  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 66.3k Views 21 Watching
    SdeWeb
    wrote on last edited by SdeWeb
    Well done finally i used the dedicated .fex file for Orange Pi Plus 2E here :
    https://linux-sunxi.org/Xunlong_Orange_Pi_Plus_2E#Expansion_Port
    at this point :
    https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepiplus2e.fex
    Read the .fex file in a text editor, u'll see important things about "gpio_config" for H3 cpu :
    ; NOTE: This section is necessary only for "gpio_sunxi" driver
    ; which is obsolete for H3 boards
    [gpio_para]
    gpio_used = 0
    gpio_num = 0
    I connected my NRF24L01 on OPI P2E like this :
    NRF24L01 Port Name / (Pin N°) ----- OPI Port (Pin N°) / Name
                          GND (1)  <-----------> (20) / GND
                          VCC (2)  <-----------> (17) / 3.3V PWR
                          CE (3)   <-----------> (22) / (PA2 / GPIO2)
                          CSN (4)  <-----------> (24) / (PC3 / GPIO67)
                          SCK (5)  <-----------> (23)
                          MOSI (6) <-----------> (19) MOSI
                          MISO (7) <-----------> (21) MISO
                          IRQ (8)  <-----------> NC
    So "MySensors" setup is :
    ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
    Then
    ./bin/mysgw -d
    Return :
    root@orangepiplus2e:~/MySensors# ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    Best.
    Seb.
    E 1 Reply Last reply
    • W Wascht'l
      would it be possible to add the wiring for the RS485-Modules, please?
      will it be similar to the Raspberry Pi?
      Thank you. Waschtl.
      SdeWeb
      @Wascht'l Hi,
      Take a look here, to get some idea :
      https://fr.pinout.xyz/pinout/rs485_pi#
      Regards.
      • R
        R
        Reza
        wrote on last edited by Reza
        i have problem :/
        what about this :
        root@orangepione:~/MySensors# ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
         -bash: ./configure: Permission denied
        • R Reza
          i have problem :/
          what about this :
          Tag
          wrote on last edited by Tag
          @Reza
          Seems your ./configure script is not executable... try:
          chmod 755 ./configure
          R 1 Reply Last reply
          • T Tag
            @Reza
            R
            R
            Reza
            @Tag
            root@orangepione:~/MySensors# chmod 755 ./configure
            root@orangepione:~/MySensors# chmod 755 ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
            chmod: unrecognized option '--spi-spidev-device=/dev/spidev1.0'
            Try 'chmod --help' for more information.
            S 1 Reply Last reply
            • R Reza
              @Tag
              SdeWeb
              @Reza
              after "chmoded" the file you don't need anymore chmod command, run directly ./configure .
              Regards
              • S SdeWeb
                @Reza
                Regards
                R
                R
                Reza
                @SdeWeb thank you . this is ok
                • R
                  R
                  Reza
                  can i add this lines ? for orangepi ?
                  #define MY_RF24_CHANNEL 0
                  but after add i have problem :
                  root@orangepione:~/MySensors# make
                  gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                  g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                  g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                  g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                  g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                  g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                  g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                  g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                  g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                  g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                  g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                  In file included from examples_linux/mysgw.cpp:73:0:
                  ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                                   from ./MySensors.h:294,
                  compilation terminated.
                  T S 2 Replies Last reply
                  • R Reza
                    Tag
                    #24
                    @Reza
                    Are you sure your git environment is okay?
                    Maybe do a fresh git pull for mysensors?
                    See the howto on the orangePI page just follow from the start.... I have serious questions that your env is correct since configure was not executable....
                    • T Tag
                      @Reza
                      R
                      R
                      Reza
                      @Tag i use same files that use for raspberry. for raspberry worked. is this different between mysensors for raspberry and orange? i must download again ?
                      • R Reza
                        SdeWeb
                        @Reza <- Yes do all the procedure from the beginning :
                        https://www.mysensors.org/build/orange
                        • R Reza
                          Tag
                          #27
                          @Reza
                          You must use the OrangePI instructions, these are different conmpared to the RaspberryPI instructions
                          Thx SdeWeb!, same toughts!! :)
                          • S SdeWeb
                            R
                            R
                            Reza
                            @SdeWeb i do all steps that is orangepi page. but just i dont run this :
                            and copy this files from flash memory . is this incorrect ?
                            S T 2 Replies Last reply
                            • R Reza
                              SdeWeb
                              @Reza Bad idea :-( , wich OS are you using on your Orange PI ?
                              • R Reza
                                Tag
                                @Reza
                                I got this working like a charm on armbian( Debian Jessie) https://www.armbian.com/orange-pi-zero/
                                But you need to follow ALL steps........
                                Which OrangePI board do you use?
                                • S SdeWeb
                                  R
                                  R
                                  Reza
                                  @SdeWeb
                                  armbian for orangepi one
                                  now i add this line :
                                  so i think ok but :
                                  gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                  g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                  g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                                  g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                  g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                  g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                  g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                  g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                  g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                  g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                                  g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                                  g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                  g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                  g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                  examples_linux/mysgw.cpp:31:0: warning: "MY_RADIO_NRF24" redefined
                                  <command-line>:0:0: note: this is the location of the previous definition
                                  g++ -MT build/drivers/SPIDEV/SPI.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/SPIDEV/SPI.cpp -o build/drivers/SPIDEV/SPI.o
                                  g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/IPAddress.o build/drivers/Linux/compatibility.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o  build/drivers/SPIDEV/SPI.o
                                  root@orangepione:~/MySensors# sudo ./bin/mysgw -d
                                  mysgw: Config file /etc/mysensors.dat does not exist, creating new config file.
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: !TSM:INIT:TSP FAIL
                                  mysgw: TSM:FAIL:CNT=1
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:FAIL:RE-INIT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:CNT=2
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:CNT=3
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:CNT=4
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:CNT=5
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:CNT=6
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:CNT=7
                                  mysgw: TSM:FAIL:PDT
                                  • R Reza
                                    @SdeWeb
                                    so i think ok but :
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:PDT
                                    Tag
                                    @Reza
                                    Seems you are not able to communicate with your radio..... you need to figure out which GPIO pins you need to use, and which SPI channel.....
                                    The steps from the OrangePI page are based on the OrangePI zero model
                                    • R Reza
                                      @SdeWeb
                                      so i think ok but :
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: TSM:FAIL:PDT
                                      mysgw: TSM:INIT
                                      mysgw: TSM:FAIL:PDT
                                      mysgw: TSM:INIT
                                      mysgw: TSM:FAIL:PDT
                                      mysgw: TSM:INIT
                                      mysgw: TSM:FAIL:PDT
                                      mysgw: TSM:INIT
                                      mysgw: TSM:FAIL:PDT
                                      mysgw: TSM:INIT
                                      mysgw: TSM:FAIL:PDT
                                      mysgw: TSM:INIT
                                      mysgw: TSM:FAIL:PDT
                                      SdeWeb
                                      @Reza
                                      Your GW is OK, so exit debug mode by use Ctrl + C command, then follow the end of the procedure to install and auto start GW services.
                                      Regards.
                                      • T Tag
                                        @Reza
                                        R
                                        R
                                        Reza
                                        #34
                                        @Tag i am using similar to zero . i dont know how configure GPIO for orange pi one :(
                                        i thought orange one is similar to zero for configure....
                                        • S SdeWeb
                                          @Reza
                                          Regards.
                                          R
                                          R
                                          Reza
                                          @SdeWeb so now my problem is related to GPIO and configure this ? can you help me that how i can configure this ?
