  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 466.6k Views 30 Watching
  • AnticimexA Anticimex
    @alexsh1 is that all? It looks like it has not reached the signing setup part yet. Is node and gw alive or are one of them hanging?
    alexsh1A
    alexsh1A
    alexsh1
    @Anticimex Yes, I am afraid. The GW is showing
    "0;255;3;0;9;Message is not signed, but it should have been!
    0;255;3;0;9;!TSF:MSG:SIGN VERIFY FAIL"
    Yes, both node and GW are fine, but messages are not reaching the GW as signing is required.
    AnticimexA 1 Reply Last reply
    • alexsh1A alexsh1
      AnticimexA
      AnticimexA
      Anticimex
      @alexsh1 at startup of the node, it sends its signing preferences to the GW (assuming you have selected a signing backend, atsha204a or soft signing). The GW will then reply with its own preference to inform the node that it should sign messages. If the GW said that it rejects messages because they are unsigned, it suggests that the GW require signatures from that node, but the node does not realize that it needs to sign them. So either the node is not properly configured to sign messages or there have been a radio issue preventing message exchange during startup.
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        #359
        @Anticimex After forcing all nodes to sign with #define MY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL
        got this:
        0 MCO:BGN:INIT NODE,CP=RNNNAA-,VER=2.1.1
        4 TSM:INIT
        4 TSF:WUR:MS=0
        12 TSM:INIT:TSP OK
        14 TSM:INIT:STATID=6
        16 TSF:SID:OK,ID=6
        18 TSM:FPAR
        18 Will not sign message for destination 255 as it does not require it
        61 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        1044 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        1050 TSF:MSG:FPAR OK,ID=0,D=1
        2070 TSM:FPAR:OK
        2070 TSM:ID
        2072 TSM:ID:OK
        2074 TSM:UPL
        2076 Skipping security for command 3 type 24
        2082 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2103 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2109 TSF:MSG:PONG RECV,HP=1
        2113 TSM:UPL:OK
        2115 TSM:READY:ID=6,PAR=0,DIS=1
        2117 Skipping security for command 3 type 15
        2123 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2131 Waiting for GW to send signing preferences...
        2164 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
        2170 Mark node 0 as one that require signed messages
        2177 Mark node 0 as one that do not require whitelisting
        2183 Skipping security for command 3 type 16
        2189 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
        2197 Nonce requested from 0. Waiting...
        2201 Message to send could not be signed!
        2205 !TSF:MSG:SIGN FAIL
        2207 Skipping security for command 3 type 16
        2213 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=1,st=OK:
        2222 Nonce requested from 0. Waiting...
        2226 Message to send could not be signed!
        2230 !TSF:MSG:SIGN FAIL
        2232 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:A03E832C91BD0CC2C02E2A16D834F9CA91816D234ABB1188A2
        2244 Nonce received from 0.
        2246 Proceeding with signing...
        Message to process: 06000E2306FF00
        Current nonce: A03E832C91BD0CC2C02E2A16D834F9CA91816D234ABB1188A2AAAAAAAAAAAAAA
        HMAC: AF54D68677672C45B3E1329A9A1B4E7517D0A0FF340569C633D5DC52207F8DDA
        Signature in message: 0154D68677672C45B3E1329A9A1B4E7517D0A0FF340569C6
        2371 Message signed
        2379 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:C1FACC7B2E3B538E31853CB92C73A87E3240FBC2253CE63A9E
        2392 Nonce received from 0.
        2394 Proceeding with signing...
        Current nonce: C1FACC7B2E3B538E31853CB92C73A87E3240FBC2253CE63A9EAAAAAAAAAAAAAA
        HMAC: 9EE43EA4A510354CB2D3A0AB2C0D13D106CD9B666103E7B7115B73B646DB20DD
        Signature in message: 01E43EA4A510354CB2D3A0AB2C0D13D106CD9B666103E7B7
        2519 Message signed
        4233 Skipping security for command 3 type 16
        4239 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=OK:
        4247 Nonce requested from 0. Waiting...
        4280 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:25E2116C25EBB38BB5F87AFFC892073803D818F07FB1E36738
        4292 Nonce received from 0.
        4294 Proceeding with signing...
        4298 Failed to sign message!
        4300 Message to send could not be signed!
        4304 !TSF:MSG:SIGN FAIL
        4306 Skipping security for command 3 type 16
        4315 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=1,st=OK:
        4321 Nonce requested from 0. Waiting...
        4354 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:6FE06CCBD9098A24D65907C9C7CF62062DA365227E5A836108
        4366 Nonce received from 0.
        4368 Proceeding with signing...
        Message to process: 06001E030CFF312E31
        Current nonce: 6FE06CCBD9098A24D65907C9C7CF62062DA365227E5A836108AAAAAAAAAAAAAA
        HMAC: 564EF68106E0B7333A233F7C396BEDBE537F9AF012C78856F3BD37753B9F096E
        Signature in message: 014EF68106E0B7333A233F7C396BEDBE537F9AF012C7
        4491 Message signed
        4499 Message to send has been signed
        4505 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.1
        4513 Skipping security for command 3 type 16
        4519 TSF:MSG:SEND,6-6-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        4528 Nonce requested from 0. Waiting...
        4651 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:67AD75E666FB63B0A606CCA15003152448DE5D66C1EA34E541
        4663 Nonce received from 0.
        4665 Proceeding with signing...
        Message to process: 060006000800
        Current nonce: 67AD75E666FB63B0A606CCA15003152448DE5D66C1EA34E541AAAAAAAAAAAAAA
        HMAC: 4901D9D648B90185224D2256EADC4C607543E698EC2252B7E88BAD91696824CB
        Signature in message: 0101D9D648B90185224D2256EADC4C607543E698EC2252B7E8
        4790 Message signed
        4798 Message to send has been signed
        4804 TSF:MSG:SEND,6-6-0-0,s=0,c=0,t=8,pt=0,l=0,sg=1,ft=0,st=OK:
        4812 Skipping security for command 3 type 16
        4818 TSF:MSG:SEND,6-6-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        4827 Nonce requested from 0. Waiting...
        4950 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:44DC6983F5E93696CEFD0B73423B33946AE1BC3DC40F562012
        4962 Nonce received from 0.
        4964 Proceeding with signing...
        Message to process: 060006000601
        Current nonce: 44DC6983F5E93696CEFD0B73423B33946AE1BC3DC40F562012AAAAAAAAAAAAAA
        HMAC: 4D37001CE6A4C2E5C7C5B8995C871DA6386E9C7ADD90D3AF36D83C98C1E98166
        Signature in message: 0137001CE6A4C2E5C7C5B8995C871DA6386E9C7ADD90D3AF36
        5091 Message signed
        5099 Message to send has been signed
        5105 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=6,pt=0,l=0,sg=1,ft=0,st=OK:
        5113 Skipping security for command 3 type 16
        5122 TSF:MSG:SEND,6-6-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        5128 Nonce requested from 0. Waiting...
