  2. Announcements
  • dirkcD
    dirkcD
    dirkc
    @gohan, @marceloaqno : sorry, I corrected the "typo", the NRF was already connected as shown in https://www.mysensors.org/view/180#wiring. I double checked that again.
    What is the correct setup for ./configure ?
    Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
    • M marceloaqno
      @romeo01 You have to connect the nrf24 to the GPIO if you want to use it with the RPi, the information on the wiki was wrong, sorry about that.
      R
      R
      romeo01
      @marceloaqno
      Thanks marceloagno, the answer is clear.
      Keep up the great work !
      • dirkcD dirkc
        marceloaqno
        Code Contributor
        @dirkc The default settings for ./configure is to use the nrf24 module connected in the same way as shown in the guide and as an ethernet gateway.
        dirkcD 1 Reply Last reply
        • L
          L
          lshield
          wrote on last edited by lshield
          #419
          I'm having issues with the LED setup as shown on the page. The LEDs are just constantly on even though everything looks like it's setup just like the picture. I'm new at this so I could be doing something stupid.
          • M marceloaqno
            dirkcD
            dirkcD
            dirkc
            @marceloaqno ok, thanks, I will change the radio.
              marceloaqno
              Code Contributor
              Support for RFM69 was added to the development branch (finally!).
              jirmJ 1 Reply Last reply
              • M marceloaqno
                jirmJ
                jirmJ
                jirm
                @marceloaqno
                I´m really happy ear that !
                RFM69 is one of best RF transceivers in these days for IoT.
                So good news I believe for Mysensors community.
                You know if are any hope that RFM69 will be added too to OPI boards support mysgw development ?
                Congratulations for that great work !
                • jirmJ jirm
                  @marceloaqno
                  marceloaqno
                  Code Contributor
                  @jirm Support for RFM69 also applies to the OrangePi :wink:
                  • M marceloaqno
                    jirmJ
                    jirmJ
                    jirm
                    wrote on last edited by jirm
                    #424
                    @marceloaqno
                    Awesome !!!
                    Thank you so much.
                    Best regards
                    • F
                      F
                      ftw64
                      When I configure "MY_RFM69_MAX_POWER_LEVEL_DBM" in MyConfig.h, compiling fails.
                      Perhaps you should change the code in ./drivers/RFM69/new/RFM69_new.h from:
                      #define RFM69_MAX_POWER_LEVEL_DBM MY_RFM69_MAX_POWER_LEVEL_DBM //!< MY_RFM69_MAX_POWER_LEVEL_DBM
                      to:
                      #define RFM69_MAX_POWER_LEVEL_DBM ((rfm69_powerlevel_t)MY_RFM69_MAX_POWER_LEVEL_DBM) //!< MY_RFM69_MAX_POWER_LEVEL_DBM
                      • F
                        F
                        ftw64
                        I cannot get the RFM69(HW) working. When I start myswg in debug mode (-d), I see:
                        mysgw: Starting gateway...
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: RFM69:INIT
                        mysgw: RFM69:INIT:PIN,CS=24,IQP=22,IQN=22
                        mysgw: RFM69:PTX:LEVEL=5 dBm
                        mysgw: TSM:INIT:TSP OK
                        mysgw: TSM:INIT:GW MODE
                        mysgw: MCO:REG:NOT NEEDED
                        mysgw: MCO:BGN:STP
                        mysgw: MCO:BGN:INIT OK,TSP=1
                        But I can see ('hear' with a radio on 868.000 MHz) no transmission of the RFM69. When I power up a node, the node does not connect to the gateway: "NO REPLY":+1:
                        4 TSM:INIT
                        4 TSF:WUR:MS=0
                        8 TSM:INIT:TSP OK
                        10 TSM:INIT:STATID=4
                        12 TSF:SID:OK,ID=4
                        14 TSM:FPAR
                        274 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        2281 !TSM:FPAR:NO REPLY
                        2283 TSM:FPAR
                        2562 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        4569 !TSM:FPAR:NO REPLY
                        4571 TSM:FPAR
                        4831 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        6838 !TSM:FPAR:NO REPLY
                        6840 TSM:FPAR
                        7100 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        9107 !TSM:FPAR:FAIL
                        9109 TSM:FAIL:CNT=1
                        9111 TSM:FAIL:PDT
                        Is there any 'check' I can do to perform basic RFM69HW testing on my RPI?
                          Was it working before on a normal Arduino gateway? How did you wire everything up?
