  3. Using two gateways MQTT
9 Posts 3 Posters 2.1k Views 3 Watching
  • S Offline
    sindrome73
    Hello!!
    As the title I would use for my control Domoticz two Gateway MQTT, being my Etherneth network very well distributed.
    is it possible to use 2 Gateway MQTT with a Domoticz controller ???
    Thank you!!
    • S sindrome73
      Hello!!
      Thank you!!
      @sindrome73 yes
      • S Offline
        sindrome73
        Grazie mille!!
        Thanks!!
          wrote on last edited by gohan
          @mfalkvidd How does the system knows which gateway is?
          • S Offline
            sindrome73
            wrote on last edited by sindrome73
            I do not understand. Tell me I'm available
              @gohan I don't know but I guess it does it the same way as it does when using multiple ethernet gateways, multiple serial gateways and/or two different gateways.
                It's not actually the same because the mqtt broker is only one, the controller can not identify the gateway if they are publishing to same topic, unless there is a way to assign an ID for each gateway. Right?
                  @gohan oh, now I understand. Yes, if you use the same broker you would need to set different topics.
                    The problem is that domoticz only works with its own fixed topics. It may be worth trying to see if adding a unique sub topic for each gateway, the controller can still recognize the mysensors protocol
                    12.2k
