  3. Combining relay and temperature sketch
76 Posts 9 Posters 24.1k Views 12 Watching
    maybe you have something wrong in presentation. Pls post your code. How come you need this many sensors?
    Tim76T
    Tim76T
    Tim76
    @gohan thx for your fast reply...
    I wasn't anywhere near my laptop, so I couldn't post the code.
    the reason for that many sensors is:
    pretty big greenhouse with a few aquaponics and hydroponics systems.
    for instance, I have 4 vertical towers from wich I want to monitor the water temp and the temp inside the pvs towers.
    that alone are allready 2 temp sensors and a relay for the pump.....
    Tim76T 1 Reply Last reply
    • Tim76T Tim76
      Tim76T
      Tim76T
      Tim76
      wrote on last edited by Tim76
      hereby the code that doesn't seem to work...
      #define MY_RF24_CE_PIN 49
      #define MY_RF24_CS_PIN 53
      #define MY_NODE_ID 5
      #include <OneWire.h>
      int numSensors=0;
      bool receivedConfig = false;
      bool metric = true;
      MyMessage msg(0,V_TEMP);
      #define RELAY_1  30  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      #define NUMBER_OF_RELAYS 16 // Total number of attached relays
      void before()
        sensors.begin();
          pinMode(pin, OUTPUT);
        for (int i=17; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
           present(i, S_TEMP);
          present(sensor, S_BINARY);
        sleep(conversionTime);
          #if COMPARE_TEMP == 1
        if (message.type==V_STATUS) {
          // Change relay state
          // Store state in eeprom
         sleep(SLEEP_TIME);
        I think there is an error in the presentation function: you need to close the first for cycle before the second one, otherwise it will present 2 relays for every Dallas sensor.
          Tim76T
          Tim76T
          Tim76
          @gohan again, thx for your fast reply,
          How could I miss that...😳😳 lol...
          I'll try it later today....
          Thx upfront!
          Timu
            When doing copy/paste of code it can happen to anyone :)
              Tim76T
              Tim76T
              Tim76
              @gohan apparently..... 😂😂😉
                Mad6969
                I'm trying to do the same thing but with just one relay and a DHT22. So I combined the "air humidity sensor" sketch and the "relay with button" one.
                Each sketch works fine, but when I combine them, I get an error form the DHT
                "Failed reading humidity from DHT
                Failed reading temperature from DHT!"
                But sometimes, I get the temp/hum in the serial monitor. I first thought that I misswired something, but it work perfectly with the other sketch.
                So.. I (obviously) missed something in the program and I can't see what (probably something stupid, I'm new to arduino and mysensors.)
                Here's my code (basicly a copy/paste of the two sketches). Any advice?
                * Version 1.0: Henrik EKblad
                * sensor using a DHT11/DHT-22.
                // Enable debug prints
                //#define MY_RS485
                //Relay sketch
                #define DHT_DATA_PIN 8
                #define SENSOR_TEMP_OFFSET 0
                static const uint64_t UPDATE_INTERVAL = 60000;
                #define CHILD_ID_HUM 2
                #define CHILD_ID_TEMP 3
                float lastTemp;
                float lastHum;
                uint8_t nNoUpdatesTemp;
                uint8_t nNoUpdatesHum;
                bool metric = true;
                DHT dht;
                //Relay Sketch
                #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                #define BUTTON_PIN  5  // Arduino Digital I/O pin number for button
                #define RELAY_ON 1
                #define RELAY_OFF 0
                Bounce debouncer = Bounce();
                int oldValue=0;
                bool state;
                sendSketchInfo("Test403", "1.1");
                present(CHILD_ID_HUM, S_HUM);
                present(CHILD_ID, S_LIGHT);
                // Setup the button
                 pinMode(BUTTON_PIN,INPUT);
                 // Activate internal pull-up
                 debouncer.attach(BUTTON_PIN);
                 debouncer.interval(5);
                 pinMode(RELAY_PIN, OUTPUT);
                 state = loadState(CHILD_ID);
                dht.readSensor(true);
                if (isnan(temperature)) {
                  lastTemp = temperature;
                  if (!metric) {
                  // Reset no updates counter
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                  Serial.print("T: ");
                  nNoUpdatesTemp++;
                if (isnan(humidity)) {
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                  Serial.print("H: ");
                  Serial.println(humidity);
                  nNoUpdatesHum++;
                //Relay voidloop
                debouncer.update();
                // Get the update value
                int value = debouncer.read();
                if (value != oldValue && value==0) {
                    send(msg.set(state?false:true), true); // Send new state and request ack back
                oldValue = value;
                if (message.isAck()) {
                   state = message.getBool();
                   saveState(CHILD_ID, state);
                  try to put a wait(500) at end of loop function, or even wait(1000)
                  Tim76T M 2 Replies Last reply
                    Tim76T
                    Tim76T
                    Tim76
                      Mad6969
                      @gohan said in Combining relay and temperature sketch:
                      wait(1000)
                      Oh.. like I said : something stupid..
                      Thanks a lot. :-)
                      I also had "#define MY_NODE_ID 7", because I couldn't see the relay on my Vera.
                        DHT sensor doesn't like to work very quickly, it needs some resting time between measurements :D
                          Tim76T
                          Tim76T
                          Tim76
                          @gohan modfied my code..... still the same.... I get 16 children (relays) and no temp...... I have 4 ds18b20's connected.....
                          And I get the error switch command on the relays....😑😑
                          gohanG 1 Reply Last reply
                            Mad6969
                            Ok, now I have another problem.
                            When I build the relay/dht node, I first made the thing work with the relay with button actuator sketch alone (the DHT was plugged, but it was an additional feature I wanted to add).
                            Now, it seems that my power source doesn't have enough power to make the relay to close. The led on my relay board blinks when the relay is on and off, but nothing.
                            That's weird.. I'll try running the relay sketch alone, just to see.
                            • Tim76T Tim76
                              @Tim76 ok, let's go back to the beginning. Try with one sensors only, if everything works then add one relay, then add the second and keep adding the sensors until you see something wrong. You need to go step by step, otherwise with all that stuff you have it will be impossible to debug.
                              Tim76T 2 Replies Last reply
                                Tim76T
                                Tim76T
                                Tim76
                                @gohan ok
                                  Tim76T
                                  Tim76T
                                  Tim76
                                  @gohan both sketches work perfectly stand alone.... but I think the problem lies within the assingment of the child id's...
                                  James Bruce talks about this "bug" in his video on how to combine sketches.....
                                  They relay sketch assigns from 1 to 16
                                  And the temp sketch assigns from 0 to 15
                                  So they both try to use the same id's for their children when you try to combine them....
                                  I need a way to get around that and have relays on 1-16 and temp on 17 to 32......
                                  Or there might just be the same "bug" in the temperature sketch.....😬😬 wich might mean that they can't be combined for now......😒😒
                                    if use something like this in presentation?
                                    for (int i=1; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
                                         present(i+3, S_TEMP);
                                    you get the idea, just shift the child id of the dallas sensors and leave the first 4-5 IDs for relays
                                      Tim76T
                                      Tim76T
                                      Tim76
                                      @gohan aha! Will be trying that later tonight..... I'll keep you posted! 😊 Thx man!
                                        Tim76T
                                        Tim76T
                                        Tim76
                                        @gohan soooooo...... I tried this:
                                             present(i+16, S_TEMP);
                                        now I get the temp sensors with child id's 1 to 16 and no relays at all
                                          I probably used wrong sintax
