  3. Vera
  4. Well I'm lost
Well I'm lost
33 Posts 6 Posters 14.8k Views 2 Watching
  • N
    N
    niccodemi
    @5546dug did you download Vera files from this website? There is "Download ZIP" button on the right side. Extract those files and upload one by one to Veralite. After that is done you should have Mysensors plugin under your Devices tab (same as on photo below except Lib version should stay blank until Veralite starts communicating with serial gateway).
    • 5546dug5
      5546dug5
      5546dug
      I believe that is what I have done,
      I extracted the files and uploaded to veralite and I get version 1.3
      Is there a way to delete these lua files on the veralite so to start fresh?
      These files were extracted to folder aurduino/vera-master
      then up to the vera if I purge 1.3 maybe 1.4 will populate veralte?
      • 5546dug5
        5546dug5
        5546dug
        thanks for your time @niccodemi
        • N
          N
          niccodemi
          @5546dug Delete Mysensors plugin. You don't have to delete lua files from Vera; just upload new ones (from previous link).
          As for deleting files from vera I believe you would have to ssh in vera.
          • 5546dug5
            5546dug5
            5546dug
            ok will try this now @niccodemi
            • 5546dug5
              5546dug5
              5546dug
              just thinking out loud Would this be best done using chrome or internet explorer browser?
              I downloaded the zip from gitrepo with chrome but may have used ie to upload to veralite.
              Issues?
              N 1 Reply Last reply
              • 5546dug5
                5546dug5
                5546dug
                If I can get the veralite ui5 to work with 1.4 plugin then the vera3 will be reset to ui5 until ui7 is a little more stable and friendly.
                I just need one system and a little hair!
                • 5546dug5 5546dug
                  Issues?
                  N
                  N
                  niccodemi
                  Issues?
                  I don't think it should matter.
                  • 5546dug5
                    5546dug5
                    5546dug
                    this is silly--- reloaded the files one by one from laptop to veralite and got the same thing ver 1.3 with no library ver.
                    • 5546dug5
                      5546dug5
                      5546dug
                      just uploaded again from my files on laptop to the vera lua files as shown on my sensors
                      I did them one by one it says upload ok
                      create new device config serial port and there it is again! ver 1.3 and no lib version
                      red banner " Lua startup failure"
                      • N
                        N
                        niccodemi
                        @5546dug I guess you are uploading wrong files or something is wrong with vera. Did you try removing Mysensors plugin and rebooting (not just reloading) vera before uploading new files?
                        Anyway if you want to remove files from vera check this thread and this one on how to get your ssh password. Maybe you could also ask MIOS support to remove files for you.
                        • 5546dug5
                          5546dug5
                          5546dug
                          ok progress
                          I Do need to upload the vera plugin file sto veralite with chrome,
                          Under the Devices page the device MySensors Plugin was created showing
                          plugin ver 1.4
                          lib ver
                          so looking at the serial config there was not any
                          research on this site under /Lost USB/ Serial Port on Vera3 again
                          @blacey gave advice to @clippermiami on how he acheves usb connection
                          unplug usb>reload>plug usb>reload> set config for port
                          now I have port set for gw/vera communications
                          no lib version yet
                          I know the files are in folder Users/Arduino/libraries/Mysensors/
                          also using nano v3.0 from gravitech and not clone
                          next step(s)
                          • 5546dug5
                            5546dug5
                            5546dug
                            Ok So this seems to be the end
                            After the last post I went by the veralite and saw the inclusion light fluttering
                            What the heck I pressed the reset button on the nano and then the plus on veralite and left it alone
                            opened the vera a little later see ver 1.4
                            lib 1.4
                            looks like success for now
                            thanks to you who responded to my plight and those who posted other issuses on this site.
                            I did not know about inclusion for the gw
                            Nowtosee if I can get a device to be recognized by vera
                            keep you informed
                            • 5546dug5
                              5546dug5
                              5546dug
                              so an update for the veralite ui5
                              built and installed the humidity sensor
                              used the my sensor library/humidity and uploaded this to second nano with radio and as the instructions on adding new sensors on the vera plugin page on "My Sensors"/vera,
                              got the node to be recognized by vera and created three nodes!
                              main, humidity and temp.
                              Man this is neat
                              so thanks again for all your posts on these pages very good help
                              Guess now it is time to set vera3 back to ui5 until I here ui7 is better than now.
                              But before doing so will see if the ui7 will let this node be accepted and stop the red "No device detected" banner.
                              • N
                                N
                                niccodemi
                                wrote on last edited by niccodemi
                                #32
                                good to hear that you got it working. Let us know how it goes on ui7.
                                • 5546dug5
                                  5546dug5
                                  5546dug
                                  well no suprises it did not work sooo,
                                  reverted to ui5 and after micasa intervention got back-- to normal and starting to rebui;ld all on vera3
