  3. Simplifying MySensors security: the third option.
19 Posts 4 Posters 5.2k Views 6 Watching
  • alowhumA
    alowhumA
    alowhum
    I'd be happy to help. I'm not in a rush, and you don't have to do anything. Your proposal is already above and beyond what I could have expected.
    AnticimexA 1 Reply Last reply
    • alowhumA alowhum
      AnticimexA
      AnticimexA
      Anticimex
      @alowhum well, it will be clear to the user that it isn't enterprise grade security the particular flag will implement. Even so, it will be based on the atsha204a compatible software backend so as long as the node is protected from memory readouts (by fuses, or by simply keeping it locked in) and still making sure the random seed is based on an unconnected analog pin (like it is today) hacking also the simplified security solution though an OTA attack will be as hard as the other solutions (depending on the quality of the password). And it won't support whitelisting of nodes as that would require a unique serial for each node and that complicates things. So my rationale is that if a user wants security including whitelisting, regular personalization procedure will be required (and it will be simpler than today to deploy).
      Your proposal is a valid one I have concluded after looking more into what it would mean to implement. And the implementation won't be complicated either.
      • alowhumA
        alowhumA
        alowhum
        Well, that's just fantastic!
        • AnticimexA
          AnticimexA
          Anticimex
          No, actually it's just evolution :)
          • alowhumA
            alowhumA
            alowhum
            I'm curious if this has been taken up. Is there anyway I can help?
            • alowhumA alowhum
              AnticimexA
              AnticimexA
              Anticimex
              @alowhum it has and implementation is well under way. But I am not finished with verification and documentation. There is a pull request of you want to test, but be aware that I am force pushing updates to it.
              • alowhumA
                alowhumA
                alowhum
                @Anticimex said in Simplifying MySensors security: the third option.:
                pull request
                Wonderful!
                Very cool to see this in the code :-)
                +    --my-signing=[none|software|password]
                • alowhumA alowhum
                  pull request
                  Wonderful!
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @alowhum well, verifying on rPi is the one system I cannot test myself so you are very welcome to try that :)
                  alowhumA 1 Reply Last reply
                  • AnticimexA Anticimex
                    alowhumA
                    alowhumA
                    alowhum
                    @Anticimex And it's the one system I have, so: perfect! PM me when you want me to do a test.
                    • alowhumA alowhum
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @alowhum whenever you like. Code logic should be done. Whitelisting is also supported. Doxygen docs need more work. Thanks!
