  3. Microwave Radar Module as PIR replacement.
42 Posts 21 Posters 48.0k Views 26 Watching
  • cimba007C cimba007
    @Yveaux I did some extensive testing on the FC1816 module and I thought I might drop my experience:
    http://electronics.stackexchange.com/questions/226031/pinout-of-microwave-motion-sensor-fc1816
    In the end I used an 150ohm Series resistor + ~100µF cap behind this to power the FC1816. This eliminated much of the leftover noise. If this is not enough I presented a way to lower the module amplification. In the end I deactivated the biss-trigger output alltogether and grabbed the raw signal. Doing some manual processing:
    1. take 100 reads
    2. get the stddev (statistics library)
    3. high stddev = high fluctuation in values = movement
    Take a look at my current working copy of my code for the FC1816:
    Some notes:
    I power the VCC of the FC1816 from some arduino pins. Thus I can deactivate the microwave sensor at will. This is still not recommended. If you visit the previous link you can see that the BISS has some kind of "warmup"-Period.
    I use 3,3Volt to power the NRF24, the arduino and the FC1816 and suffered no strange consequences so far.
    Get get some insight about the link quality of the NRF24 I made the function RF24_getObserverTX() accessible from user-space:
    MySensors\drivers\RF24\RF24.cpp
    uint8_t RF24_getObserveTX(void)
    	return RF24_readByteRegister(OBSERVE_TX);
    MySensors\drivers\RF24\RF24.h
    uint8_t RF24_getObserveTX(void);
    The Idea behind the OBSERVE_TX register is that the lower byte presents the number of retrys the NRF24 used in the last send.
    The upper 4 bits present the number of total failed packets. I suggest using (0x0F & RF24_getObserveTX()) to get a usable number 0-15 presenting the retry-count. Anything > 0 suggests a packetloss on your link. 15 most likely will mean you ran into an complete fail as the max number of retrys was exhausted.
    This number might be capped by
    // ARD, auto retry count
    #define RF24_ARC 15
    from the RF24.h driver-file.
    TO not run into compiling errors you might need:
    http://arduiniana.org/libraries/streaming/
    https://github.com/RobTillaart/Arduino/tree/master/libraries/Statistic
    MicrowaveRadarSensor.ino
    #include <Streaming.h>
    #include "Statistic.h"
     * Version 1.0 - Henrik EKblad
     * Example sketch showing how to measue light level using a LM393 photo-resistor
     * http://www.mysensors.org/build/light
    #define MY_NODE_ID 10
    #define MY_BAUD_RATE 57600
    #define LIGHT_SENSOR_ANALOG_PIN A3
    #define MICRO_SENSOR_ANALOG_PIN A1
    unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
    #define CHILD_ID_LIGHT 0
    #define CHILD_ID_MICRO 0
    #define TRIPPED_THRESHOLD 50
    MyMessage msg_light(CHILD_ID_LIGHT, V_LIGHT_LEVEL); // 23
    MyMessage msg_micro(CHILD_ID_MICRO, V_TRIPPED);     // 16
    MyMessage msg_micro_debug(0,V_VAR1);   // 24
    MyMessage msg_obstx_debug(0,V_VAR2);   // 25
    void before()
      // LightSensor
      pinMode(A3,INPUT_PULLUP);
      pinMode(A2,OUTPUT);
      digitalWrite(A2,LOW);
      // Microwave
      pinMode(5,OUTPUT);        // VCC BISS0001
      digitalWrite(5,HIGH);
      pinMode(6,OUTPUT);        // Enabled
      digitalWrite(6,LOW);      // Enable
      pinMode(7,OUTPUT);        // GND
      digitalWrite(7,LOW);
      pinMode(8,OUTPUT);        // VCC Radar
      digitalWrite(8,HIGH);
      pinMode(A1,INPUT);        // PIR 2nd Amplification Stage
      // Other
    void presentation()  {
      sendSketchInfo("Microwave+Light", "1.0");
      // https://www.mysensors.org/download/serial_api_20#sensor-type
      present(CHILD_ID_MICRO, S_MOTION);
      //present(0, S_ARDUINO_NODE);
      // Report VCC
      static long vcc = readVcc();
      static int vccpercent = map(vcc,1800,3280,0,100);
      sendBatteryLevel(max(min(vccpercent,100),0),false);
      Serial << "| vcc: ";
      p(F("%4d"),vcc);
      Serial << " ";
      // Required for ack
      //wait(100);
      // Report LightLevel
      analogRead(LIGHT_SENSOR_ANALOG_PIN);
      int lightLevel_raw = analogRead(LIGHT_SENSOR_ANALOG_PIN);
      int lightLevel = (1023-lightLevel_raw)/10.23; // as of 1023 !!
