  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 119.2k Views 58 Watching
  • tekkaT tekka
    @Jan-Hicl This has been fixed - did you try the most recent version from github?
    J
    J
    Jan Hicl
    Hi @tekka and thanks for getting back to me! I tried the latest version however with no success. The node that I update is still marked as "Booting" even though I upload Blink.hex. Strangely enough, the led is blinking as it's supposed to blink and if I request presentation the node replies with correct sketch name but then it goes back to Booting. I'm using Arduino IDE 1.8.1, AVRdude v6.1 and MYScontroller v1.0.0 beta (build 3314). I'm using Arduino mini pro, 3V3, 8MHz. I have 5 different nodes but all of them with the same behavior so it does not seem as an HW issue.
    Here is my log from the upload of Blink.hex: http://pastebin.com/9grgHb27 Would you have any idea how could I fix that? Thanks!
    tekkaT 1 Reply Last reply
    • J Jan Hicl
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      #140
      @Jan-Hicl The blink sketch is somewhat special - it only blinks the built-in LED until the watchdog kicks in and resets the node. What happens if you upload one of your sketches? Please post the full debug log + source. Thanks
      • yd kimY
        yd kimY
        yd kim
        I did success with MySBootloader 1.3 beta 3 (https://github.com/mysensors/MySensorsBootloaderRF24 )
        It works both arduino and OTA firmware upgrade however it takes longer to boot up (means switch to firmware) about 3-5seconds.
        I'm using MYSensors 2.1.0 and MYController (http://www.mycontroller.org) on arduino pro mini 8Mhz 3.3V.
        How many sensor you try at the same time?
        From memory When I do firmware update for 3-4 sensors, I have to change "Tx message processing delay" to 300ms.
        If it's shorter than 300ms, keep rebooting some stage.
        I didn't use MYScontroller but probably it has similar setting.
        • J
          J
          Jan Hicl
          Thanks @tekka for a prompt response!
          I tried to upload https://github.com/mysensors/MySensors/blob/master/examples/AirQualitySensor/AirQualitySensor.ino
          here is the log: http://pastebin.com/Tc5vhEnF
          You can see that the node is successfully running with TimeReporter but AirQualitySensor cannot make it from booting. However, this is happening even with highly modified AirQualitySensor sketch or some of my custom sketches. In the log, you can also see that if I request presentation of that node it replies with correct sketch name.
          Please let me know if you need some more info. Thanks in advance!
          • J Jan Hicl
            tekkaT
            tekkaT
            tekka
            @Jan-Hicl Please also post the full debug log of the node (running AirQualitySensor).
            J 1 Reply Last reply
            • tekkaT tekka
              J
              J
              Jan Hicl
              @tekka here is the AirQualitySensor node log: http://pastebin.com/XWfFCbUx
              • J Jan Hicl
                tekkaT
                tekkaT
                tekka
                @Jan-Hicl The GW and node logs are inconsistent: your GW log shows a rebooting node 1 - the node log shows a running node trying to establish the uplink. Do you have logs from GW and node taken simultaneously?
                • tekkaT tekka
                  J
                  J
                  Jan Hicl
                  Sorry @tekka, should've sent this in the first post. Here is AirQuality sensor node log: http://pastebin.com/9MVtfRNV
                  Here is gateway log: http://pastebin.com/QNpmBz4m
                  Both of them logged simultaneously. Node Id I'm updating is 1. In the log you can again see that TimeReporter is working well before the flashing. Please let me know if there is anything I can provide you with in order to solve this... Thanks!
                  • Nicolas CharrierN
                    Nicolas CharrierN
                    Nicolas Charrier
                    Hello
                    I succed to program booloader but y can not add my sketch to arduino with serial or USB line.
                    Is is activated by default?
                    • J
                      J
                      Jan Hicl
                      Hi @tekka any update what could be wrong with the upload? Any advice on a workaround? Thanks!
                      • J Jan Hicl
                        tekkaT
                        tekkaT
                        tekka
                        #149
                        @Jan-Hicl The upload via bootloader is ok (the sketch is running - based on your debug log) - so no issue here.
                        However, you may have some issues with the CPU frequency (wrong board selected when compiling?) - there are scrambled chars in the debug output:
                        Starting óensor (RNNNA-, 2.0.0)
                        TSM:INIT
                        TSM:RADIO:OK
                        TSP:ASSIGNID:OK (ID=1)
                        TSM:FPAR
                        TSP:MSG:ÓEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                        TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        TSP:MSG:FPAR RES (IÄ=0, dist=0)
                        TSP:MSG:PAR OK (ÉD=0, dist=1)
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:CHKID:OË (ID=1)
                        TSM:UPL
                        TSP:PING:SEND (dest=0)
                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                        TSP:CHKUPL:FAIL (hops=255)
                        !TSM:UPL:FAIÌ
                        TSM:FPAR
                        TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                        TSP:MSG:READ 2-2-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                        TSP:MSG:BC
                        TSP:MSG:ÒEAD 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        ÔSP:MSG:FPAR RES (ID=0, dist=0)
                        TSP:MSG:PAR OK (ID=0, diót=1)
                        TSM:ÆPAR:OK
                          Samuel235
                          #150
                          How do we go about compiling this for 8MHz crystal (Internal and External), i'm sure this has already been asked but I can't seem to search through this post very efficiently... Sorry if it has been covered already, just a link back or something would probably suit me if it has been :)
                          MySensors 2.1.1
                          • R
                            R
                            romeo01
                            wrote on last edited by romeo01
                            #151
                            Nice job, the last bootloader seems to run in good conditions.
