  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • U user2684
    @bilbolodz I understand what you are saying. I've opened this: https://github.com/mysensors/NodeManager/issues/42. I did not consider this use case before because according to DallasTemperature documentation the attached sensors are always returned in the same order but you're right, if one of the sensor for any reason is not detected, it will mess up your logic. Thanks for reporting it.
    B
    B
    bilbolodz
    @user2684 Great, so I'm waiting for version 1.4. Any ideas about timeline?
    U 1 Reply Last reply
    • U user2684
      V
      V
      vikasjee
      @user2684 This is exactly i had mentioned in my requirement for IOExpanded pins attached to any sensor or virtual buttons... getting the same child_id everytime. Hope its clear now...
      • U user2684
        Hi, @Robbie_ the order doesn't matter since all of this is happening inside before(), NodeManager just keeps track of all your settings without doing anything at that stage.
        Your configuration looks correct to me, the DHT sensor attached to pin 3, pin 6 playing the role of ground, pin 7 the role of vcc and waiting for 10 seconds after powering on, before actually reading the value from the sensor. The log also tells the same story, pin 7 is turned on, then 10s of sleep and then the "nan" read which I cannot really understand (the code is very simple, just executes a digitalWrite(_vcc_pin, HIGH) at that stage).
        Would you please ensure pin 7 is HIGH during the 10s sleep?
        Not sure if it matters (and those more expert than me with a DHT sensor can confirm) but I've noticed that I call dht.begin() only once (during before()) and during loop() I just call readTemperature(). Does powering off the sensor have an impact on this? e.g. should I call begin() before every read?
        R
        R
        Robbie_
        wrote on last edited by Robbie_
        #46
        @user2684 Thanks for your reply. Ive tested the following;
        i editted the NodeManager.cpp and added _dht->begin(); to the beginning of "SensorDHT::onLoop()"
        I also disabled both debug, still the same issue.
        In your other post you mentioned "Would you please ensure pin 7 is HIGH during the 10s sleep?"
        My log looks as following;
        PWR G=6 V=7
        REG I=1 P=3 P=6 T=0
        REG I=2 P=3 P=7 T=1
        NodeManager v1.30
        INT1 M=255
        INT2 M=255
        RADIO OK
        PRES I=200, T=23
        PRES I=201, T=30
        BATT V=3.26 P=94
        SEND D=0 I=201 C=0 T=38 S= I=0 F=3.26
        PRES I=1 T=6
        PRES I=2 T=7
        READY
        MY I=100 M=1
        SEND D=0 I=200 C=0 T=48 S=STARTED I=0 F=0.00
        ON P=7
        DHT I=1 T=nan
        OFF P=7
        SLEEP 60s
        SEND D=0 I=200 C=1 T=48 S=SLEEPING I=0 F=0.00
        AWAKE
        SEND D=0 I=200 C=1 T=48 S=AWAKE I=0 F=0.00
        ON P=7
        DHT I=1 T=nan
        OFF P=7
        SLEEP 60s
        Where do you want me to messure if the pin is on?
        AWAKE
        ON P=7
        DHT I=1 T=nan
        <------------------------ I messured here and the voltage is 3.something volts
        OFF P=7
        SLEEP 60s
        <--------------------------- HERE?
          use a multimeter and check if pin 7 during the startup of the arduino and see if you get 5v out for 10 seconds
          • B bilbolodz
            U
            U
            user2684
            wrote on last edited by user2684
            #48
            @bilbolodz v1.4 is actually ready, just want to see if the DHT issue discussed here requires a code fix or not before releasing but it is already available in the dev branch (https://github.com/mysensors/NodeManager/tree/8280de908929a117287a70e73cd047f50ab9a5bb). Let me explain the way I have implemented it because may look cumbersome but I didn't want to make exceptions and have a sensor configured in a different way the all the others.