      Serial << "| light_raw: ";
      p(F("%4d"),lightLevel_raw);
      Serial << " ";
      Serial << "| light: ";
      p(F("%3d"),lightLevel);
      Serial << " ";
      send(msg_light.set(lightLevel),false);
      // Report WirelessLink Information
      Serial << "| observe_tx: ";
      uint8_t obstx = RF24_getObserveTX();
      p(F("%X"),obstx);
      Serial << " ";
      send(msg_obstx_debug.set(0x0F&obstx),false);
      // Report Microwave
      Statistic mw_s;
      mw_s.clear();
      delay(90);
      analogRead(MICRO_SENSOR_ANALOG_PIN);
      delay(10);
      for(int i = 0; i < 1000; i++)
        mw_s.add(analogRead(MICRO_SENSOR_ANALOG_PIN));
        delay(1);
      Serial << "| mw_raw: ";
      int stddev = mw_s.pop_stdev();
      p(F("%4d"),stddev);
      Serial << " ";
      Serial << "| mw_min: ";
      int minimum = mw_s.minimum();
      p(F("%4d"),minimum);
      Serial << " ";
      Serial << "| mw_max: ";
      int maximum = mw_s.maximum();
      p(F("%4d"),maximum);
      Serial << " ";
      Serial << "| mw: " << (stddev > TRIPPED_THRESHOLD ? "1" : "0") << " ";
      send(msg_micro_debug.set(stddev),false);
      while(!send(msg_micro.set(stddev > TRIPPED_THRESHOLD ? "1" : "0"),true))
        wait(10);
      if(isTransportOK())
        wait(100);
        wait(1000);
      Serial << endl;
      //mysleep(500);
    // https://forum.mysensors.org/topic/3463/m_ack_variable-or-m_set_variable/2
      if (message.isAck()) {
          Serial.print("| GW ack");
    Helper.ino
    long readVcc() {
      //result *= 1.0637;
    #include <stdarg.h>
    void p(const __FlashStringHelper *fmt, ... ){
      char buf[128]; // resulting string limited to 128 chars
      va_list args;
      va_start (args, fmt);
    #ifdef __AVR__
      vsnprintf_P(buf, sizeof(buf), (const char *)fmt, args); // progmem for AVR
      vsnprintf(buf, sizeof(buf), (const char *)fmt, args); // for the rest of the world
      va_end(args);
      Serial.print(buf);
    void mysleep(int SLEEP_TIME)
        if(isTransportOK()){
          Serial << "| wait ";
          wait(25);
          Serial << "| zZz > ";
          sleep(SLEEP_TIME);
          Serial << "| < zZz " << endl;
        else {
          wait(1000);
    @cimba007 wow, you did some serious research there! (I see you make good use of the arduino plot function)
    I'll certainly come back to your research once I start with this sensor (so much to choose from...)
    Any ideas about current consumption? Is this a viable alternative to battery powered pir sensors?
    cimba007C 1 Reply Last reply
    • YveauxY Yveaux
      cimba007C
      cimba007C
      cimba007
      wrote on last edited by cimba007
      #28
      @Yveaux From my oppinion the radar modules are not suited for battery usage. Their drain something like 3-5mA and are not easy to put to sleep. Remember the warm-up period of the BISS. It seems to be like 10-15seconds.
      The plots are from another sketch, not the one I posted but using them is pretty straight forward.
      In my sketch have a look at these parts:
        Serial << " ";
      To use the arduino plotting all you ahve to do is send a string like this:
      0,10,534,123 .. whatever .. beware that no other serial output should happen if you want to use the arduino build-in plotting. Using the streaming library ( http://arduiniana.org/libraries/streaming/ ) it all boils down to a single line:
      Serial << mw_s.minimum() << "," << mw_s.maximum() << "," << mw_s.pop_stdev() << endl;
      In addition to the power consumption my approach requires sampling the analog input for a whole second .. or the more the better.
      This might be improved if you can prevent the FC1816 from retriggering itself. I had some serious problems as during the "inhibitor" period the analogOutput from the 2nd amplification stage was quite high often instantly retrigger the biss-output after the inhibition period ended.
      One solution might be this:
      Try this if you want to look down this approch:
      • Power the FC1816 VCC and UDP through an RC-Section (100Ohm Resistor and after that (on the side of the FC1816) an capacitory ~100-220µF)
      • Replace amplification resistor from 105 to eg. 154 (lowering the amplification)
      To find the best value I used an variable resistor parallel to the 105-Ohms SMD-Resistor
      But .. don't forget the benefits of *he microwave sensor. You can mount it straight to a door and it would detect persons in front of the door without them noticing. For this reason I try to build an "Alarm-node" that can be hidden inside the house. Later I might improve the FC1816 with some aluminium foil for shielding as suggested earlier.
