  3. Node dont connect to RaspBerry gateway
28 Posts 4 Posters 7.8k Views 4 Watching
    Yes, development is the default branch (and the only one accepting PRs etc).
    If you want to switch to master after cloning the repo, do:
    git checkout master
      Could be worth adding that command to the guide 😉
        @gohan
        What guide?
        The rpi guide checks out master: https://www.mysensors.org/build/raspberry
        The contribution guide is focused on creating pull requests, so it naturally uses the default (development).
          Ah my bad, I didn't see the - - branch master at the end of the line as I'm on mobile 😌
          keldandorinK 1 Reply Last reply
          • Jeff WilleckeJ
            Jeff WilleckeJ
            Jeff Willecke
            Try assigning a node ID. Sometimes controllers will provide an ID but the gateway will not. Currently it is using the ID of 255. I think the line of code to add to the sketch is
            #define node_ID #
            Where the # at the end is the number of your node. Any value between 1 and 254 should work.
              keldandorinK
              keldandorinK
              keldandorin
              @gohan hehe N00b misstake thougt --branch Master was referens that the rest downloaded master...have just started to try out git :)
              • keldandorinK
                keldandorinK
                keldandorin
                OK got version 2.1.1 on place on Rpi deffined Node Id but still no luck connecting to Rpi GW :cry:
                GW Log
                mysgw: Starting gateway...
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: TSM:INIT:TSP OK
                mysgw: TSM:INIT:GW MODE
                mysgw: MCO:REG:NOT NEEDED
                mysgw: MCO:BGN:STP
                mysgw: MCO:BGN:INIT OK,TSP=1
                mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                mysgw: TSF:MSG:BC
                mysgw: TSF:MSG:FPAR REQ,ID=255
                mysgw: TSF:PNG:SEND,TO=0
                mysgw: TSF:CKU:OK
                mysgw: TSF:MSG:GWL OK
                mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                mysgw: TSF:MSG:BC
                mysgw: TSF:CKU:OK,FCTRL
                Node Log:
                3 TSM:INIT
                4 TSF:WUR:MS=0
                11 TSM:INIT:TSP OK
                13 TSM:FPAR
                15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2022 !TSM:FPAR:NO REPLY
                2024 TSM:FPAR
                2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                4034 !TSM:FPAR:NO REPLY
                4036 TSM:FPAR
                4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                6046 !TSM:FPAR:NO REPLY
                6048 TSM:FPAR
                6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                8058 !TSM:FPAR:FAIL
                8059 TSM:FAIL:CNT=1
                8061 TSM:FAIL:PDT
                Going to replace radio and try again.
                  Double check node ID, I don't see it in node log
                    keldandorinK
                    keldandorinK
                    keldandorin
                    @gohan Changed radio on Rpi
                    and node log looks like this now, Forgot MY_ before node :smile:
                    3 TSM:INIT
                    4 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    13 TSM:INIT:STATID=2
                    18 TSF:SID:OK,ID=2
                    19 TSM:FPAR
                    55 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2063 !TSM:FPAR:NO REPLY
                    2065 TSM:FPAR
                    2101 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    4108 !TSM:FPAR:NO REPLY
                    4110 TSM:FPAR
                    4146 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    6153 !TSM:FPAR:NO REPLY
                    6155 TSM:FPAR
                    6191 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    8198 !TSM:FPAR:FAIL
                    8199 TSM:FAIL:CNT=1
                    8201 TSM:FAIL:PDT
                    • keldandorinK keldandorin
                      3 TSM:INIT
                      4 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      18 TSF:SID:OK,ID=2
                      19 TSM:FPAR
                      2065 TSM:FPAR
                      4110 TSM:FPAR
                      6155 TSM:FPAR
                      8198 !TSM:FPAR:FAIL
                      8199 TSM:FAIL:CNT=1
                      8201 TSM:FAIL:PDT
                      keldandorinK
                      keldandorinK
                      keldandorin
                      @keldandorin Looks like I get som data to GW now but it dosent connect. Node has ID 3
                      mysgw: TSF:MSG:BC
                      mysgw: TSF:MSG:FPAR REQ,ID=3
                      mysgw: !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      mysgw: TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      mysgw: TSF:MSG:BC
                        Do you have cap on the radio?
