  3. Vera Plus and ESP8266
23 Posts 5 Posters 8.6k Views 5 Watching
  • korttomaK korttoma
    Have you verified that the ESP connects to your WiFi?
    Can you ping it?
    Please also try restarting Vera a few times.
    Did you try connecting with some other controller software? I usually check how the GW is working by connecting it to the MYSController running on a windows computer.
    adding the following to your GW sketch enables you to connect more than one controller.
    djzang
    wrote on last edited by djzang
    @korttoma said in Vera Plus and ESP8266:
    Can you ping it?
    Ya, as I mentioned I can ping the ESP and telnet to 5003 on it, so i know its on the network and listening.
    I've restarted Luup multiple times. I haven't rebooted the entire controller yet. I can give that a shot.
    I'll give this a try, though I'm convinced the issue is with the Vera plugin, not the GW since I don't even see the Vera attempt to connect to the GW when I'm monitoring the serial monitor on the ESP. Where I can see my connection in the serial monitor when I telnet to it.
    • D
      djzang
      I made some progress.... my issue was "dumb user" :) I needed to upload all the xml and json files, not just the two. So I have them loaded on the Vera now and I can connect to the gateway. So as I mentioned in the original post, my plan is to have the ESX8266 act as a gw and a sensor and not have any radio modules connected to it. So I went a head and loaded on code to read the DHT22 temp.humidity sensor that I have hooked up to it. I installed MYSController and connected it to the gw/sensor and I can see the data coming in: http://imgur.com/unSkSKK
      However I can't seem to get a temperature or humidity device to show up in the Vera. From what I've ready I should just click on "start" in the Vera MySensors plugin to start the inclusion process and when it detects the sensor the device should be automatically added. But that doesn't seem to be working at all. In the Luup logs of the Vera I can see it receiving the data:
      50      03/17/17 20:55:19.974   luup_log:34: Arduino: Set variable: 0;1;1;0;0;26.0 <0x739d1520>
      50      03/17/17 20:55:19.986   luup_log:34: Arduino: Set variable: 0;0;1;0;1;23.5 <0x739d1520>
      But I just can't figure out how to have an actual temperature or humidity device show up in the Vera device list.
      Any thoughts?
      Thanks!`
      korttomaK 1 Reply Last reply
      • D djzang
        Any thoughts?
        Thanks!`
        korttomaK
        korttomaK
        korttoma
        @djzang do you have the following line in your sketch?
        • Tomas
        D 1 Reply Last reply
          djzang
          Yes I do.... here is my full sketch:
           * Version 1.0 - Henrik EKblad
           * Contribution by Ivo Pullens (ESP8266 support)
           * The EthernetGateway sends data received from sensors to the WiFi link.
           * VERA CONFIGURATION:
           * LED purposes:
           * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
           * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
           * nRF24L01+  ESP8266
           * VCC        VCC
           * CE         GPIO4
           * CSN/CS     GPIO15
           * SCK        GPIO14
           * MISO       GPIO12
           * MOSI       GPIO13
           * GND        GND
            * Inclusion mode button:
          #define MY_BAUD_RATE 9600
          //#define MY_RADIO_NRF24
          #define MY_GATEWAY_ESP8266
          #define MY_ESP8266_SSID "myssid"
          #define MY_ESP8266_PASSWORD "mypassword"
          // Enable UDP communication
          //#define MY_USE_UDP
          #define MY_ESP8266_HOSTNAME "esp01"
          #define MY_PORT 5003
          // Enable inclusion mode
          // #define MY_INCLUSION_BUTTON_FEATURE
          // Set blinking period
          // #define MY_DEFAULT_LED_BLINK_PERIOD 300
          // Flash leds on rx/tx/err
          #if defined(MY_USE_UDP)
          #include <WiFiUdp.h>
          #include <ESP8266WiFi.h>
          #include "DHT.h"
          #define DHTTYPE DHT22
          const int DHTPin = 2;
          DHT dht(DHTPin, DHTTYPE);
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          static char celsiusTemp[7];
          static char humidityTemp[7];
          delay(10);
          dht.begin();
          	sendSketchInfo("TemperatureAndHumidity", "1.1");
            present(CHILD_ID_HUM, S_HUM);
          	float h = dht.readHumidity();
            float t = dht.readTemperature();
            if (isnan(h) || isnan(t)) {
                        Serial.println("Failed to read from DHT sensor!");
                        strcpy(celsiusTemp,"Failed");
                        strcpy(humidityTemp, "Failed");
                      else{
                        dtostrf(t, 6, 2, celsiusTemp);
                        dtostrf(h, 6, 2, humidityTemp);
                        // You can delete the following Serial.print's, it's just for debugging purposes
                        Serial.print("Humidity: ");
                        Serial.print(h);
                        Serial.print(" %\t Temperature: ");
                        Serial.print(t);
                        Serial.println(" *C ");
                        send(msgTemp.set(t, 1));
                        send(msgHum.set(h, 1));
            delay(15000);
          When I clock on "start" inclusion in the Vera plugin, it scans but always says 0 devices found. I haven't setup an inclusion button on my GW. I figured that wasn't necessary if the GW was the sensor?
