  3. About DS18B20 onewire.
dallasone wireonewireds18b20
48 Posts 5 Posters 18.7k Views 10 Watching
  • F
    F
    flopp
    1. Anyone know how many ds18b20 you can connect to a MySensors sketch?
      This sketch saying maximum 16, https://www.mysensors.org/build/temp.
    2. Lets say you have 3 sensors and sending them to e.g. Domoticz.
      Sensor A=15 °C
      Sensor B=25 °C
      Sensor C=35 °C
      If I understand the sketch correct, it will first search for connected sensors and then send one by one to Controller.
      I will create a Device called "A" in Controller and will receive value from sensor A to Device A, same for B and C.
      What happen if sensor B fails or I disconnect it.
      Will sensor C be the new sensor B?
    • F
      F
      flopp
      I have now tested this and the answer is YES, if B disconnects C will be the new B
      • F
        F
        flopp
        wrote on last edited by flopp
        I have modify the sketch so now if sensor B is disconnected A will be A and C will be C, as soon as B is connected again it will send the values again.
         * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
         * http://www.mysensors.org/build/temp
        #include <OneWire.h>
        #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
        unsigned long SLEEP_TIME = 3000; // Sleep time between reads (in milliseconds)
        byte D[3][8] = {
        { 0x28, 0xB1, 0x47, 0xB4, 0x04, 0x00, 0x00, 0x97 },
        { 0x28, 0xFF, 0x53, 0x78, 0x63, 0x15, 0x02, 0xC9 },
        { 0x28, 0xFF, 0xCD, 0x06, 0x52, 0x04, 0x00, 0x80 }
        int numSensors=0;
        boolean receivedConfig = false;
        boolean metric = true;
        MyMessage msg(0,V_TEMP);
          sensors.begin();
          // Startup and initialize MySensors library. Set callback for incoming messages.
          gw.begin();
          gw.sendSketchInfo("Temperature Sensor", "1.1");
          //numSensors = sensors.getDeviceCount();
          for (int i=0; i<3 && i<MAX_ATTACHED_DS18B20; i++) {
             gw.present(i, S_TEMP);
        Serial.println(millis());
          // Process incoming messages (like config from server)
          gw.sleep(conversionTime);
         //   float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
              float temperature = sensors.getTempC(D[i]);
            #if COMPARE_TEMP == 1
              gw.send(msg.setSensor(i).set(temperature,1));
          //gw.sleep(SLEEP_TIME);
        first you need to use this sketch to get the correct addresses for all your DS18B20
        // OneWire DS18S20, DS18B20, DS1822 Temperature Example
        // http://www.pjrc.com/teensy/td_libs_OneWire.html
        // The DallasTemperature library can do all this work for you!
        // http://milesburton.com/Dallas_Temperature_Control_Library
        OneWire  ds(3);  // on pin 10 (a 4.7K resistor is necessary)
        int count=0;
        void setup(void) {
          Serial.begin(9600);
        void loop(void) {
          byte i;
          byte present = 0;
          byte type_s;
          byte data[12];
          byte addr[8];
          float celsius;
          if ( !ds.search(addr)) {
            //Serial.println("No more addresses.");
            Serial.println();
            ds.reset_search();
            delay(250);
            Serial.println(count);
            Serial.println();
            count=0;
            return;
          //Serial.print("ROM =");
          Serial.print("{");
          for( i = 0; i < 8; i++) {
          Serial.print(" 0x");
            //Serial.write(' ');
            //int a = (addr[i], DEC);
            //Serial.print(a);
            if (addr[i] <= 15){
              Serial.print("0");
            Serial.print(addr[i], HEX);
            if (i < 7){
              Serial.print(",");
            Serial.print(" },");
          if (OneWire::crc8(addr, 7) != addr[7]) {
              Serial.println("CRC is not valid!");
              return;
          Serial.println();
          // the first ROM byte indicates which chip
          switch (addr[0]) {
            case 0x10:
              //Serial.println("  Chip = DS18S20");  // or old DS1820
              type_s = 1;
            case 0x28:
              //Serial.println("  Chip = DS18B20");
              type_s = 0;
            case 0x22:
              //Serial.println("  Chip = DS1822");
              type_s = 0;
            default:
              //Serial.println("Device is not a DS18x20 family device.");
              return;
          ds.reset();
          ds.select(addr);
          ds.write(0x44, 1);        // start conversion, with parasite power on at the end
          delay(1000);     // maybe 750ms is enough, maybe not
          // we might do a ds.depower() here, but the reset will take care of it.
