  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 66.0k Views 21 Watching
  • YveauxY
    @marceloaqno Great job man!
    Looking at the radio connection, there is a 5V -> 3V3 conversion layed out.
    The Pi Zero Schematics sheet 7-D1, 7-B5 and 11-D4 indicate VCC3V3-EXT is present on pin 1 of the IO connector and internally connected to VCC-IO, which can supply 1A @ 3V3.
    Don't you think there is enough margin to supply the nRF24 directly from VCC3V3-EXT?
    • YveauxY Yveaux
      marceloaqno
      Code Contributor
      @Yveaux Yes, more than enough :smile: . Thanks and thanks for pointing that out.
        i've not checked yet, i miss time for trying the linux port :blush: but i'm curious to know if this power supply would be noisy..which may need a ferrite and capas, else radio could have a bad snr and less range/sensitiviy. Maybe i'm wrong.. i'll try to scope when i'll have some time, or if i remember about it lol!
        • pansenP pansen
          @marceloaqno: ok so here are my conclusions:
          After going through the schematics of the OPi Plus2e I realized that the H3 has dedicated pins for NAND/eMMC, which is probably not the case for the H2+ in the OPi zero. They used the pins of SPI1 for a status LED and a "MUTE" net, which is not connected anywhere so at first I was like "wtf?"...
          So, the SPI0 is free for usage out of the box and the .fex does not need to be modified. Summed up:
          If the OPi to be used has "SPI0" in the GPIO header, no .fex modifications are necessary. CE and CN/CS/CSN pin can be chosen freely (?), I picked it like this:
          ce - gray - pa13 - PHYSICAL pin8 - LOGICAL pin13 (1-1)*32 + 13
          cn - blue - pa14 - PHYSICAL pin10 - LOGICAL pin14 (1-1)*32 + 14
          If another pin is chosen, the pin number can be calculated with that formula: (position of letter in alphabet - 1) * 32 + pin number (from: https://linux-sunxi.org/GPIO)
          The pinout of the connector can be found here: https://linux-sunxi.org/Xunlong_Orange_Pi_Plus_2E#Expansion_Port (SPI0 pins are PC0-PC2 or 19,21,23)
          After connecting the physical pins 8,10,19,21 and 23 to the nrf24 (and pin 1 for 3.3v), following command was sufficient to set up mysgw and get the nrf24 to respond:
          ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=13 --my-rf24-cs-pin=14
          SdeWeb
          wrote on last edited by SdeWeb
          @pansen Hi, Please could you confirm your pin connection beetween NRF24L01 and the Opi Plus2E, il followed your setup inctruction (no .fex modification and your specific ./configure), but mine don't work, i got this error "mysgw: Could not open /sys/class/gpio/gpio13/direction".
          I connected my NRF24L01 on OPI P2E like this :
          • NRF Port Name / (N°) ------- OPI Port (N°) / Name
            • GND (1) <------------> (6) GND
            • VCC (2) <------------> (17) 3.3V PWR
            • CE (3) <---------------> (8)
            • CSN (4) <------------> (10)
            • SCK (5) <-------------> (23)
            • MOSI (6) <-----------> (19) MOSI
            • MISO (7) <-----------> (21) MISO
            • IRQ (8) <---------------> NC
          Seb.
          • pansenP
            pansenP
            pansen
            Hi @SdeWeb header pins 8 and 10 are used by some other hardware (SPI1, UART3) which might need to be deactivated in the .fex in your system, for me it worked straight away so that would be weird..just check the .fex if SPI1 and UART3 are indeed disabled.
            It looks like the definitions for the GPIO are faulty, you could try a LED test to see if they work at all. If the problem persists rather open a topic in the Development sub forum 8) Or, pick another GPIO, for example header pins 14 and 16.
            Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
            • W
              W
              Wascht'l
              would it be possible to add the wiring for the RS485-Modules, please?
              will it be similar to the Raspberry Pi?
              Thank you. Waschtl.
