  3. RF433 NODE, help with code
4 Posts 2 Posters 2.0k Views 1 Watching
  • C
    C
    craktor
    wrote on last edited by craktor
    I have been tampering and testing MySensors for a while but never taken myself the time to do something serious with it.
    My first serious node is a 433mhz transmitter to control Nexa outlets and dimmers.
    The node is housed in a case from a riddex pest repellent (not working ;) and the hardware is soldered to sundbergs84's nice Easy PCB.
    I am using Domoticz as controller on a Rpi.
    Pictures of casing
    Pictures of PCB, RF433 transmitter and HLK power module with fuses.
    I didn't have any pictures at the final assembly but that can be arranged if someone is interested.
    Enough rubbish and on to the code :smile:
    This code is working both for switching and dimming the "Self learning" Nexa outlets/dimmers.
    But I have a few things that bother me:
    1st Send_status is not working properly is it configured the right way? "int CHILD=switch_no;" doesn't seem to do what it should.
    2nd If i reset the node i want it to request the state from the controller (Domotizc) and set the outlets accordingly, it seems to work sometimes, but not properly for all ten switches shown in domotizc.
    3rd The code is quite crude, i believe i have over complicated it "just to make it work".
    It would be nice i someone could help tidy it up. :blush:
    Over to you geniouses :smile:
    Best Regards //Viktor //Craktor
       REVISION HISTORY
       Version 1.0 - May 01, 2017 - Viktor Lundström (craktor@gmail.com)
       DESCRIPTION
       This sketch provides a Node to control NEXA outlets.
    #define MY_NODE_ID 9 // Set NODE_ID to something unique in your sensor network (1-254)
    #include <NexaTransmitter.h>
    #define NUMBER_OF_SWITCHES 10  //Register switches as child devices (MAX99 Nexa/remote??, havent tried.)
    NexaTransmitter remote(8, 5519105); // Create the nexa remote on PIN 8 with REMOTE_ID 5519105
    //DIMMER VARIABLES
    #define SN "RF433_170501_1"
    #define SV "1.0"
    int CHILD;
    long set_dim;
    int datavalue;
    int dimvalue;
    int switch_no;
    int set_value;
    MyMessage dimmerMsg(CHILD+switch_no, V_PERCENTAGE);
    MyMessage lightMsg(CHILD+switch_no, V_STATUS);
      Serial.println("Setup initiated");
      // remote.setSwitch(true,1,15); //TEST RF TRANSMITTER (ON DEVICE 1 DIMLEVEL 15)
      wait(500);
      // remote.setSwitch(false,1); //TEST RF TRANSMITTER (OFF DEVICE 1)
      //LOOP REQUEST
      for (int CHILD = 0; CHILD < NUMBER_OF_SWITCHES; CHILD++)
    #ifdef MY_DEBUG
        Serial.print("REQUEST CHILD STATUS NO:");
        Serial.println(CHILD + 1);
        request( CHILD + 1, V_DIMMER );
        wait(300);
        request( CHILD + 1, V_STATUS );
    #ifdef MY_DEBUG
        Serial.print("END REQUEST NO:");
      Serial.println ("Register Switches");
      // LOOP Register sensors to gw (they will be created as child devices)
        Serial.print("PRESENT CHILD NO:");
        present(CHILD + 1, S_DIMMER);
        wait(250);
    #ifdef MY_DEBUG
      Serial.println("loop present Switches");
        Serial.print("LightMsg: ");
        MyMessage lightMsg(CHILD + 1, V_STATUS);
        Serial.print("DimmerMsg: ");
        MyMessage dimmerMsg(CHILD + 1, V_PERCENTAGE);
        wait(100);
        send(dimmerMsg.set(0));
        wait(100);
        send(lightMsg.set(0));
      sendSketchInfo(SN, SV); // Send the sketch version information to the gateway and Controller
    void loop() {}
    void transmitt (bool set_value, int switch_no)
      Serial.println( "transmitt" );
      Serial.print( "Set Value:" );
      Serial.println (set_value);
      Serial.print( "Switch Number:" );
      Serial.println (switch_no);
      remote.setSwitch(set_value, switch_no);
      sendstatus(set_value, switch_no, set_dim);
    void transmittdim (bool set_value, int switch_no, int set_dim)
      Serial.println( "transmittdim" );
      Serial.print( "Set  dim value:" );
      Serial.println (set_dim);
