  3. Gas Meter Reading Using a Magnetometer
77 Posts 10 Posters 40.3k Views 12 Watching
  • dpcrD dpcr
    @dpcr Are you using VAR1 for the pulse count? The reason why we didn't store the top and bottom values on the GW was if the GW went down for any reason we could still keep a pulse count. But it should still work if you have a connection to your GW and controller.
    Here are some results from Domoticz. As you can see last Friday I had a spike. This was due to some of the same problems you are having. It has been running fine for the past several days since the last upgrade. I am using the same sketch that I posted.
    0_1488408954566_chart.png 0_1488408961804_chart (1).png 0_1488408967898_chart (2).png
    I haven't figure out how to remove the Energy (Wh) from the gas usage or the word Waterflow.
    As for the fixing of the excessive pulse counts I also at times had he same problem as well. But make sure that your top and bottoms are correct first. If they are and your "next pulse at" number is just being bypassed and the pulse count keeps going up the solution was to reorder the code. Not sure how that helped but it did. I'm not the software guy in this project, my son is. But I know most of what is going on with it. If it continues to give you problems let me know, post your code and I'll get him to look at it.
    The memory or GW numbers should be 0 but it not too critical if you are there to start it. It will recalculate the top and bottom values automatically after there has been 22 pulses within a send frequency. Just turn the stove or gas on so there is plenty of flow and download the sketch. It should either start reading the magnetic values and count pulses or start the time to find the top and bottom.
    What do you mean by not understanding the pulse count? Are you sending any flow or volume data? Sorry if this jumps around but I'm in the process of doing something else and I'm distracted. Thanks for you patience.
    markcame
    wrote on last edited by markcame
    #35
    @dpcr Yes I use var1 for pulse count Var2 for Top and Var3 for bottom
    if the retrieve of value from Gw/Controller is fine get the last Top and Bottom otherwise if retrieve fails after power cycle use locally hard coded, if the retrieve is 0 for TOP and BOTTOM starts auto-detect (gas must be flow) this happens on first run or if you want to manually starts a recalculation.
    I think that the problem of spike... maybe related to a non triggering of top or bottom after magnetic field change due to temperature so pulse count going up until new top and bottom was recalculated and applied, there are a control over max pulse for cycle ?
    for the count up probably there are a part of code time spending and the reading jump ?
    on version V3.6304 of domoticz m3/h are displayed fine if you select gas type counter .... for flow maybe is still water flow reported.
    for the pulse count i meaning looking at the code that you take a period then divide in division and trigger a pulse for every division is passed but i didn't understand if the metodology for counting pulse changed on the old and on the new code
    here the code i have modified is a mix of old and new code you have posted plus the support to store on controller and a chek for not count more than todividers on rising or falling , i want to test if i can improve the count or not...
     * Currently the autoDetectMaxMin in set to true which will find the TOP and BOTTOM of the wave, however if you want
     * to use it the gas must be flowing.
    #include <Wire.h>                       //I2C Arduino Library
    #define CHILD_ID 1                      //ID of the sensor child
    #define SLEEP_MODE false                //prevent sensor from sleeping
    #define address 0x1E                    //0011110b, I2C 7bit address of HMC5883
    int TOP = 0;                            //highest magnetic field registered from meter (Ga)Initialize low if using AutoDetectMaxMin
    int BOTTOM = 0;                         //lowest magnetic field registered from meter (Ga) Initialize high if using AutoDetectMaxMin
    int NewTop=-9000;
    int NewBottom=9000;
    int tol = 50;
    unsigned long SEND_FREQUENCY = 30000;   // Minimum time between send (in milliseconds). We don't want to spam the gateway.