              S 1 Reply Last reply
                SdeWeb
                Well done finally i used the dedicated .fex file for Orange Pi Plus 2E here :
                at this point :
                https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepiplus2e.fex
                Read the .fex file in a text editor, u'll see important things about "gpio_config" for H3 cpu :
                ; NOTE: This section is necessary only for "gpio_sunxi" driver
                ; which is obsolete for H3 boards
                [gpio_para]
                gpio_used = 0
                gpio_num = 0
                NRF24L01 Port Name / (Pin N°) ----- OPI Port (Pin N°) / Name
                                      GND (1)  <-----------> (20) / GND
                                      VCC (2)  <-----------> (17) / 3.3V PWR
                                      CE (3)   <-----------> (22) / (PA2 / GPIO2)
                                      CSN (4)  <-----------> (24) / (PC3 / GPIO67)
                                      SCK (5)  <-----------> (23)
                                      IRQ (8)  <-----------> NC
                So "MySensors" setup is :
                ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
                Then
                ./bin/mysgw -d
                Return :
                root@orangepiplus2e:~/MySensors# ./bin/mysgw -d
                mysgw: Starting gateway...
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: TSM:INIT:TSP OK
                mysgw: TSM:INIT:GW MODE
                mysgw: MCO:REG:NOT NEEDED
                mysgw: MCO:BGN:STP
                mysgw: MCO:BGN:INIT OK,TSP=1
                Best.
                Seb.
                E 1 Reply Last reply
                • W Wascht'l
                  Thank you. Waschtl.
                  SdeWeb
                  @Wascht'l Hi,
                  Take a look here, to get some idea :
                  https://fr.pinout.xyz/pinout/rs485_pi#
                  Regards.
                  • R
                    R
                    Reza
                    wrote on last edited by Reza
                    i have problem :/
                    what about this :
                    root@orangepione:~/MySensors# ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
                     -bash: ./configure: Permission denied
                    • R Reza
                      i have problem :/
                      what about this :
                      Tag
                      wrote on last edited by Tag
                      @Reza
                      Seems your ./configure script is not executable... try:
                      chmod 755 ./configure
                      R 1 Reply Last reply
                      • T Tag
                        @Reza
                        R
                        R
                        Reza
                        @Tag
                        root@orangepione:~/MySensors# chmod 755 ./configure
                        root@orangepione:~/MySensors# chmod 755 ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
                        chmod: unrecognized option '--spi-spidev-device=/dev/spidev1.0'
                        Try 'chmod --help' for more information.
                        • R Reza
                          @Tag
                          SdeWeb
                          @Reza
                          after "chmoded" the file you don't need anymore chmod command, run directly ./configure .
                          Regards
                          • S SdeWeb
                            @Reza
                            Regards
                            R
                            R
                            Reza
                            @SdeWeb thank you . this is ok
                            • R
                              R
                              Reza
                              can i add this lines ? for orangepi ?
                              #define MY_RF24_CHANNEL 0
                              but after add i have problem :
                              root@orangepione:~/MySensors# make
                              gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                              g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                              g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                              g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                              g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                              g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                              g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                              g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                              g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                              g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                              g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                              In file included from examples_linux/mysgw.cpp:73:0:
                              ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                                               from ./MySensors.h:294,
                              compilation terminated.
                              T S 2 Replies Last reply
                              • R Reza
                                Tag
                                #24
                                @Reza
                                Are you sure your git environment is okay?
                                Maybe do a fresh git pull for mysensors?
                                See the howto on the orangePI page just follow from the start.... I have serious questions that your env is correct since configure was not executable....
                                • T Tag
                                  @Reza
                                  R
                                  R
                                  Reza
                                  @Tag i use same files that use for raspberry. for raspberry worked. is this different between mysensors for raspberry and orange? i must download again ?
                                  • R Reza
                                    SdeWeb
                                    @Reza <- Yes do all the procedure from the beginning :
                                    https://www.mysensors.org/build/orange
                                    • R Reza
                                      Tag
                                      #27
                                      @Reza
                                      You must use the OrangePI instructions, these are different conmpared to the RaspberryPI instructions
                                      Thx SdeWeb!, same toughts!! :)
                                      • S SdeWeb
                                        R
                                        R
                                        Reza
                                        @SdeWeb i do all steps that is orangepi page. but just i dont run this :
                                        and copy this files from flash memory . is this incorrect ?
                                        S T 2 Replies Last reply
                                        • R Reza
                                          SdeWeb
                                          @Reza Bad idea :-( , wich OS are you using on your Orange PI ?
