  3. Loosing my mind sensor not talking to esp gw latest 2.2.0 beta
6 Posts 3 Posters 3.1k Views 4 Watching
  • ledfreak3dL Offline
    ledfreak3dL Offline
    ledfreak3d
    wrote on last edited by ledfreak3d
    Hey Guys
    Best wishes for 2017
    I think I am loosing my mind or I am overlooking something
    I have saveral esp12 devices one is a nodemcu 1.0
    wired everthing according to the sp8266 gateway page
    its sees the radio but i will not comunicate to the sensor node
    the sensor node is a arduino nano running the dallas temp sensor sketch
    both the esp side as the nano side have a cap directtly solder to the nrf
    but the sensor side will never see the gw
    Gw debug info
    ‚n?†$“¦£ÿ_CAJþû0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGE--,VER=2.2.0-beta
    0;255;3;0;9;TSF:LRT:OK
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 9
    cnt
    connected with Martijn, channel 13
    dhcp client start...
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    f r0, scandone
    ....ip:192.168.1.85,mask:255.255.255.0,gw:192.168.1.1
    .IP: 192.168.1.85
    0;255;3;0;9;MCO:BGN:STP
    pm open,type:2 0
    Sensor side
    0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.2.0-beta
    4 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:FPAR
    1612 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    3620 !TSM:FPAR:NO REPLY
    3622 TSM:FPAR
    5222 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    7230 !TSM:FPAR:NO REPLY
    7232 TSM:FPAR
    8832 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    10840 !TSM:FPAR:NO REPLY
    10842 TSM:FPAR
    12441 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    14449 !TSM:FPAR:FAIL
    14450 TSM:FAIL:CNT=1
    14452 TSM:FAIL:PDT
    the only other problem i can think of is that these are the problem
    http://www.banggood.com/3Pcs-NRF24L01-SI24R1-2_4G-Wireless-Power-Enhanced-Communication-Receiver-Module-p-1057155.html?rmmds=myorder
    have some other ones on the way for testing
    Y 1 Reply Last reply
    • ledfreak3dL ledfreak3d
      Hey Guys
      Gw debug info
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 9
      cnt
      f r0, scandone
      .IP: 192.168.1.85
      pm open,type:2 0
      Sensor side
      4 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      13 TSM:FPAR
      3622 TSM:FPAR
      7232 TSM:FPAR
      10842 TSM:FPAR
      14452 TSM:FAIL:PDT
      Y Offline
      Y Offline
      Quite likely. You bought some modules with a blob instead of an IC, and these are notorious for connection issues.
      I wouldn't waste any more time on these modules.
      mppM 1 Reply Last reply
        ledfreak3dL Offline
        ledfreak3d
        yea I thought so to pretty sure that's the issue
        already got some new ones on the way
        • Y Yveaux
          mppM Offline
          mppM Offline
          mpp
          @Yveaux what is a blob?
          MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
          • mppM mpp
            Y Offline
            Y Offline
            @mpp a drop of black resin, deposited on the semiconductor. It has no sharp edges, nor text on it.
            • mppM Offline
              mppM Offline
              mpp
              @Yveaux thanks for you response. I don't this this is the cause though, I have tested these transceivers and they're running perfectly with the Moteino code.
              @ledfreak3d, did you manage to get it fixed?
              12.1k