    bool metric = true;                     //sets units to Metric or English
    bool autoDetectMaxMin = false;           //lets Arduino decide the values for TOP and BOTTOM
    bool pcReceived = false;                //whether or not the gw has sent us a pulse count
    bool rising = true;                     //whether or not a pulse has been triggered
    bool inside = true;                     //whether the magnetic field is within TOP and BOTTOM limits
    unsigned long pulsecount = 0;           //total number of pulses measured ever
    unsigned long oldPulseCount = 0;        //old total
    double vpp = 0.12;                      //Volume of gas per pulse
    unsigned long lastSend = 0;             //time since last transmission - msec
    double volume = 0;                      //Cumulative amount of gas measured
    const int len = 3;                      //number of flow rate measurements to save
    double flow [len];                      //array of previous gas flow rate measurements
    double avgFlow = 0;                     //average of all elements in flow array
    double oldAvgFlow = 0;                  //previous average flow
    int divider = 1;                        //Current divider
    int totDividers = 10;                    //Number of dividers
    int increment = (TOP - BOTTOM) / totDividers;   //space b/w dividers
    int newTop = -9000;                     //potential new Top
    int newBottom = 9000;                   //potential new Bottom
    int counter=0;
    MyMessage flowMsg(CHILD_ID,V_FLOW);
    MyMessage volumeMsg(CHILD_ID,V_VOLUME);
    MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
    MyMessage lastTopMsg(CHILD_ID,V_VAR2);
    MyMessage lastBottomMsg(CHILD_ID,V_VAR3);
    void setup(){
      //Initialize Serial and I2C communications
      Wire.begin();
      // Fetch last known pulse count , TOP and BOTTOM value from gw
      request(CHILD_ID, V_VAR1);
      request(CHILD_ID, V_VAR2);
      request(CHILD_ID, V_VAR3);
      // Wait until timeout of 2 seconds for message from gw
      wait(2000, 2, V_VAR1);
      wait(2000, 2, V_VAR2);
      wait(2000, 2, V_VAR3);
      //Put the HMC5883 IC into the correct operating mode
      Wire.beginTransmission(address); //open communication with HMC5883
      Wire.write(0x02); //select mode register
      Wire.write(0x00); //continuous measurement mode
      Wire.endTransmission();
      int y = 0;
      int oldy = 0;
      //WARNING: MAKE SURE GAS IS RUNNING IF USING THIS OPTION!!!
      if(TOP==0 && BOTTOM==0){
      autoDetectMaxMin = true;
        //determine max and min magnetic field strength over a few minutes
        lastSend = millis();
        while(millis() - lastSend < 120000){
          y = readMag();
          if(y > TOP){
            TOP = y;                        //update TOP if new max has been detected
          else if(y < BOTTOM){
            BOTTOM = y;                     //update BOTTOM if new min has been detected
        TOP -= tol;                         //nudge TOP and BOTTOM so that they have a chance of being triggered
        BOTTOM += tol;
        increment = (TOP - BOTTOM) / totDividers;    //recalculate increment to match new TOP and BOTTOM
        autoDetectMaxMin = false;           //finished determining TOP and BOTTOM
      Serial.println("Store on Controller TOP and BOTTOM found");
      send(lastTopMsg.set(TOP));
      send(lastBottomMsg.set(BOTTOM));
      Serial.print("Increment = ");
      Serial.println(increment);
      oldy = readMag();
      y = readMag();
      while(abs(y - oldy) < increment / 2){ //wait until difference b/w y and oldy is greater than half an increment
        y = readMag();
      rising = (y > oldy);
      Serial.println(rising ? "Magnetic field is rising" : "Magnetic field is falling");
        sendSketchInfo("Gas Meter", "0.4");
        // Register this device as Gas sensor
        present(CHILD_ID, S_GAS);
    void loop(){
      if (!pcReceived) {
        //Last Pulsecount not yet received from controller, request it again
        return;
      //detecting magnetic pulses - Fractional Simple Method
      while(millis() - lastSend < SEND_FREQUENCY){
        int y = readMag();
      if(y >NewTop ){
            NewTop = y;                        //update TOP if new max has been detected
          else if(y < NewBottom){
            NewBottom = y;                     //update BOTTOM if new min has been detected
        if(inside && rising && y > BOTTOM + divider * increment && divider < totDividers+1){
          divider++;
          pulsecount++;
        else if(inside && !rising && y < TOP - divider * increment &&  divider < totDividers+1){
          divider++;
          pulsecount++;
        if(inside && (y > TOP || y < BOTTOM )){        //switch directions once TOP or BOTTOM divider has been reached
          inside = false;                 //keep this from happening multiple times once signal exceeds TOP or BOTTOM
          Serial.println("OUTSIDE");
        else if(!inside && (y < TOP - increment / 2 && y > BOTTOM + increment / 2)){
