  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • rhaymoR rhaymo
    first of all, thanks to user2684 for his great job.
    I wonder if it would possible adding a feature in nodeManager, where after a wake up from interrupt, only the onLoop method of the sensor attached to that pin is executed. onLoop of sensors not attached to interrupt are executed only after a full sleep cycle. (of course, this requires that after a wakeup from interrupt, the node come to sleep only for (sleepTime - elapsedTimeBeforeWakeup) )
    In my case, I have a sketch for a node with a temperature and door sensor. Temperature is sent each 60 minutes, while door status only on interrupt.
    U
    U
    user2684
    @rhaymo you're right, combining sensors waking up from an interrupt and sensors reporting periodically does not work properly with NodeManager right now. I've opened this enhancement request: https://github.com/mysensors/NodeManager/issues/41.
    It may be not trivial to implement so it will not be part of the next release which is almost ready but I'll work on it just after since looks like a key requirement for many projects.
    • U user2684
      Hi, being a newbie in this wonderful MySensors world, I found myself excited about the flexibility of the overall platform but also somehow implementing the same common functionalities across my sensors over and over again. I decided then to spend some reasonable amount of time to expand the idea behind MyExtention (https://forum.mysensors.org/topic/6062/myextension) into something I have called NodeManager (I know, I'm bad with names!).
      NodeManager is intended to take care on your behalf of all those common tasks a MySensors node has to accomplish, speeding up the development cycle of your projects. It should help who is new to MySensors to get up to speed quicker and for those already into the matter to delegate to NodeManager common and boring tasks so to focus on more interesting scenarios.
      NodeManager main features are:
      • Manage all the aspects of a sleeping cycle by leveraging smart sleep
      • Allow configuring the sleep mode and the sleep duration remotely
      • Allow waking up a sleeping node remotely at the end of a sleeping cycle
      • Allow powering on each connected sensor only while the node is awake to save battery
      • Report battery level periodically and automatically
      • Calculate battery level without requiring an additional pin and the resistors
      • Report battery voltage through a built-in sensor
      • Can report battery level on demand
      • Allow rebooting the board remotely
      • Provide out-of-the-box sensors personalities and automatically execute their main task at each cycle
      Specifically on this last point, the idea behind providing built-in the functionalities of most common sensors is to simplify the development especially for somebody new to it.
      E.g. if I connect a thermistor to one of the pin, I just need a single line to have it working, as it was leveraging some sort of embedded firmware:
      nodeManager.registerSensor(SENSOR_THERMISTOR,A2);
      The following built-in sensors are available:
      • SENSOR_ANALOG_INPUT Generic analog sensor, return a pin's analog value or its percentage
      • SENSOR_LDR LDR sensor, return the light level of an attached light resistor in percentage
      • SENSOR_THERMISTOR Thermistor sensor, return the temperature based on the attached thermistor
      • SENSOR_DIGITAL_INPUT Generic digital sensor, return a pin's digital value
      • SENSOR_DIGITAL_OUTPUT Generic digital output sensor, allows setting the digital output of a pin to the requested value
      • SENSOR_RELAY Relay sensor, allows activating the relay
      • SENSOR_LATCHING_RELAY Latching Relay sensor, allows activating the relay with a pulse
      • SENSOR_DHT11 DHT11 sensor, return temperature/humidity based on the attached DHT sensor
      • SENSOR_DHT22 DHT22 sensor, return temperature/humidity based on the attached DHT sensor
      • SENSOR_SHT21 SHT21 sensor, return temperature/humidity based on the attached SHT21 sensor
      • SENSOR_SWITCH Generic switch, wake up the board when a pin changes status
      • SENSOR_DOOR Door sensor, wake up the board and report when an attached magnetic sensor has been opened/closed
      • SENSOR_MOTION Motion sensor, wake up the board and report when an attached PIR has triggered
      • SENSOR_DS18B20 DS18B20 sensor, return the temperature based on the attached sensor
      I put the package on Sourceforce so to avoid leaving here piece of code which may become obsolete in a short time.
