  3. 💬 RFM69 Livolo 2 channels 1 way EU switch(VL-C700X-1 Ver: B8)
mysensorslivolo
100 Posts 14 Posters 49.8k Views 17 Watching
    shabba
    I got my PCBs today in the post. Is there a way to hack them to work with new circuit or should I just bin them?
    mtiutiuM 1 Reply Last reply
    • S shabba
      mtiutiuM
      mtiutiuM
      mtiutiu
      #76
      @shabba
      Until I get my hands on the new switches I cannot say. The thing is that they use now a 2x7 connector instead of a 2x6 one. I don't know how the relays are mapped to the new one and the 3V line. But I think that for sure a new pcb needs to be created. But until then maybe @tonnerre33 can shed some light here with some pictures? Is the new connector mapped ok in your schematics?
      If I see well in the pictures they moved the connector in the opposite direction so yeah...a new pcb design is needed.
      And to be honest I cannot keep up with the Lenovo manufacturer and create every time a new pcb because they maybe didn't slept very well over night and decided to change hw revision of the power/relays board on which this project relies. This is overkill and it's a downside for this project as I need to rely on their power supply board.
      Now as I promised I will create a new pcb for the new hw revision but ONLY for that and not the future ones. The new hw revision that they use now is the one that @tonnerre33 and @shabba has which is: VL-C702X-2 VER:C1
      But @shabba there's @tonnerre33 who works on this and started ahead of me so maybe you two can sync up on this?
      • mtiutiuM mtiutiu
        @alexus
        Hi, I don't know of any. There was @DJONvl who claims that he did it on this thread: https://forum.mysensors.org/topic/2775/livolo-glass-panel-touch-light-wall-switch-arduino-433mhz/75. But it didn't got my attention as ESP or any WiFi module is too power hungry for this project where simple sensors/actuators are involved and very light in terms of power usage(including radio transport). But as I said this is only my personal preference.
        alexus
        @mtiutiu Very much I ask, prompt as to connect esp-01 instead of RFM
        • A alexus
          mtiutiuM
          mtiutiuM
          mtiutiu
          @alexus
          Creating a new board with new hardware/new stuff like the ESP-01 is a thing that requires time and testing which is a luxury that I really don't have now. So I'm sorry but I won't invest time/money in creating/testing boards with ESP modules. The only thing that I'm going to do is to re-design the RFM board only as it doesn't require too much changes/work/time/money and it was tested beforehand.
          A 1 Reply Last reply
          • mtiutiuM mtiutiu
            @alexus
            alexus
            @mtiutiu I'm not asking you to design the board again. If you can tell how to connect the ESP module to your board?
            thanks for the advice
            • mtiutiuM mtiutiu
              @shabba
              tonnerre33T
              tonnerre33T
              tonnerre33
              #80
              @mtiutiu Yes the new connector is mapped for the new version. I have checked the pins with the multimeter.
              I have done many picture that you can see here :
              http://www.photorapide.com/albums/jordan/kqadrk/livolo-vl-c702x-2-ver-c1.html
              I hope you will find the informations that you want.
              Caution if you look my schema for see the mapping of the pin because on my board the bottom is your top and the top your bottom ;)
              Edit : I have added the mapping in the picture album
              Did you know why the pin in red surrounded is connected to the VIN ? alt text
              • A alexus
                mtiutiuM
                mtiutiuM
                mtiutiu
                @alexus
                Ok...my bad. I didn't understand your initial question. But now the next question is: what do you want to accomplish exactly? Can you be more specific?
                • tonnerre33T tonnerre33
                  mtiutiuM
                  mtiutiuM
                  mtiutiu
                  #82
                  @tonnerre33
                  Thanks for the pics and for your time. Well that's how the SOT-89 package is designed. If I'm not mistaking the big metallic pad was made like that for better thermal dissipation if you make the copper area which it connects to big enough. Now why it was specifically connected to Vin...that I'm afraid I don't know.
                  • mtiutiuM mtiutiu
                    @alexus
                    alexus
                    @mtiutiu I ask you to help me connect ESP-01 to your board
                    • bjornhallbergB
                      bjornhallbergB
                      bjornhallberg
                      Just want to confirm that I also received a "VL-C702X-2 VER:C1" today in the mail so at least they haven't made yet another version.
                      • tonnerre33T
                        tonnerre33T
                        tonnerre33
                        #85
                        Hello @mtiutiu i think i have finished my first version.
                        I have modified the pcb with your suggestions (power the node with 12VCC).
                        I have corrected a big mistake too, the AT25DF512C footprint was wrong (convertor mistake i think) ...
                        I have to put 2 resistors on the prohibided face ^^ but normaly it should be ok
                        hhaliboH 1 Reply Last reply
                          shabba
                          So besides the header being bigger what else has changed? I have received the current PCBs and wondering what I might need to do to make them still work?
                          • S shabba
                            tonnerre33T
                            tonnerre33T
                            tonnerre33
                            #87
                            @shabba said in 💬 Livolo 2 channels 1 way EU switch(VL-C700X-1 Ver: B8):
                            The position of the header has changed too. Now it's on the right part.
                            I think you can use your pcb but you'll need some wires between the femal header and the new mal header.
                            S 1 Reply Last reply
                              shabba
                              @tonnerre33 Thanks - do you happen to know the pin out?
                              • tonnerre33T
                                tonnerre33T
                                tonnerre33
                                #89
                                Yes, you can find the new pint out here :
                                http://www.photorapide.com/images.php?photoName=dm0l6i.jpg&photoId=1002306
                                  shabba
                                  wrote on last edited by shabba
                                  #90
                                  @tonnerre33 Thanks! Do you know the old one?
                                    hhaliboH
                                    hhaliboH
                                    hhalibo
                                    @tonnerre33 I just browsed your Github repo, found nothing there today, you deleted the contents?
                                    • hhaliboH
                                      hhaliboH
                                      hhalibo
                                      That's my fool. I saw it in the develop branch.
                                      • S shabba
                                        tonnerre33T
                                        tonnerre33T
                                        tonnerre33
                                        #93
                                        @shabba You can see the old one on the picture of this project ;)
                                        @hhalibo Yes i'll push this project in the master branch only when i'll have test it. @mtiutiu is working on it too, i did this node for training me because i'll develop other livolo EU ;)
                                        I think the mtiutiu node will be more optimised. I learned and i hope continu to learn many things with him.
                                          shabba
                                          hi @mtiutiu - I see https://github.com/mtiutiu/kicad/tree/master/mysensors/node/livolo_EU_switch/VL-C702X-2_Ver_C1 - Is this good to be ordered? If you give me a link on where you get a % I would like to order from there.