            First of all, for any sensor, the child id can be manually assigned by providing a third argument to registerSensor(), e.g. to assign child id 5:
            nodeManager.registerSensor(SENSOR_THERMISTOR,A1,5);
            This was available also in v1.3 but not very clear from the docs. Of course this approach does not work when you have multiple DS18B20 sensors attached since they are all configured with a single line.
            So I have implemented a renameSensor() function which basically assign a different child id, e.g. to give the sensor with child id 1 the child id 5:
            nodeManager.renameSensor(1,5);
            This is available for all the sensors. So in the case of multiple DS18B20 you need to register them all in the usual way ( registerSensor(SENSOR_DS18B20,pin)) then assign the child id you like just after so in case one is lost, you still have a static mapping. The alternative would have been to provide a special registerSensor only for DS18B20 which I don't like that much. Any other better alternative of course is more than welcome!
            Btw, I have also added for DS18B20 getDeviceAddress() - in case you want to assign the child id based on the device address, getResolution() and setResolution()
            B 1 Reply Last reply
            • R Robbie_
              PWR G=6 V=7
              REG I=1 P=3 P=6 T=0
              REG I=2 P=3 P=7 T=1
              NodeManager v1.30
              INT1 M=255
              INT2 M=255
              RADIO OK
              PRES I=200, T=23
              PRES I=201, T=30
              BATT V=3.26 P=94
              PRES I=1 T=6
              PRES I=2 T=7
              READY
              MY I=100 M=1
              ON P=7
              DHT I=1 T=nan
              OFF P=7
              SLEEP 60s
              AWAKE
              ON P=7
              DHT I=1 T=nan
              OFF P=7
              SLEEP 60s
              AWAKE
              ON P=7
              DHT I=1 T=nan
              OFF P=7
              SLEEP 60s
              U
              U
              user2684
              @Robbie_ even if unfortunately I do not have a spare DHT sensor to test right now, I did some tests with other sensors trying to understand the issue. My educated guess it that the problem is related to the fact that setPowerPins() set both ground and vcc but initialize both to LOW. This means that when you register the sensor (and the DHT library is initialized), the sensor is off. This behavior will be changed in v1.4 (vcc wil be set to high). What you can do with the version you are currently running is to call nodeManager.powerOn() just after the call to setPowerPins() and before registering the sensor so to keep the power on.
              If this does not work, try calling nodeManager.setAutoPowerPins(false) after setPowerPins(): this prevent nodeManager to turn the power off which is not what you want but can help in isolating the issue.
              R 1 Reply Last reply
              • luizrrochaL
                luizrrochaL
                luizrrocha
                Hello, good work !!! I'll be trying your extension very soon....
                Quick question: is it compatible with ATMEGA chips flashed with MYSBootloader pre-1.3a ?
                • luizrrochaL luizrrocha
                  U
                  U
                  user2684
                  #51
                  @luizrrocha I did not test it by myself but the bootloader used should have no impact on the code (unless you need to call different/specific functions with that bootloader but I guess this is not the case).
                  • U user2684
                    R
                    R
                    Robbie_
                    @user2684 Ive tested this morning a DHT22 without resistor between VIN & DATA, now it works correct. I reverted the changes back and just use the default code (1.3), everything keeps functioning. I don't understand why it works but hey, i got data! :-)
                    Somehow the following issue pops up with domoticz (also before the DHT22 was working), im not sure if anybody can help me here with it, else il open a threat at the domoticz forum. As soon ase NodeManager presents itself (via ESP8266 WiFi Gateway // MyS v2.1.0) to domoticz, domoticz goes offline. Does somebody else had the same experiance?
                    R 2 Replies Last reply
                    • R Robbie_
                      R
                      R
                      Robbie_
                      • R Robbie_
                        R
                        R
                        Robbie_
                        @Robbie_ Narrowed down the issue with domoticz, if i #define SERVICE_MESSAGES 1 in config.h domoticz crashes, if i put it back to 0 it stays online.
