  3. [SOLVED] MQTT message does not show (MySensors on ESP8266)
4 Posts 3 Posters 1.9k Views 3 Watching
  • P Offline
    P Offline
    pansen
    wrote on last edited by pansen
    I put the below code on a Sonoff switch (which has an ESP8266 on it). I installed mosquitto as MQTT broker on my orange pi and tested it, so the broker is ok.
    Now, when I subscribe to the topic I set, nothing is shown when my relay state changes:
    mosquitto_sub -h localhost -t Sonoff-Out
    I am sure I am just missing some configuration or a command...Any ideas?
    main.h
    #define PIN_PIR_SENSOR 14
    #define PIN_RELAY  12
    #define PIN_LED 13
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define LED_ON 0
    #define LED_OFF 1
    #define CHILD_ID 73
    #define MY_BAUD_RATE 115200
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "REMOVED"
    #define MY_ESP8266_PASSWORD "REMOVED"
    #define MY_ESP8266_HOSTNAME "Sonoff-PIRSwitch-Lamp"
    //#define MY_IP_ADDRESS 1,1,1,80
    //#define MY_IP_GATEWAY_ADDRESS 1,1,1,10
    //#define MY_USE_UDP
    #define MY_CONTROLLER_IP_ADDRESS 1,1,1,1
    #define MY_PORT 1883
    //#define MY_GATEWAY_MAX_CLIENTS 1
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "Sonoff-Out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "Sonoff-In"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "Sonoff-PIRSwitch-Lamp"
    #if defined(MY_USE_UDP)
    #include <WiFiUdp.h>
    #include <Arduino.h>
    //#include <ESP8266mDNS.h>
    #include <ESP8266WiFi.h>
    void setup();
    void loop();
    void present();
    void receive(const MyMessage &message);
    void ISR_PIRPinHasChanged();
    void SetRelayAndLedStatus();
    void ToggleRelay();
    void TransmitStatusToController();
    main.cpp
    #include "main.h"
    int currentRelayStatus;
    MyMessage msg(CHILD_ID,V_STATUS);
    void setup(){
      pinMode(PIN_LED, OUTPUT);
      pinMode(PIN_RELAY, OUTPUT);
      pinMode(PIN_PIR_SENSOR, INPUT);
      currentRelayStatus = RELAY_OFF;
      attachInterrupt(PIN_PIR_SENSOR, ISR_PIRPinHasChanged, RISING);
      //flash led
      digitalWrite(PIN_LED,LED_ON);
      delay(100);
      digitalWrite(PIN_LED,LED_OFF);
      delay(100);
      delay(100);
      delay(100);
    void presentation()  {
      // Send the sketch version information
      sendSketchInfo("Sonoff PIR Switch", "1.1");
      // Register sensor
      present(CHILD_ID, S_BINARY);
      if (message.type==V_STATUS  && message.sensor==CHILD_ID) {
        if(message.getBool() == true)
          currentRelayStatus = RELAY_ON;
        else{
    void ISR_PIRPinHasChanged(){
      int currentPinStatus = digitalRead(PIN_PIR_SENSOR);
      if(currentPinStatus == LOW){
        Serial.println("ISR fired, pin LOW");
      else{
        Serial.println("ISR fired, pin HIGH");
        ToggleRelay();
    void ToggleRelay(){
      if(currentRelayStatus == RELAY_ON){
        Serial.println("toggling relay to OFF");
      else{
        Serial.println("toggling relay to ON");
    void SetRelayAndLedStatus(){
        Serial.println("switching on");
        digitalWrite(PIN_LED, LED_ON);
        digitalWrite(PIN_RELAY, RELAY_ON);
      else{
        Serial.println("switching off");
        digitalWrite(PIN_LED, LED_OFF);
        digitalWrite(PIN_RELAY, RELAY_OFF);
    void TransmitStatusToController(){
      Serial.println("sending status to controller");
        send(msg.set(true));
      else{
        send(msg.set(false));
    Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
    Y 1 Reply Last reply
      Have you considered using easy esp or other similar firmware?
      P 1 Reply Last reply
      • P pansen
        main.h
        #define PIN_LED 13
        #define RELAY_ON 1
        #define RELAY_OFF 0
        #define LED_ON 0
        #define LED_OFF 1
        #define CHILD_ID 73
        void setup();
        void loop();
        void present();
        void ToggleRelay();
        main.cpp
        #include "main.h"
        void setup(){
          //flash led
          delay(100);
          delay(100);
          delay(100);
          delay(100);
          // Register sensor
            else{
          else{
            ToggleRelay();
        void ToggleRelay(){
          else{
          else{
          else{
        Y Offline
        Y Offline
        @pansen said in MQTT message does not show (MySensors on ESP8266):
        Try subscribing to all topics starting with the Sonoff-Out prefix, using a wildcard, and see if that makes a difference:
        mosquitto_sub -h localhost -t Sonoff-Out/#
          P Offline
          P Offline
          pansen
          @gohan said in MQTT message does not show (MySensors on ESP8266):
          Esay esp won't work for me since it depends on the Arduino IDE but I am using platform.io. Any incentives to change?
          @Yveaux said in MQTT message does not show (MySensors on ESP8266):
          That was it, thanks!
          Sonoff PIR Switch
          1.1
          edit: and some verbose output for completeness:
          x@x:~$ mosquitto_sub -h localhost -v -t Sonoff-Out/#
          Sonoff-Out/0/73/1/0/2 1
          Sonoff-Out/0/73/1/0/2 0
          12.1k