          present = ds.reset();
          ds.select(addr);
          ds.write(0xBE);         // Read Scratchpad
          //Serial.print("  Data = ");
          //Serial.print(present, HEX);
          //Serial.print(" ");
          for ( i = 0; i < 9; i++) {           // we need 9 bytes
            data[i] = ds.read();
            //Serial.print(data[i], HEX);
          //Serial.print(" CRC=");
          //Serial.print(OneWire::crc8(data, 8), HEX);
          //Serial.println();
          // Convert the data to actual temperature
          // because the result is a 16 bit signed integer, it should
          // be stored to an "int16_t" type, which is always 16 bits
          // even when compiled on a 32 bit processor.
          int16_t raw = (data[1] << 8) | data[0];
          if (type_s) {
            raw = raw << 3; // 9 bit resolution default
            if (data[7] == 0x10) {
              // "count remain" gives full 12 bit resolution
              raw = (raw & 0xFFF0) + 12 - data[6];
            byte cfg = (data[4] & 0x60);
            // at lower res, the low bits are undefined, so let's zero them
            if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
            else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
            else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
            //// default is 12 bit resolution, 750 ms conversion time
          celsius = (float)raw / 16.0;
          //Serial.print("  Temperature = ");
          //Serial.print(celsius);
          //Serial.println(" Celsius, ");
          count++;
        you will get the address like this format
        pepsonP 1 Reply Last reply
        • F
          F
          flopp
          it takes about 80 ms for each sensor that you add
          • F
            F
            flopp
            My test has been running now for 4 days now and it works perfect. Of course it is the same sketch that MySensors is using but I have modified it a little bit.
            • F
              F
              flopp
              First test with 3 temps is still OK.
              Second test is with 9 temps is still OK.
              • F
                F
                flopp
                I have now 2 nodes, one with 27 temps, second with 17 temps.
                working with out problems since I started them 1 weeks ago
                I had some problem when adding more sensors, some of them seems not to work together that is why I have 2 nodes
                • T
                  tomasandersson
                  How can I get this to work with 2.0 or 2.1.1
                  I would so much have to help because I am a beginner
                  rejoe2R 1 Reply Last reply
                  • T tomasandersson
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @tomasandersson Did some work wrt. this some time ago, sketches for MySensors 2.0+ are available here: https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency.
                    Easiest to use may be the "stored id"-Version, based on a concept of leodesigner. This is designed für max. 20 DS18x20.
                    • rejoe2R rejoe2
                      tomasandersson
                      @rejoe2
                      I have now tried the stored ID "version and it works much better than the previous.
                      I still get the wrong values sometimes. Wonder if there is control domoticz which mixes the ID.
                      • T tomasandersson
                        @rejoe2
                        rejoe2R
                        rejoe2R
                        rejoe2
                        @tomasandersson I really doubt the controller to mix things up, nor the node doing so.
                        What are the absolute values of the measured temperatures? The "faulty" values seem to be more or less identical, so this could indicate powering problems or may be related to cabeling or resistor size. Did you stick to the 30 seconds intervall or something else?
                        Normally 750ms for conversion should be enought, but official (according to datasheet) seem to be a little longer, so trying to change line 69 may help: conversionTime = 1000 / (1 << (12 - resolution));).
                        • rejoe2R rejoe2
                          tomasandersson
                          @rejoe2
                          I will try to change.