                        • R Robbie_
                          U
                          U
                          user2684
                          @Robbie_ glad to see it is working now! It has been still a good excuse for me to review and correct the logic of the power pins. Regarding SERVICE_MESSAGES, NodeManager sends a set of V_CUSTOM, SET messages from its service child id 200. When starts, it sends a STARTED payload , when going to sleep SLEEPING and when out of sleep AWAKE. I'm not familiar with domoticz but the service child id is presented correctly as S_CUSTOM, maybe the controller does not expect or handle a string payload. However, if you disable SERVICE_MESSAGES, this has no impact on the way NodeManager works, it just does not send those messages but if you are not using them, you are ready to go.
                          In future versions I should probably even disable SERVICE_MESSAGES by default also because I expect it costs in terms of battery to send string payloads...
                          • U
                            U
                            user2684
                            Hi, v1.4 is out and available at https://github.com/mysensors/NodeManager:
                            • Added support for ML8511 UV intensity sensor
                            • Added support for MQ air quality sensor
                            • Added ability to manually assign a child id to a sensor
                            • Ensured compatibility for non-sleeping nodes
                            • Ability to control if waking up from an interrupt counts for a battery level report
                            • When power pins are set the sensor is powered on just after
                            • Service messages are disabled by default
                            • Bug fixes
                            Full changelog at https://github.com/mysensors/NodeManager/milestone/4?closed=1
                            • mar.conteM
                              mar.conteM
                              mar.conte
                              wrote on last edited by mar.conte
                              #57
                              I am trying to sketch a simple PIR motion as an example the official NodeManager but does not appear to me the pir of domoticz
                              DOMOTICZ OUTPUT
                              1	S_TEMP		#1. V_TEMP (56.5)	true	1200	2017-04-09 12:11:15
                              200	S_CUSTOM			true	1200	2017-04-09 11:34:45
                              201	S_MULTIMETER			true	1200	2017-04-09 12:11:15
                              255	S_ARDUINO_NODE	2.1.1```
                              SKETCH
                              NodeManager is intended to take care on your behalf of all those common tasks a MySensors node has to accomplish, speeding up the development cycle of your projects.
                              NodeManager includes the following main components:
                              - Sleep manager: allows managing automatically the complexity behind battery-powered sensors spending most of their time sleeping
                              - Power manager: allows powering on your sensors only while the node is awake
                              - Battery manager: provides common functionalities to read and report the battery level
                              - Remote configuration: allows configuring remotely the node without the need to have physical access to it
                              - Built-in personalities: for the most common sensors, provide embedded code so to allow their configuration with a single line
                              Documentation available on: https://mynodemanager.sourceforge.io
                              // load user settings
                              #include "config.h"
                              // load MySensors library
                              // load NodeManager library
                              #include "NodeManager.h"
                              // create a NodeManager instance
                              NodeManager nodeManager;
                              // before
                              void before() {
                                Serial.begin(MY_BAUD_RATE);
                                 * Register below your sensors
                                nodeManager.setSleep(SLEEP,60,MINUTES);
                                nodeManager.registerSensor(SENSOR_MOTION,3);
                                 * Register above your sensors
                                nodeManager.before();
                              // presentation
                              	sendSketchInfo(SKETCH_NAME,SKETCH_VERSION);
                                nodeManager.presentation();
                              // setup
                                nodeManager.setup();
                              // loop
                                nodeManager.loop();
                              // receive
                                nodeManager.receive(message);
                              M.C.
                              gohanG 1 Reply Last reply
                              • U user2684
                                B
                                B
                                bilbolodz
                                @user2684 said in NodeManager: plugin for a rapid development of battery-powered sensors:
                                Thanks for support but actually in case of multiple DS18B20 your "general solution" is not very useful..... It require manual checking ID (first it IDs need to bs stored in EEPROM) renaming child id sensor in case of change and so on. In my private opinion it could be better add special registerSensor() function which takes pin and DS18B20 ID and register sensor (or not). Please consider these.
