  3. Sun / cloud sensor?
Sun / cloud sensor?
10 Posts 5 Posters 7.1k Views 5 Watching
  • Martin TellblomM
    Martin TellblomM
    Martin Tellblom
    Has anyone build a cloud/ sun sensor?
    I.e is it a sunny day or is it cloudy
    MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
    • NiklasON
      NiklasON
      NiklasO
      wrote on last edited by NiklasO
      With the light sensor you should be able to identify cloudy days (I clearly see cloudy days in the history).
      Some scripting and you could use the lux-value, sunset and sunrise times to figure it out. Maybe adding a UV-meter to the mix. Hmmmm...
      Something like this one does:
      http://diffractionlimited.com/product/portable-cloud-sensor/
      "The sky temperature".
      https://mynasadata.larc.nasa.gov/science_projects/measuring-the-temperature-of-the-sky-and-clouds/
      Edit:
      We could use MLX90614 sensor to measure the sky temperature and compare to ground temperature and in that way, detect cloudy or sunny days.
      http://www.ebay.com/itm/MLX90614ESF-BAA-000-TU-ND-Infrared-Thermometer-Module-IR-Sensor-for-Arduino-/201402795181?hash=item2ee48ac4ad:g:Pl8AAOSw32lYorlr
      or
      http://www.ebay.com/itm/MLX90614ESF-BAA-000-TU-ND-Infrared-Thermometer-Module-IR-Sensor-for-Arduino-MO-/152234019326?hash=item2371dac9fe:g:fEYAAOSw9IpX0Qsl
      Info about using with Arduino:
      In this link we even have the correction factor and code that use the info from sensors:
      https://indiduino.wordpress.com/2013/02/02/meteostation/
      I will order a sensor and try this out! Should be able to port that to MySensors.
      • Martin TellblomM
        Martin TellblomM
        Martin Tellblom
        Sounds very interesting :)
        • AffordableTechA
          AffordableTechA
          AffordableTech
          Yes, I use a low cost (10 cent) Light Dependent Resistor (LDR) to measure ambient light levels. The wiring is quite simple, one end of the LDR to ground and the other wire connects to a 10k Ohm resistor. The other end of the 10k resistor goes to +5 or +3 (whichever you are using). The junction of the LDR and 10k goes to an analog pin on the Arduino.
          The sensitivity is quite good, covering the full spectrum from total darkness to bright sunlight. With a bit of observation I was able to determine 'value ranges' to display in my home automation as "Total Darkness", "Moonlight", "Bright Moonlight", "Dusk/Dawn", "Gloomy", "Overcast", "Bright" and "Very Bright". If you read it often enough, you can detect a dip in the value as a cloud passes over. Other motion sensor nodes (in bath, kitchen and bedroom) send read requests to an indoor LDR node every 15 minutes to know if its dark enough to turn on that room's light when motion is detected. I never have to turn an lights on or off anymore. An external motion sensor is used to detect someone approaching the front door and turns on a light and sounds a small beeper inside, negating the need for a doorbell.
          I also use one with my TV and computer screen to detect when the TV and/or my PC screen is on. This data is used to record the amount of time I spend watching TV or at my PC. The LDR is mounted in a small, 7mm black plastic cap like those used to protect the end of round tubing and is pointed towards the screen but shielded from ambient and overhead lights. It's simple, cheap and very effective.
          You will find ready to use code for an LDR based node in the NodeManager library (link below).
          Refer: https://github.com/mysensors/NodeManager
          Hope the above helps...
          Paul
          • F
            F
            flopp
            wrote on last edited by flopp
            You can use Lux sensor
            http://www.ebay.com/itm/1PCS-BH1750FVI-Digital-Light-intensity-Sensor-Module-3V-5V-For-Arduino-/311431379611?hash=item4882c1ba9b:g:2CUAAOSwyQtV2vJ7
            or UV index sensor
            https://www.aliexpress.com/item/GY-8511-ML8511-UVB-UV-Rays-Sensor-Breakout-Test-Module-Detector-Analog-Output/32597000768.html
            parachutesjP 1 Reply Last reply
            • F flopp
              or UV index sensor
              parachutesjP
              parachutesjP
              parachutesj
              wrote on last edited by parachutesj
              @Martin-Tellblom @NiklasO all...
              I've also built a light sensor for my home automation project but I was never really satisfied with it. The light level is different in summer and winter but still you might want to drive your shades. Also during dusk and dawn it was difficult. And you need to make sure that the lens is always clean or it is not working properly...
              I have a new solution which works imho much better:
              two temp sensors. One in direct sun, the other one in the shade. I look for the delta temperature and based on that can tell if sun is shining or not.
              using the water proof dallas sensors for that. easy, cheap, reliable.
              SJ
              • NiklasON
                NiklasON
                NiklasO
                I am waiting for the sensors to arrive. Should be fun. ;)
                • F
                  F
                  flopp
                  If you use a sensor that measures UV and maybe some other sensors, you can't use all material between sun and the sensors.
                  It must be a material that doesn't block UV
                  • NiklasON
                    NiklasON
                    NiklasO
                    Sure, that is another and later problem. ;)
                    • F flopp
                      parachutesjP
                      parachutesjP
                      parachutesj
                      @flopp ...and need to make sure it stays clean all the time