                          keldandorinK
                          keldandorinK
                          keldandorin
                          @gohan yes
                            @gohan yes
                            keldandorinK
                            keldandorinK
                            keldandorin
                            @keldandorin If I pars log from GW it says
                            Sent Message
                            Sender: 0
                            Last Node: 0
                            Next Node: 3
                            Destination: 3
                            Sensor Id: 255
                            Command: INTERNAL
                            Message Type:I_FIND_PARENT_RESPONSE
                            Payload Type: P_BYTE
                            Payload Length: 1
                            Signing: 0
                            Failed uplink counter: 0
                            Status: NACK (OK=success, NACK=no radio ACK received)
                            Payload: 0
                            Just like its acctualy responding to Node !
                            But the node dosent like the awnser
                            • keldandorinK
                              keldandorinK
                              keldandorin
                              Hi guys, realy need som help here. Got my Rpi gateway up and running and logfile looks ok, see below.
                              have a working Node running with DTH22. (know its working sins its conenct to my Arduino GW)
                              Tryed to onfigured Node Id on node. Connecting to my RpiGW with MYScontroller and can see the gateway but no nodes connect.
                              Log on PRI looks like this
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: MCO:BGN:STP
                              mysgw: TSF:MSG:BC
                              Log on Node like this
                              3 TSM:INIT
                              4 TSF:WUR:MS=0
                              11 TSM:INIT:TSP OK
                              13 TSM:INIT:STATID=3
                              14 TSF:SID:OK,ID=3
                              16 TSM:FPAR
                              52 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              2059 !TSM:FPAR:NO REPLY
                              2061 TSM:FPAR
                              2097 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              4104 !TSM:FPAR:NO REPLY
                              4106 TSM:FPAR
                              4142 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              6149 !TSM:FPAR:NO REPLY
                              6151 TSM:FPAR
                              6187 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              8194 !TSM:FPAR:FAIL
                              8195 TSM:FAIL:CNT=1
                              8197 TSM:FAIL:PDT
                              From my basic understanding it looks like the GW dont responding in the correct way or the node dont like the awnser. Anyone with more experince out there that can give me some ideas how to fix this.
                              Thx
                              /Håkan
                                The gateway is replying but node is not receiving. Where are you getting power for your nrf24 radio on the rpi? Are you using a capacitor ? size?
                                  keldandorinK
                                  keldandorinK
                                  keldandorin
                                  @gohan taking power from 3v3 pin number 1 an using capasitor that is 10uF
                                    Other users reported a similar problem and they solved by using something like this (that's the one I have on my rpi) or any other similar voltage regulator + capacitor
                                      keldandorinK
                                      keldandorinK
                                      keldandorin
                                      @gohan had it running now for a cuple of hours and sudenly it registerd. No luck efter reboot though. Guess I have to order one of them Voltage regulators/capacitors....realy wish I hade one now in my Man Cave :joy:
                                        I ordered them by mistake some time ago, but they turned out to be very useful 😂
                                        keldandorinK 2 Replies Last reply
                                          keldandorinK
                                          keldandorinK
                                          keldandorin
                                          @gohan had it running again for some time and at message1890739 It got connected again and seems to be able to send message to GW. But as you say its the GW sending part that dosent seems to work.
                                          1890739 TSM:FPAR:OK
                                          1890740 TSM:ID
                                          1890742 TSM:ID:OK
                                          1890744 TSM:UPL
                                          1890749 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          1892756 TSM:UPL
                                          1892761 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          1892768 TSF:MSG:READ,0-0-3,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          1892773 TSF:MSG:PONG RECV,HP=1
                                          1892776 TSM:UPL:OK
