  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • mar.conteM mar.conte
    I noticed that the battery report if set to one hour does not happen every hour ...
    U
    U
    user2684
    @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
    More details please :-) Does not happen at all, it is not regular, happens every other hour, etc. what is the case?
    mar.conteM 1 Reply Last reply
    • U user2684
      mar.conteM
      mar.conteM
      mar.conte
      @user2684
      It happens even if i put 6 hours or every 3 hours so in the specified hours it is not regular the report sometimes jumps some report
      M.C.
      U 1 Reply Last reply
        @user2684
        U
        U
        user2684
        Ok, I'd probably need both MySensors and NodeManagers's logs to troubleshoot this, just to ensure there is no failure in sending out the messages as I've seen in the other logs you have previously shared.
        • U user2684
          mar.conteM
          mar.conteM
          mar.conte
          @user2684
          Ok Tanks
          M.C.
          • mar.conteM
            mar.conteM
            mar.conte
            Then solved the problem of the accuracy of the battery report: basically I did not realize that the sleep wait time started from the last pir movement then if i put an hour of sleep and during this active time the pir time resumes; The communication problems I solved them by letting antenna from rfm69 so every hour the battery report does not even send pir moviment
            ....Very strange my rfm69 modules communicate better without an antenna even at a distance of 10 meters with a wall
            M.C.
              There is a risk of damaging the radio module if you don't use an antenna. Also a wrong tuned antenna will make transmitting more difficult.
                mar.conteM
                mar.conteM
                mar.conte
                @gohan
                Ok Tanks, but the 86 mm wire for 868 what is Ideal diameter and thread type for simple antenna no dipole e non ground ant?
                M.C.
                  wrote on last edited by gohan
                  #120
                  Found in another forum
                  433 1/4 wave = 164.7mm
                  433 1/2 wave = 329.4mm
                  433 full wave = 692.7mm
                  868 1/4 wave = 82.2mm
                  868 1/2 wave = 164.3mm
                  868 full wave = 345.5mm
                  915 1/4 wave = 77.9mm
                  915 1/2 wave = 155.9mm
                  915 full wave = 327.8mm
                  Try shortening a little bit. What kind of wire are you using?
                  mar.conteM 2 Replies Last reply
                    mar.conteM
                    mar.conteM
                    mar.conte
                    @gohan
                    Wery good Tanks gohan
                    M.C.
                      mar.conteM
                      mar.conteM
                      mar.conte
                      @gohan
                      Normal wire electric 1 mm diameter
                      M.C.
                        Single core or threaded?
                          mar.conteM
                          mar.conteM
                          mar.conte
                          @gohan
                          Threaded
                          M.C.
                            You need to use single core, that's why it is not working well
                              mar.conteM
                              mar.conteM
                              mar.conte
                              @gohan
                              Should it be isolated or even without a sheath?
                              M.C.
                                I think you can leave insulation on; there are some guides on how to make antennas for rfm69,just Google it. In addition there are also spring single wire antennas for different frequencies you can buy.
                                  U
                                  U
                                  user2684
                                  Yes, when the pir wakes the node up, the sleep is aborted and when going back to sleep, it starts from scratch without resuming it. If this is not creating an issue, I'll keep the current behavior. Regarding the antenna, I'm using the small antennas from the store for my RFM69 and have a decent range without big issues.
                                  • U user2684
                                    mar.conteM
                                    mar.conteM
                                    mar.conte
                                    @user2684
                                    Tanks of course bye
                                    M.C.
                                    • B
                                      B
                                      bilbolodz
                                      #130
                                      I'm trying to build sensor to drive 3 relays and connect it to Domoticz. Simple sketch:
                                      // before
                                      void before() {
                                        Serial.begin(MY_BAUD_RATE);
                                         * Register below your sensors
                                      int przek1 = nodeManager.registerSensor(SENSOR_RELAY,3);
                                      int przek2 = nodeManager.registerSensor(SENSOR_RELAY,4);
                                         * Register above your sensors
                                        nodeManager.before();
                                      sensors are visible into Domoticz as switches but It's not possible to turn it on/off from Domoticz. It looks that Nodemanager expect REQ message to change state of relay but Domoticz sends SET message to change state:
                                      RECV S=0 I=3 C=1 T=2 D=1
                                      RECV S=0 I=3 C=1 T=2 D=0
                                      When I've used MYSController and send C_REQ message all is working fine.
                                      I think that in case of "output" sensors logic of getting/setting should be reversed.
                                      • U
                                        U
                                        user2684
                                        Hello, I think I was able to implement most of the requests discussed here during the last few weeks in a pre-release v1.5 version. Please consider it still as a dev release which gone through very limited testing but since I had to make quite a few changes to core code, would be great to start collecting some feedback now.
                                        Is is available here: https://github.com/mysensors/NodeManager/tree/9a485cdcaf8e9856219338553335e2dce7253eb3
                                        It is complicated to reference each of you who requested something so please whoever is interested the full list of new additions/fixes is available here https://github.com/mysensors/NodeManager/milestone/5?closed=1. I did my best to add verbose comments so you should find all the details there. Please add any comment and report any problem directly to the existing issues on github so I can better understand the context. The documentation has been updated as well.
                                        • U user2684
                                          mar.conteM
                                          mar.conteM
                                          mar.conte
                                          @user2684
                                          M.C.
