  3. Is there a logging function in the Raspberry Pi Gateway?
6 Posts 3 Posters 2.0k Views 3 Watching
  • S Offline
    strangeoptics
    I am looking for a log to have the posibillity to look up error messages if something goes wrong in the gateway.
      If you have an ethernet or mqtt gw you can log data using myscontroller or any mqtt client that can log data to a file
      S 1 Reply Last reply
      • dirkcD Offline
        dirkcD Offline
        dirkc
        @strangeoptics I've created a simple python file just to connect to an ethernet MySensors gateway and monitor all output:
        https://github.com/dirkclemens/myssniffer.py/blob/master/myssniffer.py
        If you want to use it with a serial gateway you have to make some changes in the main() routine to grab data from the usb port instead the ethernet port.
        Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
        • S Offline
          strangeoptics
          Ok I use the mqtt gw.
          But is there a special topic for errors, infos, debugs?
          Messages like
          Starting gateway...
          Protocol version - 2.2.0-beta
          TSM:INIT:TSP OK
          TSM:INIT:GW MODE
          and so on are for example not posted to a topic!
            strangeoptics
            @gohan Where can I find the project myscontroller and the latest downloads?
              wrote on last edited by gohan
              There is a topic in the forum, but it's just for ethernet gateway.
              If you subscribe to topic # you get all messages
