  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 66.0k Views 21 Watching
  • pansenP pansen
    @marceloaqno: ok so here are my conclusions:
    After going through the schematics of the OPi Plus2e I realized that the H3 has dedicated pins for NAND/eMMC, which is probably not the case for the H2+ in the OPi zero. They used the pins of SPI1 for a status LED and a "MUTE" net, which is not connected anywhere so at first I was like "wtf?"...
    So, the SPI0 is free for usage out of the box and the .fex does not need to be modified. Summed up:
    If the OPi to be used has "SPI0" in the GPIO header, no .fex modifications are necessary. CE and CN/CS/CSN pin can be chosen freely (?), I picked it like this:
    ce - gray - pa13 - PHYSICAL pin8 - LOGICAL pin13 (1-1)*32 + 13
    cn - blue - pa14 - PHYSICAL pin10 - LOGICAL pin14 (1-1)*32 + 14
    If another pin is chosen, the pin number can be calculated with that formula: (position of letter in alphabet - 1) * 32 + pin number (from: https://linux-sunxi.org/GPIO)
    The pinout of the connector can be found here: https://linux-sunxi.org/Xunlong_Orange_Pi_Plus_2E#Expansion_Port (SPI0 pins are PC0-PC2 or 19,21,23)
    After connecting the physical pins 8,10,19,21 and 23 to the nrf24 (and pin 1 for 3.3v), following command was sufficient to set up mysgw and get the nrf24 to respond:
    ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=13 --my-rf24-cs-pin=14
    SdeWeb
    wrote on last edited by SdeWeb
    @pansen Hi, Please could you confirm your pin connection beetween NRF24L01 and the Opi Plus2E, il followed your setup inctruction (no .fex modification and your specific ./configure), but mine don't work, i got this error "mysgw: Could not open /sys/class/gpio/gpio13/direction".
    I connected my NRF24L01 on OPI P2E like this :
    • NRF Port Name / (N°) ------- OPI Port (N°) / Name
      • GND (1) <------------> (6) GND
      • VCC (2) <------------> (17) 3.3V PWR
      • CE (3) <---------------> (8)
      • CSN (4) <------------> (10)
      • SCK (5) <-------------> (23)
      • MOSI (6) <-----------> (19) MOSI
      • MISO (7) <-----------> (21) MISO
      • IRQ (8) <---------------> NC
    Seb.
    • pansenP
      pansenP
      pansen
      Hi @SdeWeb header pins 8 and 10 are used by some other hardware (SPI1, UART3) which might need to be deactivated in the .fex in your system, for me it worked straight away so that would be weird..just check the .fex if SPI1 and UART3 are indeed disabled.
      It looks like the definitions for the GPIO are faulty, you could try a LED test to see if they work at all. If the problem persists rather open a topic in the Development sub forum 8) Or, pick another GPIO, for example header pins 14 and 16.
      Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
      • W
        W
        Wascht'l
        would it be possible to add the wiring for the RS485-Modules, please?
        will it be similar to the Raspberry Pi?
        Thank you. Waschtl.
        S 1 Reply Last reply
          SdeWeb
          Well done finally i used the dedicated .fex file for Orange Pi Plus 2E here :
          at this point :
          https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepiplus2e.fex
          Read the .fex file in a text editor, u'll see important things about "gpio_config" for H3 cpu :
          ; NOTE: This section is necessary only for "gpio_sunxi" driver
          ; which is obsolete for H3 boards
          [gpio_para]
          gpio_used = 0
          gpio_num = 0
          NRF24L01 Port Name / (Pin N°) ----- OPI Port (Pin N°) / Name
                                GND (1)  <-----------> (20) / GND
                                VCC (2)  <-----------> (17) / 3.3V PWR
                                CE (3)   <-----------> (22) / (PA2 / GPIO2)
                                CSN (4)  <-----------> (24) / (PC3 / GPIO67)
                                SCK (5)  <-----------> (23)
                                IRQ (8)  <-----------> NC
          So "MySensors" setup is :
          ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
          Then
          ./bin/mysgw -d
          Return :
          root@orangepiplus2e:~/MySensors# ./bin/mysgw -d
          mysgw: Starting gateway...
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:INIT:TSP OK
          mysgw: TSM:INIT:GW MODE
          mysgw: MCO:REG:NOT NEEDED
          mysgw: MCO:BGN:STP
          mysgw: MCO:BGN:INIT OK,TSP=1
          Best.
          Seb.
          E 1 Reply Last reply
          • W Wascht'l
            Thank you. Waschtl.
            SdeWeb
            @Wascht'l Hi,
            Take a look here, to get some idea :
            https://fr.pinout.xyz/pinout/rs485_pi#
            Regards.
