  2. Announcements
  • Richard van der PlasR
    excellent, will the cpu utilisation be much higher that with a usb connected gw ?
      No, it uses very few cpu
      • manulM
        manulM
        manul
        @Richard van der Plas: I strongly recommend to use MQTT instead of Ethernet gateway, as it is a standard way for 2 processes to communicate, and platform-agnostic.
        HASS comes with an embed MQTT broker taht works out of the box.
        Plus:
        • you can easily mock either your sensors network or your controller
        • it does support secure communication
        • you can add other clients to observe the event, e.g. to log what is coming from/what is sent to the gateway
          I suggested ethernet because it's easier to setup and configure, mqtt is the next step.
          • P
            P
            pettib
            Hi
            I also have problem to get the NRF24L01+ chip to work with the RPi3.
            I find that the masterbranch don't recognize the board as RPi3 and sets SoC and Type as unknown.
            But if i take development branch it´s detecting RPi3 and seems to work correct.
            This is result from development Branch configure:
            [OK] SPI driver detected:BCM.
            [OK] Finished.
            This is result from Master Branch configure:
            [OK] Finished.
            This is the result from cat /proc/cpuinfo:
            Hardware : BCM2835
            Revision : a02082
            //Peter
              That's odd, I have the 2.1.1 compiled on mine rpi 3
                marceloaqno
                Code Contributor
                wrote on last edited by marceloaqno
                #456
                @pettib @gohan There have been some changes in /proc/cpuinfo in newer versions of kernels which leads to a wrong detection.
                The problem was fix in #827 and will be available in the master branch in the next mysensor release.
                  I'm using dietpi and I compiled it like 2 weeks ago..
                  • Richard van der PlasR Richard van der Plas
                    How will this work with HASS running on the same pi ?
                    Fat FlyF
                    Fat FlyF
                    Fat Fly
                    @Richard-van-der-Plas what is this: HASS ?
                      Ok, i am standig on a crossroad it seems, i have to build a new gateway but i am also interested in the MQTT option, this is between mysensors & HomeASSistant i presume? i have some ESP's lying around unused, but i have 0 knowledge of mqtt (i dont think my hass has it running by default)
                        Just go with ethernet first that is easier, get used to it then take your time to learn MQTT. Of course MQTT is more advanced has authentication and encryption but it adds complexity to initial setup.
                          Damn, just connected as in manual, but gives an error : mysgw: !TSM:INIT:TSP FAIL
                          Double checked the GPIO pins (except 15 cannot find that one) but seems ok
                            NM, used GPIO numbers instead of Pin numbers RTFM :)
                              A Former User
                              wrote on last edited by [[global:former-user]]
                              #463
                              I always have a mysgw: accept: Bad file descriptor error when I launch a new ./bin/mysgw -d Exact problem is the following:
                              mysgw: bind: Address already in use
                              mysgw: Failed to bind!
                              And I always need to kill the process first. Is this normal ? (I'm in LAN GW)
                                If you already installed mysgw as service to start at boot, it is normal that you can not run another process in debug mode and it conflicts
                                  A Former User
                                  @gohan said in 💬 Building a Raspberry Pi Gateway:
                                  Oh, Ok. Thanks.
                                  Another thing is that when i close PuTTY, the gateway doesn't retrieve anymore the data...
                                    You need to install it as service so it always runs in background
                                      A Former User
                                      Is it this process :
                                      1421 ?        Rs    40:25 /usr/local/bin/mysgw
                                      Seems it runs for 40 minutes, but no the gateway sees no data...
                                        what gateway did you compile? What option in ./configure did you use?
                                          A Former User
                                          #469
                                          First of all : thanks for helping !
                                          I compiled an Ethernet gateway
                                          The options are the following:
                                          ./configure --my-gateway=ethernet --my-port=5003 --my-rf24-irq-pin=15 --my-transport=nrf24
                                          The only way I make the GW working is through the debug mode (by switching off the service process)