      I would suggest using an PIR if you need a battery powered node. Have a look at ( http://kavacky.lv/bypassing-sen-08630-pir-motion-sensors-voltage-regulator-to-work-with-3-3-v ). Some PIRs have a Regulator which might not be suited if you are running on battery using 3,3Volt.
          Serial << " ";
        @cimba007 I know, I also used serial plotting for some projects. Very handy, very unstable (at that time). Probably improved since then, as I haven't used it recently.
        • cimba007C
          cimba007C
          cimba007
          #30
          All things from my previous post regarding the wiring are still needed:
          Here is a stripped down example on how to use the FC1816 Microwave Sensor. You need the following library:
            Serial.begin(57600);
            Serial.print("begin");
            // Microwave
            digitalWrite(6,LOW);      // DISABLE PLEASE!
            pinMode(A1,INPUT);        // PIR 2nd amplification stage
            pinMode(A0,OUTPUT);       // UPD microwave generator
            digitalWrite(A0,HIGH);
            // Report Microwave
            static Statistic mw_s;
            static uint16_t stdev_sum = 0;
            //mw_s.clear();
            //digitalWrite(8,HIGH);
            //delay(100);
            uint16_t reading;
            for(int i = 0; i < 200; i++)
              reading = analogRead(MICRO_SENSOR_ANALOG_PIN);
              mw_s.add(reading);
              //Serial.println(reading);
              //Serial.flush();
              //delay(50);
              //LowPower.powerDown(SLEEP_60MS, ADC_ON, BOD_OFF);
              //delay(1);
            Serial.print(mw_s.minimum());   Serial.print(",");
            Serial.print(mw_s.average());   Serial.print(",");
            Serial.print(mw_s.maximum());   Serial.print(",");
            Serial.print(mw_s.pop_stdev()); Serial.print(",");
            stdev_sum += mw_s.pop_stdev();
            Serial.print(stdev_sum); //Serial.print(",");
            Serial.println();
            stdev_sum *= 0.9;
            mw_s.clear();
          I just had the idea to sum up the std-dev and decrease it by 10% every round. Thus the code is less prone to peaks.
          0_1471429474464_upload-9c26c9f3-6ccd-4aaf-9bcc-797ad4c03be4
          stdev_sum is the lower dark blue line which can now be much easier compared to a threshold.
          Some measurement with my µCurrent-Gold:
          Unmodified code as above, power LED removed from ProMini @ 8Mhz internal osci with LDO desoldered
          4,8mA
          I tried to put the FC1816 into sleep by disable the power to the Microwave generator but this doesn't work.
          I modified the fuses for 8Mhz with 0ms wakeup delay for stabelizing the oscillator. No risk no phun ;-)
          The most practical solution I got to replace a PIR (still nothing as close as a PIR ;-ö)
          1530µA
          with this code:
          Note that the radar generator just can't be disable as it needs 10-15seconds to stabelize after power up
          #include <LowPower.h>
            // Microwave
            // Report Microwave
            //mw_s.clear();
            //delay(100);
            uint16_t reading;
            for(int i = 0; i < 10; i++)
              LowPower.powerDown(SLEEP_15Ms, ADC_ON, BOD_OFF);
              mw_s.add(reading);
              //Serial.flush();
              //delay(50);
              //delay(1);
            Serial.println();
            Serial.flush();
            stdev_sum *= 0.9;
            mw_s.clear();
              // Microwave
              // Report Microwave
              //mw_s.clear();
              //delay(100);
              uint16_t reading;
                mw_s.add(reading);
                //Serial.flush();
                //delay(50);
                //delay(1);
              Serial.println();
              stdev_sum *= 0.9;
              mw_s.clear();
            4,8mA
            1530µA
            with this code:
              // Microwave
              // Report Microwave
              //mw_s.clear();
              //delay(100);
              uint16_t reading;
                mw_s.add(reading);
                //Serial.flush();
                //delay(50);
                //delay(1);
              Serial.println();
              Serial.flush();
              stdev_sum *= 0.9;
              mw_s.clear();
            @cimba007 Thanks for the update :+1: Very interesting numbers!
            The 'sleep' current of 1.5mA rules out the microwave module as battery powered PIR replacement for me...
            As a mains powered sensor they're still very interesting, though!
