  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
    Ok, but is it causing any problem?
    mar.conteM 1 Reply Last reply
      mar.conteM
      mar.conteM
      mar.conte
      @gohan
      Definitely, if I put a pir sensor to monitor a security access I will never know if I had an intrusion if I have a false alarm
      M.C.
        if it reports "no motion" it is not a false alarm. The important thing is it must report when there is "motion"
        U 1 Reply Last reply
          U
          U
          user2684
          @gohan said in NodeManager: plugin for a rapid development of battery-powered sensors:
          Agree with what @gohan says. But I'll look into this anyway @mar-conte, reporting no motion when waking up should not happen even if it is a minor issue (https://github.com/mysensors/NodeManager/issues/71). What should not happen at all is reporting motion (payload 1) but as far as I've understood this is the case.
          • U user2684
            mar.conteM
            mar.conteM
            mar.conte
            @user2684
            So with version 1.5 do I solve my problem too?
            M.C.
            • mar.conteM
              mar.conteM
              mar.conte
              wrote on last edited by mar.conte
              #111
              I noticed that the battery report if set to one hour does not happen every hour ...
              M.C.
              • mar.conteM mar.conte
                @user2684
                U
                U
                user2684
                @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
                I'll look into it by then. Feel free to follow the github issue to see how it will evolve. Thanks!
                  U
                  U
                  user2684
                  More details please :-) Does not happen at all, it is not regular, happens every other hour, etc. what is the case?
                  • U user2684
                    mar.conteM
                    mar.conteM
                    mar.conte
                    @user2684
                    It happens even if i put 6 hours or every 3 hours so in the specified hours it is not regular the report sometimes jumps some report
                    M.C.
                      @user2684
                      U
                      U
                      user2684
                      Ok, I'd probably need both MySensors and NodeManagers's logs to troubleshoot this, just to ensure there is no failure in sending out the messages as I've seen in the other logs you have previously shared.
                      • U user2684
                        mar.conteM
                        mar.conteM
                        mar.conte
                        @user2684
                        Ok Tanks
                        M.C.
                        • mar.conteM
                          mar.conteM
                          mar.conte
                          Then solved the problem of the accuracy of the battery report: basically I did not realize that the sleep wait time started from the last pir movement then if i put an hour of sleep and during this active time the pir time resumes; The communication problems I solved them by letting antenna from rfm69 so every hour the battery report does not even send pir moviment
                          ....Very strange my rfm69 modules communicate better without an antenna even at a distance of 10 meters with a wall
                          M.C.
                            There is a risk of damaging the radio module if you don't use an antenna. Also a wrong tuned antenna will make transmitting more difficult.
                              mar.conteM
                              mar.conteM
                              mar.conte
                              @gohan
                              Ok Tanks, but the 86 mm wire for 868 what is Ideal diameter and thread type for simple antenna no dipole e non ground ant?
                              M.C.
                                wrote on last edited by gohan
                                #120
                                Found in another forum
                                433 1/4 wave = 164.7mm
                                433 1/2 wave = 329.4mm
                                433 full wave = 692.7mm
                                868 1/4 wave = 82.2mm
                                868 1/2 wave = 164.3mm
                                868 full wave = 345.5mm
                                915 1/4 wave = 77.9mm
                                915 1/2 wave = 155.9mm
                                915 full wave = 327.8mm
                                Try shortening a little bit. What kind of wire are you using?
                                mar.conteM 2 Replies Last reply
                                  mar.conteM
                                  mar.conteM
                                  mar.conte
                                  @gohan
                                  Wery good Tanks gohan
                                  M.C.
                                    mar.conteM
                                    mar.conteM
                                    mar.conte
                                    @gohan
                                    Normal wire electric 1 mm diameter
                                    M.C.
                                      Single core or threaded?
                                        mar.conteM
                                        mar.conteM
                                        mar.conte
                                        @gohan
                                        Threaded
                                        M.C.
                                          You need to use single core, that's why it is not working well