          rising = !rising;
          divider = 1;
          inside = true;
          Serial.println("INSIDE");
    counter += (pulsecount - oldPulseCount);      //update counter
        if(counter >= ((totDividers + 1) * 2)){
        if ( (abs(TOP-NewTop)) > tol || (abs(BOTTOM-NewBottom)) >tol){
          TOP=NewTop-tol;
          BOTTOM=NewBottom+tol;
          //Send Top and Bottom to gateway
          //reset newTop and newBottom
          newTop = -9000;
          newBottom = 9000;
          counter = 0;
          //display new bounds
          Serial.println("NEW BOUNDARIES SET:");
          Serial.print("Top = ");
          Serial.println(TOP);
          Serial.print("Bottom = ");
          Serial.println(BOTTOM);
      //shift all flow array elements to the right by 1, ignore last element
      for(int idx = len - 1; idx > 0; idx--){
        flow[idx] = flow[idx - 1];
      //calculate newest flow reading and store it as first element in flow array
      flow[0] = (double)(pulsecount - oldPulseCount) * (double)vpp * 60000.0 / (double)SEND_FREQUENCY;
      //display flow array state
      Serial.print("Flow Array State: [");
      for(int idx = 0; idx < len - 1; idx++){
        Serial.print(flow[idx]);
        Serial.print("|");
      Serial.print(flow[len - 1]);
      Serial.println("]");
      //calculate average flow
      avgFlow = 0;                                //reset avgFlow
      for(int idx = 0; idx < len; idx++){         //calculate weighted sum of all elements in flow array
        avgFlow += (flow[idx] * (len - idx));
      avgFlow /= (len * (len + 1) / 2);           //divide by triangle number of elements to get linear weighted average
      Serial.print("Average flow: ");             //display average flow
      Serial.println(avgFlow);
      //send flow message if avgFlow has changed
      if(avgFlow != oldAvgFlow){
        oldAvgFlow = avgFlow;
        send(flowMsg.set(avgFlow, 2));
      //send updated cumulative pulse count and volume data, if necessary
      if(pulsecount != oldPulseCount){
        oldPulseCount = pulsecount;              //update old total
        //calculate volume
        volume = (double)oldPulseCount * (double)vpp / 1000.0;
        //send pulse count and volume data to gw
        send(lastCounterMsg.set(pulsecount));
        send(volumeMsg.set(volume, 3));
      if (message.type==V_VAR1) {
        unsigned long gwPulseCount=message.getULong();
        pulsecount = gwPulseCount;
        Serial.print("Received last pulse count from gw:");
        Serial.println(pulsecount);
        pcReceived = true;
      if (message.type==V_VAR2) {
        int gwStoredTOP=message.getInt();
        TOP = gwStoredTOP;
        Serial.print("Received stored TOP value from gw:");
      if (message.type==V_VAR3) {
        int gwStoredBOTTOM=message.getInt();
        BOTTOM = gwStoredBOTTOM;
        Serial.print("Received stored BOTTOM value from gw:");
    int readMag(){
      int x = 0, y = 0, z = 0;
      //Tell the HMC5883 where to begin reading data
      Wire.write(0x03); //select register 3, X MSB register - was called Wire.send but the compiler had an error and said to rename to to Wire.write
      //Read data from each axis, 2 registers per axis
      Wire.requestFrom(address, 6);
      if(6<=Wire.available()){
        x = Wire.read()<<8; //X msb
        x |= Wire.read(); //X lsb
        z = Wire.read()<<8; //Z msb
        z |= Wire.read(); //Z lsb
        y = Wire.read()<<8; //Y msb
        y |= Wire.read(); //Y lsb
      if(!autoDetectMaxMin){
        //show real-time magnetic field, pulse count, and pulse count total
        Serial.print("y: ");
        Serial.print(y);
        Serial.print(rising ? "  Rising, " : "  Falling, ");
        Serial.print("next pulse at: ");
        Serial.print(rising ? BOTTOM + divider * increment : TOP - divider * increment);
        Serial.print("  Current Number of Pulses: ");
        Serial.print(pulsecount - oldPulseCount);
        Serial.print("  Last Total Pulse Count Sent to GW: ");
        Serial.println(oldPulseCount);
      else{
        //show real-time magnetic field, TOP, BOTTOM, and time left in auto-detect mode
        Serial.print(y);
        Serial.print("  TOP: ");
        Serial.print(TOP);
        Serial.print("  BOTTOM: ");
        Serial.print(BOTTOM);
        unsigned long remainingTime = 120000 + lastSend - millis();
        Serial.print("  Time remaining: ");
        Serial.print(remainingTime / 60000);
        Serial.print(":");
        remainingTime = (remainingTime % 60000) / 1000;
        if(remainingTime >= 10){
          Serial.println(remainingTime);
        else{
          Serial.print("0");
      return y;
    I have another little problem that after a while the node stop to work i don't know but on the serial stop to print data and no more message is sent to the gateway if i close and re-open the serial monitor the data readed by magnetometer is displayed again but no data is sent,
    Can be related to radio issue ? or overbuffering serial ? do you have experienced similar problem?