                          • F
                            F
                            ftw64
                            I'm pretty sure I wired up the RFM69 correctly.
                            However, I'm debugging. It seems we are stuck in "core/MyGatewayTransport.cpp":
                            inline void gatewayTransportProcess(void)
                              if (gatewayTransportAvailable()) {
                                // NEVER REACHED
                            I never seem to get pass gatewayTransportAvailable. I will continue debugging.
                            Disclaimer: I'm relatively new to MySensors and not really 'up to speed' with the source code :-).
                            F 1 Reply Last reply
                            • F ftw64
                                  // NEVER REACHED
                              F
                              F
                              ftw64
                              @ftw64 Ok, this has to do with connecting an Ethernet client. When a client connects, this code works...
                              Any idea where to start debugging for incoming RFM69 messages?
                                Download myscontroller and connect it to the gateway, you can now see all messages from ethernet controller
                                  F
                                  F
                                  ftw64
                                  @gohan said in 💬 Building a Raspberry Pi Gateway:
                                  myscontroller
                                  I just did. When I also have a Domoticz controller connected to the gateway:
                                  2017-04-23 11:18:33	INFO	Connected to 192.168.10.24:5003
                                  2017-04-23 11:18:33	CHILD	New child discovered, node id=0, child id=internal
                                  2017-04-23 11:18:33	RX	0;255;3;0;14;Gateway startup complete.
                                  2017-04-23 11:18:33	DEBUG	Update child id=255, type=ARDUINO_RELAY
                                  2017-04-23 11:18:33	RX	0;255;0;0;18;2.2.0-beta
                                  2017-04-23 11:18:33	RX	0;255;3;0;22;208103
                                  2017-04-23 11:18:33	RX	0;255;3;0;2;2.2.0-beta
                                  2017-04-23 11:18:43	RX	0;255;3;0;22;218106
                                  2017-04-23 11:18:53	RX	0;255;3;0;22;228110
                                  2017-04-23 11:19:03	RX	0;255;3;0;22;238101
                                  2017-04-23 11:19:13	RX	0;255;3;0;22;248104
                                  2017-04-23 11:19:23	RX	0;255;3;0;22;258110
                                  2017-04-23 11:19:33	RX	0;255;3;0;22;268107
                                  2017-04-23 11:19:43	RX	0;255;3;0;22;278106
                                  2017-04-23 11:19:53	RX	0;255;3;0;22;288110
                                  2017-04-23 11:20:03	RX	0;255;3;0;22;298116
                                  However, I found out that the DI00 (=IRQ) on the RFM69 never gives a rising edge...
                                  I'm suspecting that the RFM69 is not being initialised properly... I added some debugging in the RFM69 code to see what registers are being written and read:
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: RFM69:INIT
                                  mysgw: FtW:RFM69:write register, reg=0x01, value=4
                                  mysgw: FtW:RFM69:write register, reg=0x02, value=0
                                  mysgw: FtW:RFM69:write register, reg=0x03, value=2
                                  mysgw: FtW:RFM69:write register, reg=0x04, value=64
                                  mysgw: FtW:RFM69:write register, reg=0x05, value=3
                                  mysgw: FtW:RFM69:write register, reg=0x06, value=51
                                  mysgw: FtW:RFM69:write register, reg=0x18, value=136
                                  mysgw: FtW:RFM69:write register, reg=0x19, value=66
                                  mysgw: FtW:RFM69:write register, reg=0x26, value=7
                                  mysgw: FtW:RFM69:write register, reg=0x28, value=16
                                  mysgw: FtW:RFM69:write register, reg=0x29, value=220
                                  mysgw: FtW:RFM69:write register, reg=0x2c, value=0
                                  mysgw: FtW:RFM69:write register, reg=0x2d, value=3
                                  mysgw: FtW:RFM69:write register, reg=0x2e, value=136
                                  mysgw: FtW:RFM69:write register, reg=0x2f, value=45
                                  mysgw: FtW:RFM69:write register, reg=0x30, value=101
                                  mysgw: FtW:RFM69:write register, reg=0x37, value=212
                                  mysgw: FtW:RFM69:write register, reg=0x38, value=66
                                  mysgw: FtW:RFM69:write register, reg=0x39, value=255
                                  mysgw: FtW:RFM69:write register, reg=0x3a, value=255
                                  mysgw: FtW:RFM69:write register, reg=0x3c, value=5
                                  mysgw: FtW:RFM69:write register, reg=0x3d, value=16
