  2. Announcements
  3. ๐Ÿ’ฌ Building a Raspberry Pi Gateway
    @keldandorin just add a capacitor between vcc and gnd on the radio module as I suggested above.
    keldandorinK
    keldandorinK
    keldandorin
    @gohan Been trying to find my old post to tell you all how it got with my rpi and nodes that did not register. I bougt some voltage regulators LM350. used the 5v output insted of 3.3 V but still no luck to get node to register. when messauring volatage when GW send awnser it drops way below 3.3v. I think voltage output from rpi just is to bad. So I bought a nodemcu for GW instead and it works like a sharm :)
    • R romeo01
      @gohan
      With the serial Gateway on the raspberry; how is connected the nfr24 ??
      If usb/serial port is no possible, which serial port to use ?
      marceloaqno
      Code Contributor
      @romeo01 You have to connect the nrf24 to the GPIO if you want to use it with the RPi, the information on the wiki was wrong, sorry about that.
      gohanG R 2 Replies Last reply
      • M marceloaqno
        @marceloaqno he said he can't connect nrf24 chip on the rpi, so that's why he is struggling
        • dirkcD dirkc
          When talking about this Raspberry Pi Gateway, I suppose, that its just connecting the NFR24L01+ to the Raspberry Pi GPIO and run
          ./bin/mysgw -d
          right? On my Pi it does not work this way, maybe the NFR24L01+ is not ok. Instead I am running an external esp-wifi-gateway, but a direct gateway seems the better solution to me.
          So did I get it right, that I can use a NFR24L01+ connected to the Raspberry PI GPIO without any external gateway? If so, what are the parameters for building the mysgw daemon? I tried this one:
          ./configure --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev0.0
          update: as in https://www.mysensors.org/view/180#wiring
          22 โ€“ CE
          24 โ€“ CSN/CS
          23 โ€“ SCK
          19 โ€“ MOSI
          21 โ€“ MISO
          SPI is activated:
          $ls /dev/spidev*
          And this is the result, when building it with the settings mentioned above. (Raspberry Pi 3, jessie 4.9.13-v7+)
          $ sudo ./bin/mysgw -d
          mysgw: Starting gateway...
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: !TSM:INIT:TSP FAIL
          mysgw: TSM:FAIL:CNT=1
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:FAIL:RE-INIT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:CNT=2
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:CNT=3
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:CNT=4
          mysgw: TSM:FAIL:PDT
          And can someone show how to bind this gateway into FHEM? As said, today I am running an esp-wifi-gateay.
          Thanks in advance for any support...
          marceloaqno
          Code Contributor
          @dirkc Try to connect your module to the SPI0 (https://www.mysensors.org/view/180#wiring).
          You only need to enable the SPIDEV if you want to use the SPI1.
          • dirkcD dirkc
            ./bin/mysgw -d
            22 โ€“ CE
            24 โ€“ CSN/CS
            23 โ€“ SCK
            19 โ€“ MOSI
            21 โ€“ MISO
            SPI is activated:
            $ls /dev/spidev*
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: TSM:FAIL:PDT
            mysgw: TSM:INIT
            mysgw: TSM:FAIL:PDT
            mysgw: TSM:INIT
            mysgw: TSM:FAIL:PDT
            mysgw: TSM:INIT
            mysgw: TSM:FAIL:PDT
            @dirkc I don't know where you got those pin numbers but they don't look like the ones on the guide. In addition you don't have to use spi driver. The PA version of nrf24 are quite a pain to get them working, so I suggest you first test with regular modules and then upgrade to PA
            • dirkcD
              dirkcD
              dirkc
              @gohan, @marceloaqno : sorry, I corrected the "typo", the NRF was already connected as shown in https://www.mysensors.org/view/180#wiring. I double checked that again.
              What is the correct setup for ./configure ?
              Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
              • M marceloaqno
                R
                R
                romeo01
                @marceloaqno
                Thanks marceloagno, the answer is clear.
                Keep up the great work !
                • dirkcD dirkc
                  marceloaqno
                  Code Contributor
                  @dirkc The default settings for ./configure is to use the nrf24 module connected in the same way as shown in the guide and as an ethernet gateway.
                  dirkcD 1 Reply Last reply
                  • L
                    L
                    lshield
                    wrote on last edited by lshield
                    #419
                    I'm having issues with the LED setup as shown on the page. The LEDs are just constantly on even though everything looks like it's setup just like the picture. I'm new at this so I could be doing something stupid.
