  2. Announcements
  3. 💬 RFID Lock Sensor
💬 RFID Lock Sensor
25 Posts 14 Posters 12.7k Views 13 Watching
  • miroM miro
    It was just that easy as a broken radio. Thank you for your help to get me think in other ways :)
    Great work @miro, thanks for reporting back.
    • miroM
      miroM
      miro
      Has anyone got this http://www.ebay.com/itm/271316626820?rmvSB=true to work with NFC and Android phone?
      • ben999B
        ben999B
        ben999
        wrote on last edited by ben999
        Hi all,
        I can not get status of my doorlock node... begging for help! ;)
        Got myself bits and pieces as per "build" page :
        • arduino micro
        • NRF24
        • PN532
        • relay
          Raspberry SGtw works fine with another node (temp, motion and hum)
          RFID node "speaks" with Raspberry as follows (IDE serial monitor) :
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=10)
        TSM:FPAR
        TSP:MSG:SEND 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSM:FPAR
        TSP:MSG:READ 0-0-10 s=255,c=3,t=8,pt=1,l=1,sg=0:0
        TSP:MSG:PAR OK (ID=0, dist=1)
        TSM:FPAR:OK
        TSM:ID
        TSM:CHKID:OK (ID=10)
        TSM:UPL
        TSP:PING:SEND (dest=0)
        TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
        TSP:MSG:READ 0-0-10 s=255,c=3,t=25,pt=1,l=1,sg=0:1
        TSP:MSG:PONG RECV (hops=1)
        TSP:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        Found NFC chip PN532
        Firmware ver. 1.6
        close lock
        NODE:!REG
        TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
        TSP:MSG:SEND 10-10-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
        TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
        TSP:MSG:READ 0-0-10 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        TSP:MSG:READ 0-0-10 s=255,c=3,t=6,pt=0,l=1,sg=0:M
        TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=ok:RFID Lock
        TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
        TSP:MSG:SEND 10-10-0-0 s=1,c=0,t=19,pt=0,l=0,sg=0,ft=0,st=ok:
        Request registration...
        TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
        TSP:MSG:READ 0-0-10 s=255,c=3,t=27,pt=1,l=1,sg=0:1
        Node registration=1
        Init complete, id=10, parent=0, distance=1, registration=1
        Found tag id: 0x35,0xA8,0xF5,0xAA,0x00,0x00,0x00
        open lock
        TSP:MSG:SEND 10-10-0-0 s=1,c=1,t=36,pt=1,l=1,sg=0,ft=0,st=ok:1
        That's my things file :
        Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ] {
                lock            hallRfid01              [ nodeId="10", childId="1" ]    }
        And my items file :
        Contact         hallRfid01      "Front door lock"                 <frontdoor>             (gHall)                                 { channel="mysensors:lock:gateway:hallRfid01:lock" }
        This is the openhab "mysensors log tail" when powering node on (presenting to gateway)
        06:48:57.990 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        06:49:05.585 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;0;0;17;2.0.0
        06:49:05.597 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.IllegalStateException: Could not update state, because callback is missing) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
        06:49:05.600 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;3;0;6;0
        06:49:05.603 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - I_CONFIG request received from M, answering: (is imperial?)false
        06:49:05.606 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 10;255;3;0;6;M
        06:49:05.609 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.IllegalStateException: Could not update state, because callback is missing) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
        06:49:05.632 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;3;0;11;RFID Lock
        06:49:05.636 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.IllegalStateException: Could not update state, because callback is missing) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
        06:49:05.679 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;3;0;12;1.0
        06:49:05.683 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.IllegalStateException: Could not update state, because callback is missing) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
        06:49:05.684 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;1;0;0;19;
        06:49:05.696 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 10 to 2016-12-19T06:49:05.687+0000
        06:49:05.712 [INFO ] [marthome.event.ItemStateChangedEvent] - mysensors_lock_gateway_hallRfid01_lastupdate changed from 2016-12-18T21:14:31.444+0000 to 2016-12-19T06:49:05.687+0000
        06:49:07.991 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        06:49:17.992 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        And last when RFID tag is presented to reader
        06:49:47.996 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        06:49:49.305 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;1;1;0;36;1
        06:49:49.310 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.IllegalStateException: Could not update state, because callback is missing) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
        06:49:57.998 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        06:49:58.567 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;1;1;0;36;0
        06:49:58.572 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.IllegalStateException: Could not update state, because callback is missing) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
        06:50:07.999 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        On the bright side, the relay attached to arduino opens and closes as i present RFID tag in front of reader... :)
        Unfortunately i don't get the lock status (locked or unlocked) in PaperUI nor openHab for iOS...