                                  mysgw: FtW:RFM69:write register, reg=0x6f, value=48
                                  mysgw: FtW:RFM69:write register, reg=0x07, value=217
                                  mysgw: FtW:RFM69:write register, reg=0x08, value=0
                                  mysgw: FtW:RFM69:write register, reg=0x09, value=0
                                  mysgw: FtW:RFM69:read register, reg=0x27, value=128
                                  mysgw: FtW:RFM69:read register, reg=0x3d, value=16
                                  mysgw: FtW:RFM69:write register, reg=0x11, value=87
                                  mysgw: FtW:RFM69:read register, reg=0x02, value=0
                                  mysgw: FtW:RFM69:read register, reg=0x03, value=2
                                  mysgw: FtW:RFM69:read register, reg=0x04, value=64
                                  mysgw: FtW:RFM69:read register, reg=0x05, value=3
                                  mysgw: FtW:RFM69:read register, reg=0x06, value=51
                                  mysgw: FtW:RFM69:read register, reg=0x30, value=101
                                  mysgw: FTW attachInterrupt: gpioPin=25 mode=3
                                  mysgw: FtW:RFM69:write register, reg=0x39, value=0
                                  mysgw: FtW:RFM69:write register, reg=0x25, value=64
                                  mysgw: FtW:RFM69:write register, reg=0x13, value=26
                                  mysgw: FtW:RFM69:write register, reg=0x5a, value=85
                                  mysgw: FtW:RFM69:write register, reg=0x5c, value=112
                                  mysgw: FtW:RFM69:write register, reg=0x3d, value=20
                                  mysgw: FtW:RFM69:write register, reg=0x01, value=16
                                  mysgw: MCO:BGN:STP
                                  mysgw: Client 0 connected
                                  mysgw: Client 0: 0;0;3;0;2;
                                  mysgw: gatewayTransportAvailable
                                  • F
                                    F
                                    ftw64
                                    Can't get the RFM69HW to work on RPI. I tried the following:
                                    1. I installed on an old RPI1 (clean Rasbian install). Same results as on my Domoticz RPI-3.
                                    2. Setup the original RPI3 as a node, using the 2.2.0-beta code. I verified that in this case the RFM69HW actually transmits (I can hear it burst on 868.000 MHz). However, it is unable to connect to an existing Arduino 2.1.1 gateway.
                                    3. I built an Arduino 2.2.0-beta serial gateway. Even then, the RPI as a node fails to connect to the 2.2.0-beta serial gateway.
                                    4. I built an Arduino 2.2.0-beta node. This node is able to connect to the above gateway.
                                    There seems to be something different in the radio network between the RFM69HW on the RPI and the RFM69HW on the Arduino. But I'm unable to find out what the difference is :-(.
                                    The RPI RFM69HW will not communicate with the Arduino RFM69HW. When the RPI is a gateway, the RFM69HW will not physically interrupt when another node is trying to connect. When the RPI is a node, the RFM69HW on the ARduino does not interrupt either.
                                    Did anyone get the RFM69HW working on the RPI? I'd really like to get this beautiful piece of code working!
                                      I have to ask a stupid question : did you use a logic converter between rpi and rfm69 radio?
                                        F
                                        F
                                        ftw64
                                        @gohan There are no stupid questions, right :-)? But perhaps a stupid answer: no, I did not use any logic convertors. The RFM69 is 3.3V and as far as I know, so are the GPIO pins on the RPI. But I might be mistaken, of course... Should I use logic convertors?
                                        At the moment I have no idea where it fails. Perhaps I need to give it a rest for a couple of days to think it over...
                                        I followed the steps as given on the web site (git branch development). Connected the RFM radio (7 wires: Vcc, GND, MOSI, MISO, SCK, NSS, DI00). Only modified MyConfig.h with regard to the NETWORKID (100 --> 101; my 'production' MySensors runs at 100) and enabling "MY_DEBUG_VERBOSE_RFM69". I configured with:
                                        % ./configure --my-debug=enable --my-config-file=/usr/local/etc/mysensors.dat --my-gateway=ethernet --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw
                                        % make -j 4
                                        % sudo bin/mysgw -d
                                        • mfalkviddM
                                          The gpio pins on raspberry pi are 3.3V. https://raspberrypi.stackexchange.com/questions/3209/what-are-the-min-max-voltage-current-values-the-gpio-pins-can-handle