    • dpcrD
      dpcrD
      dpcr
      Yes, a major change in magnetic field readings while the sensor is powered down could result in a large number of pulses being triggered if Top and Bottom are drastically different than what the sensor has stored. It is best to reset Top and Bottom to 0 in that case, forcing Auto-Detect to run and get accurate values for Top and Bottom.
      In future versions, I plan to add a feature that lets users choose to reset Top and Bottom from the Serial Monitor. If it's been a while since the sensor was last running or if operating conditions have changed (the sensor was relocated or something similar), users can use that feature to ensure that the program begins with proper values for Top and Bottom. I also plan on publishing two versions of the sketch: one that stores Top, Bottom, and Pulse Count in Fram, and one that stores those values on the controller.
      As far as counting pulses goes, the old version and the new version aren't too different. They both divide the space between Top and Bottom into a number of divisions, and trigger pulses once a division is passed. The math they use to do it is slightly different. The old version calculates what number the magnetic field reading needs to rise/fall to and compares that to the most recent reading. The new version checks if the distance between the magnetic field reading that last triggered a pulse and the most recent reading is equal to or greater than the distance between divisions. The old version had problems when the magnetic field was switching from rising to falling (probably because I didn't continuously update Top and Bottom), but the new version feels more elegant. There's probably not much of a difference at this point, though.
      I did have a problem where it seemed like the sensor wasn't printing anything to the serial monitor, but that was due to bad program flow that occasionally made it impossible to update lastSend. I've never had a problem that prevented the sensor from sending data to the Gateway.
      dpcrD 1 Reply Last reply
      • dpcrD dpcr
        dpcrD
        dpcrD
        dpcr
        @dpcr New Sketch: This one is version 1.0 and works well with the hardware I'm using. It has an interactive start up menu in the serial monitor when starting which allows one to choose several options and var1 (variable used to store the pulse count on the controller) was removed and the pulse count is now stored in FRAM. It's been running for several months with no problem.
         * Created by Sean Creel <creels15@gmail.com>
         * Based on these projects by Henrik Ekblad and Korneliusz Jarzębski:
         * https://www.mysensors.org/build/pulse_water
         * https://github.com/jarzebski/Arduino-HMC5883L
         * DESCRIPTION:
         * Uses an I2C triple-axis magnetometer to measure a home's gas usage by
         * detecting small fluxuations in the local magnetic field caused by the
         * meter's bellows pumping in and out. Requires users to determine how
         * many cycles their meter completes per unit volume of gas flow.
        #define MY_DEBUG                        //enables debugging of MySensors messages
        #define MY_RADIO_NRF24                  //lets MySensors know what radio you're using
        #include <Wire.h>                       //I2C communications library
        #include <Adafruit_FRAM_I2C.h>          //Adafruit FRAM memory library
        #define address 0x1E                    //0011110b, I2C 7bit address of HMC5883 magnetometer
        #define topAddr 4                       //address of Top in FRAM
        #define bottomAddr 6                    //address of Bottom in FRAM
        #define pulseAddr 0                     //address of pulseCount in FRAM
        //USER-DEFINED CONSTANTS
        #define METRIC true                     //specifies the units of measurement
        #define AXIS "Y"                        //specifies which axes of the magnetometer to read from (multiple axes permitted, e.g. "ZX" or "YXZ")
        #define CYCLES_PER_CUFT 8               //cycles of the meter's bellows per cubic foot of gas (varies by  meter model)
        #define NUM_DIVISIONS 10                //desired number of subdivisions per cycle. higher => more accuracy, lower => more tolerant of noise
        #define ERR 0.00221513400975639000      //used to fix discrepancies between theoretical and actual volume per pulse (vpp)
        #define LEN 3                           //number of flow rate measurements to save for moving average. set to 1 if you want to send raw flow data instead
        #define SEND_FREQUENCY 30000            //Minimum time between messages to the GW (msec)
        #define TOL 50                          //margin of error to account for noise coming from the sensor
        bool autoDetect = false;                //true if the program is auto detecting Top and Bottom
        bool safe = false;                      //whether or not it is safe to switch directions
        unsigned long pulseCount = 0;           //total number of pulses measured ever
        double vpp = ERR + (METRIC ? 28.3168 : 1.0) / (CYCLES_PER_CUFT * 2 * (NUM_DIVISIONS + 1));//Volume of gas per pulse ft^3/L
        double flow [LEN];                      //array of previous gas flow rate measurements
        int b = 0;                              //magnetic field reading
