  3. 💬 NodeManager
💬 NodeManager
contest2017arduinonewbiemysensorsbattery sensor
196 Posts 42 Posters 117.0k Views 41 Watching
  • U
    U
    user2684
    @Ivan-Z if you mean an example with DHT22, you need first of all to enable the DHT module in config.h with:
    #define MODULE_DHT 1
    Then just register the sensor in before() with:
    nodeManager.registerSensor(SENSOR_DHT22,6);
    Where 6 is the pin where the sensor is attached to. NodeManager will then create automatically two child ids, one for temperature and the other for humidity.
    As written in the documentation you need the DHT library from https://github.com/adafruit/DHT-sensor-library (or install it by using the arduino IDE). For some unknown (to me) reasons I had issues in using the library from the mysensors example.
    What do you mean by optimization flag?
    As for avoid sending the same value, this is already available, have a look at setTackLastValue() from the documentation. When set to true, the value will not be send if the same as the previous (default is of course false). I also implemented setForceUpdate(), to force to send an update after the configured number of cycles, as many examples here are using this approach.
    D 1 Reply Last reply
    • U
      U
      user2684
      Hi, I've updated the project (including files and documentation) to version 1.4.
      Main changes are:
      • Added support for ML8511 UV intensity sensor
      • Added support for MQ air quality sensor
      • Added ability to manually assign a child id to a sensor
      • Ensured compatibility for non-sleeping nodes
      • Ability to control if waking up from an interrupt counts for a battery level report
      • When power pins are set the sensor is powered on just after
      • Service messages are disabled by default
      • Bug fixes
        https://www.openhardware.io/view/363/NodeManager
        Straydog
        @openhardware.io Great idea. Can we expect to see support for Sonoff/ESP8266(without SLEEP) in a near future?
        Also, would love to see an example of a custom sensor/HC-SR04 distance sensor, 3-pin implementation.
        Keep up the great work.
        U 3 Replies Last reply
        • S Straydog
          U
          U
          user2684
          @Straydog said in 💬 NodeManager:
          Thanks for the advice! I'd be very happy to support any sensor which would be useful for the community! I've opened https://github.com/mysensors/NodeManager/issues/63 and https://github.com/mysensors/NodeManager/issues/62.
          Since I don't have those sensors and delivery is kind of a pain, would you like to give me a hand in testing the code I can put together? If so, please add a comment on git with some sample code and I'll integrate it into NodeManager straight away for your testing.
            @user2684
            If you send me your paypal email, I'll forward community donations to help you buy a sonoff and HC-SR04 for testing.
            • jlehtinenJ
              jlehtinenJ
              jlehtinen
              @user2684 Good work with NodeManager, greatly appreciated by "MySensors noob" like myself! :+1:
              • Ivan ZI
                Ivan ZI
                Ivan Z
                This version already allows wizard (.php) to generate a sketch
                • S Straydog
                  U
                  U
                  user2684
                  I spend some time in the forum but still I'm struggling a bit to understand the Sonoff use case to then buy the right piece to test. Is it related to what has been discussed in this thread?
                  https://forum.mysensors.org/topic/5858/sonoff-relay-using-mysensors-esp8266-wifi-or-mqtt-gateway
                  EfflonE S 2 Replies Last reply
                  • U user2684
                    EfflonE
                    EfflonE
                    Efflon
                    @user2684 I have a sonoff and have posted a few examples here https://www.mysensors.org/build/sonoff, nodeManager would maybe save a few lines of code for the end user but you will have quite a lot to code :smile: I guess if you add esp8266 support, the sonoff is just a relay with a LED and a button which nodeManager already supports.
                    U 1 Reply Last reply
                    • S Straydog
                      U
                      U
                      user2684
                      @Straydog just to be sure I'm buying the right sensor, I can only see HC-SR04 with 4 pins on aliexpress I guess this is the right sensor but I will use only three of the four pins, is it the case?
                      S 1 Reply Last reply
                      • EfflonE Efflon
                        U
                        U
                        user2684
                        @Efflon said in 💬 NodeManager:
                        Cool project, I wonder how I've missed it so far! I understand the idea, basically the sonoff runs as a gateway (otherwise would require a radio attached which is not possible/easy) and has a relay type of sensor attached. I think I can make it easily, I'm ordering a sonoff right now so to test the implementation. I need this https://github.com/mysensors/NodeManager/issues/65 first of all and then I can adapt the SENSOR_RELAY which is already available in NodeManager. I'll keep you posted while I will progress.