        5253 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:B6C405695A2B551DE4C1AFC02125F42528209A3DF9013820E2
        5263 Nonce received from 0.
        5267 Proceeding with signing...
        Message to process: 060006000702
        Current nonce: B6C405695A2B551DE4C1AFC02125F42528209A3DF9013820E2AAAAAAAAAAAAAA
        HMAC: B767B39D7B5F78422608CCF763DA7C94B333DA95C07087D896DFB36CACF0CE77
        Signature in message: 0167B39D7B5F78422608CCF763DA7C94B333DA95C07087D896
        5392 Message signed
        5398 Message to send has been signed
        5404 TSF:MSG:SEND,6-6-0-0,s=2,c=0,t=7,pt=0,l=0,sg=1,ft=0,st=OK:
        5412 Skipping security for command 3 type 16
        5421 TSF:MSG:SEND,6-6-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        5427 Nonce requested from 0. Waiting...
        5554 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:9A92C415D6BE672E588BE107BE88637D9D3551A029796C12EF
        5566 Nonce received from 0.
        5568 Proceeding with signing...
        Message to process: 060006000D03
        Current nonce: 9A92C415D6BE672E588BE107BE88637D9D3551A029796C12EFAAAAAAAAAAAAAA
        HMAC: B75B0F0C356378B1EEC25726EE552581F98B1957ADE9A82EF48408FD528927E6
        Signature in message: 015B0F0C356378B1EEC25726EE552581F98B1957ADE9A82EF4
        5693 Message signed
        5699 Message to send has been signed
        5707 TSF:MSG:SEND,6-6-0-0,s=3,c=0,t=13,pt=0,l=0,sg=1,ft=0,st=OK:
        5713 MCO:REG:REQ
        5715 Skipping security for command 3 type 26
        5724 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
        5830 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        5836 MCO:PIM:NODE REG=1
        5838 MCO:BGN:STP
        BME280 Pressure Sensor1.1isMetric: 1
        6160 Skipping security for command 3 type 16
        6168 TSF:MSG:SEND,6-6-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        6174 Nonce requested from 0. Waiting...
        6207 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:F7F1A5F6C487947D093E7676AA05AF1BE65AFE31B4223034C2
        6219 Nonce received from 0.
        6221 Proceeding with signing...
        Message to process: 06002EE12603EE7C4F4002
        Current nonce: F7F1A5F6C487947D093E7676AA05AF1BE65AFE31B4223034C2AAAAAAAAAAAAAA
        HMAC: DF2217C08446766ECC9CD41D4C9643B546CC921AEAA9E1971DF314F965D2D0FE
        Signature in message: 012217C08446766ECC9CD41D4C9643B546CC921A
        6346 Message signed
        6354 Message to send has been signed
        6361 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=38,pt=7,l=5,sg=1,ft=0,st=OK:3.24
        6369 Skipping security for command 3 type 16
        6377 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        6383 Nonce requested from 0. Waiting...
        6508 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:027634E4197B49C4FDB8059CB6D34AA6D81EB340D934252BBF
        6518 Nonce received from 0.
        6522 Proceeding with signing...
        Message to process: 06000E2300FF67
        Current nonce: 027634E4197B49C4FDB8059CB6D34AA6D81EB340D934252BBFAAAAAAAAAAAAAA
        HMAC: 572A1585F50CE39199035088548A9877A08B8B3FA8404FA31B8B55B5190320C1
        Signature in message: 012A1585F50CE39199035088548A9877A08B8B3FA8404FA3
        6645 Message signed
        6651 Message to send has been signed
        6660 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=1,ft=0,st=OK:103
        6666 MCO:BGN:INIT OK,TSP=1
        Temperature = 24.90 *C
        Humidity = 48.62 %
        Pressure = 994.33 hPa
        Forecast = unknown
        6678 Skipping security for command 3 type 16
        6688 TSF:MSG:SEND,6-6-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        6696 Nonce requested from 0. Waiting...
        6805 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:988D1BCE8B949E24FA8D7FE18200429C16B01AF0B927CE0709
        6815 Nonce received from 0.
        6819 Proceeding with signing...
        Message to process: 06002EE1149307E4071493
        Current nonce: 988D1BCE8B949E24FA8D7FE18200429C16B01AF0B927CE0709AAAAAAAAAAAAAA
        HMAC: EAB0E2B8ECF6B95E6D07BE2651BECF977C53DDB8516DD847CFE6688DD61140ED
        Signature in message: 01B0E2B8ECF6B95E6D07BE2651BECF977C53DDB8
        6944 Message signed
        6952 Message to send has been signed
        6959 TSF:MSG:SEND,6-6-0-0,s=147,c=1,t=20,pt=7,l=5,sg=1,ft=0,st=OK:0.00000000
        6967 Skipping security for command 3 type 16
        6975 TSF:MSG:SEND,6-6-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        6981 Nonce requested from 0. Waiting...
        6985 Message to send could not be signed!
        6989 !TSF:MSG:SIGN FAIL
        6993 Skipping security for command 3 type 16
        7000 TSF:MSG:SEND,6-6-0-0,s=0,c=3,t=16,pt=0,l=0,sg=0,ft=1,st=OK:
        7006 Nonce requested from 0. Waiting...
        7010 Message to send could not be signed!
        7014 !TSF:MSG:SIGN FAIL
        7018 Skipping security for command 3 type 16
        7024 TSF:MSG:SEND,6-6-0-0,s=0,c=3,t=16,pt=0,l=0,sg=0,ft=1,st=OK:
        7030 Nonce requested from 0. Waiting...
        7034 Message to send could not be signed!
        7038 !TSF:MSG:SIGN FAIL
        7092 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
        7098 MCO:SLP:TPD
        What do you think the problem is?