                                • mar.conteM mar.conte
                                  DOMOTICZ OUTPUT
                                  SKETCH
                                  #include "config.h"
                                  // before
                                  void before() {
                                  // presentation
                                  // setup
                                  // loop
                                    nodeManager.loop();
                                  // receive
                                  @mar.conte please include node log and gateway log when node tries to connect
                                  mar.conteM 1 Reply Last reply
                                  • BeniKB
                                    BeniKB
                                    BeniK
                                    Needles to say and re-say this is really a much needed plugin for us beginners!
                                    Made a bunch of battery operating nodes with only DHT22 and all are working flawlessly.
                                    Today I tried making a node using a DS18B20 and DHT22. DS18B20 connected to digital pin 3 and DHT22 to digital pin 4. Both sensors have 10K resistors between their vcc and data lines (tried without resistors but none of the sensors worked).
                                    Sketch compiles and uploads fine to a Arduino Pro Mini 328 3.3v 8MHz. It also connects to the gateway, but I run into some problems;
                                    The first one being that watching from the serial debug, the node strarts up, connects to the gateway, reports some data and then hangs. No more activity from the node watching on the serial debug.
                                    The second one is that the node never sleeps - Activity led on Arduino Pro Mini remains lit.
                                    The last one is that DS18B20 reports the Temp to the gateway but DHT22 reports only Temp and not the Humidity. Tried changing pins for the sensors, but the same.
                                    Connection logs (from the serial interface) are as follows:
                                    REG I=1 P=3 P=6 T=0
                                    REG I=2 P=4 P=6 T=0
                                    REG I=3 P=4 P=7 T=1
                                    NodeManager v1.4
                                    INT1 M=255
                                    INT2 M=255
                                    RADIO OK
                                    PRES I=200, T=23
                                    PRES I=201, T=30
                                    BATT V=3.44 P=100
                                    SEND D=0 I=201 C=0 T=38 S= I=0 F=3.44
                                    PRES I=1 T=6
                                    PRES I=2 T=6
                                    PRES I=3 T=7
                                    READY
                                    MY I=199 M=1
                                    DS18B20 I=1 T=47.75
                                    SEND D=0 I=1 C=0 T=0 S= N=0 F=47.75
                                    DHT I=2 T=25.00
                                    SEND D=0 I=2 C=0 T=0 S= N=0 F=25.00
                                    And the sketch I use is as follows:
                                    Documentation available on: https://github.com/mysensors/NodeManager
                                    #include "config.h"
                                    // before
                                    void before() {
                                        nodeManager.setBatteryMin(2.0);
                                        nodeManager.setBatteryMax(3.3);
                                        nodeManager.setSleep(SLEEP,60,SECONDS);
                                        nodeManager.registerSensor(SENSOR_DS18B20,3);
                                        nodeManager.registerSensor(SENSOR_DHT22,4);
                                    // presentation
                                    // setup
                                    // loop
                                      nodeManager.loop();
                                    // receive
                                    Also on config.h I have enabled DS18B20 and DHT22 modules.
                                    Really, any help would be welcome!
                                    Thanks all in advance!