      The project is here: https://sourceforge.net/projects/mynodemanager
      I've also tried to document everything the best as I could on https://sourceforge.net/p/mynodemanager/wiki
      B
      B
      bilbolodz
      @user2684 Great plugin, thanks. Please: consider adding support for a more than one DS18B20 devices and fixed mapping sensor_id <-> DS18B20 id.
      U 1 Reply Last reply
      • R
        R
        Robbie_
        wrote on last edited by Robbie_
        #33
        Hi User2684,
        As promised i took NodeManager for a spin. It functions well but i have an issue with powering a DHT22 from the digital pins. It just does not show any temp/hum. If i use the power from the battery it functions well.
        Any clue what this could be?
        I used setPowerPins6,7,10000 to be sure the DHT22 has enough time to start up. If i use my multimeter between pins 6,7 i see the voltage going to 3.something volts and to 0 when the 10000 miliseconds are gone.
        My config is as following;
        // before
        void before() {
          Serial.begin(MY_BAUD_RATE);
           * Register below your sensors
          nodeManager.setSleep(SLEEP,1,MINUTES);
        nodeManager.registerSensor(SENSOR_DHT22,3);
        nodeManager.setPowerPins(6,7,10000);
           * Register above your sensors
          nodeManager.before();
        B 1 Reply Last reply
        • R Robbie_
          Hi User2684,
          // before
          void before() {
          B
          B
          bilbolodz
          @Robbie_ I've NOT checked anything but I think that probably better:
          1. power up DHT
          2. wait a little to "dht startup"
          3. register sensor
          R 1 Reply Last reply
          • B bilbolodz
            1. power up DHT
            3. register sensor
            R
            R
            Robbie_
            @bilbolodz
            So like this?
            • R Robbie_
              @bilbolodz
              So like this?
              B
              B
              bilbolodz
              @Robbie_ said in NodeManager: plugin for a rapid development of battery-powered sensors:
              Try this:
              wait(10000);
              nodeManager.registerSensor(SENSOR_DHT22,3);```
              • R
                R
                Robbie_
                #37
                @bilbolodz said in NodeManager: plugin for a rapid development of battery-powered sensors:
                wait(10000);
                Thanks for the fast reply! Still the same issue;
                SEND D=0 I=200 C=0 T=48 S=STARTED I=0 F=0.00
                14258 TSF:MSG:SEND,100-100-0-0,s=200,c=1,t=48,pt=0,l=7,sg=0,ft=0,st=OK:STARTED
                14395 MCO:BGN:INIT OK,TSP=1
                ON P=7
                14426 MCO:SLP:MS=10000,SMS=0,I1=255,M1=255,I2=255,M2=255
                14493 MCO:SLP:TPD
                14512 MCO:SLP:WUP=-1
                DHT I=1 T=nan
                OFF P=7
                SLEEP 60s
                SEND D=0 I=200 C=1 T=48 S=SLEEPING I=0 F=0.00
                • B bilbolodz
                  U
                  U
                  user2684
                  @bilbolodz multiple DS18B20 are supported indeed, when you register a DS18B20 sensor and provide the pin where multiple devices are attached, NodeManager will go through all of them (by calling getDeviceCount() of DallasTemperature) and will register each of them with a different child id. Is this what you were looking for?
                  • R Robbie_
                    wait(10000);
                    ON P=7
                    14493 MCO:SLP:TPD
                    DHT I=1 T=nan
                    OFF P=7
                    SLEEP 60s
                    U
                    U
                    user2684
                    Hi, @Robbie_ the order doesn't matter since all of this is happening inside before(), NodeManager just keeps track of all your settings without doing anything at that stage.
