but I am using an "adapter" for nrf24 with a socket and has voltage regulator + capacitors, so if you don't have any cap on the radio module, I'd suggest you put one on (try from a 4.7 uF up to 47 and see if anything changes)
        marlin
        @gohan Thanks! You were correct. I also had one of those "adapters" lying around which I did not need for my Arduino nodes with MySensors, though it came into use for the Rp3.
          After updating domoticz to beta version I finally have the MQTT working with controller and I can see the sensor node seding in data: my question now is how to I debug the gateway if it is running as a service on the RPI without messing things up?
          G
          G
          Grubstake
          @gohan said in 💬 Building a Raspberry Pi Gateway:
          I have my gateway on a headless pi 3, no monitor, GUI or keyboard. (I don't care for the nest of wires connection to the pi.) I also use MQTT which is very reliable.
          An easy way to see the full MQTT traffic is to not start (or kill if it starts on boot) the MQTT server in the background, and start it in the console you can monitor. This won't impact Domotics one bit. In my case I do this by invoking "mosquitto -d" in the terminal
          A simple way to monitor MQTT once its up and running is to look at the Domotics Log on the Setup menu.
          Another way to watch it is to, in a terminal window such as running ssh from your computer, use MQTT "sub" in your terminal to see the MQTT traffic both ways to and from Domotics. If this isn't familiar, you need to learn it, (read the MQTT docs) and it's quite simple. Example might be "ssh pi@rpi.local" or "ssh <IP address>" from a computer on the local network, assuming the user is named pi and the pi is named "rpi"
          Your MQTT topic must match what is in the sensor node sketch, the gateway sketch, and the domotics MQTT config. In my case I use "mosquitto_sub -d -v -t domoticz" and everything starts showing in real time in the terminal window.
          MQTT is a bit more fiddly to set up but it's nice that different environments can push sensor data into the same MQTT server, in my case MySensors and ESP Easy.
          Tim
          gohanG 1 Reply Last reply
          • M marlin
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: TSM:FAIL:PDT
            and
            G
            G
            Grubstake
            @marlin said in 💬 Building a Raspberry Pi Gateway:
            Be careful because the wiring page shows two pinout diagrams, one for the Pi 1, another for the Pi 2&3, but which is which is not inside the graphic itself. Please don't ask how I know. ;-)
            Tim
            • G Grubstake
              Tim
              @Grubstake
              I am using mqtt fx from pc and subscribing to topic # so I get the full traffic of what is going on, but I haven't had time lately to compare if you get same log details as the myscontroller connected to ethernet gateway or starting the gateway on rpi with debug flag
              • M marlin
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: TSM:FAIL:PDT
                and
                keldandorinK
                keldandorinK
                keldandorin
                @marlin Got the same issue, Did you solve yours and if so how?
                M gohanG 2 Replies Last reply
                • keldandorinK keldandorin
                  marlin
                  @keldandorin Yes. See the response by @gohan. I used a "adapter" with a voltage regulator on it etc. Though, at the moment I don't recall the model number.
                    @keldandorin just add a capacitor between vcc and gnd on the radio module as I suggested above.
                    • C
                      C
                      ccy
                      wrote on last edited by ccy
                      #377
                      I am trying to connect NRF24L01+ and Raspberry Pi 2 (Model B+). I am confuse about pin 22/24 too. In the diagram it shows "SPI0 CS0" and "SPI0 CS1" but these two pins aren't exist in NRF24L01+. How should I connect the pin? I connect Pi2 pin 24 to CS and Pi2 pin 26 to CE (Not sure it is correct)? Here is the message from mysgw:
                      [root@alarmpi bin]# ./mysgw -d
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:FAIL:RE-INIT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:CNT=2
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:CNT=3
                      mysgw: TSM:FAIL:PDT
                      • C ccy
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: TSM:FAIL:PDT
                        mysgw: TSM:INIT
                        mysgw: TSM:FAIL:PDT
                        mysgw: TSM:INIT
                        mysgw: TSM:FAIL:PDT
                        G
                        G
                        Grubstake
                        wrote on last edited by Grubstake
                        #378
                        @ccy Look at the chart below "NRF24L01+ Radio". That shows the PIN numbers on the Pi and the pin labels on the radio to interconnect. Pay no attention to the labels on the RPi generic pinout diagram except the PIN numbers. The RPi SPIO labels are not what you are looking for. And be sure to use the chart for the correct RPi model.