      remote.setSwitch(set_value, switch_no, set_dim);
      wait(50);
    void sendstatus(int set_value, int switch_no, int set_dim)
      #ifdef MY_DEBUG
      Serial.println( "Send status" );
      Serial.print( "Set Dim:" );
      send(lightMsg.set(set_value));
      wait(100);
      send(dimmerMsg.set(set_dim));
      wait(100);
    #ifdef MY_DEBUG
      Serial.print("Message sensor:");
      Serial.print("Message data:");
      Serial.println(message.data);
      Serial.print("Message type:");
      Serial.println(message.type);
      int switch_no =  message.sensor;      //vilken switch
      int dimvalue =  atoi(message.data ); // 0 =off, 1=ON, dim level =0-100
      int datavalue =  atoi(message.data ); // 0 =off, 1=ON, dim level=0-100
      Serial.print( "Data value?:" );
      Serial.println( datavalue );
      if (datavalue >= 3) {
        datavalue = 3;
        Serial.print( "New data value:" );
      //message.type // 2 vid ON/OFF, 3 vid DIM  (ANVÄND VID DIMMER)
      if (message.type == V_PERCENTAGE) {
        switch (datavalue) {
          case 0 :
            set_value = 0;
            dimvalue = 0;
            Serial.println( "V_STATUS_CASE0" );
            transmitt (set_value, switch_no);
          case 1 :
            set_value = 1;
            dimvalue = 100;
            Serial.println( "V_STATUS_CASE1" );
          case 3 :
            set_value = 1;
            set_dim = map(message.getInt(), 0, 100, 2, 15); // map dimmer values to Switch states 0..9  and wrap
    #ifdef MY_DEBUG
            Serial.println( "V_PERCENTAGE" );
            Serial.print( "Mapped value:" );
            transmittdim (set_value, switch_no, set_dim);
      else if (message.type == V_STATUS) {
          case 0 :
            set_value = 0;
            dimvalue = 0;
          case 1  :
            set_value = 1;
            dimvalue = 100;
    • C craktor
      Pictures of casing
         REVISION HISTORY
         DESCRIPTION
      //DIMMER VARIABLES
      #define SV "1.0"
      int CHILD;
      long set_dim;
      int datavalue;
      int dimvalue;
      int switch_no;
      int set_value;
        wait(500);
        //LOOP REQUEST
      #ifdef MY_DEBUG
          wait(300);
      #ifdef MY_DEBUG
          wait(250);
      #ifdef MY_DEBUG
          wait(100);
          wait(100);
      void loop() {}
        wait(50);
        #ifdef MY_DEBUG
        wait(100);
        wait(100);
      #ifdef MY_DEBUG
          datavalue = 3;
            case 0 :
              set_value = 0;
              dimvalue = 0;
            case 1 :
              set_value = 1;
              dimvalue = 100;
            case 3 :
              set_value = 1;
      #ifdef MY_DEBUG
            case 0 :
              set_value = 0;
              dimvalue = 0;
            case 1  :
              set_value = 1;
              dimvalue = 100;
      sundberg84S
      sundberg84S
      @craktor - Nice node.
      In most code I have seen the last status is stored in the eeprom. What do you think about that?
      Also, you have linked to the new EasyPCB (with RFM69 transiever). This PCB will be just right for you if you are using 433mhz but the one in the picture is https://www.openhardware.io/view/4 :+1:
      Never mind! Great work!
      C 1 Reply Last reply
      • sundberg84S sundberg84
        C
        C
        craktor
        @sundberg84
        Thanks for the reply. I have edited the link to the correct PCB. :+1:
        Storing the switch states in EEPROM could be an option, but i always want it to request the state from domoticz on startup.
        Thats the reason why ihavent tried to use EEPROM.
        I am concerned that it might set the switches in the wrong state after powerfailure/reboot if the light timers/states in domoticz have changed during downtime.
        • C craktor
          @sundberg84
          sundberg84S
          sundberg84S
          @craktor - after a power failuer you can request it by using v_var1 i think
          Check the pulse power meter example on how to :)