                        • U user2684
                          Straydog
                          @user2684 It's the regular HC-SR04, with ECHO & TRIGGER soldered together. I believe you can get them in either 5 or 3.3V
                          There are only 3 exposed pins on the SonOff SV, I need the other pins for other sensors.
                          Would like to help you test this project, tried to sign up to GIT yesterday but all Usernames came back as in use, will try again.
                          Two issues 1) AVR/EEPROM is not found, with PERSIST 0 & board ESP8266. 2) Don't know how to define HC-SR04 as a custom sensor, or can disguise it as another sensor type, with a PulseWidth.
                          Great job
                          • U user2684
                            Straydog
                            @user2684 You mean, why use SonOff?!?!
                            In my case I want to have sensors I can control over the Internet i.e. SonOff for the garage door opener(RELAY), with a PIR and HC_SR04.
                            I also prefer the SonOff/ESP8266 as it has more memory than the Arduino.
                            • S Straydog
                              Great job
                              U
                              U
                              user2684
                              Great, so if I order the HC-SR04 with 4 pins I should be ready to go. As for the Sonoff, I'm working on it right now, I need to add a few conditions here and there to have NodeManager running as a gateway but it is not that complicated. I'll let you know when I have something ready to test, can be quicker while I'm waiting my sonoff to be delivered.
                              As for the Sonoff use case it took me a while because it was not clear to me why a gateway and not a node but now I can see it clearly. And btw I needed something similar at home so I'll explore it even more ;-)
                              • K
                                K
                                ksga
                                wrote on last edited by ksga
                                #23
                                Way too cool solution :dancers:
                                I decided to give it a go with my Light/Baro/Hum/Temp node.
                                Installed the dependencies from Adafruit, cleared EEPROM, compiled and flashed - no issues :+1:
                                The node reports the expected sensors to MyController.
                                The BH1750 light sensor works like a charm, but I'm not getting anything from the BME280 except from a 0.0°C reading on temperature (which, even though spring is pretty lousy so far is a bit on the low side for my office).
                                Output on serial looks like this:
                                PWR G=6 V=7
                                REG I=1 P=18 P=16 T=37
                                REG I=2 P=18 P=6 T=0
                                REG I=3 P=18 P=7 T=1
                                REG I=4 P=18 P=8 T=4
                                NodeManager v1.4
                                INT1 M=255
                                INT2 M=255
                                RADIO OK
                                PRES I=200, T=23
                                PRES I=201, T=30
                                BATT V=3.35 P=94
                                SEND D=0 I=201 C=0 T=38 S= I=0 F=3.35
                                PRES I=1 T=16
                                PRES I=2 T=6
                                PRES I=3 T=7
                                PRES I=4 T=8
                                READY
                                MY I=1 M=1
                                ON P=7
                                BH1 I=1 L=2500
                                SEND D=0 I=1 C=0 T=37 S= N=2500 F=0.00
                                BME I=2 T=0.00
                                SEND D=0 I=2 C=0 T=0 S= N=0 F=0.00
                                BME I=3 H=69.25
                                SEND D=0 I=3 C=0 T=1 S= N=0 F=69.25
                                BME I=4 P=0.00
                                SEND D=0 I=4 C=0 T=4 S= N=0 F=0.00
                                OFF P=7
                                SLEEP 300s
                                AWAKE
                                ON P=7
                                BH@PWR G=6 V=7
                                NodeManager v1.4
                                INT1 M=255
                                INT2 M=255
                                RADIO OK
                                PRES I=200, T=23
                                PRES I=201, T=30
                                BATT V=3.35 P=94
                                PRES I=1 T=16
                                PRES I=2 T=6
                                PRES I=3 T=7
                                PRES I=4 T=8
                                READY
                                MY I=1 M=1
                                ON P=7
                                BH1 I=1 L=9951
                                SEND D=0 I=1 C=0 T=37 S= N=9951 F=0.00
                                BME I=2 T=0.00
                                BME I=3 H=69.25
                                BME I=4 P=0.00
                                OFF P=7
                                SLEEP 300s
                                The node was running fine for months using the same BH1750 library, but the BME280 library by Tyler Glenn.
                                Any ideas?
