  3. Vera Plus and ESP8266
23 Posts 5 Posters 8.6k Views 5 Watching
  • R
    R
    r-nox
    perhaps you need to set the duration?
    • D
      djzang
      @r-nox said in Vera Plus and ESP8266:
      I uncommented out the above line and tested.... it keeps saying 0 devices found. I also tried removing everything under loop() as well and i get the same behavior.
      06      03/20/17 20:24:35.616   Device_Variable::m_szValue_set device: 39 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionMode was: 0 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0xfc3e10/NONE duplicate:0 <0x73ce5520>
      50      03/20/17 20:24:35.616   luup_log:39: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, 0 devices found, 39 <0x73ce5520>
      06      03/20/17 20:24:35.616   Device_Variable::m_szValue_set device: 39 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was:  now: 0 devices found #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73ce5520>
      50      03/20/17 20:25:35.599   luup_log:39: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionMode, 0, 39 <0x73ce5520>
      06      03/20/17 20:25:35.599   Device_Variable::m_szValue_set device: 39 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionMode was: 1 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xfc3e10/NONE duplicate:0 <0x73ce5520>
      50      03/20/17 20:25:35.610   luup_log:39: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, , 39 <0x73ce5520>
      06      03/20/17 20:25:35.610   Device_Variable::m_szValue_set device: 39 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was: 0 devices found now:  #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73ce5520>
      50      03/20/17 20:25:35.611   luup_log:39: Arduino: Inclusion mode ended. <0x73ce5520>
      and this is what i see in the serial monitor of the gateway:
      0;255;3;0;9;MCO:BGN:STP
      0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA pm open,type:2 0
      0;255;3;0;9;Client 0 connected
      0;255;3;0;9;Client 0: 0;0;3;0;2;Get Version
      0;255;3;0;9;Client 0: 0;0;3;0;5;1
      • mntlvrM
        mntlvrM
        mntlvr
        Hello djzang
        I just built the serial gw using esp-8266 but can not find how to physically hook it to Vera Plus or Vera 3 , do you have step by step instruction as how to do that maybe with pictures and what setup you entered in to the serial port configuration?
        korttomaK 1 Reply Last reply
        • mntlvrM mntlvr
          Hello djzang
          korttomaK
          korttomaK
          korttoma
          @mntlvr I'm not sure what kind of serial chip is on the ESP8266 but Vera can not detect all types of serial chips because there are no drivers installed. FTDI chips should be detected by Vera automatically and then you just need to set the correct serial port settings:
          • Tomas
          • mntlvrM
            mntlvrM
            mntlvr
            Thank you so much yes my 8266 has a ch340 serial chip.
            Where did you find your 8266 with FTDI chip on board?
            Bob
            • dbemowskD
              dbemowskD
              Vera does not support the CH340. I had a CH340 based serial adapter that I was trying to use when I first got my Vera and I found out that it wasn't supported.
              • mntlvrM
                mntlvrM
                mntlvr
                So do you have a working serial general on your Vera now and does it use an ESP 8266 or a Arduino Nano
                dbemowskD 1 Reply Last reply
                • mntlvrM mntlvr
                  dbemowskD
                  dbemowskD
                  @mntlvr If you are asking me, I run a plain serial gateway.
                  • mntlvrM
                    mntlvrM
                    mntlvr
                    So you are using a Arduino Nano with a FTDI chip?
                    • mntlvrM mntlvr
                      dbemowskD
                      dbemowskD
                      @mntlvr Well, a pro mini, but close enough. It is a pro mini running an nRF24 network set up as a serial interface. Mine is not actually an FTDI chip, it is a PL2303 which is made by Prolific.
                      • mntlvrM
                        mntlvrM
                        mntlvr
                        How did you get Vera to install the non FTDI chip?
                        • mntlvrM mntlvr
                          dbemowskD
                          dbemowskD
                          @mntlvr The Vera controllers have a list of supported serial devices. If you look at this page under USB Serial Devices, looking at the chipset column you will see that the FTDI and PL2303 chipsets are the only ones that Vera natively supports. For the 2303 chipsets, some say that they don't work, and others say that manual configuration is needed. Mine luckily just worked with no extra configuration. That list was last modified in 2013 though, so what is supported/works and what doesn't most likely has changed since then.
                          • mntlvrM
                            mntlvrM
                            mntlvr
                            Okay thanks
                            Well I built a Ethernet board using 1.4.1 library and a W5100 Ethernet board and it worked right off so now I am as curious as heck to make the ESP 8266 work but I still think it has something to do with the newest library. I think I will start out with the Arduino IDE 1.6.4 or something like that and see if that makes a difference. Not very many on this site can help with the issue because they do not have Vera Controllers, so I have to figure this out and just keep trying