        int oldB = 0;                           //previous magnetic field reading
        int top = 0;                            //highest magnetic field registered from meter (Ga)Initialize low if using autoDetectMaxMin
        int bottom = 0;                         //lowest magnetic field registered from meter (Ga) Initialize high if using autoDetectMaxMin
        int increment = 0;                      //space b/w dividers
        int counter = 0;                        //used to count pulses over periods longer than SEND_FREQUENCY
        Adafruit_FRAM_I2C fram = Adafruit_FRAM_I2C();
        void setup(){
          //Initialize Serial, I2C, and FRAM communications
          Serial.begin(9600);
          Wire.begin();
          fram.begin();
          //Prompt user for permission to clear all or part of FRAM
          Serial.println("Do you wish to clear all or part of long-term memory?");
          Serial.println("Please enter a number 0-3:");
          Serial.println("0: (default) Clear nothing");
          Serial.println("1: Clear Top and Bottom");
          Serial.println("2: Clear Pulse Count");
          Serial.println("3: Clear Top, Bottom, and Pulse Count");
          int choice = 0;
          while(Serial.available() == 0 && millis() - lastSend < 30000); //wait 30s max for user input
          choice += Serial.parseInt();
          if(choice == 1){
            clearFram(4,8);
            Serial.println("Top and Bottom values reset");
          else if(choice == 2){
            clearFram(0,4);
            Serial.println("Pulse Count reset");
          else if(choice == 3){
            clearFram(0,8);
            Serial.println("All stored values reset");
          //get pulseCount from FRAM
          pulseCount = readUL(pulseAddr);
          oldPulseCount = pulseCount;
          //get Top and Bottom from FRAM
          newTop = readInt(topAddr);
          newBottom = readInt(bottomAddr);
          updateBounds();
          //WARNING: MAKE SURE GAS IS RUNNING ON FIRST RUNNING OF THIS PROGRAM!!!
          if(top == 0 && bottom == 0){
            autoDetect = true;
            newTop = -9000;
            newBottom = 9000;
            Serial.println("FRAM has been cleared. Auto-detecting max and min magnetic field reading.");
            Serial.println("WARNING: MAKE SURE GAS IS RUNNING!!");
              readMag();
              detectMaxMin();
              //display details
              Serial.print("Magnetic Field: ");
              Serial.print(b);
              Serial.print("  Top: ");
              Serial.print(newTop);
              Serial.print("  Bottom: ");
              Serial.print(newBottom);
              Serial.print(":");
              else{
                Serial.print("0");
            updateBounds();
            autoDetect = false;
          readMag();
          oldB = b;
          while(abs(b - oldB) < increment / 2){ //wait until difference b/w b and oldB is greater than half an increment
            readMag();
          rising = (b > oldB);
          Serial.print("Volume Per Pulse = ");
          Serial.print(vpp,16);
          Serial.println(METRIC ? " L/pulse" : "cuft/pulse");
            sendSketchInfo("Gas Meter", "1.0 (4/4/17)");
        void loop(){
          //detecting magnetic pulses - variable boundary method
            //check if the signal has significantly increased/decreased
            if(abs(oldB - b) > increment){
              pulseCount ++;
              //increment or decrement oldB by one increment based on direction
              oldB += rising ? increment : -1 * increment;
              safe = false;             //reset safe now that oldB has updated
            //check if the signal has recently switched directions
            else if(safe){                  //first make sure b has moved a significant distance from oldB
              if((rising && b <= oldB) || (!rising && b >= oldB)){
                pulseCount ++;              //add one extra pulse
                rising = !rising;           //update direction
                safe = false;
            //take another reading
            readMag();
            //check if b has moved a significant distance from oldB
            if(abs(b - oldB) > TOL / 2){
              safe = true;
            //update newTop and newBottom
            detectMaxMin();
          for(int idx = LEN - 1; idx > 0; idx--){
          flow[0] = (double)(pulseCount - oldPulseCount) * vpp * 60000.0 / (double)SEND_FREQUENCY;
          for(int idx = 0; idx < LEN - 1; idx++){
            Serial.print("|");
          Serial.print(flow[LEN - 1]);
          for(int idx = 0; idx < LEN; idx++){         //calculate weighted sum of all elements in flow array
            avgFlow += (flow[idx] * (LEN - idx));
          avgFlow /= (LEN * (LEN + 1) / 2);           //divide by triangle number of elements to get linear weighted average
          //send updated volume data if necessary
          if(pulseCount != oldPulseCount){
            //send volume data to gw
            send(volumeMsg.set(((double)pulseCount * vpp / (METRIC ? 1000.0 : 1)), 3));
            //store updated pulse count total in FRAM
            writeUL(pulseAddr,pulseCount);
            counter += (pulseCount - oldPulseCount);      //update counter
            if(counter >= ((NUM_DIVISIONS + 1) * 2)){