                                Should notice that I'm using this kind of BME280 from Ali
                                • K ksga
                                  PWR G=6 V=7
                                  NodeManager v1.4
                                  INT1 M=255
                                  INT2 M=255
                                  RADIO OK
                                  PRES I=200, T=23
                                  PRES I=201, T=30
                                  BATT V=3.35 P=94
                                  PRES I=1 T=16
                                  PRES I=2 T=6
                                  PRES I=3 T=7
                                  PRES I=4 T=8
                                  READY
                                  MY I=1 M=1
                                  ON P=7
                                  BH1 I=1 L=2500
                                  BME I=2 T=0.00
                                  BME I=3 H=69.25
                                  BME I=4 P=0.00
                                  OFF P=7
                                  SLEEP 300s
                                  AWAKE
                                  ON P=7
                                  BH@PWR G=6 V=7
                                  NodeManager v1.4
                                  INT1 M=255
                                  INT2 M=255
                                  RADIO OK
                                  PRES I=200, T=23
                                  PRES I=201, T=30
                                  BATT V=3.35 P=94
                                  PRES I=1 T=16
                                  PRES I=2 T=6
                                  PRES I=3 T=7
                                  PRES I=4 T=8
                                  READY
                                  MY I=1 M=1
                                  ON P=7
                                  BH1 I=1 L=9951
                                  BME I=2 T=0.00
                                  BME I=3 H=69.25
                                  BME I=4 P=0.00
                                  OFF P=7
                                  SLEEP 300s
                                  Any ideas?
                                  U
                                  U
                                  user2684
                                  @ksga I can see from the logs the light sensor correctly returning something but the BME280 apparently only able to get the humidity. I also see the node rebooting itself at a certain point. Was it you resetting it? Because if it was not you, it may be due to the memory almost full and when this happens, the behaviors I've seen are really unpredictable including weird numbers reported. To start with, I'd recommend to disable NodeManager's debug which will save some memory and see on the controller if the data returned is correct. If it is still not correct, do you set any specific i2c channel in the other sketch where both the sensors are working fine? I wonder if there is any difference between the two sketches.
                                  Also, are the sensors powered by pin 6 and 7? If so I'd power them directly just to take away this variable at least for now.
                                  K 1 Reply Last reply
                                  • U user2684
                                    K
                                    K
                                    ksga
                                    @user2684 Yeah.. missed that it rebooted... Thanks.
                                    I cleared EEPROM again, recompiled with and without debug (no usable result without, so decided to add eyes again :) )
                                    void before() part of the sketch looks like this:
                                    // before
                                    void before() {
                                      Serial.begin(MY_BAUD_RATE);
                                       * Register below your sensors
                                      nodeManager.setSleep(SLEEP,1,MINUTES);
                                      nodeManager.registerSensor(SENSOR_BH1750);
                                      nodeManager.registerSensor(SENSOR_BME280);
                                       * Register above your sensors
                                      nodeManager.before();
                                    and config.h:
                                     * NodeManager configuration
                                    // if enabled, enable debug messages on serial port
                                    #define DEBUG 1
                                    //#define DEBUG 0
                                    // if enabled, will load the sleep manager library. Sleep mode and sleep interval have to be configured to make the board sleeping/waiting
                                    #define SLEEP_MANAGER 1
                                    // if enabled, enable the capability to power on sensors with the arduino's pins to save battery while sleeping
                                    #define POWER_MANAGER 0
                                    // if enabled, will load the battery manager library to allow the battery level to be reported automatically or on demand
                                    #define BATTERY_MANAGER 0
                                    // if enabled, allow modifying the configuration remotely by interacting with the configuration child id
                                    #define REMOTE_CONFIGURATION 1
                                    // if enabled, persist the remote configuration settings on EEPROM
                                    #define PERSIST 0
                                    // if enabled, send a SLEEPING and AWAKE service messages just before entering and just after leaving a sleep cycle and STARTED when starting/rebooting
                                    #define SERVICE_MESSAGES 0
                                    // if enabled, a battery sensor will be created at BATTERY_CHILD_ID and will report vcc voltage together with the battery level percentage
                                    #define BATTERY_SENSOR 0
                                    // Enable this module to use one of the following sensors: SENSOR_ANALOG_INPUT, SENSOR_LDR, SENSOR_THERMISTOR, SENSOR_MQ, SENSOR_ML8511
                                    #define MODULE_ANALOG_INPUT 1
                                    // Enable this module to use one of the following sensors: SENSOR_DIGITAL_INPUT
                                    #define MODULE_DIGITAL_INPUT 1
                                    // Enable this module to use one of the following sensors: SENSOR_DIGITAL_OUTPUT, SENSOR_RELAY, SENSOR_LATCHING_RELAY
                                    #define MODULE_DIGITAL_OUTPUT 1
                                    // Enable this module to use one of the following sensors: SENSOR_DHT11, SENSOR_DHT22