                            I use MySensors 2.2.0 beta, MYSController 1.0.0 (3314) and the last version MYSbootloader 1.3.0-beta.4 (https://github.com/mysensors/MySensorsBootloaderRF24)
                            Update, flash, firmware via OTA is ok.
                            But 1 problem occurs when a node reboot.
                            I tried to isolate the problem, so I think that's arround the presentation request.
                            When I click on "request presentation", I got it
                            http://hpics.li/93e8861
                            and below the debug output (via serial) of the node
                            70437 TSF:MSG:READ,0-0-1,s=0,c=3,t=19,pt=0,l=1,sg=0:0
                            70445 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                            70453 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            70460 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                            70469 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                            70497 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                            70504 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:OTA Test
                            70512 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=1,sg=0,ft=0,st=OK:1
                            70521 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Sensor 1
                            Maybe a bug or where is the mistake ?
                            Thanks in advance foryour help
                            Edit: After a couple of test, the problem is related to the gateway with MySensor Library version 2.2.0 beta.
                            All nodes (2.1.1 & 2.2.0 libs) from my network present the same error.
                            Probably a vartype unexpected by the Gateway (2.2.0 lib).
                            The serial Gateway (2.1.1) is ok
                            • Nicolas CharrierN Nicolas Charrier
                              Hello
                              ahmedadelhosniA
                              ahmedadelhosniA
                              ahmedadelhosni
                              @Nicolas-Charrier
                              Hello @tekka , I have the same problem.
                              I am trying to set up my Serial Gateway. I flashed the OTA bootloader but how can I upload the Gateway sketch through Serial ?
                              I tried to use the MySysController but the node is not presented so that I can flash new firware with the Gateway sketch. It only worked when I flashed normal Optiboot bootloader and then flashed the Serial Gateway sketch through Serial, then I connected the Gateway to the Controller and the presentation worked well. Thus I now have a Gateway which I can flash other nodes with through OTA.
                              Is there another way to flash a gateway sketch other than this ?
                                @Nicolas-Charrier
                                tekkaT
                                tekkaT
                                tekka
                                @ahmedadelhosni Why would you want to flash MYSBootloader on your GW? OTA FW update capabilities only make sense on sensor nodes...
                                • tekkaT tekka
                                  ahmedadelhosniA
                                  ahmedadelhosniA
                                  ahmedadelhosni
                                  @tekka I just thought that if I flashed a bootloader on a new hardware IC then I can decide whether to flash GW or sensor node when connected to the serial computer.
                                  • K
                                    K
                                    ksya
                                    I see that after compiling I get to choose between sketch.ino.hex and sketch.ino.with_bootloader.hex
                                    Is it possible to update the bootloader OTA by using this hex file instead? Which is the best bootloader available now, because my nodes are now on 1.3pre (from topic start).
                                    • I
                                      I
                                      itbeyond
                                      How does GW mode actually work - I have been trying to relay a connection to Vera but not matter what combination I am trying I cannot understand how the GW mode operates?
                                      • petewillP
                                        petewillP
                                        petewill
                                        @itbeyond Have you opened up your firewall so the Vera can communicate with the computer running MYSController?
                                        Here is how I have MYSContoller configured...
                                        First, connect MYSController to your existing gateway (if you are using Ethernet
                                        you only want one device to connect so don't have your Vera connected at the same time)
                                        0_1510582509499_upload-28bab7f1-4863-41bc-a749-179cb82ecf6c
                                        Once you do that you need to choose a port in the settings:
                                        0_1510582093482_upload-14ac4c29-1501-49ea-b0c5-d7503a02b769
                                        Then you press Connect (to connect to the actual Ethernet or Serial gateway).
                                        Once connected turn on GW Mode (mine is grayed out because I'm not at home connected to my gateway):
                                        0_1510582137860_upload-dd16413a-ef4c-4c1f-9dd9-7377f5090ed5
                                        In your Vera you would obviously want to connect to the IP address of the computer running MYSController
                                        0_1510582624549_upload-5296052c-b9b0-446b-b089-259b375d11e9
                                        I 1 Reply Last reply
                                        • karlheinz2000K
                                          karlheinz2000K
                                          karlheinz2000
                                          I have problems connecting a serial NRF24 gateway to MYSController b3314. After some minutes working properly, no more messages seem to get received by MYSController. If I disconnect and connect again (button, not USB), it works for about the same time until it stops again.
                                          I put a second USB2serial in parallel and connected a terminal program (hterm). The terminal programm continuously receives messages, even when MYSController stops receiving. So it's no gateway issue.
                                          I tried several different USB2serial adapter with MYSController - no difference.
                                          Any idea how to get MYSController to work continuously ?
