  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 122.4k Views 26 Watching
    What's the problem if it reports no motion?
    mar.conteM
    mar.conteM
    mar.conte
    @gohan
    The problem is that motion report whenever sleep goes to wake to send me the battery status every 60 minutes ,then every 60 minutes sends me battery status and motion pir
    M.C.
      Ok, but is it causing any problem?
      mar.conteM 1 Reply Last reply
        mar.conteM
        mar.conteM
        mar.conte
        @gohan
        Definitely, if I put a pir sensor to monitor a security access I will never know if I had an intrusion if I have a false alarm
        M.C.
          if it reports "no motion" it is not a false alarm. The important thing is it must report when there is "motion"
          U 1 Reply Last reply
            U
            U
            user2684
            @gohan said in NodeManager: plugin for a rapid development of battery-powered sensors:
            Agree with what @gohan says. But I'll look into this anyway @mar-conte, reporting no motion when waking up should not happen even if it is a minor issue (https://github.com/mysensors/NodeManager/issues/71). What should not happen at all is reporting motion (payload 1) but as far as I've understood this is the case.
            • U user2684
              mar.conteM
              mar.conteM
              mar.conte
              @user2684
              So with version 1.5 do I solve my problem too?
              M.C.
              • mar.conteM
                mar.conteM
                mar.conte
                wrote on last edited by mar.conte
                #111
                I noticed that the battery report if set to one hour does not happen every hour ...
                M.C.
                • mar.conteM mar.conte
                  @user2684
                  U
                  U
                  user2684
                  @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
                  I'll look into it by then. Feel free to follow the github issue to see how it will evolve. Thanks!
                    U
                    U
                    user2684
                    More details please :-) Does not happen at all, it is not regular, happens every other hour, etc. what is the case?
                    • U user2684
                      mar.conteM
                      mar.conteM
                      mar.conte
                      @user2684
                      It happens even if i put 6 hours or every 3 hours so in the specified hours it is not regular the report sometimes jumps some report
                      M.C.
                        @user2684
                        U
                        U
                        user2684
                        Ok, I'd probably need both MySensors and NodeManagers's logs to troubleshoot this, just to ensure there is no failure in sending out the messages as I've seen in the other logs you have previously shared.
                        • U user2684
                          mar.conteM
                          mar.conteM
                          mar.conte
                          @user2684
                          Ok Tanks
                          M.C.
                          • mar.conteM
                            mar.conteM
                            mar.conte
                            Then solved the problem of the accuracy of the battery report: basically I did not realize that the sleep wait time started from the last pir movement then if i put an hour of sleep and during this active time the pir time resumes; The communication problems I solved them by letting antenna from rfm69 so every hour the battery report does not even send pir moviment
                            ....Very strange my rfm69 modules communicate better without an antenna even at a distance of 10 meters with a wall
                            M.C.
                              There is a risk of damaging the radio module if you don't use an antenna. Also a wrong tuned antenna will make transmitting more difficult.
                                mar.conteM
                                mar.conteM
                                mar.conte
                                @gohan
                                Ok Tanks, but the 86 mm wire for 868 what is Ideal diameter and thread type for simple antenna no dipole e non ground ant?
                                M.C.
                                  wrote on last edited by gohan
                                  #120
                                  Found in another forum
                                  433 1/4 wave = 164.7mm
                                  433 1/2 wave = 329.4mm
                                  433 full wave = 692.7mm
                                  868 1/4 wave = 82.2mm
                                  868 1/2 wave = 164.3mm
                                  868 full wave = 345.5mm
                                  915 1/4 wave = 77.9mm
                                  915 1/2 wave = 155.9mm
                                  915 full wave = 327.8mm
                                  Try shortening a little bit. What kind of wire are you using?
                                  mar.conteM 2 Replies Last reply
                                    mar.conteM
                                    mar.conteM
                                    mar.conte
                                    @gohan
                                    Wery good Tanks gohan
                                    M.C.
                                      mar.conteM
                                      mar.conteM
                                      mar.conte
                                      @gohan
                                      Normal wire electric 1 mm diameter
                                      M.C.
                                        Single core or threaded?
                                          mar.conteM
                                          mar.conteM
                                          mar.conte
                                          @gohan
                                          Threaded
                                          M.C.