              updateBounds();                 //update bounds if at least 1 cycle has been read
              counter = 0;                    //reset counter
            oldPulseCount = pulseCount;              //update old pulse count total
        void updateBounds(){
          if((top != newTop) && (bottom != newBottom)){   //check if anything has actually changed
            //lock in Top and Bottom
            top = newTop;
            bottom = newBottom;
            //recalculate increment to match new top and bottom
            increment = (top - bottom - (2 * TOL)) / NUM_DIVISIONS;
            //store updated Top and Bottom in FRAM
            writeInt(topAddr,top);
            writeInt(bottomAddr,bottom);
            newTop = -9000;
            newBottom = 9000;
            Serial.println(top);
            Serial.println(bottom);
        void detectMaxMin(){
          if(b > newTop){
                newTop = b;                    //update newTop if new max has been detected
          else if(b < newBottom){
            newBottom = b;                     //update newBottom if new min has been detected
        void writeInt(int addr, int val){       //write an int value to FRAM
          byte b = highByte(val);
          fram.write8(addr,b);
          b = lowByte(val);
          fram.write8(addr + 1,b);
        void writeUL(int addr, unsigned long val){  //write an unsigned long falue to FRAM
          byte b = B00000000;
          for(int idx = 0; idx < sizeof(unsigned long); idx++){
            b = val >> 8 * (sizeof(unsigned long) - 1 - idx);
            fram.write8(addr + idx,b);
        unsigned long readUL(int addr){         //read an unsigned long value from FRAM
          unsigned long result = 0;
            result = result << 8;
            result += (unsigned long)fram.read8(addr + idx);
          return result;
        int readInt(int addr){                  //read an int value from FRAM
          int result = 0;
          result += (int)fram.read8(addr);
          result += (int)fram.read8(addr + 1);
          return result;
        void clearFram(int first, int last){
          for(int addr = first; addr < last; addr++){
            fram.write8(addr,byte(0));
        void readMag(){
          static int x = 0, y = 0, z = 0;
          if(String(AXIS).equalsIgnoreCase("X")){
            b = x;
          else if(String(AXIS).equalsIgnoreCase("Y")){
            b = y;
          else if(String(AXIS).equalsIgnoreCase("Z")){
            b = z;
          else if(String(AXIS).equalsIgnoreCase("XY") || String(AXIS).equalsIgnoreCase("YX")){
            b = x * x + y * y;
          else if(String(AXIS).equalsIgnoreCase("XZ") || String(AXIS).equalsIgnoreCase("ZX")){
            b = x * x + z * z;
          else if(String(AXIS).equalsIgnoreCase("YZ") || String(AXIS).equalsIgnoreCase("ZY")){
            b = y * y + z * z;
          else if(String(AXIS).equalsIgnoreCase("XYZ") || String(AXIS).equalsIgnoreCase("XZY")
                  || String(AXIS).equalsIgnoreCase("YXZ") || String(AXIS).equalsIgnoreCase("YZX")
                  || String(AXIS).equalsIgnoreCase("ZYX") || String(AXIS).equalsIgnoreCase("ZXY")){
            b = x * x + y * y + z * z;
          else {
            b = 0;
          if(!autoDetect){
            Serial.print(b);
            Serial.print(rising ? oldB + increment : oldB - increment);
            Serial.print(pulseCount - oldPulseCount);
        dynamiteD 1 Reply Last reply
        • dpcrD dpcr
           * DESCRIPTION:
          void setup(){
            Serial.begin(9600);
            Wire.begin();
            fram.begin();
            int choice = 0;
            if(choice == 1){
              clearFram(4,8);
              clearFram(0,4);
              clearFram(0,8);
            updateBounds();
              autoDetect = true;
              newTop = -9000;
              newBottom = 9000;
                readMag();
                detectMaxMin();
                //display details
                Serial.print(b);
                Serial.print(":");
                else{
                  Serial.print("0");
              updateBounds();
              autoDetect = false;
            readMag();
            oldB = b;
              readMag();
          void loop(){
                pulseCount ++;
                  safe = false;
              readMag();
                safe = true;
              detectMaxMin();
              Serial.print("|");
              top = newTop;
              bottom = newBottom;
              newTop = -9000;
              newBottom = 9000;
            if(b > newTop){
            b = lowByte(val);
            byte b = B00000000;
            return result;
            int result = 0;
            return result;
          void readMag(){
              b = x;
              b = y;
              b = z;
              b = x * x + y * y;
              b = x * x + z * z;
              b = y * y + z * z;
            else {
              b = 0;
            if(!autoDetect){
              Serial.print(b);
          dynamiteD
          dynamiteD
          dynamite
          wrote on last edited by dynamite
          #38
          @dpcr Nice adjustment of your Original code. Based on your Original version I have started coding as well as I like the simpleness of just adding a sensor to the meter without taking care of the direct position.