                          Exactly, I was about to write pretty much the same 😀
                            G
                            G
                            Grubstake
                            @gohan I beat you to it! :smiley:
                            • C
                              C
                              ccy
                              #381
                              @Grubstake: Thanks. I have tried to follow "NRF24L01+ Radio" pin out connection. I have double / triple check my wiring is correct. But I still get the same fail message in mysgw debug mode:
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: TSM:FAIL:PDT
                              mysgw: TSM:INIT
                              mysgw: TSM:FAIL:PDT
                              mysgw: TSM:INIT
                              mysgw: TSM:FAIL:PDT
                              mysgw: Received SIGINT
                              Here is my /boot/config.txt:
                              gpu_mem=64
                              initramfs initramfs-linux.img followkernel
                              dtparam=spi=on
                              and the spi dev:
                              # ls /dev/spidev0.*
                              I am using ArchLinuxARM:
                              # uname -a
                              Linux alarmpi 4.9.13-3-ARCH #1 SMP Fri Mar 3 18:45:16 MST 2017 armv7l GNU/Linux
                              I only wiring 7 pins (1-7) on NRF24l01+.
                              Raspberry Pi 2 hardware information:
                              # cat /proc/cpuinfo
                              processor       : 0
                              model name      : ARMv7 Processor rev 5 (v7l)
                              BogoMIPS        : 38.40
                              Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
                              CPU implementer : 0x41
                              CPU architecture: 7
                              CPU variant     : 0x0
                              CPU part        : 0xc07
                              CPU revision    : 5
                              processor       : 1
                              BogoMIPS        : 38.40
                              CPU architecture: 7
                              CPU variant     : 0x0
                              CPU part        : 0xc07
                              CPU revision    : 5
                              processor       : 2
                              BogoMIPS        : 38.40
                              CPU architecture: 7
                              CPU variant     : 0x0
                              CPU part        : 0xc07
                              CPU revision    : 5
                              processor       : 3
                              BogoMIPS        : 38.40
                              CPU architecture: 7
                              CPU variant     : 0x0
                              CPU part        : 0xc07
                              CPU revision    : 5
                              Hardware        : BCM2835
                              Revision        : a21041
                              Serial          : 00000000475d18a4
                              # cat /sys/firmware/devicetree/base/model
                              Raspberry Pi 2 Model B Rev 1.1
                              Output from MySensors configure:
                              # ./configure
                              ./configure: line 111: warning: command substitution: ignored null byte in input
                              [OK] Finished.
                              I finally find out my raspberry pi board isn't detected properly in configure. I change the function detect_machine:
                              function detect_machine {
                                  case $hardware in
                                  BCM2835)
                                      soc="BCM2835"
                                      if [[ $machine == "Raspberry"* ]]; then
                                          local rev=($(detect_rpi_revision))
                                          if [[ $rev == "a02082" || $rev == "a22082" ]]; then
                                              tp="RPi3"
                                              tp="Rpi2"
                                          fi
                                      fi
                              make mysgw again, and I get this finally:
                              # ./mysgw -d
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: TSM:INIT:TSP OK
                              mysgw: TSM:INIT:GW MODE
                              mysgw: MCO:REG:NOT NEEDED
                              mysgw: MCO:BGN:STP
                              mysgw: MCO:BGN:INIT OK,TSP=1
                              enloE J 2 Replies Last reply
                              • C
                                C
                                ccy
                                #382
                                I can run mysgw. But what can I use it for? I want to make it control my light with 2.4G RF. But I don't know what to do next. Please advice Thank you.
                                • C ccy
                                  @ccy
                                  You need to provide some more details about your hw and general setup, what have you done so far, log messages, etc.
                                  C 1 Reply Last reply
                                    @ccy
                                    C
                                    C
                                    ccy
                                    @gohan Sorry for my typo mistake. I can now run mysgw. But what can I use it for? I am trying to control my light with 2.4G RF.
                                      Do you mean your light has already 2.4G RF or do you need to make a relay node with NRF24 that can switch on and of that light? But this is going a little OT in this thread.
                                        C
                                        C
                                        ccy
                                        @gohan Yes. I want to do that. I am sure my LED controller is 2.4G RF. But I can't detect any signal yet from my nrf24l01+ on raspberry pi. I am not sure what's wrong. Still trying now...
                                        • C ccy
                                          @ccy
                                          Being 2.4G RF doesn't mean it is NRF24L01 compatible also without knowing what channel is using will make it even more difficult. So, unless you want to make a Mysensors LED Controller, I think you are out of luck if you want to directly control your existing one with a RPI and the mysensors gateway. Either way this is OT.
