  3. Combining relay and temperature sketch
76 Posts 9 Posters 24.1k Views 12 Watching
    try to put a wait(500) at end of loop function, or even wait(1000)
    Mad6969
    @gohan said in Combining relay and temperature sketch:
    wait(1000)
    Oh.. like I said : something stupid..
    Thanks a lot. :-)
    I also had "#define MY_NODE_ID 7", because I couldn't see the relay on my Vera.
      DHT sensor doesn't like to work very quickly, it needs some resting time between measurements :D
      Tim76T 1 Reply Last reply
        Tim76T
        Tim76T
        Tim76
        wrote on last edited by Tim76
        @gohan modfied my code..... still the same.... I get 16 children (relays) and no temp...... I have 4 ds18b20's connected.....
        And I get the error switch command on the relays....😑😑
        gohanG 1 Reply Last reply
          Mad6969
          Ok, now I have another problem.
          When I build the relay/dht node, I first made the thing work with the relay with button actuator sketch alone (the DHT was plugged, but it was an additional feature I wanted to add).
          Now, it seems that my power source doesn't have enough power to make the relay to close. The led on my relay board blinks when the relay is on and off, but nothing.
          That's weird.. I'll try running the relay sketch alone, just to see.
          • Tim76T Tim76
            @Tim76 ok, let's go back to the beginning. Try with one sensors only, if everything works then add one relay, then add the second and keep adding the sensors until you see something wrong. You need to go step by step, otherwise with all that stuff you have it will be impossible to debug.
            Tim76T 2 Replies Last reply
              Tim76T
              Tim76T
              Tim76
              @gohan ok
                Tim76T
                Tim76T
                Tim76
                @gohan both sketches work perfectly stand alone.... but I think the problem lies within the assingment of the child id's...
                James Bruce talks about this "bug" in his video on how to combine sketches.....
                They relay sketch assigns from 1 to 16
                And the temp sketch assigns from 0 to 15
                So they both try to use the same id's for their children when you try to combine them....
                I need a way to get around that and have relays on 1-16 and temp on 17 to 32......
                Or there might just be the same "bug" in the temperature sketch.....😬😬 wich might mean that they can't be combined for now......😒😒
                  if use something like this in presentation?
                  for (int i=1; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
                       present(i+3, S_TEMP);
                  you get the idea, just shift the child id of the dallas sensors and leave the first 4-5 IDs for relays
                    Tim76T
                    Tim76T
                    Tim76
                    @gohan aha! Will be trying that later tonight..... I'll keep you posted! 😊 Thx man!
                      Tim76T
                      Tim76T
                      Tim76
                      @gohan soooooo...... I tried this:
                           present(i+16, S_TEMP);
                          pinMode(pin, OUTPUT);
                      now I get the temp sensors with child id's 1 to 16 and no relays at all
                        I probably used wrong sintax
                          Tim76T
                          Tim76T
                          Tim76
                          @gohan tried this again...... same result.....
                            for (int i=17; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
                               present(i, S_TEMP);
                          • Tim76T Tim76
                                 present(i, S_TEMP);
                            Tim76T
                            Tim76T
                            Tim76
                            here's the complete code as she is right now...
                            #define MY_RF24_CE_PIN 49
                            #define MY_RF24_CS_PIN 53
                            #define MY_NODE_ID 30
                            #include <OneWire.h>
                            int numSensors=0;
                            bool receivedConfig = false;
                            bool metric = true;
                            MyMessage msgTemp(0,V_TEMP);
                            #define RELAY_1  30  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                            #define NUMBER_OF_RELAYS 16 // Total number of attached relays
                            void before()
                              sensors.begin();
                              sendSketchInfo("Greenhouse main controller", "1.0");
                                 present(i, S_TEMP);
                              sleep(conversionTime);
                                #if COMPARE_TEMP == 1
                                  send(msgTemp.setSensor(i).set(temperature,1));
                              wait(3000);
                              if (message.type==V_STATUS) {
                                // Change relay state
                                // Store state in eeprom
                              @Tim76 you forgot to present the relays.... :sweat:
                                Tim76T
                                Tim76T
                                Tim76
                                @gohan no I didn't...
                                     present(i, S_TEMP);
                                • Tim76T Tim76
                                       present(i, S_TEMP);
                                  Tim76T
                                  Tim76T
                                  Tim76
                                  @gohan seems like it's early for both of us.....;-)
                                    you only have present(i, S_TEMP) but you also need to add present(sensor, S_BINARY) in the relay section otherwise you will not present any relay at all.
                                      Tim76T
                                      Tim76T
                                      Tim76
                                      @gohan 😳😳😳 seems like it's only early for one of us...... I,ll change it later today.....
                                        Tim76T
                                        Tim76T
                                        Tim76
                                        @gohan so I fixed that....... and now I get this in Domoticz....
                                        0 Unknown! #1. V_TEMP (20.7) true 2017-05-10 11:44:39
                                        1 S_LIGHT/S_BINARY #1. V_TEMP (20.7) true 2017-05-10 11:44:43
                                        2 S_LIGHT/S_BINARY #1. V_TEMP (20.9) true 2017-05-10 11:44:04
                                        3 S_LIGHT/S_BINARY true 2017-05-10 11:34:13
                                        4 S_LIGHT/S_BINARY true 2017-05-10 11:34:14
                                        5 S_LIGHT/S_BINARY true 2017-05-10 11:34:15
                                        6 S_LIGHT/S_BINARY true 2017-05-10 11:34:15
                                        7 S_LIGHT/S_BINARY true 2017-05-10 11:34:16
                                        8 S_LIGHT/S_BINARY true 2017-05-10 11:34:17
                                        9 S_LIGHT/S_BINARY true 2017-05-10 11:34:17
                                        10 S_LIGHT/S_BINARY true 2017-05-10 11:34:18
                                        11 S_LIGHT/S_BINARY true 2017-05-10 11:34:18
                                        12 S_LIGHT/S_BINARY true 2017-05-10 11:34:19
                                        13 S_LIGHT/S_BINARY true 2017-05-10 11:34:19
                                        14 S_LIGHT/S_BINARY true 2017-05-10 11:34:20
                                        15 S_LIGHT/S_BINARY true 2017-05-10 11:34:20
                                        16 S_LIGHT/S_BINARY true 2017-05-10 11:34:21
                                        17 S_TEMP true 2017-05-10 11:34:12
                                        18 S_TEMP true 2017-05-10 11:34:12
                                        255 S_ARDUINO_NODE 2.1.1 false 2017-05-10 11:34:12
                                        so it seems I do get temp Id's from 17 to 32, but the values stay in 0,1,2 where the relays 1 and 2 don't work.....
                                          wrote on last edited by gohan
                                          #31
                                          There must be a bug in the relay section, I can't check it today, I'm out all day.
                                          Try to add some debug serial print to see what values are being exchanged