          My current code can be found at github via the following link:
          https://github.com/rspaargaren/Read_Gasmeter/blob/Workinprogress/Read_Gasmeter.ino
          Basic differences are:
          • I have removed the fram reference but this could be added again if you use it.
          • I have added a different setup sequence for fixing the top and bottom. In my case it waits until four changes in direction have occured. So no direct gas flow have to flow after a restart.
          • The number of pulses between a change in direction is fixed independent of a change in top or bottom. So in my case every half a cycle will give ten pulses and a full cycle 20 pulses.
          • The results are submitted to the gateway after a intervall but also after half a cycle.
          • The top and bottom is checked after each cycle. So in case of major difference the interval is changed.
          • During normal run, the reading of the y value is executed within the loop. So basically the arduino has time to do some other stuff as well in between the readings.
          The code is currently working but requires some clean up. Also I would like to make an option to store the values at the gateway and maybe change the hardware to an ESP version so I can have multiple ways of output. Like MQTT.
          This is the current output in Grafana:
          0_1493840069318_upload-83a800b9-0b52-4b3a-a54e-829249fcf012
          dpcrD 2 Replies Last reply
          • dynamiteD dynamite
            dpcrD
            dpcrD
            dpcr
            @dynamite I just scanned quickly over your code. So there is no need to store the top and bottom values? What do you do on a power failure? I look forward to hearing from you more.
            Do you have any pics of your hardware?
            • dpcrD dpcr
              dynamiteD
              dynamiteD
              dynamite
              #40
              @dpcr At the moment I do not store the top and bottom value permanently. In case of a power failure I will "loose" to the max two rounds of the wheel on pulses as it uses that to calibrate the top and bottom. That could be reduced to potentially only one cycle. Which is in my case 0,01m3 to 0,02 m3 of gas indication.
              After the power failure the process starts in the calibration loop which is ended only after the required cycles have registered. So this could last 30 sec in case you are having a shower but can last a week if you are away...
              I will post a picture of my setup later.
              Now I am thinking of it. If you do not care about the accuracy that much you do not need the top and bottom values at all. You just need to detect the rice and fall. That still gives you double the accuracy than a reed contact or Hall effect. The sketch for that will be very simple and after power down you can continue most probably without loss of pulses.
                dpcrD
                dpcrD
                dpcr
                @dynamite Great idea (top and bottom). We were kicking that around when we made this but wanted to err on the side of missing little to no gas flow. We have a pilot light on our water heater the draws around .1 lpm and I want to capture that as well.
                I agree with you on the accuracy of using a magnetometer over a hall or reed switch, but they (hall or reed) are much easy to program. Too bad there isn't a library for converting a sine wave to pulses, don't forget that sometimes it doesn't look like a sine wave.
                I'm curious to see how you mounted your magnetometer to your gas meter, mine seems a little too bulky and obtrusive. I did manage to buy another magnetometer and dip it in some stuff called PlastiDip. Its used for insulating the handles of tools. I just haven't switched them out yet to see how well it works.
                • dpcrD dpcr
                  dynamiteD
                  dynamiteD
                  dynamite
                  #42
                  @dpcr Hi the reason that it is sometimes not a sine wave is the reason why I used a fixed number of pulses between the top of bottom. So in case the flow is very low as for your pilot light it will detect every puls. In case you have a very heavy flow pulses can be skipped as long as the change is detected then in my case 10 pulses are submitted to the gate way. I was detecting in your original sketch sometimes extra pulses were submitted as the sine was little bit rising or the opposite dropping.
                  The code for just detecting rise and fall can be quite straigh foreward. I might make a second version like that...just for the record.