          • D djzang
             * LED purposes:
             * nRF24L01+  ESP8266
             * VCC        VCC
             * CE         GPIO4
             * CSN/CS     GPIO15
             * SCK        GPIO14
             * MISO       GPIO12
             * MOSI       GPIO13
             * GND        GND
            #include "DHT.h"
            delay(10);
            dht.begin();
                        else{
                          Serial.print(h);
                          Serial.print(t);
              delay(15000);
            korttomaK
            korttomaK
            korttoma
            @djzang don't use delay() in your sketch please chang it to wait(). Your GW will not receive the presentation command when it is in "delay".
            • Tomas
              djzang
              I switched delay() to wait() but I'm still seeing the same behavior. When i click on "start" the inclusion process it always returns 0 devices found. There must be something that I'm missing. It seems like the way I'm doing things is not what most are doing, but from what I've ready it should be possible. Since my GW IS the sensor I can't simply power cycle the sensor node to have the GW pick it up during inclusion. Is there something else I should be doing instead?
              • D
                djzang
                I must not be doing the inclusion correctly in my sketch or in general as I see this in the Vera logs:
                08      03/19/17 10:20:56.071   JobHandler_LuaUPnP::HandleActionRequest device: 36 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StartInclusion <0x74d9d520>
                08      03/19/17 10:20:56.072   JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=36 <0x74d9d520>
                08      03/19/17 10:20:56.072   JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x74d9d520>
                08      03/19/17 10:20:56.072   JobHandler_LuaUPnP::HandleActionRequest argument action=StartInclusion <0x74d9d520>
                50      03/19/17 10:20:56.073   luup_log:36: Arduino: Sending: 0;0;3;0;5;1 <0x77e42320>
                04      03/19/17 10:20:56.078   <Job ID="14" Name="" Device="36" Created="2017-03-19 10:20:56" Started="2017-03-19 10:20:56" Completed="2017-03-19 10:20:56" Duration="0.5062000" Runtime="0.4342000" Status="Successful" LastNote=""/> <0x77e42320>
                50      03/19/17 10:20:56.118   luup_log:36: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionMode, 1, 36 <0x73b3d520>
                06      03/19/17 10:20:56.119   Device_Variable::m_szValue_set device: 36 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionMode was: 0 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0xa920d0/NONE duplicate:0 <0x73b3d520>
                50      03/19/17 10:20:56.119   luup_log:36: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, 0 devices found, 36 <0x73b3d520>
                06      03/19/17 10:20:56.120   Device_Variable::m_szValue_set device: 36 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was:  now: 0 devices found #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73b3d520>```
                • korttomaK
                  korttomaK
                  korttoma
                  Maybe you could try commenting out everything in the loop() function to rule out this being the problem.
                  And if you have not already tried then reboot and/or restart luup for your Vera.
                  • Tomas
                  • R
                    R
                    r-nox
                    perhaps you need to set the duration?
                    • D
                      djzang
                      @r-nox said in Vera Plus and ESP8266:
                      I uncommented out the above line and tested.... it keeps saying 0 devices found. I also tried removing everything under loop() as well and i get the same behavior.