        Why is it still MSG:SIGN FAIL
        EDIT: this is the GW log:
        0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGAS-,VER=2.1.1
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSF:WUR:MS=0
        0;255;3;0;9;TSM:INIT:TSP OK
        0;255;3;0;9;TSM:INIT:GW MODE
        IP: 10.1.1.120
        0;255;3;0;9;MCO:BGN:STP
        0;255;3;0;9;TSF:MSG:READ,15-15-0,s=1,c=1,t=0,pt=7,l=5,sg=0:27.0
        0;255;3;0;9;TSF:MSG:READ,15-15-0,s=0,c=1,t=4,pt=7,l=5,sg=0:996
        0;255;3;0;9;TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        0;255;3;0;9;TSF:MSG:BC
        0;255;3;0;9;TSF:MSG:FPAR REQ,ID=6
        0;255;3;0;9;TSF:PNG:SEND,TO=0
        0;255;3;0;9;TSF:CKU:OK
        0;255;3;0;9;TSF:MSG:GWL OK
        0;255;3;0;9;Skipping security for command 3 type 8
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        0;255;3;0;9;Skipping security for command 3 type 24
        0;255;3;0;9;TSF:MSG:PINGED,ID=6,HP=1
        0;255;3;0;9;Skipping security for command 3 type 25
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
        0;255;3;0;9;Skipping security for command 3 type 15
        0;255;3;0;9;Mark node 6 as one that require signed messages
        0;255;3;0;9;Mark node 6 as one that do not require whitelisting
        0;255;3;0;9;Informing node 6 that we require signatures
        0;255;3;0;9;Informing node 6 that we do not require whitelisting
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
        0;255;3;0;9;Skipping security for command 3 type 16
        0;255;3;0;9;SHA256: BB0EE26FC4C35E155CA36591DFC8DF866D188923ADCCA99ED700000000000000
        0;255;3;0;9;Skipping security for command 3 type 17
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:BB0EE26FC4C35E155CA36591DFC8DF866D188923ADCCA99ED7
        0;255;3;0;9;Transmitted nonce
        0;255;3;0;9;SHA256: C62553080FACCBBA84B0BE05AEA1871324370BD8BBF431D38CAAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:C62553080FACCBBA84B0BE05AEA1871324370BD8BBF431D38C
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
        0;255;3;0;9;SHA256: AA4BF678F8D0BE6885E67795A8D6E001CF8E0AFECD0D6146B0AAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:AA4BF678F8D0BE6885E67795A8D6E001CF8E0AFECD0D6146B0
        0;255;3;0;9;SHA256: 6122BFB72296B95B45E44C2B4D43A3CE1C9D1F43F24137149AAAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:6122BFB72296B95B45E44C2B4D43A3CE1C9D1F43F24137149A
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.1
        0;255;3;0;9;Signature in message: 016583B112FED6ED3698EB4A4AE12B319ACC2755CF92
        0;255;3;0;9;Message to process: 06001E030CFF312E31
        0;255;3;0;9;Current nonce: 6122BFB72296B95B45E44C2B4D43A3CE1C9D1F43F24137149AAAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: DD6583B112FED6ED3698EB4A4AE12B319ACC2755CF9239836E845A5B3DD186FF
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
        0;255;3;0;9;SHA256: D3F6004F4966A6D33936AC7EBCEEBF9CE919AD644BFA33289AAAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:D3F6004F4966A6D33936AC7EBCEEBF9CE919AD644BFA33289A
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=0,c=0,t=8,pt=0,l=0,sg=1:
        0;255;3;0;9;Signature in message: 01CF6F511AAA6A0F2750F6437F3DEA644A13335E155EC94488
        0;255;3;0;9;Message to process: 060006000800
        0;255;3;0;9;Current nonce: D3F6004F4966A6D33936AC7EBCEEBF9CE919AD644BFA33289AAAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: D6CF6F511AAA6A0F2750F6437F3DEA644A13335E155EC944884A4A6D7C667140
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
        0;255;3;0;9;SHA256: E310DE1F44902508B12558EB2C3C51066F381572694AD4D7CEAAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:E310DE1F44902508B12558EB2C3C51066F381572694AD4D7CE
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=1,c=0,t=6,pt=0,l=0,sg=1:
        0;255;3;0;9;Signature in message: 012F140689293B434B043699F131C397F629633FD7D9E9D489
        0;255;3;0;9;Message to process: 060006000601
        0;255;3;0;9;Current nonce: E310DE1F44902508B12558EB2C3C51066F381572694AD4D7CEAAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: 942F140689293B434B043699F131C397F629633FD7D9E9D48992B327A0CB9BB8
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
        0;255;3;0;9;SHA256: 0EB8A85D42109C29EBE8E78BF9B8C66092845EB7D92AC1B381AAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:0EB8A85D42109C29EBE8E78BF9B8C66092845EB7D92AC1B381
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=2,c=0,t=7,pt=0,l=0,sg=1:
        0;255;3;0;9;Signature in message: 018D9FBD8E3E4730D1932EE4E4BB998B10B593631551BBB575
        0;255;3;0;9;Message to process: 060006000702
        0;255;3;0;9;Current nonce: 0EB8A85D42109C29EBE8E78BF9B8C66092845EB7D92AC1B381AAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: 798D9FBD8E3E4730D1932EE4E4BB998B10B593631551BBB575BEC03A5C759E36
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=3,t=16,pt=0,l=0,sg=1:
        0;255;3;0;9;SHA256: F8F8706BAAAD66823E6048248088515F8083EB545EBAF8C1DFAAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:F8F8706BAAAD66823E6048248088515F8083EB545EBAF8C1DF
        0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=17,pt=5,l=4,sg=0:332
        0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=24,pt=5,l=4,sg=0:51270118
        0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=18,pt=7,l=5,sg=0:51270.1210
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=0,t=13,pt=0,l=0,sg=1:
        0;255;3;0;9;Signature in message: 0137F7F5A35542631C67BB42381A81FAB165AE75D7B5C7408F
        0;255;3;0;9;Message to process: 060006000D03
        0;255;3;0;9;Current nonce: F8F8706BAAAD66823E6048248088515F8083EB545EBAF8C1DFAAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: 1237F7F5A35542631C67BB42381A81FAB165AE75D7B5C7408F3EE91419294238
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
        0;255;3;0;9;Skipping security for command 3 type 26
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
        0;255;3;0;9;Nonce requested from 6. Waiting...
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=17,pt=6,l=25,sg=0:84A969C4138F0268D8E015A27E2306F288252601FE54AE62A6
        0;255;3;0;9;Nonce received from 6.
        0;255;3;0;9;Proceeding with signing...
        0;255;3;0;9;Message to process: 00060E231BFF01
        0;255;3;0;9;Current nonce: 84A969C4138F0268D8E015A27E2306F288252601FE54AE62A6AAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: DB6CBDAB2875D284BE0CEA1518B86988A8CE3DC36A0B38E4BF1A35C416295EB3
        0;255;3;0;9;Signature in message: 016CBDAB2875D284BE0CEA1518B86988A8CE3DC36A0B38E4
        0;255;3;0;9;Message signed
        0;255;3;0;9;Message to send has been signed
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
        0;255;3;0;9;SHA256: D38475550145574228E4E252AB0608F22CFADB55C307F076C4AAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:D38475550145574228E4E252AB0608F22CFADB55C307F076C4
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=1,t=38,pt=7,l=5,sg=1:3.29
        0;255;3;0;9;Signature in message: 01A48C0E185B8B50EDA96A7C905C0778B16D2C78
        0;255;3;0;9;Message to process: 06002EE126035C8F524002
        0;255;3;0;9;Current nonce: D38475550145574228E4E252AB0608F22CFADB55C307F076C4AAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: 8BA48C0E185B8B50EDA96A7C905C0778B16D2C78707A2959F86F0DBAF3FFE851
        0;255;3;0;9;SHA256: 028248EABB9E64FD89808ED98032CB650D3DCB81525A43BB31AAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:028248EABB9E64FD89808ED98032CB650D3DCB81525A43BB31
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=1:106
        0;255;3;0;9;Signature in message: 01D5CB11EFD24211E2CDCED741211AE9FF3E0AFE0AA9BBEE
        0;255;3;0;9;Message to process: 06000E2300FF6A
        0;255;3;0;9;Current nonce: 028248EABB9E64FD89808ED98032CB650D3DCB81525A43BB31AAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: F5D5CB11EFD24211E2CDCED741211AE9FF3E0AFE0AA9BBEE96970EB2EF247BB5
        0;255;3;0;9;SHA256: 6DE60F283CD99033EEC6DF5DE044BE08F5151149E6DFD04FEAAAAAAAAAAAAAAA
        0;255;3;0;9;!TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=NACK:6DE60F283CD99033EEC6DF5DE044BE08F5151149E6DFD04FEA
        0;255;3;0;9;Failed to transmit nonce!
