  3. SOLVED: MQTT ESP8266 Gateway issue
16 Posts 4 Posters 6.2k Views 5 Watching
  • YeitsoY
    YeitsoY
    Yeitso
    Riiight so when inspecting the radios I have I notice that the H on the back is not ticked. There might be an issue that the seller have sent me the wrong radios.
    But removing the define #define MY_IS_RFM69HW did not help.
    If one where to run the RFM69W as a HW would that damage the chip?
    • YeitsoY
      YeitsoY
      Yeitso
      After using lowpowerlabs example sketches "Gateway.ino" and "Node.ino" I now know that the radios work. and at a nice range as well. But they are not HW.
      That being said even if I remove #define MY_IS_RFM69HW I'm still getting this issue.
        wrote on last edited by gohan
        You can't remove that define, otherwise the library doesn't know what radio has to set up. If I remember well the H stands for high power so it should be the same.
        • YeitsoY
          YeitsoY
          Yeitso
          That define is to turn on high power mode if you have a rfm69hw
          I sill have
          #define MY_RADIO_RFM69
          So radio is define but not in high power mode.
          • Johannes HodneJ
            Johannes HodneJ
            Johannes Hodne
            I changed back to 2.0.0 lib. Then everything start working again:-)
            • YeitsoY
              YeitsoY
              Yeitso
              Thank you, so did I and it works.
              Will open a ticket on github with this find and hopefully the devs will be able to recreate and fix the issue.
              • Johannes HodneJ
                Johannes HodneJ
                Johannes Hodne
                anyone got the gatway working with the 2.1.1 lib?
                • mppM
                  mppM
                  mpp
                  Alas, I'm also struggling with ESP crashes and weird messages:
                  TSM:INIT
                  TSF:WUR:MS=0
                  TSM:INIT:TSP OK
                  TSM:INIT:STATID=22
                  TSF:SID:OK,ID=22
                  TSM:FPAR
                  TSF:MSG:SEND,22-22-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 5 (10)
                  add 0
                  aid 5
                  cnt
                  chg_B1:-40
                  connected with Airport, channel 6
                  dhcp client start...
                  chg_B1:-80
                  !TSM:FPAR:NO REPLY
                  TSM:FPAR
                  chg_B1:-120
                  !TSM:FPAR:NO REPLY
                  TSM:FPAR
                  !TSM:FPAR:NO REPLY
                  MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
                    Is it the same problem as your other post?
                    mppM 1 Reply Last reply
                      mppM
                      mppM
                      mpp
                      @gohan there are different things going wrong, the parent id can't be found (eventhough it is set manually to 0), but there's also a lot of debug specific to the esp module.