            • R
              R
              Reza
              wrote on last edited by Reza
              i have problem :/
              what about this :
              root@orangepione:~/MySensors# ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
               -bash: ./configure: Permission denied
              • R Reza
                i have problem :/
                what about this :
                Tag
                wrote on last edited by Tag
                @Reza
                Seems your ./configure script is not executable... try:
                chmod 755 ./configure
                R 1 Reply Last reply
                • T Tag
                  @Reza
                  R
                  R
                  Reza
                  @Tag
                  root@orangepione:~/MySensors# chmod 755 ./configure
                  root@orangepione:~/MySensors# chmod 755 ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
                  chmod: unrecognized option '--spi-spidev-device=/dev/spidev1.0'
                  Try 'chmod --help' for more information.
                  • R Reza
                    @Tag
                    SdeWeb
                    @Reza
                    after "chmoded" the file you don't need anymore chmod command, run directly ./configure .
                    Regards
                    • S SdeWeb
                      @Reza
                      Regards
                      R
                      R
                      Reza
                      @SdeWeb thank you . this is ok
                      • R
                        R
                        Reza
                        can i add this lines ? for orangepi ?
                        #define MY_RF24_CHANNEL 0
                        but after add i have problem :
                        root@orangepione:~/MySensors# make
                        gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                        g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                        g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                        g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                        g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                        g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                        g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                        g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                        g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                        g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                        g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                        In file included from examples_linux/mysgw.cpp:73:0:
                        ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                                         from ./MySensors.h:294,
                        compilation terminated.
                        T S 2 Replies Last reply
                        • R Reza
                          Tag
                          #24
                          @Reza
                          Are you sure your git environment is okay?
                          Maybe do a fresh git pull for mysensors?
                          See the howto on the orangePI page just follow from the start.... I have serious questions that your env is correct since configure was not executable....
                          • T Tag
                            @Reza
                            R
                            R
                            Reza
                            @Tag i use same files that use for raspberry. for raspberry worked. is this different between mysensors for raspberry and orange? i must download again ?
                            • R Reza
                              SdeWeb
                              @Reza <- Yes do all the procedure from the beginning :
                              https://www.mysensors.org/build/orange
                              • R Reza
                                Tag
                                #27
                                @Reza
                                You must use the OrangePI instructions, these are different conmpared to the RaspberryPI instructions
                                Thx SdeWeb!, same toughts!! :)
                                • S SdeWeb
                                  R
                                  R
                                  Reza
                                  @SdeWeb i do all steps that is orangepi page. but just i dont run this :
                                  and copy this files from flash memory . is this incorrect ?
                                  S T 2 Replies Last reply
                                  • R Reza
                                    SdeWeb
                                    @Reza Bad idea :-( , wich OS are you using on your Orange PI ?
                                    • R Reza
                                      Tag
                                      @Reza
                                      I got this working like a charm on armbian( Debian Jessie) https://www.armbian.com/orange-pi-zero/
                                      But you need to follow ALL steps........
                                      Which OrangePI board do you use?
                                      • S SdeWeb
                                        R
                                        R
                                        Reza
                                        @SdeWeb
                                        armbian for orangepi one
                                        now i add this line :
                                        so i think ok but :
                                        gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                        g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                        g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                                        g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                        g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                        g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                        g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                        g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                        g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                        g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                                        g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                                        g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                        g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                        g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                        examples_linux/mysgw.cpp:31:0: warning: "MY_RADIO_NRF24" redefined
                                        <command-line>:0:0: note: this is the location of the previous definition
                                        g++ -MT build/drivers/SPIDEV/SPI.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/SPIDEV/SPI.cpp -o build/drivers/SPIDEV/SPI.o
                                        g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/IPAddress.o build/drivers/Linux/compatibility.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o  build/drivers/SPIDEV/SPI.o
                                        root@orangepione:~/MySensors# sudo ./bin/mysgw -d
                                        mysgw: Config file /etc/mysensors.dat does not exist, creating new config file.
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: !TSM:INIT:TSP FAIL
                                        mysgw: TSM:FAIL:CNT=1
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:FAIL:RE-INIT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:CNT=2
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:CNT=3
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:CNT=4
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:CNT=5
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:CNT=6
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:CNT=7
                                        mysgw: TSM:FAIL:PDT
                                        • R Reza
                                          @SdeWeb
                                          so i think ok but :
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:PDT
                                          Tag
                                          @Reza
                                          Seems you are not able to communicate with your radio..... you need to figure out which GPIO pins you need to use, and which SPI channel.....
                                          The steps from the OrangePI page are based on the OrangePI zero model