                          Here is a picture where you see that the sensor ID picks temperature of another sensor0_1490096020397_Skärmavbild 2017-03-21 kl. 12.31.12.png
                          • T tomasandersson
                            @rejoe2
                            rejoe2R
                            rejoe2R
                            rejoe2
                            @tomasandersson This really looks strange.
                            Some additional remarks:
                            • Some values represent also failure codes, beside -127°, 85° (C), which are already filtered out by code I also suspect 0° to be one of these. This is the backgound of me asking above for absolute figures.
                            • There seem to be also fake chips on the market; they may have slightly different operation conditions esp. wrt. to timing (if they work at all; I don't have own experience on this).
                            • How are your cabeling conditions? I had some troubles when using nRF+PA+LNA modules together with the new (post 2.0.1-) MySensors-libs and more than 5 DS18B20 on one line (non-parasitic mode). This seems to be solved by the use of a small delay between temp-sends (wait(50) or so). With a lot of sensors and long lines and/or star topology, you may have to lower the pullup resistor value (e.g. 3.3k).
                            • rejoe2R rejoe2
                              tomasandersson
                              @rejoe2
                              Thanks so much for your help.
                              I think you're a little ahead of me in programming. Interesting with time delay between temp sends. How do I create it?
                              • T tomasandersson
                                @rejoe2
                                rejoe2R
                                rejoe2R
                                rejoe2
                                @tomasandersson You are welcome!
                                I am more feeling as a beginner also in most programming aspects. This is just some sort of copy/pasting in addition with some thoughts on how things may work and reading technical documentation and examples :simple_smile:; most of this is based on leodesigners work here somewhere in the forum (fride monitor). I had a hard time to find solutions working for me, so I'm happy if someone can learn from this.
                                Back to the answer: just add a wait(50); as new line 120 (somewhere within the reading/sending for-loop).
                                • rejoe2R rejoe2
                                  tomasandersson
                                  @rejoe2
                                  Now I have tried both of the programs. It works much the same. It pops up a fault sometimes.
                                  Is it difficult to enter a line in the program, says that if the temperature has changed system than - + 5 degrees so it shall not be reported
                                  • T tomasandersson
                                    @rejoe2
                                    rejoe2R
                                    rejoe2R
                                    rejoe2
                                    @tomasandersson To me, this really seems to be hardware related, so triple check your wirings first.
                                    If you really believe this to be a software problem, you may add an additional condition in line 119 with another "&&", (from memory something like abs(lastTemperature[i] - temperature < 5). I would have to test it myself and don't find this reasonable (s.o.), so feel free to finish this part of the job yourself.
                                    • rejoe2R rejoe2
                                      tomasandersson
                                      @rejoe2
                                      Thank you for helping me in the right direction
                                      I do not think there is anything wrong with the hardware because I have two identical sets. One to a spa and a heat pump. Maybe I'll try it with less resistance. Now i have 4.8kohm
                                      I'm now trying with more or less distinction from the former transient temp.
                                      I will reply when I got it to work.
                                      Tomas
                                      • T tomasandersson
                                        @rejoe2
                                        Tomas
                                        rejoe2R
                                        rejoe2R
                                        rejoe2
                                        @tomasandersson Just 2 DS18B20 on each line should never cause trouble wrt current draw using a 4.8k resistor and 30 sec. intervals and no additional sensors drawing current from the arduino. If not already in place I would anyhow recommend using 3 wires for operation instead of parasitic mode.
                                        Anyhow: Best way to identify these chips is using the addresses. Most likely you now are also prepared to do some small editing in sketches?
                                        "My" array-sketch-version also prints the ID's as array information you need to serial. You may test it and then disable this feature once you have the info for both of your sketches (begin the respecting line with the #define with a "//"). Doing so will definitely eliminate any smallest risk of mixing data...
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          Is any chance to connect more than 16 dallas ? By change value 16 to example 20 ?