                                      mar.conteM
                                      mar.conteM
                                      mar.conte
                                      #61
                                      @gohan
                                      node
                                      40 MCO:BGN:BFR
                                      REG I=1 P=3 P=6 T=0
                                      NodeManager v1.4
                                      INT1 M=255
                                      INT2 M=255
                                      59 TSM:INIT
                                      135 TSF:WUR:MS=0
                                      155 TSM:INIT:TSP OK
                                      176 TSM:INIT:STATID=100
                                      202 TSF:SID:OK,ID=100
                                      225 TSM:FPAR
                                      370 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2244 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      2301 TSF:MSG:FPAR OK,ID=0,D=1
                                      2447 TSM:FPAR:OK
                                      2463 TSM:ID
                                      2478 TSM:ID:OK
                                      2492 TSM:UPL
                                      2639 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                      3678 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      3737 TSF:MSG:PONG RECV,HP=1
                                      3768 TSM:UPL:OK
                                      3784 TSM:READY:ID=100,PAR=0,DIS=1
                                      3883 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                      4003 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      4202 !TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
                                      4415 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=NACK:0
                                      6733 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=2,st=NACK:NodeManagerTemplate
                                      6928 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=3,st=OK:1.0
                                      RADIO OK
                                      PRES I=200, T=23
                                      7137 !TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=NACK:
                                      PRES I=201, T=30
                                      7321 TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=OK:
                                      BATT V=3.25 P=93
                                      SEND D=0 I=201 C=0 T=38 S= I=0 F=3.25
                                      7469 !MCO:SND:NODE NOT REG
                                      7587 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:93
                                      PRES I=1 T=6
                                      7794 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
                                      READY
                                      7868 MCO:REG:REQ
                                      7933 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                                      9019 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      9078 MCO:PIM:NODE REG=1
                                      9105 MCO:BGN:STP
                                      MY I=100 M=1
                                      9123 MCO:BGN:INIT OK,TSP=1
                                      THER I=1 V=354.00 T=40.05
                                       M=1
                                      SEND D=0 I=1 C=0 T=0 S= N=0 F=40.05
                                      9224 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:40.05
                                      SLEEP 3600s
                                      9316 MCO:SLP:MS=3600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                                      9527 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:287
                                      9607 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      9666 !TSF:MSG:LEN,0!=8
                                      10108 MCO:SLP:TPD```
                                      Gateway
                                      0;255;3;0;9;TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;TSF:MSG:BC
                                      0;255;3;0;9;TSF:MSG:FPAR REQ,ID=100
                                      0;255;3;0;9;TSF:PNG:SEND,TO=0
                                      0;255;3;0;9;TSF:CKU:OK
                                      0;255;3;0;9;TSF:MSG:GWL OK
                                      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                      0;255;3;0;9;TSF:MSG:PINGED,ID=100,HP=1
                                      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
                                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/0/0/17
                                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=19,sg=0:NodeManagerTemplate
                                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/11
                                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=200,c=0,t=23,pt=0,l=0,sg=0:
                                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/200/0/0/23
                                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=0,pt=1,l=1,sg=0:85
                                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/0
                                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=1,c=1,t=0,pt=7,l=5,sg=0:36.72
                                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/1/1/0/0
                                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=22,pt=5,l=4,sg=0:286
                                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/22
                                      0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/0/3/0/18
                                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/22
                                      M.C.
                                        I think relay is the pir sensor you are looking for.
                                          @gohan
                                          node
                                          40 MCO:BGN:BFR
                                          REG I=1 P=3 P=6 T=0
                                          NodeManager v1.4
                                          INT1 M=255
                                          INT2 M=255
                                          59 TSM:INIT
                                          135 TSF:WUR:MS=0
                                          155 TSM:INIT:TSP OK
                                          225 TSM:FPAR
                                          2447 TSM:FPAR:OK
                                          2463 TSM:ID
                                          2478 TSM:ID:OK
                                          2492 TSM:UPL
                                          3768 TSM:UPL:OK
                                          RADIO OK
                                          PRES I=200, T=23
                                          PRES I=201, T=30
                                          BATT V=3.25 P=93
                                          PRES I=1 T=6
                                          READY
                                          7868 MCO:REG:REQ
                                          9105 MCO:BGN:STP
                                          MY I=100 M=1
                                           M=1
                                          SLEEP 3600s
                                          Gateway
                                          U
                                          U
                                          user2684
                                          @mar.conte your configuration looks correct, SENSOR_MOTION is what you want to use indeed. However, the logs are saying NodeManager is presenting the sensor as S_TEMP so the issue is on NodeManager's side also because looks like SensorThermistor has been instantiated but if I look at the code, there is no way this should happen.I'll try to setup something similar to see if I can reproduce the behavior. Very stupid question: are you sure you have uploaded successfully that sketch and it is not an old one? I really cannot explain it otherwise at a first look...
