  3. Starting with MySensors
startingnoobnewbie
9 Posts 4 Posters 3.5k Views 4 Watching
  • S Offline
    siddmon
    Hi guys,
    Just started and finished my ESP8266MQTTClient, I still don't understand how all this works and I was wondering if there is any documentation or just a simple example like:
    Node - button - present it and send msg when button is pressed
    MQTTGateway - I don't know what goes into presentation or loop and haven't seen any examples for receive yet
    My guess is that I still need a controller which gets the information from the gateway but it's only a guess I haven't found any documentation yet on how to get started.
    Thanks, feel free to refer me to other posts if this was already answered
    • S siddmon
      Hi guys,
      @siddmon welcome to the MySensors community!
      The best place to start is the Getting started guide.
      The button example is available here: https://www.mysensors.org/build/binary
      • S Offline
        siddmon
        Thanks for the links, I got the gateway working (I think)
        ..0;255;3;0;9;TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
        ....0;255;3;0;9;TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
        .pm open,type:2 0
        ............................................................................................................................0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        0;255;3;0;9;TSF:MSG:BC
        0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
        0;255;3;0;9;TSF:PNG:SEND,TO=0
        0;255;3;0;9;TSF:CKU:OK
        0;255;3;0;9;TSF:MSG:GWL OK
        0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        I think that means it's receiving data from the other node.
        In my other node I have the following output, which I think is sending information correctly
        0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.2.0-beta
        4 TSM:INIT
        4 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        13 TSM:FPAR
        15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        823 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        828 TSF:MSG:FPAR OK,ID=0,D=1
        2023 TSM:FPAR:OK
        2024 TSM:ID
        2025 TSM:ID:REQ
        2028 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        4035 TSM:ID
        4036 TSM:ID:REQ
        4038 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        6046 TSM:ID
        6047 TSM:ID:REQ
        6049 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        8057 TSM:ID
        8058 TSM:ID:REQ
        8060 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        For the ESP8266MQTTClient, what IPs do I need to set?
        #define MY_IP_ADDRESS 192,168,1,5
        #define MY_IP_GATEWAY_ADDRESS 192,168,1,5  //This is the IP of my PC
        // MQTT broker ip address.
        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 88
        #define MY_PORT 1883
        From this code I think:
        MY_IP_ADDRESS - IP address of the gateway
        MY_IP_GATEWAY_ADDRESS - should this be the same as above?
        For connecting to Domoticz, do I need to what IP do I need to use? should it be port 1883 or something different?
        TIA
        • S Offline
          siddmon
          found this page which should help me get Domoticz configured
          https://www.domoticz.com/wiki/MySensors
            @siddmon
            For beginning domoticz is a good point to start with, also consider using ethernet gateway instead of mqtt as it is simpler than mqtt (al least until you are more familiar with everything)
            • S Offline
              siddmon
              @gohan, I'm so close now, I just need to make Domoticz to recognize my gw and the devices.
              I have verified that I get a message in the gw when toggling the switch in the node, so that part works :)
              Posted in their forums for help configuring Domoticz, I'm so close to have a working setup
              L gohanG 2 Replies Last reply
              • S siddmon
                L Offline
                L Offline
                LastSamurai
                @siddmon Whats the problem with domoticz and the gw? Should be very easy to setup. Here is a picture of my settings:
                0_1490808772283_upload-e4d4a00e-c7b8-43ed-8611-602ac5c6818a
                Just use the right topic names in your gw sketch. More infos on that here.
                • S siddmon
                  @siddmon remember to install beta version of Domoticz otherwise you will not get mysensors support
                  • S Offline
                    siddmon
                    @LastSamurai Thanks for the image, I had the address as localhost instead of the IP of the raspberry PI, changed it and everything works now :)
                    @gohan , yes, I upgraded to beta version since release doesn't have MQTT support yet.
                    12.2k