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=2,c=3,t=16,pt=0,l=0,sg=0:
        0;255;3;0;9;SHA256: 21D7B27EEF84BF6A8ABEA9264986E7637435C28952B4477F7AAAAAAAAAAAAAAA
        0;255;3;0;9;!TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=NACK:21D7B27EEF84BF6A8ABEA9264986E7637435C28952B4477F7A
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=0,c=3,t=16,pt=0,l=0,sg=0:
        0;255;3;0;9;SHA256: 3B83A566EB5C3E32546BE372D5913CB3FA8596A2F61DC57F1FAAAAAAAAAAAAAA
        0;255;3;0;9;!TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=NACK:3B83A566EB5C3E32546BE372D5913CB3FA8596A2F61DC57F1F
        0;255;3;0;9;SHA256: B6A6160EAF37C79EBCAEEE7701A6D798E2244CEB8B067A1FADAAAAAAAAAAAAAA
        0;255;3;0;9;!TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=NACK:B6A6160EAF37C79EBCAEEE7701A6D798E2244CEB8B067A1FAD
        RF issue?
        • alexsh1A alexsh1
          got this:
          4 TSM:INIT
          4 TSF:WUR:MS=0
          12 TSM:INIT:TSP OK
          16 TSF:SID:OK,ID=6
          18 TSM:FPAR
          2070 TSM:FPAR:OK
          2070 TSM:ID
          2072 TSM:ID:OK
          2074 TSM:UPL
          2113 TSM:UPL:OK
          2371 Message signed
          2519 Message signed
          4491 Message signed
          4790 Message signed
          5091 Message signed
          5392 Message signed
          5693 Message signed
          5713 MCO:REG:REQ
          5838 MCO:BGN:STP
          6346 Message signed
          6645 Message signed
          Humidity = 48.62 %
          Forecast = unknown
          6944 Message signed
          7098 MCO:SLP:TPD
          IP: 10.1.1.120
          RF issue?
          AnticimexA
          AnticimexA
          Anticimex
          @alexsh1 I think the problem is that you use the GW you reported was malfunctioning where the self test reported that the atsha204a did not answer as expected. And that you now try to use that device. Since the log said that a message failed to be signed.
            alexsh1A
            alexsh1A
            alexsh1
            @Anticimex No, the GW I am using is Mega 2560 with W5100 not the sensebender GW.
            It has been working for many months after I resolved a power issue. However, signing is a different thing...
            • alexsh1A alexsh1
              got this:
              4 TSM:INIT
              4 TSF:WUR:MS=0
              12 TSM:INIT:TSP OK
              16 TSF:SID:OK,ID=6
              18 TSM:FPAR
              2070 TSM:FPAR:OK
              2070 TSM:ID
              2072 TSM:ID:OK
              2074 TSM:UPL
              2113 TSM:UPL:OK
              2371 Message signed
              2519 Message signed
              4491 Message signed
              4790 Message signed
              5091 Message signed
              5392 Message signed
              5693 Message signed
              5713 MCO:REG:REQ
              5838 MCO:BGN:STP
              6346 Message signed
              6645 Message signed
              Humidity = 48.62 %
              Forecast = unknown
              6944 Message signed
              7098 MCO:SLP:TPD
              IP: 10.1.1.120
              RF issue?
              AnticimexA
              AnticimexA
              Anticimex
              @alexsh1 seeing your latest log it appears you have rf issues. You have NACKs.
              alexsh1A 2 Replies Last reply
                alexsh1A
                alexsh1A
                alexsh1
                @Anticimex It seems that the legacy of nrf24l01+ RF communication is still chasing me ...
                Thank for your help
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @Anticimex I did manage to make it after swapping a radio module:
                  Node log:
                  4 TSM:INIT
                  4 TSF:WUR:MS=0
                  12 TSM:INIT:TSP OK
                  16 TSF:SID:OK,ID=6
                  18 TSM:FPAR
                  245 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  249 Skipping security for command 3 type 8
                  256 TSF:MSG:FPAR OK,ID=0,D=1
                  2070 TSM:FPAR:OK
                  2070 TSM:ID
                  2072 TSM:ID:OK
                  2074 TSM:UPL
                  2101 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  2107 Skipping security for command 3 type 25
                  2111 TSF:MSG:PONG RECV,HP=1
                  2115 TSM:UPL:OK
                  2117 TSM:READY:ID=6,PAR=0,DIS=1
                  2119 Signing required
                  2123 Skipping security for command 3 type 15
                  2129 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                  2138 Waiting for GW to send signing preferences...
                  2166 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                  2172 Skipping security for command 3 type 15
                  2179 Mark node 0 as one that require signed messages
                  2183 Mark node 0 as one that do not require whitelisting
                  2189 Skipping security for command 3 type 16
                  2195 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                  2203 Nonce requested from 0. Waiting...
                  2207 Message to send could not be signed!
                  2211 !TSF:MSG:SIGN FAIL
                  2213 Skipping security for command 3 type 16
                  2222 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=1,st=OK:
                  2228 Nonce requested from 0. Waiting...
                  2232 Message to send could not be signed!
                  2236 !TSF:MSG:SIGN FAIL
                  2240 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:1BE362BF98C9E1F508502D7747DED1F8376FC361937F20CE6A
                  2250 Skipping security for command 3 type 17
                  2256 Nonce received from 0.
                  2258 Proceeding with signing...
                  Current nonce: 1BE362BF98C9E1F508502D7747DED1F8376FC361937F20CE6AAAAAAAAAAAAAAA
                  HMAC: 3B9527A241A1BFB1A02E518D14912973BE3D259FC8A6CAFA402A677AEE279E20
                  Signature in message: 019527A241A1BFB1A02E518D14912973BE3D259FC8A6CAFA
                  2383 Message signed
                  2392 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:44401CD36C03AD558AA6503466C5DA2F01E5704FDB694FEC79
                  2402 Skipping security for command 3 type 17
                  2406 Nonce received from 0.
                  2410 Proceeding with signing...
                  Current nonce: 44401CD36C03AD558AA6503466C5DA2F01E5704FDB694FEC79AAAAAAAAAAAAAA
                  HMAC: D0AE81996EB21C95474594FDB94C39A7632D3742FB4D7C2E75E765037BEE3041
                  Signature in message: 01AE81996EB21C95474594FDB94C39A7632D3742FB4D7C2E
                  2533 Message signed
                  4239 Skipping security for command 3 type 16
                  4245 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=OK:
                  4253 Nonce requested from 0. Waiting...
                  4284 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:E2261FE7028EC3025346CDB70233DAEB1371B5230AAD518FC3
                  4296 Skipping security for command 3 type 17
                  4300 Nonce received from 0.
                  4302 Proceeding with signing...
                  4306 Failed to sign message!
                  4308 Message to send could not be signed!
                  4313 !TSF:MSG:SIGN FAIL
                  4317 Skipping security for command 3 type 16
                  4323 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=1,st=OK:
                  4329 Nonce requested from 0. Waiting...
                  4362 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:A96C3564F5D0DFAF77FB11B256ED369DFBA6241F5089345413