                    Your configuration looks correct to me, the DHT sensor attached to pin 3, pin 6 playing the role of ground, pin 7 the role of vcc and waiting for 10 seconds after powering on, before actually reading the value from the sensor. The log also tells the same story, pin 7 is turned on, then 10s of sleep and then the "nan" read which I cannot really understand (the code is very simple, just executes a digitalWrite(_vcc_pin, HIGH) at that stage).
                    Would you please ensure pin 7 is HIGH during the 10s sleep?
                    Not sure if it matters (and those more expert than me with a DHT sensor can confirm) but I've noticed that I call dht.begin() only once (during before()) and during loop() I just call readTemperature(). Does powering off the sensor have an impact on this? e.g. should I call begin() before every read?
                      I think you need to call the begin if you power off the sensor
                      • U user2684
                        B
                        B
                        bilbolodz
                        @user2684 said in NodeManager: plugin for a rapid development of battery-powered sensors:
                        Multiple sensors: great but for me important thing is "fixed" matching exact DS18B20 to particular child id. I'm going to monitor may two function water boiler and check input/output temperature. In case when one of the DS disappear (because of many reasons) after next nodemanager device startup assigning sensors to child id will change and it will be a great problem. That's why I'm asking for exact assigning DS id - child id. Is it clear now?
                          U
                          U
                          user2684
                          Thanks @gohan. @Robbie_ if you can then try copying that "_dht->begin();" you have in line 576 of NodeManager.cpp also at the beginning of "SensorDHT::onLoop()" which is just below we can see if this can help (unfortunately I don't have anymore a DHT sensor to test by myself).
                          Another try would be to disable both MySensors and NodeManager debug: I've seen strange behaviors happening when approaching the dynamic memory limit (including this) and since objects are allocated dynamically, it could be the case (this issue is partially mitigated in the dev branch)
                          • B bilbolodz
                            U
                            U
                            user2684
                            @bilbolodz I understand what you are saying. I've opened this: https://github.com/mysensors/NodeManager/issues/42. I did not consider this use case before because according to DallasTemperature documentation the attached sensors are always returned in the same order but you're right, if one of the sensor for any reason is not detected, it will mess up your logic. Thanks for reporting it.
                            B V 2 Replies Last reply
                            • U user2684
                              B
                              B
                              bilbolodz
                              @user2684 Great, so I'm waiting for version 1.4. Any ideas about timeline?
                              • U user2684
                                V
                                V
                                vikasjee
                                @user2684 This is exactly i had mentioned in my requirement for IOExpanded pins attached to any sensor or virtual buttons... getting the same child_id everytime. Hope its clear now...
                                • U user2684
                                  R
                                  R
                                  Robbie_
                                  #46
                                  @user2684 Thanks for your reply. Ive tested the following;
                                  i editted the NodeManager.cpp and added _dht->begin(); to the beginning of "SensorDHT::onLoop()"
                                  I also disabled both debug, still the same issue.
                                  In your other post you mentioned "Would you please ensure pin 7 is HIGH during the 10s sleep?"
                                  My log looks as following;
                                  PWR G=6 V=7
                                  REG I=1 P=3 P=6 T=0
                                  REG I=2 P=3 P=7 T=1
                                  NodeManager v1.30
                                  INT1 M=255
                                  INT2 M=255
                                  RADIO OK
                                  PRES I=200, T=23
                                  PRES I=201, T=30
                                  BATT V=3.26 P=94
                                  SEND D=0 I=201 C=0 T=38 S= I=0 F=3.26
                                  PRES I=1 T=6
                                  PRES I=2 T=7
                                  READY
                                  MY I=100 M=1
                                  ON P=7
                                  DHT I=1 T=nan
                                  OFF P=7
                                  SLEEP 60s
                                  AWAKE
                                  SEND D=0 I=200 C=1 T=48 S=AWAKE I=0 F=0.00
                                  ON P=7
                                  DHT I=1 T=nan
                                  OFF P=7
                                  SLEEP 60s
                                  Where do you want me to messure if the pin is on?