        I don't get "open" or "closed" status as i do with motion sensor. I also don't get any change to the door icon (door_closed and door_opened)
        Thanks a lot for your help :)
        Best Regards,
        Ben
          @miro the node is unable to connect to your gateway. What type of gateway are you using? Could you post the debug log from the gateway?
          samburner3S
          samburner3S
          samburner3
          wrote on last edited by samburner3
          @miro said in 💬 RFID Lock Sensor:
          @mfalkvidd
          I have followed the guide here (https://www.mysensors.org/build/rfid) to the letter. Yes, it could be me that have problems but this isn´t so hard project. Feels like something is missing?
          In the description it says:
          "To find out the unique ID of your tag just run the example while looking at serial monitor. Hold tag in front of reader and your identifier should pop up."
          This I did, but the monitor don`t show anything, just this
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          ... And yes, I have switched the little pin to I2C on my PN532 RFID reader.
          I had the same question as @miro however my node is communicating and connected to the gateway correctly.
          I only see the mysensors radio debug info on the serial monitor, and no application serial prints eg (Serial.print("Couldn't find PN53x board");) doesn't show up in the serial monitor at all.
          Neither does "Found NFC chip" or anything else in the main code...
          My radio is working and as I said no errors in the radio debug.
          Is the main application even running?
          I cannot get it to scan a card at all.
          However if I comment out the <MySensors.h> library along with its dependencies in the main program, it works and I can scan cards, and get the Uid from them...
          Any clues?
          • ostgardhO
            ostgardhO
            ostgardh
            Hi.
            Started using mysensors with RFID readers.
            I have a suggestion by I am bad code programmer.
            Is better to save the RFID tag key in the EPROM approved.
            And If you want to add a key/tag with special tag which add new or remove tag.
            What do you think?
            • cadetC
              cadetC
              cadet
              Hi can you modify scetch for spi interface??
              • D
                DirkB19
                PN532.h: No such file or directory
                Is driving me crazy ... I have Downloaded the zip file and extracted the 4 folders(PN532, PN532_SPI, PN532_I2C and PN532_HSU) into Arduino's libraries.
                Same error.
                I've tried adding the library as .zip : it says not a valid library file
                what could be the problem ?
                D 1 Reply Last reply
                • D DirkB19
                  Same error.
                  DirkB19
                  @DirkB19
                  Nevermind, I placed the PN532 related folders into the C:\Program Files (x86)\Arduino\libraries folder and now it works.
                  Before, I placed them into the \libraries folder where all my sketches are which does not work for this libary .
                  • Michel - ItM Michel - It
                    Hi, I have a MFRC522 module, and I would like to implement it with 2.0 library. could I use this code?
                    Aron SjöbergA
                    Aron SjöbergA
                    Aron Sjöberg
                    @Michel---It said in 💬 RFID Lock Sensor:
                    I would also really like to know how to use a RFID-RC522 module instead of the PN532 NFC RFID Reader/Writer Module used in the example! The RC522 is included in a lot of different beginner kits.
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      It would make much sense if this example used signing.
                      • jopebeJ
                        jopebeJ
                        jopebe
                        Hallo,
                        I like this example of RFID Lock Sensor.
                        But I`m not able to change it for my aim myself (just a user and beginner).
                        Here my imaginations:
                        1. There should be always a default after switching on, after calling seriell monitor or after power cut.
                          This should be "Sensor Locked"
                        2. Every change to "Sensor open" should be for only let`s say 3 seconds or another adjustable time and than fall back to Default = "Sensor Locked" . Time enough e.g. to open the door or s.e.
                          Is there anybody who can give me some hints how to ad this features into the given sketch?
                          Thank You in advance
                          Jopebe
                        • ben999B
                          ben999B
                          ben999
                          #24
                          • jopebeJ jopebe
                            Hallo,
                              Jopebe
                            The-Holgi
                            @jopebe said in 💬 RFID Lock Sensor:
                            1. Every change to "Sensor open" should be for only let`s say 3 seconds or another adjustable time and than fall back to Default = "Sensor Locked" . Time enough e.g. to open the door or s.e.
                              Jopebe
                            i have the same problem.
                            Does anyone have a solution? The relay should only put on for 3 seconds.
                            Greeting Holger