                  4372 Skipping security for command 3 type 17
                  4376 Nonce received from 0.
                  4380 Proceeding with signing...
                  Current nonce: A96C3564F5D0DFAF77FB11B256ED369DFBA6241F5089345413AAAAAAAAAAAAAA
                  HMAC: D39D3672372B7BD037D571D8D35F6F6322A7349F3148B40F286ACFA2805B82A2
                  Signature in message: 019D3672372B7BD037D571D8D35F6F6322A7349F3148
                  4505 Message signed
                  4513 Message to send has been signed
                  4519 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.1
                  4528 Skipping security for command 3 type 16
                  4534 TSF:MSG:SEND,6-6-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  4542 Nonce requested from 0. Waiting...
                  4663 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:F5DCC8A96132142030ACFDE7E7EFC75232D0F27E7CD5845D5D
                  4675 Skipping security for command 3 type 17
                  4679 Nonce received from 0.
                  4681 Proceeding with signing...
                  Current nonce: F5DCC8A96132142030ACFDE7E7EFC75232D0F27E7CD5845D5DAAAAAAAAAAAAAA
                  HMAC: 9EB71F4EB9B6CF53A94E491367F3BD380C87FF26C413CFD4F2798C8F52BD7A3D
                  Signature in message: 01B71F4EB9B6CF53A94E491367F3BD380C87FF26C413CFD4F2
                  4806 Message signed
                  4814 Message to send has been signed
                  4820 TSF:MSG:SEND,6-6-0-0,s=0,c=0,t=8,pt=0,l=0,sg=1,ft=0,st=OK:
                  4829 Skipping security for command 3 type 16
                  4835 TSF:MSG:SEND,6-6-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  4843 Nonce requested from 0. Waiting...
                  4966 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:F310284FED0D6C8F5856B3CAD3460974122858DD71EDEFD8F8
                  4976 Skipping security for command 3 type 17
                  4980 Nonce received from 0.
                  4984 Proceeding with signing...
                  Current nonce: F310284FED0D6C8F5856B3CAD3460974122858DD71EDEFD8F8AAAAAAAAAAAAAA
                  HMAC: 7C53D2D46131415C36657634AF69950186687C143509D199AD8DA3358CB0F636
                  Signature in message: 0153D2D46131415C36657634AF69950186687C143509D199AD
                  5107 Message signed
                  5115 Message to send has been signed
                  5122 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=6,pt=0,l=0,sg=1,ft=0,st=OK:
                  5128 Skipping security for command 3 type 16
                  5136 TSF:MSG:SEND,6-6-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  5144 Nonce requested from 0. Waiting...
                  5265 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:D8B7B2BAC0485BFF1AC6CFB2312B8ABD392E776AE29670ABF1
                  5277 Skipping security for command 3 type 17
                  5281 Nonce received from 0.
                  5283 Proceeding with signing...
                  Current nonce: D8B7B2BAC0485BFF1AC6CFB2312B8ABD392E776AE29670ABF1AAAAAAAAAAAAAA
                  HMAC: FC0F44D95CCF58C065DFD54B4AD7A4222067560BB3957088E7FC1D4AF82E4FF8
                  Signature in message: 010F44D95CCF58C065DFD54B4AD7A4222067560BB3957088E7
                  5408 Message signed
                  5416 Message to send has been signed
                  5427 TSF:MSG:SEND,6-6-0-0,s=2,c=0,t=7,pt=0,l=0,sg=1,ft=0,st=OK:
                  5433 Skipping security for command 3 type 16
                  5441 TSF:MSG:SEND,6-6-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  5447 Nonce requested from 0. Waiting...
                  5568 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:01075582171E1B52EF26C04A9F6CD20BF2A4B690F430131644
                  5578 Skipping security for command 3 type 17
                  5584 Nonce received from 0.
                  5586 Proceeding with signing...
                  Current nonce: 01075582171E1B52EF26C04A9F6CD20BF2A4B690F430131644AAAAAAAAAAAAAA
                  HMAC: 15723FF6A4D539DE67CD75B2D42D7743012DAADD2282DF2C54633BB2A0426467
                  Signature in message: 01723FF6A4D539DE67CD75B2D42D7743012DAADD2282DF2C54
                  5711 Message signed
                  5720 Message to send has been signed
                  5726 TSF:MSG:SEND,6-6-0-0,s=3,c=0,t=13,pt=0,l=0,sg=1,ft=0,st=OK:
                  5732 MCO:REG:REQ
                  5734 Skipping security for command 3 type 26
                  5742 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                  5851 TSF:MSG:READ,0-0-6,s=255,c=3,t=16,pt=0,l=0,sg=1:
                  5857 Skipping security for command 3 type 16
                  SHA256: 28366C70B76446E6C5DC055CC58108A110D2C824AB7F3F1B642845A9C0D087AE
                  5937 Skipping security for command 3 type 17
                  5949 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:28366C70B76446E6C5DC055CC58108A110D2C824AB7F3F1B64
                  5961 Transmitted nonce
                  6078 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=1:1
                  Signature in message: 016CD1F0B409A5501C07F29F8D0CD5C1B7E39D86D679C9BB
                  Current nonce: 28366C70B76446E6C5DC055CC58108A110D2C824AB7F3F1B64AAAAAAAAAAAAAA
                  HMAC: 1F6CD1F0B409A5501C07F29F8D0CD5C1B7E39D86D679C9BB62AA56E3DA35E996
                  6207 MCO:PIM:NODE REG=1
                  6213 MCO:BGN:STP
                  6535 Skipping security for command 3 type 16
                  6543 TSF:MSG:SEND,6-6-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  6549 Nonce requested from 0. Waiting...
                  6580 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:F8B4C6C225F5F91BE58A32A2B45F8ACFA2D9BBC0C56DF1704E
                  6592 Skipping security for command 3 type 17
                  6596 Nonce received from 0.
                  6598 Proceeding with signing...
                  Message to process: 06002EE126033333534002
                  Current nonce: F8B4C6C225F5F91BE58A32A2B45F8ACFA2D9BBC0C56DF1704EAAAAAAAAAAAAAA
                  HMAC: 738C2FFDEAA1208BFA4FAA139FFEB6DD08D9A3DDE5575DC11A40A9CB7A892B49
                  Signature in message: 018C2FFDEAA1208BFA4FAA139FFEB6DD08D9A3DD
                  6721 Message signed
                  6729 Message to send has been signed
                  6735 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=38,pt=7,l=5,sg=1,ft=0,st=OK:3.30
                  6744 Skipping security for command 3 type 16
                  6754 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  6762 Nonce requested from 0. Waiting...
                  6881 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:1EF21E9C248C620832C15B2B31BFA59494E58B0025A12105C7
                  6891 Skipping security for command 3 type 17
                  6897 Nonce received from 0.
                  6899 Proceeding with signing...
                  Message to process: 06000E2300FF6B
                  Current nonce: 1EF21E9C248C620832C15B2B31BFA59494E58B0025A12105C7AAAAAAAAAAAAAA
                  HMAC: 2EA40330191EBC1C034C9B5FE86F15BB200C897E39C01A6A001387F54A7AC87E
                  Signature in message: 01A40330191EBC1C034C9B5FE86F15BB200C897E39C01A6A
                  7026 Message signed
                  7034 Message to send has been signed
                  7041 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=1,ft=0,st=OK:107
                  7049 MCO:BGN:INIT OK,TSP=1
                  Temperature = 25.59 *C
                  Humidity = 47.27 %
                  Pressure = 993.82 hPa
                  Forecast = unknown
                  7061 Skipping security for command 3 type 16
                  7071 TSF:MSG:SEND,6-6-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  7079 Nonce requested from 0. Waiting...
                  7084 Message to send could not be signed!
                  7088 !TSF:MSG:SIGN FAIL
                  7090 Skipping security for command 3 type 16
                  7096 TSF:MSG:SEND,6-6-0-0,s=2,c=3,t=16,pt=0,l=0,sg=0,ft=1,st=OK:
                  7104 Nonce requested from 0. Waiting...
                  7186 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:A534CA40967C4BF2319ECB1E9F78A46DAE29876C512FA43068