                  My Setup is quite straight forward. A small box with the arduino pro mini and radio. A cable to the magneto sensor. In my case water proof is not required. I have applied the sensor by Velcro strap so I can remove the setup in case of "Maintenance".
                  YveauxY dpcrD 2 Replies Last reply
                    @dynamite I seem to have the same meter; the BK-G4 :
                    0_1494093064638_upload-7b4dd65e-d3af-43fc-ac01-4c8357b57059
                    The 'official' place to stick a reed sensor is a hole on the bottom-right, as you can see in the picture.
                    I had a spare reed switch from a Senseo coffee machine, which perfectly fits the hole and works perfect!
                    Maybe if you stick the compass sensor here, the signal will be more consistent/repeatable, as it should be more or less the same with each revolution.
                      dpcrD
                      dpcrD
                      dpcr
                      @dynamite I noticed some pulses missing as well. It looks like the newer sketch catches them. I also checked the volume used with our gas suppliers volume used and it was pretty close. We added an error correction variable to try to be more accurate. When I get a chance I'm going to try your sketch, it looks interesting.
                      • YveauxY Yveaux
                        dynamiteD
                        dynamiteD
                        dynamite
                        @Yveaux Hi thanks for the suggestion. Basically the position I am using now gives me a very accurate signal. It is more the small changes in the Sine curve which could result in miss reading. But I have added some filtering by appying a running average.
                        I have tried other position just to see the results. Basically if you stick it to close to the magnet used, like the official reed position it will go in overload and magnetic reading is maximized for a period.
                        • dpcrD dpcr
                          dynamiteD
                          dynamiteD
                          dynamite
                          #46
                          @dpcr Hi i am looking forward for your experience, as far as I have experienced now, and it took me quite some debugging I did not miss a pulse. :-)
                          @Yveaux @dpcr My next testing is to apply this sensor for the watermeter.
                            For water meters I saw people using those lines trackers that are used on small robots
                              dynamiteD
                              dynamiteD
                              dynamite
                              @gohan Yes i have Seen them as Well that would be the easy way out ;-)
                              I am just curious wether i am picking up a workable signal when i stick this sensor to it. If so it would make installation quite simple.
                                @dynamite said in Gas Meter Reading Using a Magnetometer:
                                Yes, works like a charm! At least for my sensor
                                • YveauxY Yveaux
                                  dynamiteD
                                  dynamiteD
                                  dynamite
                                  #50
                                  @Yveaux nice! and what code are you using? or are you referring to putting the ir sensor to the meter?
                                    dpcrD
                                    dpcrD
                                    dpcr
                                    @dynamite Just checking in, how is your set up working? We just had some major problems with too many extra pulses. It looks like something you experienced earlier, we added some smoothing to the readMag output similar to what you have in your sketch and it seems to working fine. Any updates?
                                    • jumpingJ
                                      jumpingJ
                                      jumping
                                      I have a BK-G4L gas meter and I want to build a Mysensor node and measure the gas flow: what is the best solution, a reed switch or a magnetometer?
                                      and for a magnetometer based sensor, do I need HMC5883 or HMC5983?
                                      thanks
                                      Raspberrry PI3 - Domoticz
                                      ESP8266 GW - MySensors 2.1.1
                                      • jumpingJ jumping
                                        thanks
                                        dynamiteD
                                        dynamiteD
                                        dynamite
                                        @jumping Hi I have used the magnetometer. (GY-282 HMC5983)
                                        I these are the +/- of both the systems:
                                        • More easy to locate on your gas meter
                                        • Higher accuracy of output (more pulses per cycle)
                                        • Code is more complex
                                        Read Sensor
                                        • Simple code
                                        • Exact installation from position
                                        • 1 puls per round
                                        jumpingJ 1 Reply Last reply
                                        • dpcrD dpcr
                                          dynamiteD
                                          dynamiteD
                                          dynamite
                                          #54
                                          @dpcr Hi, I need to recalibrate to see if the reading is still OK. Somewhere during a total reset I have lost track. But it is on my to do list to get everything up and running again.
                                          As far as I could recollect an overshoot had no influence on my code as the number of pulses for a total cycle is consistent within my code.
                                          On the Y reading from the sensor I do have a running average smoothing.
                                          Basically every cycle is splitted into rising and falling part. Each splitted into a fixed number of steps. Based on the current reading of y the number of pulses is calculated within that step. So the amount of pulses within a rise or fall can never be more than the number of steps within that cycle.
                                          I am thinking of making the code more simple and only give a pulse on the changes and maybe one in the middle. That would give me about 4 pulses per cycle.