                    • M marceloaqno
                      dirkcD
                      dirkcD
                      dirkc
                      @marceloaqno ok, thanks, I will change the radio.
                        marceloaqno
                        Code Contributor
                        Support for RFM69 was added to the development branch (finally!).
                        jirmJ 1 Reply Last reply
                        • M marceloaqno
                          jirmJ
                          jirmJ
                          jirm
                          @marceloaqno
                          Iยดm really happy ear that !
                          RFM69 is one of best RF transceivers in these days for IoT.
                          So good news I believe for Mysensors community.
                          You know if are any hope that RFM69 will be added too to OPI boards support mysgw development ?
                          Congratulations for that great work !
                          • jirmJ jirm
                            @marceloaqno
                            marceloaqno
                            Code Contributor
                            @jirm Support for RFM69 also applies to the OrangePi :wink:
                            • M marceloaqno
                              jirmJ
                              jirmJ
                              jirm
                              wrote on last edited by jirm
                              #424
                              @marceloaqno
                              Awesome !!!
                              Thank you so much.
                              Best regards
                              • F
                                F
                                ftw64
                                When I configure "MY_RFM69_MAX_POWER_LEVEL_DBM" in MyConfig.h, compiling fails.
                                Perhaps you should change the code in ./drivers/RFM69/new/RFM69_new.h from:
                                #define RFM69_MAX_POWER_LEVEL_DBM MY_RFM69_MAX_POWER_LEVEL_DBM //!< MY_RFM69_MAX_POWER_LEVEL_DBM
                                to:
                                #define RFM69_MAX_POWER_LEVEL_DBM ((rfm69_powerlevel_t)MY_RFM69_MAX_POWER_LEVEL_DBM) //!< MY_RFM69_MAX_POWER_LEVEL_DBM
                                • F
                                  F
                                  ftw64
                                  I cannot get the RFM69(HW) working. When I start myswg in debug mode (-d), I see:
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: RFM69:INIT
                                  mysgw: RFM69:INIT:PIN,CS=24,IQP=22,IQN=22
                                  mysgw: RFM69:PTX:LEVEL=5 dBm
                                  mysgw: TSM:INIT:TSP OK
                                  mysgw: TSM:INIT:GW MODE
                                  mysgw: MCO:REG:NOT NEEDED
                                  mysgw: MCO:BGN:STP
                                  mysgw: MCO:BGN:INIT OK,TSP=1
                                  But I can see ('hear' with a radio on 868.000 MHz) no transmission of the RFM69. When I power up a node, the node does not connect to the gateway: "NO REPLY":+1:
                                  4 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  8 TSM:INIT:TSP OK
                                  10 TSM:INIT:STATID=4
                                  12 TSF:SID:OK,ID=4
                                  14 TSM:FPAR
                                  274 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2281 !TSM:FPAR:NO REPLY
                                  2283 TSM:FPAR
                                  2562 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  4569 !TSM:FPAR:NO REPLY
                                  4571 TSM:FPAR
                                  4831 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  6838 !TSM:FPAR:NO REPLY
                                  6840 TSM:FPAR
                                  7100 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  9107 !TSM:FPAR:FAIL
                                  9109 TSM:FAIL:CNT=1
                                  9111 TSM:FAIL:PDT
                                  Is there any 'check' I can do to perform basic RFM69HW testing on my RPI?
                                    Was it working before on a normal Arduino gateway? How did you wire everything up?
                                    • F
                                      F
                                      ftw64
                                      I'm pretty sure I wired up the RFM69 correctly.
                                      However, I'm debugging. It seems we are stuck in "core/MyGatewayTransport.cpp":
                                      inline void gatewayTransportProcess(void)
                                        if (gatewayTransportAvailable()) {
                                          // NEVER REACHED
                                      I never seem to get pass gatewayTransportAvailable. I will continue debugging.
                                      Disclaimer: I'm relatively new to MySensors and not really 'up to speed' with the source code :-).
                                      F 1 Reply Last reply
                                      • F ftw64
                                            // NEVER REACHED
                                        F
                                        F
                                        ftw64
                                        @ftw64 Ok, this has to do with connecting an Ethernet client. When a client connects, this code works...
                                        Any idea where to start debugging for incoming RFM69 messages?
                                          Download myscontroller and connect it to the gateway, you can now see all messages from ethernet controller
                                          With your input, this post could be even better ๐Ÿ’—