                      06      03/20/17 20:24:35.616   Device_Variable::m_szValue_set device: 39 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionMode was: 0 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0xfc3e10/NONE duplicate:0 <0x73ce5520>
                      50      03/20/17 20:24:35.616   luup_log:39: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, 0 devices found, 39 <0x73ce5520>
                      06      03/20/17 20:24:35.616   Device_Variable::m_szValue_set device: 39 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was:  now: 0 devices found #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73ce5520>
                      50      03/20/17 20:25:35.599   luup_log:39: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionMode, 0, 39 <0x73ce5520>
                      06      03/20/17 20:25:35.599   Device_Variable::m_szValue_set device: 39 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionMode was: 1 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xfc3e10/NONE duplicate:0 <0x73ce5520>
                      50      03/20/17 20:25:35.610   luup_log:39: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, , 39 <0x73ce5520>
                      06      03/20/17 20:25:35.610   Device_Variable::m_szValue_set device: 39 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was: 0 devices found now:  #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73ce5520>
                      50      03/20/17 20:25:35.611   luup_log:39: Arduino: Inclusion mode ended. <0x73ce5520>
                      and this is what i see in the serial monitor of the gateway:
                      0;255;3;0;9;MCO:BGN:STP
                      0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA pm open,type:2 0
                      0;255;3;0;9;Client 0 connected
                      0;255;3;0;9;Client 0: 0;0;3;0;2;Get Version
                      0;255;3;0;9;Client 0: 0;0;3;0;5;1
                      • mntlvrM
                        mntlvrM
                        mntlvr
                        Hello djzang
                        I just built the serial gw using esp-8266 but can not find how to physically hook it to Vera Plus or Vera 3 , do you have step by step instruction as how to do that maybe with pictures and what setup you entered in to the serial port configuration?
                        • mntlvrM mntlvr
                          Hello djzang
                          korttomaK
                          korttomaK
                          korttoma
                          @mntlvr I'm not sure what kind of serial chip is on the ESP8266 but Vera can not detect all types of serial chips because there are no drivers installed. FTDI chips should be detected by Vera automatically and then you just need to set the correct serial port settings:
                          • Tomas
                          • mntlvrM
                            mntlvrM
                            mntlvr
                            Thank you so much yes my 8266 has a ch340 serial chip.
                            Where did you find your 8266 with FTDI chip on board?
                            Bob
                            • dbemowskD
                              dbemowskD
                              Vera does not support the CH340. I had a CH340 based serial adapter that I was trying to use when I first got my Vera and I found out that it wasn't supported.
                              • mntlvrM
                                mntlvrM
                                mntlvr
                                So do you have a working serial general on your Vera now and does it use an ESP 8266 or a Arduino Nano
                                dbemowskD 1 Reply Last reply
                                • mntlvrM mntlvr
                                  dbemowskD
                                  dbemowskD
                                  @mntlvr If you are asking me, I run a plain serial gateway.
                                  • mntlvrM
                                    mntlvrM
                                    mntlvr
                                    So you are using a Arduino Nano with a FTDI chip?
                                    • mntlvrM mntlvr
                                      dbemowskD
                                      dbemowskD
                                      @mntlvr Well, a pro mini, but close enough. It is a pro mini running an nRF24 network set up as a serial interface. Mine is not actually an FTDI chip, it is a PL2303 which is made by Prolific.
                                      • mntlvrM
                                        mntlvrM
                                        mntlvr
                                        How did you get Vera to install the non FTDI chip?
                                        • mntlvrM mntlvr
                                          dbemowskD
                                          dbemowskD
                                          @mntlvr The Vera controllers have a list of supported serial devices. If you look at this page under USB Serial Devices, looking at the chipset column you will see that the FTDI and PL2303 chipsets are the only ones that Vera natively supports. For the 2303 chipsets, some say that they don't work, and others say that manual configuration is needed. Mine luckily just worked with no extra configuration. That list was last modified in 2013 though, so what is supported/works and what doesn't most likely has changed since then.