                                  AWAKE
                                  ON P=7
                                  DHT I=1 T=nan
                                  <------------------------ I messured here and the voltage is 3.something volts
                                  OFF P=7
                                  SLEEP 60s
                                  <--------------------------- HERE?
                                    use a multimeter and check if pin 7 during the startup of the arduino and see if you get 5v out for 10 seconds
                                    • B bilbolodz
                                      U
                                      U
                                      user2684
                                      wrote on last edited by user2684
                                      #48
                                      @bilbolodz v1.4 is actually ready, just want to see if the DHT issue discussed here requires a code fix or not before releasing but it is already available in the dev branch (https://github.com/mysensors/NodeManager/tree/8280de908929a117287a70e73cd047f50ab9a5bb). Let me explain the way I have implemented it because may look cumbersome but I didn't want to make exceptions and have a sensor configured in a different way the all the others.
                                      First of all, for any sensor, the child id can be manually assigned by providing a third argument to registerSensor(), e.g. to assign child id 5:
                                      nodeManager.registerSensor(SENSOR_THERMISTOR,A1,5);
                                      This was available also in v1.3 but not very clear from the docs. Of course this approach does not work when you have multiple DS18B20 sensors attached since they are all configured with a single line.
                                      So I have implemented a renameSensor() function which basically assign a different child id, e.g. to give the sensor with child id 1 the child id 5:
                                      nodeManager.renameSensor(1,5);
                                      This is available for all the sensors. So in the case of multiple DS18B20 you need to register them all in the usual way ( registerSensor(SENSOR_DS18B20,pin)) then assign the child id you like just after so in case one is lost, you still have a static mapping. The alternative would have been to provide a special registerSensor only for DS18B20 which I don't like that much. Any other better alternative of course is more than welcome!
                                      Btw, I have also added for DS18B20 getDeviceAddress() - in case you want to assign the child id based on the device address, getResolution() and setResolution()
                                      • R Robbie_
                                        PWR G=6 V=7
                                        REG I=1 P=3 P=6 T=0
                                        REG I=2 P=3 P=7 T=1
                                        NodeManager v1.30
                                        INT1 M=255
                                        INT2 M=255
                                        RADIO OK
                                        PRES I=200, T=23
                                        PRES I=201, T=30
                                        BATT V=3.26 P=94
                                        PRES I=1 T=6
                                        PRES I=2 T=7
                                        READY
                                        MY I=100 M=1
                                        ON P=7
                                        DHT I=1 T=nan
                                        OFF P=7
                                        SLEEP 60s
                                        AWAKE
                                        ON P=7
                                        DHT I=1 T=nan
                                        OFF P=7
                                        SLEEP 60s
                                        AWAKE
                                        ON P=7
                                        DHT I=1 T=nan
                                        OFF P=7
                                        SLEEP 60s
                                        U
                                        U
                                        user2684
                                        @Robbie_ even if unfortunately I do not have a spare DHT sensor to test right now, I did some tests with other sensors trying to understand the issue. My educated guess it that the problem is related to the fact that setPowerPins() set both ground and vcc but initialize both to LOW. This means that when you register the sensor (and the DHT library is initialized), the sensor is off. This behavior will be changed in v1.4 (vcc wil be set to high). What you can do with the version you are currently running is to call nodeManager.powerOn() just after the call to setPowerPins() and before registering the sensor so to keep the power on.
                                        If this does not work, try calling nodeManager.setAutoPowerPins(false) after setPowerPins(): this prevent nodeManager to turn the power off which is not what you want but can help in isolating the issue.
                                        • luizrrochaL
                                          luizrrochaL
                                          luizrrocha
                                          Hello, good work !!! I'll be trying your extension very soon....
                                          Quick question: is it compatible with ATMEGA chips flashed with MYSBootloader pre-1.3a ?