            • cimba007C
              cimba007C
              cimba007
              #32
              After a few more days of testing I noticed these ugly "PEAKS" from my FC1816 readings. I added lots of capacitors and RC and LC sections but still .. nasty little peaks (left side in the beginning)
              0_1471879150498_upload-a9d03c1d-941a-4179-9306-7fb6eb708a7b
              In my previous post replace this line:
              with this:
                // Ignore the first 3 peaks within short succession
                // Real movement should mean there are more peaks/activity over a long time
                static uint8_t peakcount = 0;
                if(mw_s.pop_stdev() > 30 && peakcount < 3)
                  peakcount++;
                  stdev_sum *= 0.92; //
                  if (stdev_sum >= 7)
                    stdev_sum -= 7; // Default background noise
                  if (stdev_sum > 512)
                    stdev_sum = 512;
                  if(peakcount > 0)
                    peakcount--;
              With this code the first 3 peaks are essentially removed .. if there is really some movement it should last for a few seconds and would still be detected.
              I have invested like 10-20hours into testing and debugging the FC1816 and I can say .. this thing is .. peculiar ..
              I hate it cause of the spikes, the amplification which has to be manually altered with a pot .. but at the same time I love it ..
              I can detect my foot beckoning 2-3meters apart in my bed :D
              An example of the code snipped in action:
              0_1471879619120_upload-a3996be3-43b2-417d-ab69-e2545d288fd3
              Here you can see the big spikes in the beginning completely ignored (1)
              0_1471879713596_upload-3031e15c-37cb-4799-8b4a-ea6c3193f6bf
                with this:
                    peakcount++;
                    if (stdev_sum >= 7)
                      stdev_sum = 512;
                    if(peakcount > 0)
                      peakcount--;
                @cimba007 awesome to read about all the research and debugging you did on this topic!
                Did you consider pouring the code into a library, so it can be reused and updated easily?
                • cimba007C
                  cimba007C
                  cimba007
                  #34
                  Currently I don't plan to make a library .. a library implies that the sensor is very easy to use .. plug in + import library.
                  The FC1816 is not such a sensor.
                  • Needs Voltage-Supply filter (RC Section)
                  • Need separate cable to grab the signal at the 2nd amplification stage
                  • Need potentiometer to lower the amplification
                  • Is very prone to random noise (in fact even entering RF24 or ATMEGA328 low power mode might increase noise floor a lot)
                  Using a "simple to use" library and not getting the expected result of an "easy"-sensor would be very disappointing. For now I would say this is an advanced sensor with some pitfalls.
                  I update this thread with my findings to hopefully make everybodys life a bit easyer if you want to tinker with the FC1816 although you now know it is a little beast ;-)
                  If you need any help just ask here and I will support you the best I can.
                    Are there any new updates on these sensors? I noticed there are some "new" one that have 2 potentiometers like the standard PIR sensors.
                      It's a review of some radar sensors if anyone is interested.
                      https://youtu.be/9WiJJgIi3W0
                      P 1 Reply Last reply
                        P
                        P
                        pandeyg
                        @gohan Can you help how to bypass this sensor without changing of sensor ....
                          I did not get what you meant
                          • alowhumA
                            alowhumA
                            alowhum
                            Does anyone have a complete MySensors sketch for these that they would be willing to share?
                            I tried to create a wildlife sensor with it a while ago.. but the signal seemed to always be high.
                            berkseoB 2 Replies Last reply
                              It depends a lot on the sensor type so minor changes need to be made on sketch to make it handle the inverse logic.
                              • alowhumA alowhum
                                berkseoB
                                berkseoB
                                berkseo
                                #41
                                @alowhum
                                I when the tested here is such:
                                https://ru.aliexpress.com/item/5-8GHZ-Microwave-Radar-Sensor-Module-Smart-Sensoring-Switch-6-9M-Home-Control-New-Electric-Unit/32752738026.html?spm=a2g0v.search0204.3.182.51813dffPLeG2R&ws_ab_test=searchweb0_0,searchweb201602_1_10152_5013111_10151_10065_10344_10068_10342_10343_316_10340_10341_10696_10084_10083_10618_10307_5723511_10301_10059_5013411_100031_10103_10624_10623_10622_10621_10620_5013311_5013211,searchweb201603_2,ppcSwitch_3_ppcChannel&algo_expid=6975e011-d892-4cfb-9b54-88979e999308-25&algo_pvid=6975e011-d892-4cfb-9b54-88979e999308&transAbTest=ae803_2&priceBeautifyAB=0
                                They work great on an almost standard PIR MOTION sketch
                                ..By the way why no one makes these motion sensors MW for MySensors on openhardware, it seems there is nothing complicated?
                                • alowhumA alowhum
                                  berkseoB
                                  berkseoB
                                  berkseo
                                  #42
                                  @alowhum
                                  Now I remembered that I once shot a video about this sensor. In the description below the video there are links to sketches that work with such sensors. But for this video I did not do subtitles in English, in sketches comments also seem to be in Russian. But I think it won't be a problem.
                                  https://www.youtube.com/watch?v=Q0sxeT0VsVg
                                  https://www.youtube.com/watch?v=NdrU0byfbvI