                  7196 Skipping security for command 3 type 17
                  7202 Nonce received from 0.
                  7204 Proceeding with signing...
                  Message to process: 0600160407E307FD
                  Current nonce: A534CA40967C4BF2319ECB1E9F78A46DAE29876C512FA43068AAAAAAAAAAAAAA
                  HMAC: DF63A40176DC348626CCF63EF31FDF9B381922BBA1035A00F48475B533B1FFB8
                  Signature in message: 0163A40176DC348626CCF63EF31FDF9B381922BBA1035A
                  7331 Message signed
                  7340 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=0:CDABB60B9D503D264DE301FC0E70DBB3F14A5682D1D519643A
                  7352 Skipping security for command 3 type 17
                  7356 Nonce received from 0.
                  7358 Proceeding with signing...
                  Message to process: 0600160407E30802
                  Current nonce: CDABB60B9D503D264DE301FC0E70DBB3F14A5682D1D519643AAAAAAAAAAAAAAA
                  HMAC: B9D87BB4381C95DE3F87DB59BF7F8A3B78596AB1779ABD8A9D7000539D0FC9B3
                  Signature in message: 01D87BB4381C95DE3F87DB59BF7F8A3B78596AB1779ABD
                  7483 Message signed
                  7491 Message to send has been signed
                  7497 TSF:MSG:SEND,6-6-0-0,s=227,c=4,t=7,pt=0,l=2,sg=1,ft=0,st=OK:
                  7505 Skipping security for command 3 type 16
                  7512 TSF:MSG:SEND,6-6-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  7520 Nonce requested from 0. Waiting...
                  7524 Message to send could not be signed!
                  7528 !TSF:MSG:SIGN FAIL
                  7530 Skipping security for command 3 type 16
                  7536 TSF:MSG:SEND,6-6-0-0,s=0,c=3,t=16,pt=0,l=0,sg=0,ft=1,st=OK:
                  7544 Nonce requested from 0. Waiting...
                  7548 Message to send could not be signed!
                  7553 !TSF:MSG:SIGN FAIL
                  7606 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  7612 MCO:SLP:TPD
                  But it still throws many SIGN FAIL.
                  • alexsh1A alexsh1
                    Node log:
                    4 TSM:INIT
                    4 TSF:WUR:MS=0
                    12 TSM:INIT:TSP OK
                    16 TSF:SID:OK,ID=6
                    18 TSM:FPAR
                    2070 TSM:FPAR:OK
                    2070 TSM:ID
                    2072 TSM:ID:OK
                    2074 TSM:UPL
                    2115 TSM:UPL:OK
                    2383 Message signed
                    2533 Message signed
                    4505 Message signed
                    4806 Message signed
                    5107 Message signed
                    5408 Message signed
                    5711 Message signed
                    5732 MCO:REG:REQ
                    6213 MCO:BGN:STP
                    6721 Message signed
                    7026 Message signed
                    Humidity = 47.27 %
                    Forecast = unknown
                    7331 Message signed
                    7483 Message signed
                    7612 MCO:SLP:TPD
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @alexsh1 the log still looks like you sometimes don't get the nonce you requested so signing times out and fails. I am still quite sure that if you looked in the log on the other side, it would show NACKs on some nonce transmissions. Signing won't work when those fail.
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #366
                      @Anticimex This is what we discussed before, this is not a signing issue. Guess what? I did notice that RF is much better with non-amplified nrf24l01+. Given my experience in the past with nrf24l01+ pa+lna, I have just soldered out and replaced AMS1117-3.3V (Mega 2560 works on 5V so I need a stable 3.3V source, which I cannot take from Mega's 3.3V pin for a hungry nrf24l01+pa+lna) and signing started working!
                      0 MCO:BGN:INIT NODE,CP=RNNNAS-,VER=2.1.1
                      4 TSM:INIT
                      4 TSF:WUR:MS=0
                      12 TSM:INIT:TSP OK
                      14 TSM:INIT:STATID=15
                      16 TSF:SID:OK,ID=15
                      18 TSM:FPAR
                      20 Will not sign message for destination 255 as it does not require it
                      63 TSF:MSG:SEND,15-15-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      1026 TSF:MSG:READ,0-0-15,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      1032 Skipping security for command 3 type 8
                      1038 TSF:MSG:FPAR OK,ID=0,D=1
                      2070 TSM:FPAR:OK
                      2070 TSM:ID
                      2072 TSM:ID:OK
                      2074 TSM:UPL
                      2082 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      2111 TSF:MSG:READ,0-0-15,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      2117 Skipping security for command 3 type 25
                      2121 TSF:MSG:PONG RECV,HP=1
                      2123 TSM:UPL:OK
                      2125 TSM:READY:ID=15,PAR=0,DIS=1
                      2129 Signing required
                      2131 Skipping security for command 3 type 15
                      2140 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                      2148 Waiting for GW to send signing preferences...
                      2181 TSF:MSG:READ,0-0-15,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                      2187 Skipping security for command 3 type 15
                      2191 Mark node 0 as one that require signed messages
                      2197 Mark node 0 as one that do not require whitelisting
                      2203 Skipping security for command 3 type 16
                      2211 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                      2220 Nonce requested from 0. Waiting...
                      2275 TSF:MSG:READ,0-0-15,s=255,c=3,t=17,pt=6,l=25,sg=0:BC9F06296E185623C02C586CECB3CBA37A7AD097699C918CB1
                      2287 Skipping security for command 3 type 17
                      2291 Nonce received from 0.
                      2295 Proceeding with signing...
                      Message to process: 0F002E0011FF322E312E31
                      Current nonce: BC9F06296E185623C02C586CECB3CBA37A7AD097699C918CB1AAAAAAAAAAAAAA
                      HMAC: D96C3B9964666D36495BBAF4E6C4E414088A553065E8CCA764CD8DF65D6353CA
                      Signature in message: 016C3B9964666D36495BBAF4E6C4E414088A5530
                      2469 Message signed
                      2478 Message to send has been signed
                      2486 TSF:MSG:SEND,15-15-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=OK:2.1.1
                      2494 Skipping security for command 3 type 16
                      2502 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      2510 Nonce requested from 0. Waiting...
                      2643 TSF:MSG:READ,0-0-15,s=255,c=3,t=17,pt=6,l=25,sg=1:556C16AFC48CBCC8758A6D0BA0CA9920BAAFB13290AC599CC1
                      2656 Skipping security for command 3 type 17
                      2660 Nonce received from 0.
                      2662 Proceeding with signing...
                      Message to process: 0F000E2306FF00
                      Current nonce: 556C16AFC48CBCC8758A6D0BA0CA9920BAAFB13290AC599CC1AAAAAAAAAAAAAA
                      HMAC: 598965B2F76BF9805E79A23C9CDBEA71A5F0B5749D4E2FA44C3DEDDAD21B3238
                      Signature in message: 018965B2F76BF9805E79A23C9CDBEA71A5F0B5749D4E2FA4
                      2838 Message signed
                      2844 Message to send has been signed
                      2854 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
                      3801 TSF:MSG:READ,0-0-15,s=255,c=3,t=16,pt=0,l=0,sg=1:
                      3807 Skipping security for command 3 type 16
                      SHA256: 46DEE622257BDFA07B804BA9C02440CC083DC010C7A609123900000000000000
                      3842 Skipping security for command 3 type 17
                      3858 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:46DEE622257BDFA07B804BA9C02440CC083DC010C7A6091239
                      3870 Transmitted nonce
                      4012 TSF:MSG:READ,0-0-15,s=255,c=3,t=6,pt=0,l=1,sg=1:M
                      Signature in message: 018AF802A7325E4D37B322FA8B0F4BA61CA5DF6548CEE589
                      Message to process: 000F0E0306FF4D
                      Current nonce: 46DEE622257BDFA07B804BA9C02440CC083DC010C7A6091239AAAAAAAAAAAAAA
                      HMAC: DA8AF802A7325E4D37B322FA8B0F4BA61CA5DF6548CEE58953ADF17286D22669
                      4190 Skipping security for command 3 type 16
                      4202 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      4208 Nonce requested from 0. Waiting...
