Atmega328+rfm69HW sleep mode problem
i have a problem with atmega328p + rfm69hw. I have bootloader with bod disable for 8 mhz internal. The problem is not run in power mode when i wire rf69 to atmega with sketch lowpowerlab, radiohead, etc consumption near 5 mAh, but if upload simple sketch in atmega with avr/sleep library without rfm69 consumption is 30 uAh .What is the proble for you? The output pin 11 is HIGH when use sketch example lowpowerlab etc library!!!!
I recently discovered the same problem in my design and after weeks of debugging I found out that I was using the wrong flux. So my first guess here: have you double checked the wiring?
Have you switched the RFM69 module? -
Hello.
It depends. You don't give enough informations:
- hardware? 328p standalone with custom board, the circuit? arduino mini, hacked ? ..
- Measurement? how do you measure power consumption? multimeter only, not the most precise, uCurrent Gold ? ..
- software? what's your sketch? are you using Mysensors? have you tried Gammon sketch "J" ? ..
you should be able to get a few uA. Without any lib, i already got that; 140nA for 328p, <1uA rfm69 in sleep mode..
Side note : you don't need to create two topics, Mysensors is an active community ;)
Hello.
if you follow gammon howto for connecting 328p on breadboard, + sketch J, without the radio you should get 140nA.
why do you want to use lowpower lib? you can try gammon low power sketch for testing if your hardware is ok, then move to mysensors.
For your PIR, i don't know it depends of your module. i use custom made stuff so..
Maybe the 20uA is due to imprecision of voltmeter only, not sure, i use an uCurrent. -
it is not recommended to disable bod in fuses (better set it to 1.8v)
It's better to disable it by software in sleep function like in Mysensors sleep, or gammon sketch.
you can use MYSbootloader or Sensebender Micro bootloader, lowpowerlab dualoptiboot etc..
or this link too https://www.mysensors.org/about/bootloader -