                                    #define MODULE_DHT 0
                                    // Enable this module to use one of the following sensors: SENSOR_SHT21
                                    #define MODULE_SHT21 0
                                    // Enable this module to use one of the following sensors: SENSOR_SWITCH, SENSOR_DOOR, SENSOR_MOTION
                                    #define MODULE_SWITCH 0
                                    // Enable this module to use one of the following sensors: SENSOR_DS18B20
                                    #define MODULE_DS18B20 0
                                    // Enable this module to use one of the following sensors: SENSOR_BH1750
                                    #define MODULE_BH1750 1
                                    // Enable this module to use one of the following sensors: SENSOR_MLX90614
                                    #define MODULE_MLX90614 0
                                    // Enable this module to use one of the following sensors: SENSOR_BME280
                                    #define MODULE_BME280 1
                                    The serial output seems to show no reboot this time ;):
                                    NodeManager v1.4
                                    INT1 M=255
                                    INT2 M=255
                                    RADIO OK
                                    PRES I=200, T=23
                                    PRES I=1 T=16
                                    PRES I=2 T=6
                                    PRES I=3 T=7
                                    PRES I=4 T=8
                                    READY
                                    MY I=3 M=1
                                    BH1 I=1 L=-10924
                                    BME I=2 T=0.00
                                    BME I=3 H=0.00
                                    SEND D=0 I=3 C=0 T=1 S= N=0 F=0.00
                                    BME I=4 P=-793.67
                                    SLEEP 60s
                                    AWAKE
                                    BH1 I=1 L=-10924
                                    BME I=2 T=0.00
                                    SEND D=0 I=2 C=1 T=0 S= N=0 F=0.00
                                    BME I=3 H=0.00
                                    SEND D=0 I=3 C=1 T=1 S= N=0 F=0.00
                                    BME I=4 P=-793.67
                                    SLEEP 60s
                                    I would guess there should be enough memory on the arduino:
                                    Sketch uses 26.024 bytes (80%) of program storage space. Maximum is 32.256 bytes.
                                    Global variables use 1.262 bytes (61%) of dynamic memory, leaving 786 bytes for local variables. Maximum is 2.048 bytes.
                                    Definately not fixed :(
                                    Maybe I could try adding support for the alternative BME library to NodeManager...
                                    • K ksga
                                      // before
                                      void before() {
                                      and config.h:
                                      #define DEBUG 1
                                      //#define DEBUG 0
                                      #define PERSIST 0
                                      NodeManager v1.4
                                      INT1 M=255
                                      INT2 M=255
                                      RADIO OK
                                      PRES I=200, T=23
                                      PRES I=1 T=16
                                      PRES I=2 T=6
                                      PRES I=3 T=7
                                      PRES I=4 T=8
                                      READY
                                      MY I=3 M=1
                                      BH1 I=1 L=-10924
                                      BME I=2 T=0.00
                                      BME I=3 H=0.00
                                      BME I=4 P=-793.67
                                      SLEEP 60s
                                      AWAKE
                                      BH1 I=1 L=-10924
                                      BME I=2 T=0.00
                                      BME I=3 H=0.00
                                      BME I=4 P=-793.67
                                      SLEEP 60s
                                      U
                                      U
                                      user2684
                                      @ksga thanks for running this additional test! I don't like that -10924 for the BH1750 which looks to me like a random value and not impacted by the BME280 library you are using if I've understood correctly. This makes me still think of a memory issue: despite the sketch is not consuming all the memory, both the BME280 and BH1750 objects are allocated dynamically in the code so would not count against that percentage I'm afraid.
                                      Let's start by disabling MODULE_ANALOG_INPUT, MODULE_DIGITAL_INPUT and MODULE_DIGITAL_OUTPUT to save some more memory. Then I'd still try disabling NodeManager's debug: the serial output would be blank of course but on the controller you should see if the the measures reported will look better. I just want to be sure it is not a memory issue (which typically shows up as random reboots and random values) before moving ahead and troubleshoot the library you are using.
                                      • U user2684
                                        K
                                        K
                                        ksga
                                        #27
                                        @user2684 Sorry about the delay - but life claimed some time (stupid life claiming time I want to use for stuff :-| )
                                        Disabled MODULE_ANALOG_INPUT, MODULE_DIGITAL_INPUT and MODULE_DIGITAL_OUTPUT, and even tried without BH1750 - but still no luck.
                                        Node registers correctly and fires bogus data on one or two sensors...
                                        Pretty sure I have to use the other library - tried using Adafruit's examples, and it claims no BME is attached...
                                        I can make all the logic changes to NodeManager, but have not been able to initialize the sensor - maybe I could upload my edits to Git and someone could help me get the last bits together ???
                                        Made the changes here.
                                        • Ivan ZI
                                          Ivan ZI
                                          Ivan Z
                                          Double comment in NodeMamaged.h - setBatteryInternalVcc