                      4255 TSF:MSG:READ,0-0-15,s=255,c=3,t=17,pt=6,l=25,sg=1:90818AAA44B6AFD7880153E7AA7E981981744CC98028809A09
                      4265 Skipping security for command 3 type 17
                      4272 Nonce received from 0.
                      4274 Proceeding with signing...
                      Message to process: 0F00B6030BFF424D503238302050726573737572652053656E736F72
                      Current nonce: 90818AAA44B6AFD7880153E7AA7E981981744CC98028809A09AAAAAAAAAAAAAA
                      HMAC: 486FAFD76801F66D900E883F2C012B7104EE043ABC68E0AE894D0026E9D7A8AB
                      Signature in message: 016FAF
                      4448 Message signed
                      4456 Message to send has been signed
                      4466 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=11,pt=0,l=22,sg=1,ft=0,st=OK:BMP280 Pressure Sensor
                      4476 Skipping security for command 3 type 16
                      4483 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      4491 Nonce requested from 0. Waiting...
                      4642 TSF:MSG:READ,0-0-15,s=255,c=3,t=17,pt=6,l=25,sg=1:A3B017C2562256E455C640C28667B9BB3D3062687A5C49160C
                      4655 Skipping security for command 3 type 17
                      4659 Nonce received from 0.
                      4661 Proceeding with signing...
                      Message to process: 0F001E030CFF312E31
                      Current nonce: A3B017C2562256E455C640C28667B9BB3D3062687A5C49160CAAAAAAAAAAAAAA
                      HMAC: F27274FF114AE80AE6217C1B2B80A322AB82697AF3BFBE59BC53069948AA234A
                      Signature in message: 017274FF114AE80AE6217C1B2B80A322AB82697AF3BF
                      4837 Message signed
                      4843 Message to send has been signed
                      4853 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.1
                      4861 Skipping security for command 3 type 16
                      4868 TSF:MSG:SEND,15-15-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      4876 Nonce requested from 0. Waiting...
                      9881 Timeout waiting for nonce!
                      9883 !TSF:MSG:SIGN FAIL
                      9885 Skipping security for command 3 type 16
                      9895 TSF:MSG:SEND,15-15-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=OK:
                      9904 Nonce requested from 0. Waiting...
                      9957 TSF:MSG:READ,0-0-15,s=255,c=3,t=17,pt=6,l=25,sg=1:B91AB74E50528ACC3F64B480A47D6CEB269E2EA48004C57A7F
                      9967 Skipping security for command 3 type 17
                      9971 Nonce received from 0.
                      9975 Proceeding with signing...
                      Message to process: 0F0006000601
                      Current nonce: B91AB74E50528ACC3F64B480A47D6CEB269E2EA48004C57A7FAAAAAAAAAAAAAA
                      HMAC: A95DB25F392535043F3DEA960F6C2136115A29AF51F6B11D4E0BFFB7ABE9946E
                      Signature in message: 015DB25F392535043F3DEA960F6C2136115A29AF51F6B11D4E
                      10149 Message signed
                      10158 Message to send has been signed
                      10168 TSF:MSG:SEND,15-15-0-0,s=1,c=0,t=6,pt=0,l=0,sg=1,ft=0,st=OK:
                      10174 Skipping security for command 3 type 16
                      10182 TSF:MSG:SEND,15-15-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      10188 Nonce requested from 0. Waiting...
                      15194 Message to send could not be signed!
                      15198 !TSF:MSG:SIGN FAIL
                      15200 MCO:REG:REQ
                      15202 Skipping security for command 3 type 26
                      15212 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=1,st=OK:2
                      15230 TSF:MSG:READ,0-0-15,s=255,c=3,t=16,pt=0,l=0,sg=1:
                      15237 Skipping security for command 3 type 16
                      SHA256: 6F1E9148E2B8755A2B5019D803BBE9E531F1B5507406B58820AAAAAAAAAAAAAA
                      15271 Skipping security for command 3 type 17
                      15286 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:6F1E9148E2B8755A2B5019D803BBE9E531F1B5507406B58820
                      15298 Transmitted nonce
                      15429 TSF:MSG:READ,0-0-15,s=255,c=3,t=27,pt=1,l=1,sg=1:1
                      Signature in message: 01B4B105F62283F53943B57B3B2B034B44DA23B4D71C97A1
                      Message to process: 000F0E231BFF01
                      Current nonce: 6F1E9148E2B8755A2B5019D803BBE9E531F1B5507406B58820AAAAAAAAAAAAAA
                      HMAC: B3B4B105F62283F53943B57B3B2B034B44DA23B4D71C97A14CE49895135B98FA
                      15607 MCO:PIM:NODE REG=1
                      15613 MCO:BGN:STP
                      Pressure Sensor BMP280 1.1
                      isMetric: 1
                      15628 Skipping security for command 3 type 16
                      15638 TSF:MSG:SEND,15-15-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      15646 Nonce requested from 0. Waiting...
                      15683 TSF:MSG:READ,0-0-15,s=255,c=3,t=17,pt=6,l=25,sg=1:4EDBAA807BB751EFD72E54A450E8B76C3B45D503270FF3C9C6
                      15693 Skipping security for command 3 type 17
                      15699 Nonce received from 0.
                      15702 Proceeding with signing...
                      Message to process: 0F002EE1260285EB514002
                      Current nonce: 4EDBAA807BB751EFD72E54A450E8B76C3B45D503270FF3C9C6AAAAAAAAAAAAAA
                      HMAC: 66D0E5314979BE6AC80387B12A6A8CF79AAB4C325F64A6762176D35C4E36C369
                      Signature in message: 01D0E5314979BE6AC80387B12A6A8CF79AAB4C32
                      15878 Message signed
                      15884 Message to send has been signed
                      15894 TSF:MSG:SEND,15-15-0-0,s=2,c=1,t=38,pt=7,l=5,sg=1,ft=0,st=OK:3.28
                      15902 Skipping security for command 3 type 16
                      15910 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      15919 Nonce requested from 0. Waiting...
                      16048 TSF:MSG:READ,0-0-15,s=255,c=3,t=17,pt=6,l=25,sg=1:7E290F0590861636DF52F69D21796856F958F03E7956953C8D
                      16060 Skipping security for command 3 type 17
                      16064 Nonce received from 0.
                      16068 Proceeding with signing...
                      Message to process: 0F000E2300FF69
                      Current nonce: 7E290F0590861636DF52F69D21796856F958F03E7956953C8DAAAAAAAAAAAAAA
                      HMAC: 164ABE25D777EE3EA65F536ADE147D60B404561D07A26CA156E25EBB234507E0
                      Signature in message: 014ABE25D777EE3EA65F536ADE147D60B404561D07A26CA1
                      16242 Message signed
                      16250 Message to send has been signed
                      16261 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=0,pt=1,l=1,sg=1,ft=0,st=OK:105
                      16269 MCO:BGN:INIT OK,TSP=1
                      Temperature = 24.96 *C
                      Pressure = 997.80 mBar
                      Forecast = unknown
                      16277 Skipping security for command 3 type 16
                      16287 TSF:MSG:SEND,15-15-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      16295 Nonce requested from 0. Waiting...
