  3. (SOLVED) complete reset for registration and adding
6 Posts 2 Posters 2.1k Views 2 Watching
  • markjgabbM Offline
    markjgabbM Offline
    markjgabb
    wrote on last edited by markjgabb
    hi guys
    i have a issue with my mysensors gateway
    i had a node in that was giving me trouble
    so i rebuilt the code and changed the number of relays on it, and added it in and watched it register on domoticz
    but after changing it a 3rd time i got really confused on which node it was, so deleted both out of domoticz.
    now neither of them appear and im not sure how to get them to re register....
    so i planned to now that i have played around a little and gotten to understand a bit more, just resetting mysensors gateway fully so that i can re register all devices and have them reconnect correctly...
    is this possible?
    • markjgabbM markjgabb
      hi guys
      is this possible?
      @markjgabb the gateway does not keep state, so there is nothing to reset. All state is handled by the controller. I am not sure if there is a better way to reset Domoticz than re-installing it. You could try to clear the eeprom of the node and let it get a new id.
        markjgabbM Offline
        markjgabb
        that might be the best way....
        as once it has presented to domoticz it doesnt reconize it as a new device again
        so clearing eepron may cause it to re present correctly
          @markjgabb it is already presenting correctly. But since you have instructed Domoticz to ignore that node (by deleting it), Domoticz will obey your order and keep ignoring it.
          If you clear the eeprom, the node will ask Domoticz fow a new ID. Domoticz will give the node a new ID, which is not ignored.
            markjgabbM Offline
            markjgabb
            ahhh that makes so much sense now.....
            perfect, ill do that tonight... i really should remember to save my sensor files properly
              markjgabbM Offline
              markjgabb
              this solution has worked perfectly
              thanks guys for all your advice...domoticz definatly cant un ignore anyway that i can find either
              12.1k