                      16410 TSF:MSG:READ,0-0-15,s=255,c=3,t=17,pt=6,l=25,sg=1:E4C3BDA88C3EFFD0A435849C1199E79C9D2B215FA1D05A7E76
                      16422 Skipping security for command 3 type 17
                      16427 Nonce received from 0.
                      16431 Proceeding with signing...
                      Message to process: 0F002EE1000114AEC74101
                      Current nonce: E4C3BDA88C3EFFD0A435849C1199E79C9D2B215FA1D05A7E76AAAAAAAAAAAAAA
                      HMAC: 144BFD3C6A7CBE0DC1CCEEC102FDA3E3A15C1A5A22BA604A5F5CAEE2F682BE37
                      Signature in message: 014BFD3C6A7CBE0DC1CCEEC102FDA3E3A15C1A5A
                      16605 Message signed
                      16613 Message to send has been signed
                      16623 TSF:MSG:SEND,15-15-0-0,s=1,c=1,t=0,pt=7,l=5,sg=1,ft=0,st=OK:25.0
                      16631 Skipping security for command 3 type 16
                      16637 TSF:MSG:SEND,15-15-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      16646 Nonce requested from 0. Waiting...
                      16766 TSF:MSG:READ,0-0-15,s=255,c=3,t=17,pt=6,l=25,sg=1:0E091DD4985125377E63651907B9830D4D7265831F17FD65FE
                      16779 Skipping security for command 3 type 17
                      16783 Nonce received from 0.
                      16787 Proceeding with signing...
                      Message to process: 0F002EE104002973794400
                      Current nonce: 0E091DD4985125377E63651907B9830D4D7265831F17FD65FEAAAAAAAAAAAAAA
                      HMAC: A157ECB56A03D70529E1F9A26D972AF3EB1332FB20E2A3CDD909D5A8B9F7A8C4
                      Signature in message: 0157ECB56A03D70529E1F9A26D972AF3EB1332FB
                      16961 Message signed
                      16969 Message to send has been signed
                      16975 TSF:MSG:SEND,15-15-0-0,s=0,c=1,t=4,pt=7,l=5,sg=1,ft=0,st=OK:998
                      16984 Skipping security for command 3 type 16
                      16992 TSF:MSG:SEND,15-15-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      16998 Nonce requested from 0. Waiting...
                      17129 TSF:MSG:READ,0-0-15,s=255,c=3,t=17,pt=6,l=25,sg=1:E7504291BD4FE363A66BD9A571064AFEB381F5282651DB1040
                      17141 Skipping security for command 3 type 17
                      17145 Nonce received from 0.
                      17149 Proceeding with signing...
                      Message to process: 0F003E010500756E6B6E6F776E
                      Current nonce: E7504291BD4FE363A66BD9A571064AFEB381F5282651DB1040AAAAAAAAAAAAAA
                      HMAC: 9E56ED49FE4589E4F61D7A954CF433334527DB1D8BC515183834201570327BF5
                      Signature in message: 0156ED49FE4589E4F61D7A954CF433334527
                      17324 Message signed
                      17332 Message to send has been signed
                      17342 TSF:MSG:SEND,15-15-0-0,s=0,c=1,t=5,pt=0,l=7,sg=1,ft=0,st=OK:unknown
                      17448 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      17455 MCO:SLP:TPD
                      This is the second time I change AMS1117 in one year. Very odd
                      Anyway, very much appreciate your help on signing! Very helpful
                      • alexsh1A alexsh1
                        4 TSM:INIT
                        4 TSF:WUR:MS=0
                        12 TSM:INIT:TSP OK
                        16 TSF:SID:OK,ID=15
                        18 TSM:FPAR
                        2070 TSM:FPAR:OK
                        2070 TSM:ID
                        2072 TSM:ID:OK
                        2074 TSM:UPL
                        2123 TSM:UPL:OK
                        2469 Message signed
                        2838 Message signed
                        4448 Message signed
                        4837 Message signed
                        15200 MCO:REG:REQ
                        15613 MCO:BGN:STP
                        isMetric: 1
                        Forecast = unknown
                        17455 MCO:SLP:TPD
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @alexsh1 glad you got it working again :)
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @Anticimex Last time, I took me moths to resolve it. AMS1117 has not failed completely, but was working intermittently. This had a major impact on how nrf24l01+pa+lna was working. Unfortunately, range and signing were affected.
                          My theory is that it is getting probably 45-50C in my GW - there are many wires and it is a very tight fit. This may contribute in such AMS1117 behavior. Or probably just a bad batch.
                          • alexsh1A alexsh1
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @alexsh1 sounds like it. I've always considered the AMS1117 to be a trustworthy part.
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #370
                              @Anticimex it seems that replacing AMS1117 has resolved the issue.
                              I have a poor reception in one particular place and was thinking about a repeater node. Is signing working fine with the repeater node (both the node and the repeater are going to force signing by "MY_SIGNING_REQUEST_SIGNATURES"? Just curious
                              • alexsh1A alexsh1
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @alexsh1 repeaters support signing even if it isn't enabled on the repeater. It simply forwards the message and signature (and nonce).
                                Glad you resolved the issue :+1:
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @Anticimex so no need to enable signing if this is just a repeater node? (No sleeping just waiting)
                                  Yeah, every time it takes me quicker and quicker to troubleshoot mysensors ;-)
                                  Obviously, thanks to your excellent support
                                  • alexsh1A alexsh1
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @alexsh1 it never hurts to enable signing. It is not the same as requiring signatures. But no, you should not have to. I am just glad to help :)
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      I have been playing with 2.2.0 beta
                                      Security personalisation went fine for sensebender GW (serial), but signing is not working. Any ideas please?
                                      0;255;3;0;9;4840 MCO:BGN:INIT GW,CP=RNNGSA--,VER=2.2.0-beta
                                      0;255;3;0;9;4964 Could not read ATSHA204A lock config, refusing to use backend```
                                      • alexsh1A alexsh1
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @alexsh1 only that you have the atsha pin misconfigured in your gw sketch.
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #376
                                          @Anticimex This is a standard GW sketch:
                                          atsha204 pin is A3 (17). Cannot understand whats wrong...
                                          * LEDs (OPTIONAL):
                                          * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                                          #define MY_SPECIAL_DEBUG
                                          #define MY_SIGNING_ATSHA204
                                          #define MY_NODE_ID 18
                                          //#define MY_PARENT_NODE_ID 0
                                          #define MY_REPEATER_FEATURE
                                          // Enable serial gateway
                                          #define MY_GATEWAY_SERIAL
                                          #if F_CPU == 8000000L
                                          #define MY_BAUD_RATE 38400
                                          // Enable inclusion mode
                                          // Set blinking period
                                          // Flash leds on rx/tx/err
                                          AnticimexA 3 Replies Last reply
